MovieFlix00 0 Posted April 30, 2022 Posted April 30, 2022 Hola a todos, @cayars Soy nuevo en Emby World. Quería información. Soy un usuario premium: 1) ¿Cómo cambio el tema de la versión móvil? 2) ¿Cómo acceden los usuarios a la aplicación sin tener un servidor con solo una pantalla de inicio de sesión y contraseña? 3) por que no sale el "seguir viendo" en la pagina de inicio? 4) ¿Es posible crear paneles para revendedores o leí mal?
Carlo 4561 Posted May 1, 2022 Posted May 1, 2022 Hi, themes are changed the same way on all apps. Go to Display menu option in settings on each and every client and set the theme you want to use. Users can't access their own server if they don't have one. If you invite a friend to your server after having setup an account for them, they will be able to use use your server. This requires that you have configured your server for remote access and tested remote access before inviting anyone. You would then have them setup a manual entry with your domain name or IP address and port number. They then login to your system with the username and password you setup for them. Have you added "Continue Watching" to the home screen on that client/app? You can configure what appears on each and every client you use from the client Home Screen menu option right below the Display menu. Each client app will have these menu choices with specific setting that can be set/changed: No absolutely not and you can't charge anyone for access. Our software is specifically licensed to you for non-commercial purposes and only to be used personal use which could include family and close friends. Reseller panels do not fit this use as that is obviously commercial use with the intention of making sales and managing discount or commissions. The basic Premiere License is going to allow you 25 clients using Premiere functionality. We have options to raise this license count for special uses outside the specific intended use such as for a Church, or other non-profit organization, but would require a different license as well as adjustment to Premiere device counts. We require additional information as well as ongoing verification of use. If your intention is to try and use Emby to sell access, stop now and save yourself the grief. We have the ability to do commercial contracts but the vetting will require proof of contracts to all media hosted/streamed as the first step before even discussing options. This would typically be for existing cable and/or telco's looking to transition to an IPTV type solution but already have feeds and contracts in place as well as needed backend hardware to transform streams into needed formats typically using adaptive bitrates so multiple versions of each media are available. Commercial streaming would be require some things to be handled differently than our personal product which does transcoding on the fly for each stream. Streaming to mass users requires a different configuration to properly scale up and out handling any number of customers. If you meet this type of criteria or similar send me a PM and we can discuss in private. Thanks, Carlo
