Super957 24 Posted May 15, 2022 Posted May 15, 2022 In have this folder situation, see first screenshot \Music \Sountrack \CD 1 1- Song.mp3 2- Song.mp3 I set correct all songs and put also in cd 1/1, see second screenshot. But anyway in Emby i see all separate album, see third screenshot. Ao i ask if is possible that all songs under folder soundtrack appear in one Album and not in in many separate Thank Hispa
Vicpa 612 Posted May 15, 2022 Posted May 15, 2022 Hi Emby is going to use the embedded "Album" tag to group the tracks. In your example if you want them to appear under "Soundtrack" change the album tag to soundtrack. May need to change the "album artist" to "Various Artists" or whatever you use for compilation albums as well. In effect creating a custom compilation album called "Soundtracks", that should give you the display grouping you want. -vicpa 1
Luke 42186 Posted May 15, 2022 Posted May 15, 2022 The combination of the embedded album and albumartist, so those values need to be consistent for all tracks in the album. 1
Super957 24 Posted May 15, 2022 Author Posted May 15, 2022 1 hour ago, Luke said: The combination of the embedded album and albumartist, so those values need to be consistent for all tracks in the album. So both not only album ? So Album and album artist must be the same...for exampe both: soundtrack
Happy2Play 9800 Posted May 15, 2022 Posted May 15, 2022 Just the Album Artist as Album would be the name. So all tracks with Album "Against All Odds" and Album Artist "Soundtrack" will be grouped.
Solution Luke 42186 Posted May 15, 2022 Solution Posted May 15, 2022 2 hours ago, Super957 said: So both not only album ? So Album and album artist must be the same...for exampe both: soundtrack Album is different from album artist, but all tracks in the album should have the same values for those two fields. 1
