Added Library, Added Folder containing 4000+ Titles, No Progress
Go to solution Solved by BinaryBoss,
  • Solution
BinaryBoss
OK, After long time spend, problem had been rectified. It was a corrupt folder, which stopped emby scanning totally. I just skipped that folder while copying other files in another new folder, & It started working. Thanks all for inputs.
  • Thanks 1
