wewewct 0 Posted May 17, 2022 Posted May 17, 2022 what QR-code added are used for? I want to add a page for my friends to fill out the questionnaire I create. They can tell me what they want to watch by this questionnaire. what do I expect? the method to write to code. what do I have had thought? a link added to the login page. It work to jump to my page, but it only show when my fds login. a QR-code jpg with some guiding words to show on the homepage. thx guys, pls help me.
Solution Happy2Play 9811 Posted May 17, 2022 Solution Posted May 17, 2022 You would most likely need to modify the login/manuallogin.html. But since you want login first you would need a link on Homescreen not login screen. So I would assume something like this. 1
wewewct 0 Posted May 18, 2022 Author Posted May 18, 2022 12 hours ago, Happy2Play said: You would most likely need to modify the login/manuallogin.html. But since you want login first you would need a link on Homescreen not login screen. So I would assume something like this. Great thx for your solution. I've tried and it works. But after updated, the codes I edited seemed to be disappeared. Then my frd suggested me to create a library which its type is home video & photos. And I put the QR-code jpg in the folder with a guiding jpg. Thx and looking forward for the new codes.
