user101xy 26 Posted May 17, 2022 Author Posted May 17, 2022 If so, could be an error of the TV, or could be the error depend of the Emby App?
ebr 16337 Posted May 18, 2022 Posted May 18, 2022 Can you please play that item for a few seconds and then follow the instructions to send a log from the app?
user101xy 26 Posted May 18, 2022 Author Posted May 18, 2022 (edited) At 20:48 with the user name emby and the channel: "Das Erste HD" Logs were send. Edited May 18, 2022 by user101xy
ebr 16337 Posted May 18, 2022 Posted May 18, 2022 Hi. I don't see any problem with playback in that log. Was there one?
user101xy 26 Posted May 18, 2022 Author Posted May 18, 2022 Thank you! yes, i have deactived direct play, so there were no playback, only a freezed screen
ebr 16337 Posted May 18, 2022 Posted May 18, 2022 Not sure why. There are no errors. If you leave it it never starts?
user101xy 26 Posted May 18, 2022 Author Posted May 18, 2022 (edited) It never starts with disabled direct play. Edited May 18, 2022 by user101xy
Luke 42245 Posted May 19, 2022 Posted May 19, 2022 HI, can you try sideloading our standard android app on the same device and let us know how that compares? https://emby.media/emby-for-android.html Thanks !
user101xy 26 Posted May 19, 2022 Author Posted May 19, 2022 (edited) Hi @Luke! Thank you! Which should i take? I have a Synology 218play and a phillips 7900 Smart-TV with Android 10 TV OS? arm7 x86 Edited May 19, 2022 by user101xy
user101xy 26 Posted May 19, 2022 Author Posted May 19, 2022 I have not found an installation guide, to install the (which one: arm7 or x86) package on my TV?
user101xy 26 Posted May 19, 2022 Author Posted May 19, 2022 Ok…. Thanks! but, i did‘t found any installation guide in the Knowledge base, also on google i couldn‘t haven found any guide.
Luke 42245 Posted May 19, 2022 Posted May 19, 2022 48 minutes ago, user101xy said: Ok…. Thanks! but, i did‘t found any installation guide in the Knowledge base, also on google i couldn‘t haven found any guide. If you're not sure then the easiest thing to do is just get it from Synology Package Center. 1
user101xy 26 Posted May 19, 2022 Author Posted May 19, 2022 (edited) Hm? I have emby package installed on my Synology. But how can i install on the TV. I have only Google Play Store to install Emby on TV, but i don‘t see a way to install the Emby app manualy on my TV? Edited May 19, 2022 by user101xy
user101xy 26 Posted May 20, 2022 Author Posted May 20, 2022 Here in the pic, is what i mean, to install manually Android TV Emby. But how can i install manually the Emby Package on my Android TV?
CBers 7554 Posted May 20, 2022 Posted May 20, 2022 17 hours ago, user101xy said: i did‘t found any installation guide in This might point you in the right direction. It refers to Windows 11, but that's only because the downloaded file, an APK file, is stored on a Windows 11 computer. You should be able to substitute Windows 11 for Synology in the instructions. 1
user101xy 26 Posted May 20, 2022 Author Posted May 20, 2022 Since I don't have an NVidia Shield and I want to keep using Synology and also thanks to your help I haven't found any errors in the logs, I leave it enabled on Direct Play. This is how Emby works on my Android TV. Thank you all for your support!!! 1
