Super957 24 Posted May 1, 2022 Posted May 1, 2022 (edited) In description i read: "...CoverArt does not modify any of your original artwork. It does its magic on the server before the images are delivered to the clients so you can easily switch between different styles and rest assured your original posters will remain intact..." Ok i hope to set all option but in which way i can or where i select apply to my library to verify client side if CoverArt is applied ? Thank and sry Hispa Edited May 1, 2022 by Super957
Luke 42255 Posted May 1, 2022 Posted May 1, 2022 Hi, you just configure the settings how you want and then browse around the web app to see how it looks. Please let us know if this helps. Thanks. 1
Super957 24 Posted May 1, 2022 Author Posted May 1, 2022 (edited) I set option in plugin but web connect from app android or web with a client i dont see any changement Thank Hispa Edited May 1, 2022 by Super957
Luke 42255 Posted May 1, 2022 Posted May 1, 2022 16 minutes ago, Super957 said: I set option in plugin but web connect from app android or web with a client i dont see any changement Thank Hispa HI, please go over a specific example. Thanks.
Super957 24 Posted May 1, 2022 Author Posted May 1, 2022 24 minutes ago, Luke said: And then what do you see when browsing your movies? Nothing always as before Hispa
Happy2Play 9814 Posted May 1, 2022 Posted May 1, 2022 Can you provide a server log after changing a treatment styple and navigating in the web client.
Happy2Play 9814 Posted May 1, 2022 Posted May 1, 2022 Do you have Premiere? 2022-05-01 19:16:20.174 Warn CoverArt: CoverArt is expired. Please get Emby Premiere to continue using it.
Super957 24 Posted May 1, 2022 Author Posted May 1, 2022 16 minutes ago, Happy2Play said: Do you have Premiere? 2022-05-01 19:16:20.174 Warn CoverArt: CoverArt is expired. Please get Emby Premiere to continue using it. I download and use today for first time, already expire ? Hispa
Solution Happy2Play 9814 Posted May 1, 2022 Solution Posted May 1, 2022 1 minute ago, Super957 said: I download and use today for first time, already expire ? Hispa @ebrwould have to comment on this. This plugin will require an active Emby Premiere subscription after the 14 day free trial. 1
ebr 16346 Posted May 2, 2022 Posted May 2, 2022 If the plug-in was ever installed before, the trial would have been expended. 1
