Super957 24 Posted May 5, 2022 Posted May 5, 2022 (edited) I see in Emby Cinema Intros : Emby Custom Intros In addition you can specify your own custom videos to be used with cinema intros. Simply create a folder containing the videos, and enter the path in the custom intro field: Important: Make sure to run a library scan after adding new intro files. In my Nas i create a folder Intros where i put my custom intros /share/CACHEDEV1_DATA/Emby intros So i dont understand if in this case i must create a library in emby server or is sufficient indicate the folder as I did in screnshot Thank Hispa Edited May 5, 2022 by Super957
Super957 24 Posted May 5, 2022 Author Posted May 5, 2022 Thank dear Happy2Play just last request in my folder i put for the moment only one video. If i put for example 4 videos...emby select random which play ? Thank Hispa
Happy2Play 9800 Posted May 5, 2022 Posted May 5, 2022 10 minutes ago, Super957 said: If i put for example 4 videos...emby select random which play ? Yes it should be random on which one is played with every media playback.
Super957 24 Posted May 5, 2022 Author Posted May 5, 2022 (edited) All is done and run until recently ...but now no more intros ??? I dont change anything My log Hispa embyserver (6).txt Edited May 5, 2022 by Super957
Super957 24 Posted May 5, 2022 Author Posted May 5, 2022 Found the problem... this happened after install VantagePoint, Uninstall it and all comeback ok Hispa
Cheesegeezer 3104 Posted May 5, 2022 Posted May 5, 2022 34 minutes ago, Super957 said: Found the problem... this happened after install VantagePoint, Uninstall it and all comeback ok Hispa Hola amigo! I’m just working on some fixes on VantagePoint. They are in test at the moment and I should have a very stable release in the plugin catalog over the weekend. @Luke thanks for the headsup. It’s the damn codecs, couldn’t fix with nugets, however, the string that is returned from the Mediastreams, has the type, codec and displaytitle all in the string. So can imagine thats what making it fail as it can’t handle a specific codec. So ive done some string manipulation to get get just the codec info and It’ll work. 1
