nebulous312 0 Posted September 27, 2014 Posted September 27, 2014 (edited) Bonjour, j'ai un problème avec serverwmc et je ne sais pas résoudre mon problème. C'est la fin du journal de serverwmc: 2014/09/27 16:23:45.849 OpenLiveStream> -----------------start------------------------ 2014/09/27 16:23:45.849 OpenLiveStream> client: MediaBrowser^SALON-PC requesting live stream 2014/09/27 16:23:45.849 StreamProc> live-tv started 2014/09/27 16:23:45.849 SetChannel> Channel: 5 : France 5 - FB4D = { (-1 : France 5 - 2F0E) + [ 5 : France 5 - FB2B, 5 : France 5 - FB57, 5 : France 5 - FB6F, 5 : France 5 - FB87, 5 : France 5 - FC14, 5 : France 5 - 14888, 5 : France 5 - 148A8, 5 : France 5 - 148C2, 5 : France 5 - 148DE, 5 : France 5 - 16326] } 2014/09/27 16:23:45.864 SetChannel> Tuners available for this channel: 1 2014/09/27 16:23:45.864 SetChannel> Tuner DecoyMethod: OnDemand 2014/09/27 16:23:45.864 SetChannel> --- 2014/09/27 16:23:45.864 SetChannel> Attempt: 0, Tuner: AF9015 BDA Filter / da14a548-5d55-496d-8ca4-8708b3ec99de 2014/09/27 16:23:45.864 SetChannel> > Encrypted: False 2014/09/27 16:23:45.864 SetChannel> > RecorderInfo found: True 2014/09/27 16:23:45.864 SetChannel> > Recorder Content Protection: PROT_COPY_FREE 2014/09/27 16:23:45.864 SetChannel> > Status: Available, client: 2014/09/27 16:23:45.864 SetChannel> *** requested number of available tuners found, stopping search *** 2014/09/27 16:23:45.864 SetChannel> --- 2014/09/27 16:23:45.864 SetChannel> available tuners found: 1 [decoys:0], requested: 1, searched: 1 2014/09/27 16:23:45.864 SetChannel> Tuner: AF9015 BDA Filter will be used for the live stream 2014/09/27 16:23:45.864 SetChannel> Recorder acquired: True 2014/09/27 16:23:45.864 StreamProc> process start error: System.Runtime.InteropServices.COMException (0x80070032): Cette demande n’est pas prise en charge. (Exception de HRESULT : 0x80070032) Server stack trace: à ehiProxy.IRecorderEx2.SetTunerUseReason(TunerUseReason tur) à System.Runtime.Remoting.Messaging.StackBuilderSink._PrivateProcessMessage(IntPtr md, Object[] args, Object server, Object[]& outArgs) à System.Runtime.Remoting.Messaging.StackBuilderSink.AsyncProcessMessage(IMessage msg, IMessageSink replySink) Exception rethrown at [0]: à Microsoft.MediaCenter.Pvr.RecorderAsyncWrapper.SetTunerUseReason(TunerUseReason tur) à ServerWMC.Worker.RecordToWTV.SetChannel(Channel newC) à ServerWMC.Worker.RecordToWTV.ChangeChannel(Channel c, String newFileName) à ServerWMC.Worker.StreamProc..ctor(String clientName, Channel c) 2014/09/27 16:23:45.864 StreamProc> calling Close() 2014/09/27 16:23:45.864 StreamProc::Close> closed in 0,00 sec 2014/09/27 16:23:45.864 OpenLiveStream> error: System.Runtime.InteropServices.COMException (0x80070032): Cette demande n’est pas prise en charge. (Exception de HRESULT : 0x80070032) Server stack trace: à ehiProxy.IRecorderEx2.SetTunerUseReason(TunerUseReason tur) à System.Runtime.Remoting.Messaging.StackBuilderSink._PrivateProcessMessage(IntPtr md, Object[] args, Object server, Object[]& outArgs) à System.Runtime.Remoting.Messaging.StackBuilderSink.AsyncProcessMessage(IMessage msg, IMessageSink replySink) Exception rethrown at [0]: à ServerWMC.Worker.StreamProc..ctor(String clientName, Channel c) à ServerWMC.Worker.StreamProc.StartStream(String clientName, Channel c, Boolean& alreadyStreaming) à ServerWMC.Worker.RecService.OpenLiveStream(FrontEndClient client, String[] args) 2014/09/27 16:23:45.864 Finished request OpenLiveStream in 0,02s Edited September 27, 2014 by nebulous312
krustyreturns 191 Posted September 27, 2014 Posted September 27, 2014 (edited) This is a strange error. As an experiment, change this value in 'config.xml' to 'false': <UseAsyncRecorder>false</UseAsyncRecorder> You can get to the 'config.xml' file using the debug tab. Let me know if that solves the problem, if it doesn't, please post the log again after trying it. Pardon my French: C'est une erreur étrange . Comme une expérience , modifier cette valeur dans ' config.xml ' à 'false' :<UseAsyncRecorder>false</UseAsyncRecorder>Vous pouvez obtenir le fichier " config.xml " en utilisant l'onglet de débogage . Faites-moi savoir si cela résout le problème , si elle n'est pas , s'il vous plaît envoyer le journal à nouveau après l'avoir essayé . Edited September 27, 2014 by krustyreturns
nebulous312 0 Posted September 27, 2014 Author Posted September 27, 2014 thanks for your answer, i have does the modification on the "config.xml " and now the tv works properly on my pc, thanks. I have a new problem now, the HD channels does not work correctly, these channels have a video not smooth but no problem with SD channels. i think i have a cpu limited on my server. My server is a ZOTAC ZBOX CI320 nano with CPU Intel Celeron N2930 (quad-core, 1.83 GHz) Burst frequency up to 2.16 GHz and GPU Intel HD Graphics.
krustyreturns 191 Posted September 27, 2014 Posted September 27, 2014 That's good to know that it solved the problem, I know what to fix in the next rev. It is very strange that it caused a problem on your system. Its hard to me to comment on whether your system is fast enough for hd. Is your viewing client on the same computer as the server?
nebulous312 0 Posted September 27, 2014 Author Posted September 27, 2014 No i viewing the tv with media browser on another computer, i have viewed the processor operate between 90% - 95% when streaming the tv, i have tested with XBMC and the processor operate between 30% - 50% when streaming the tv and flux was smooth. I think the media browser is not correctly optimised...
krustyreturns 191 Posted September 28, 2014 Posted September 28, 2014 Mediabrowser server is transcoding the data, xbmc does not. That likely accounts for the difference.
