fbarmu 0 Posted December 27, 2022 Posted December 27, 2022 with webos 3.0 it still does not play the subtitles
Luke 42237 Posted December 27, 2022 Posted December 27, 2022 11 hours ago, fbarmu said: with webos 3.0 it still does not play the subtitles Hi there, let's look at an example. Please attach the information requested in how to report a media playback issue. Thanks!
requa3r0 12 Posted December 30, 2022 Posted December 30, 2022 (edited) I can confirm that subtitles still does not load. But its related to the embedded subtitles in the MKV file linked in a STRM file, when loading it from a web service. If you download a part of the MKV and then play it, emby will trans-code and embed the subtitles. Only workaround is to download a fresh subtitle as a text file with open subtitles.org and then display it . The drawback is that there are often included 30 different languages in a STRM mkv-file, and the download of a new subtitle is at the bottom of the language list. It would be much appreciated if the download of a new subtitle cloud be moved away from the language selection, or at least displayed at the very top. Its quite tedious to scroll down past all the languages and download a new subtitle every time you watch a stream. Kind regards Requaero Edited December 30, 2022 by requa3r0
Luke 42237 Posted January 2, 2023 Posted January 2, 2023 On 12/30/2022 at 9:58 AM, requa3r0 said: I can confirm that subtitles still does not load. But its related to the embedded subtitles in the MKV file linked in a STRM file, when loading it from a web service. If you download a part of the MKV and then play it, emby will trans-code and embed the subtitles. Only workaround is to download a fresh subtitle as a text file with open subtitles.org and then display it . The drawback is that there are often included 30 different languages in a STRM mkv-file, and the download of a new subtitle is at the bottom of the language list. It would be much appreciated if the download of a new subtitle cloud be moved away from the language selection, or at least displayed at the very top. Its quite tedious to scroll down past all the languages and download a new subtitle every time you watch a stream. Kind regards Requaero @requa3r0 Hi there, let's look at an example. Please attach the information requested in how to report a media playback issue. Thanks!
