iloveparks 7 Posted May 17, 2022 Posted May 17, 2022 Hi, I'm trying to use /Shows/{Id}/Episodes to grab the first episode of every show. I'm passing the following parameters. Season = 1 MinIndexNumber = 1 Limit = 1 However, on shows where I have a special episode in Season 1, the API returns the following: Am I misunderstanding? Shouldn't it be returning IndexNumber 1? It would also be nice if there was just a field "IndexNumber" to filter by IndexNumber, just like ParentIndexNumber. Thanks!
Luke 42237 Posted May 18, 2022 Posted May 18, 2022 Hi, MinIndexNumber means greater or equal to what you're providing. I guess we'll have to add support for just sending IndexNumber
iloveparks 7 Posted May 18, 2022 Author Posted May 18, 2022 Right, but as it stands, the logic is flawed? I am providing 1, and it is returning an item with IndexNumber as 0.
Luke 42237 Posted May 18, 2022 Posted May 18, 2022 I'll have to check but I think that endpoint might not support that param yet. 1
iloveparks 7 Posted May 18, 2022 Author Posted May 18, 2022 Yeah, you are right, that does not seem to do anything on that endpoint. Sadness.
iloveparks 7 Posted May 20, 2022 Author Posted May 20, 2022 I appreciate it! I have a few other topics open here in the dev API forums, if you have a moment, can you pop into those as well? Really appreciate your time and efforts. 1
