Bigmack3000 108 Posted May 4, 2022 Posted May 4, 2022 I love how this looks on a desktop: I'm wondering if there is a way to get the same information to display on the Shield app. If not, is there an eta for adding it? Thanks.
ebr 16337 Posted May 4, 2022 Posted May 4, 2022 Hi. You can install the standard android app on your device and I believe you will get that same two-line display. https://emby.media/emby-for-android.html
Bigmack3000 108 Posted May 4, 2022 Author Posted May 4, 2022 Are there downsides to using the android phone app on the shield? Any differences in performance or features?
Luke 42245 Posted May 4, 2022 Posted May 4, 2022 17 minutes ago, Bigmack3000 said: Are there downsides to using the android phone app on the shield? Any differences in performance or features? No downside. The standard app supports all screen sizes. And you get the download feature.
Bigmack3000 108 Posted May 4, 2022 Author Posted May 4, 2022 Does this mean it's unlikely for the android tv app to get this feature anytime soon?
Luke 42245 Posted May 5, 2022 Posted May 5, 2022 Ultimately the TV app will catch up, but development of the standard app moves quicker. It is a TV app as well.
