rbjtech 5344 Posted May 20, 2022 Posted May 20, 2022 3 minutes ago, chenks said: the shield is connected via 1Gbps ethernet, iPhone wireless (obviously). any other app i use (Tivimate, VLC etc) all start playback instantly, it's only Emby ATV that seems to have the issue. ok sure - so it's unlikely to be a network issue then - just thought I'd ask. (My test above was on Wired Ethernet as well). Over to the Dev team then I'm afraid .. sorry I could help more.
CBers 7554 Posted May 20, 2022 Posted May 20, 2022 3 hours ago, chenks said: the link only provides 2 versions - arm7 and x86, neither of which the shield in question is, which is arm64v8a ? Not that it should make a difference, but there is an arm64v8a APK you can use. See here: https://github.com/MediaBrowser/Emby.Releases/tree/master/android Perhaps @Luke can add it to the download page and mark "For Shield 2019 Pro only". 1
chenks 21 Posted May 20, 2022 Author Posted May 20, 2022 5 minutes ago, CBers said: can add it to the download page and mark "For Shield 2019 Pro only". why though? as you wouldn't be installing that version on an Android TV device anyway? isn't that the mobile app?
CBers 7554 Posted May 20, 2022 Posted May 20, 2022 1 minute ago, chenks said: why though? as you wouldn't be installing that version on an Android TV device anyway? isn't that the mobile app? Well, if it becomes the unified app for Android and Android TV it might.
FrostByte 5454 Posted May 20, 2022 Posted May 20, 2022 4 minutes ago, chenks said: why though? as you wouldn't be installing that version on an Android TV device anyway? isn't that the mobile app? The standard Android app has a TV mode now and runs on all Android devices including AndroidTV. Whereas ATV app is designed specifically around AndroidTV devices. 1
chenks 21 Posted May 20, 2022 Author Posted May 20, 2022 7 minutes ago, FrostByte said: The standard Android app has a TV mode now and runs on all Android devices including AndroidTV maybe so, but that version of the app isn't presented to you in the play store on an AndroidTV device.
FrostByte 5454 Posted May 20, 2022 Posted May 20, 2022 Just now, chenks said: maybe so, but that version of the app isn't presented to you in the play store on an AndroidTV device. Not yet, which is why CBers posted the link to the apk. Luke said it will eventually make it to the store. I have both on my Shield pro. Though they both have the same icon they both work.
chenks 21 Posted May 20, 2022 Author Posted May 20, 2022 (edited) The standard Android app running on an Android TV device ain’t a great experience after a brief testing it looks like it just presents the web Ui in a wrapper and some off of the Ui aspects don’t looK right (cover art overlapping the row headings when highlighted is one example) highlighted items don’t have a coloured border setting them The theme I use on the ATV app (material Green) isn’t available, and going into to “app” settings just puts you into the entire server settings Overall a worse experience than the ATV app, and it didn’t make any difference to the playback of live TV not the standard app guide layout is poor compared to ATV app Edited May 20, 2022 by chenks 1
CBers 7554 Posted May 20, 2022 Posted May 20, 2022 2 hours ago, chenks said: Overall a worse experience than the ATV app, and it didn’t make any difference to the playback of live TV not the standard app guide layout is poor compared to ATV app If you want, you can post your issues, here.
Spaceboy 2573 Posted May 20, 2022 Posted May 20, 2022 at some point the dev's may listen that no-one likes the standard android app. we live in hope 4
vdatanet 1619 Posted May 21, 2022 Posted May 21, 2022 21 hours ago, FrostByte said: Though they both have the same icon they both work. As of version .71 they have a different icon. 1 2
