JeffAlef 0 Posted May 2, 2022 Posted May 2, 2022 I have an Emby Premiere and I was uploading movies and series content, but I formatted my PC and I can't find anything anymore and the password and login always give errors, how do I solve this, I lose all the settings I made before I had to format the PC ?
pwhodges 2025 Posted May 2, 2022 Posted May 2, 2022 What did you actually format and why? Remember, formatting is deleting everything and starting again... Paul
Happy2Play 9801 Posted May 2, 2022 Posted May 2, 2022 Sorry I am a little confused as you don't upload any movies or series. You attach your own folder library to your install of Emby server to present your media. If you formatted your system, you would need to reinstall Emby Server and recreate your media libraries. Emby Getting Started : Emby Now if you previously used the Server Configuration Backup plugin then you just have to Reinstall Emby, install the plugin and restore your last configuration backup. But none of this has anything to with your physical media. If it was on the system you formatted, you will need to recreate it all.
JeffAlef 0 Posted May 2, 2022 Author Posted May 2, 2022 51 minutes ago, pwhodges said: O que você realmente formatou e por quê? Lembre-se, formatar é deletar tudo e começar de novo... Paulo I formatted my computer myself, and when I went to access Emby to continue I couldn't access it anymore. Is everything lost in this process if you format the computer?
JeffAlef 0 Posted May 2, 2022 Author Posted May 2, 2022 I formatted my computer myself, and when I went to access Emby to continue I couldn't access it anymore. Is everything lost in this process if you format the computer?
JeffAlef 0 Posted May 2, 2022 Author Posted May 2, 2022 25 minutes ago, Happy2Play said: Desculpe, estou um pouco confuso, pois você não envia nenhum filme ou série. Você anexa sua própria biblioteca de pastas à instalação do servidor Emby para apresentar sua mídia. Se você formatou seu sistema, precisará reinstalar o Emby Server e recriar suas bibliotecas de mídia. Emby Introdução: Emby Agora, se você usou anteriormente o plugin Server Configuration Backup, basta reinstalar o Emby, instalar o plugin e restaurar seu último backup de configuração. Mas nada disso tem a ver com sua mídia física. Se estava no sistema que você formatou, você precisará recriar tudo. I didn't know, so I lost everything, I'll have to recreate it.
quickmic 1709 Posted May 2, 2022 Posted May 2, 2022 (edited) Emby is not a cloud solution. If you have formatted/deleted the content, yes it's lost. If you just formatted the Emby server and not the actual content (e.g. stored on NAS or other location), then Emby server must be completely reconfigured. Edited May 2, 2022 by quickmic
JeffAlef 0 Posted May 2, 2022 Author Posted May 2, 2022 1 minute ago, quickmic said: Emby não é uma solução em nuvem. Se você formatou/excluiu o conteúdo, sim, está perdido. Se você acabou de formatar o servidor Emby e não o conteúdo real (por exemplo, armazenado no NAS ou em outro local), o servidor Emby deve ser completamente reconfigurado. Jeez, I'll have to recreate, thanks friends.
