ginjaninja 605 Posted May 10, 2022 Posted May 10, 2022 I am getting back some episodes from /items using powershell. i have tried $apiresult = Invoke-WebRequest -Uri $apiurl -Method Get and $apiresult = Invoke-RestMethod -ContentType 'application/json; charset=utf-8' $apiurl both give me the data but i notice episodes with special characters show as Krak�w rather than Kraków when viewed in vscode powershell debugger. (version 7.2). As a point of learning i would like the response to look right on the screen in vs code. I think its probably very important to say that when i read episode names from the filing system (get-childitem) in the same script, the episodes' special characters show properly....so vscode is capable of showing the special character but doesnt show special characters properly for responses from the api. Ive little understanding of character encoding, can any one shed any light on these questions? hopefully they make sense, and might help point me in the right direction please. is the visual discrepancy a character encoding issue? can you tell the encoding of "Krak�w" just by looking at it? is the character encoding of the response from the api dependant on the code/language or fixed by the api? is character encoding just about how characters appear on screen or does changing the encoding actually change the underlying data? anyone know enough vscode / powershell to suggest a solution? thanks in anticipation.
ginjaninja 605 Posted May 11, 2022 Author Posted May 11, 2022 8 hours ago, PenkethBoy said: try utf-16 or unicode utf-8 has limits thanks @PenkethBoy i have tried $apiresult = Invoke-RestMethod -ContentType 'application/json; charset=utf-16' $apiurl and $apiresult = Invoke-RestMethod -ContentType 'application/json; charset=unicode' $apiurl no change i suspect that i am hopelessly out of my depth on the correct syntax and in particular on the difference between -contenttype switch and -headers switch and which one (if any) affects (the interpretation of?) the response. Do you have special characters in your library, are you able to get them to show correctly in vs code? There are articles on the internet which suggest different powershell versions, ise and even encoding of the script file can make a difference.
ginjaninja 605 Posted May 11, 2022 Author Posted May 11, 2022 17 hours ago, PenkethBoy said: try utf-16 or unicode utf-8 has limits omg, thats embarrassing....the source data was wrong in the database...at some point emby had fetched the data with the wrong encoding...have since refreshed and everythings ok... sorry for wasting your time...thanks for help.
PenkethBoy 2068 Posted May 16, 2022 Posted May 16, 2022 yes i have seen this - if it comes in wrong to db at somepoint - then only a refresh will fix it was going to suggest that next
