amark 0 Posted May 17, 2022 Posted May 17, 2022 Hi! So I'm wondering if anyone can help me out with getting remote access setup with my Emby Server running off of a EX4100. I've already gone through the steps here: https://support.emby.media/support/solutions/articles/44001849007-connectivity and nothing has worked thus far. Open to any and all suggestions. Thanks!
Luke 42237 Posted May 18, 2022 Posted May 18, 2022 Hi there, what exactly happens when you try to connect remotely? Did you setup port forwarding?
amark 0 Posted May 18, 2022 Author Posted May 18, 2022 Hey Luke! I setup port forwarding. But, still getting 'Remote WAN IP Address is unreachable' if trying to connect via direct IP and seeing the attached error message via Emby Connect. I have Spectrum as my ISP and guessing it may be that they block port forwarding since I use their modem
Luke 42237 Posted May 18, 2022 Posted May 18, 2022 13 minutes ago, amark said: Hey Luke! I setup port forwarding. But, still getting 'Remote WAN IP Address is unreachable' if trying to connect via direct IP and seeing the attached error message via Emby Connect. I have Spectrum as my ISP and guessing it may be that they block port forwarding since I use their modem Can you show us the port forwarding that you setup?
