MAX92 93 Posted May 14, 2022 Posted May 14, 2022 @Luke J'ai un problème avec EMBY sur des fichiers FULL UltraHD 4K de plus de 50 Go sur ma Shield TV Pro. La lecture soit bug, soit bloque et je ne comprends pas pourquoi. Est-ce quelqu'un peut m'aider car quand je lance le même fichier avec VLC sur la shield, aucun soucis. Merci ffmpeg-transcode-10d17c2d-1e64-4c61-908b-b62354a3527b_1.txt embyserver-63788163892.txt
Luke 42239 Posted May 14, 2022 Posted May 14, 2022 Hi, can you try side loading our standard Android app on the same device and let us know how that compares: https://emby.media/emby-for-android.html Thanks
Solution MAX92 93 Posted May 15, 2022 Author Solution Posted May 15, 2022 I don't know how to install a New emby on my shield. But I think it is a problem with cache. When I put cache on médium it is good but when I put to maximum, mais I have bug
MAX92 93 Posted May 15, 2022 Author Posted May 15, 2022 20 hours ago, Luke said: Hi, can you try side loading our standard Android app on the same device and let us know how that compares: https://emby.media/emby-for-android.html Thanks No bug with this version.
