nanuk 36 Posted April 30, 2022 Posted April 30, 2022 (edited) Hi emby team, first of all thank you very much for the updates of the LG Emby App Ā The app is developing really nice!Ā But... I found a new bug in Version 1.0.35 regarding to subtitle format srt on LG TVs. Normally when selecting srt subtitles a background process is starting, converting srt into a vtt file and storing this into the emby subtitle cache. This is running in background and takes from a few seconds to a few minutes depending on the movie file size... so that you normally don't mention it when watching a movie. Now with 1.0.35 the movie/series episode isn't starting to play until the background task (SubtitleEncoder: ProcessRun 'ffmpeg-subtitle_extract') has finished. It just shows a black screen until the SubtitleEncoder has finished.Ā But ONLY when selecting the srt subtitles from movie/series main screen before pressing Play! I tested this behavior on all three of my LG TVs (different models) Workaround: Start the movie by pressing play and then select theĀ desired srt subtitle from the OSD. This still works as designed. Maybe you can check an fix this in an upcoming version of the emby LG TV App?! Thanx and greets nanuk Ā Ā Edited April 30, 2022 by nanuk
Luke 42237 Posted April 30, 2022 Posted April 30, 2022 Hi there, let's look at an example: Ā Thanks !
nanuk 36 Posted May 5, 2022 Author Posted May 5, 2022 (edited) Hi Luke, sorry that it took a while to answer. Here's the requested logfile. There is nothing special to see in the logfile beside the timestamps 1. I started the movieĀ 00:00:39.031 2. The subtitle encoder startedĀ 00:00:39.418 3. The subtitle encoder finishedĀ 00:01:42.705 4. I stopped playback of the movieĀ 00:02:44.941 after the movie played about 1 minute ->Ā Stopped at 61154 ms So you can see after I started playback the tv screen went black fromĀ 00:00:39.418 toĀ 00:01:42.705 (during subtitle encoder was running) and atĀ 00:01:42.705 when the subtitle encoder finished the movie started to play about one minute tilĀ 00:02:44.941. This behavior for srt subtitles is new inĀ 1.0.35. WithĀ 1.0.33 and the former versions this worked without any problems. As I already wrote the workaround is to start the movie without selecting srt subtitles at the movie screen and then activate the srt subs from the OSD when the movie is already playing. doing so the movie continues playing while the subtitle encoder is working in background (as it should be) embyserver.txt Edited May 5, 2022 by nanuk 1
Josh4u 3 Posted July 7, 2022 Posted July 7, 2022 I too posted about this on my LG tv "Slow or no playback if the movie has embedded forced subs". The same movie with subs chosen plays fine if played back on an amazon firetv stick - just on the LG when subs are chosen before pressing play the screen goes blank with the spinning circle and sits then until you come out of the app. As you say if you choose "no subs" before pressing play it plays fine then you can select subs DURING play which is fine. Very odd indeedy Ā
Luke 42237 Posted August 1, 2022 Posted August 1, 2022 Hi, this is resolved for the next update to the emby LG app. Thanks.
Luke 42237 Posted December 26, 2022 Posted December 26, 2022 Emby for LG TV's 1.0.37 has been released. Stay tuned to the blog for the release announcement. Can you pleaseĀ try out the new update and let us know how it compares? Thanks !
nanuk 36 Posted December 26, 2022 Author Posted December 26, 2022 The problem I described in this post seems to be fixed with emby LG version 1.0.37. thanx for the update 1
