TobyTentakel 25 Posted May 13, 2022 Posted May 13, 2022 There is a problem with the UI in the Android Emby client that makes many settings difficult to access on phones. I have tested this with 4 different Android phones, mainly Samsung ones. If you look at the first screenshot with the album view, all is fine. The bottom part of the screen with the 3 icons is the phone's native virtual buttons, e.g. home. Emby's own controls are displayed right above it. No problem there. In the second screenshot, you see the dialog for refreshing metadata, but the problem is existent for pretty much all pages that have a green save/refresh button at the bottom. This button is positioned at almost the bottom, so the native phone controls overlap it. This makes it hard or sometimes impossible to activate the button, as the phone controls take precedence. Is there any chance this can be adapted?
Luke 42243 Posted May 13, 2022 Posted May 13, 2022 Hi, yes this is an open issue that's on our to do list to tackle. Thanks for reporting.
