SteveTh 0 Posted April 30, 2022 Posted April 30, 2022 Since an update to Emby for Samsung 1.2.6 the player is causing intermittent jerks/ dropped frames. It happens a few times a minute. The problem does not occur if I use the emby app on my android to stream from my emby server (windows 10) to the samsung TV. This I assume is using a dlna connection without the intervention of Emby for Samsung since it uses the TV's own player. The problem did not exist before the update.
Abobader 3485 Posted April 30, 2022 Posted April 30, 2022 Hello SteveTh, ** This is an auto reply ** Please wait for someone from staff support or our members to reply to you. It's recommended to provide more info, as it explain in this thread: Thank you. Emby Team
FrostByte 5453 Posted April 30, 2022 Posted April 30, 2022 More information is needed in order to effectively help. Please take a look at the pinned post for the information that will be needed
Luke 42241 Posted April 30, 2022 Posted April 30, 2022 Hi, yes can we please look at an example? Thanks.
Leader2light 4 Posted May 10, 2022 Posted May 10, 2022 Any file with a bunch of subtitle options has this problem for me.
FrostByte 5453 Posted May 10, 2022 Posted May 10, 2022 51 minutes ago, Leader2light said: Any file with a bunch of subtitle options has this problem for me. It's a known problem with Samsung TVs. Video will start to stutter if the number of internal tracks reaches around 30. The best solution if to remux your video and remove any unneeded tracks.
