Super957 24 Posted May 2, 2022 Posted May 2, 2022 After buy Premiere the plugin work and well I need a suggestion: i have many movies with 1080p H264, which I would like to highlight on my own So i set HD items will use the BD cover but in this way movie 1080p H264 are togheter with movies 720p H264 There a way to to distinguish the two resolutions with different cover ?  Thank Hispa Â
ebr 16346 Posted May 2, 2022 Posted May 2, 2022 Hi. Not with a different cover but you can use the indicators to show a resolution badge.
Super957 24 Posted May 2, 2022 Author Posted May 2, 2022 (edited) 12 minutes ago, ebr said: Hi. Not with a different cover but you can use the indicators to show a resolution badge. Thank ebr i follow your suggestion but is not show resolution, while i set video yes.  Hispa Edited May 2, 2022 by Super957
ebr 16346 Posted May 2, 2022 Posted May 2, 2022 Hi. I believe it is just the preview that isn't working. Check the resolution option and then look at your actual library. 1
Super957 24 Posted May 2, 2022 Author Posted May 2, 2022 if i select resolution/icon and this is the result... is video codec and not resolution. Try also you..there is something not work proper  Hispa
Happy2Play 9814 Posted May 2, 2022 Posted May 2, 2022 Not seeing an issue here. May need to go over media info for a specific item.
Super957 24 Posted May 3, 2022 Author Posted May 3, 2022 (edited) 6 hours ago, Happy2Play said: Not seeing an issue here. May need to go over media info for a specific item. Yep work but with "FlatCase" and not with "Case", verify also you Thank  Hispa Edited May 3, 2022 by Super957
ebr 16346 Posted May 4, 2022 Posted May 4, 2022 On 5/3/2022 at 1:08 AM, Super957 said: Yep work but with "FlatCase" and not with "Case", verify also you Hi. I think it is probably just the fact that you changed treatment styles. Try refreshing one of your items.
