chenks 21 Posted May 16, 2022 Posted May 16, 2022 just noticed that the "continue watching" thumbnails are quite bigger when viewing using http://app.emby.media/ compared to local http://192.168.50.2:8096/web/ is this a setting i have missed on the user home screen settings that make them bigger on the internet hosted version?
GrimReaper 4896 Posted May 16, 2022 Posted May 16, 2022 Your local web app is stable server version 4.6+, while hosted web app is upgraded as latest beta 4.7+. Once 4.7 goes stable, you'll have same. In the meantime, you can use custom CSS to increase card size in local 4.6 web app.
chenks 21 Posted May 16, 2022 Author Posted May 16, 2022 (edited) i'm not sure this is correct, as it seems to be a scaling issue in the web ui code. reason i say that is that if i view both the hosted and local version on my laptop internal display it shows the bigger version on hosted, but if i view both on an external monitor then both hosted and local are the same size. this might be a scaling issue in the code on certain resolutions. note that the increased size is way too big and suggest/hope that this is not the intended final look. windows 11 pro using Chrome laptop display - 3200x1800 @ 175% scale external monitor - 1920 x 1080 @ 100% scale Edited May 16, 2022 by chenks
GrimReaper 4896 Posted May 16, 2022 Posted May 16, 2022 (edited) Don't use external monitor so wouldn't know, might as well be, but on laptop display observed same occurence - but I'm adjusting card size on both local stable and beta instances anyway via CSS (note that it does not apply to hosted web app). Edited May 16, 2022 by GrimReaper
chenks 21 Posted May 19, 2022 Author Posted May 19, 2022 after upgrade to 4.7.x emby server, both hosted and local now have this issue. i believe this is a scaling bug in the code, if someone can check and confirm?
chenks 21 Posted May 19, 2022 Author Posted May 19, 2022 (edited) Chrome running maximised with the display resolution running at 3200x1800 @ 175% scale (windows scaling not chrome scaling) wasn’t an issue before on 4.6.x Edited May 19, 2022 by chenks
