Milldor 14 Posted May 16, 2022 Posted May 16, 2022 Would it be possible to add side scrolling to the home scree. Using a mouse with emby theater is very difficult because to move left and right you have to drag the thumbnails... Upon releasing the mouse it selects the thumbnail that it was left on. I know that using a mouse on an HTPC is not the norm but it is convenient sometimes.
Luke 42239 Posted May 16, 2022 Posted May 16, 2022 HI, TV display mode is designed around your primary input method being a remote control. I would suggest a couple options: Try the horizonal home screen Or consider switching to desktop display mode for better mouse control
Milldor 14 Posted June 25, 2022 Author Posted June 25, 2022 On 16/05/2022 at 20:58, Luke said: HI, TV display mode is designed around your primary input method being a remote control. I would suggest a couple options: Try the horizonal home screen Or consider switching to desktop display mode for better mouse control It can't be that difficult to add this feature seen as Electron supports it natively anyway. Suggesting ways to use it rather than working on it is no good.
Luke 42239 Posted June 26, 2022 Posted June 26, 2022 1 hour ago, Milldor said: It can't be that difficult to add this feature seen as Electron supports it natively anyway. Suggesting ways to use it rather than working on it is no good. Hi, electron supports what? All of the scrolling is built by us.
