NicoLaz 4 Posted April 22, 2022 Posted April 22, 2022 (edited) Same story with media conversion from MPEG2-TS to HVEC. It fails on an old TV series I recorded - I assume the error happens when there is the change between the aspect ratios (widescreen ads and "classic" format of the serie's episode), as the moment it fails differs and seems to match the first advertisement block and it does not happen on series or movies where the aspect ratio is consistent. I updated the display driver (intel core i5 onboard graphics), but that did not help. What helped is turning HW acceleration off for transcoding on a global level in the transcoding settings. Transcoding run smoothly afterwards. However, as this results in a higher CPU usage and slower conversion speed on ALL my conversions and transcodings, I would be happy if you could either confirm that problem is being solved soon or provide me with a solution I can activate software transcoding for specific jobs only. Here is the transcoding server log (slightly anonymized for system security reasons): 2022-04-22 10:05:55.338 Operating System: Microsoft Windows 10.0.19044 OS/Process: x64/x64 Emby Server version: 4.6.7.0 Operating system: Microsoft Windows NT 6.2.9200.0 Command Line: C:\Users\xyz\AppData\Roaming\Emby-Server\system\EmbyServer.dll {"Protocol":"File","Id":"77e837bbbb21f8cbeff2c9f3713b7edc","Path":"\\\\DEVICE\\Path\\tv-recording.ts","Type":"Grouping","Container":"mpegts","Size":534917120,"Name":"XYZ","IsRemote":false,"RunTimeTicks":13840567000,"SupportsTranscoding":true,"SupportsDirectStream":true,"SupportsDirectPlay":true,"IsInfiniteStream":false,"RequiresOpening":false,"RequiresClosing":false,"RequiresLooping":false,"SupportsProbing":false,"MediaStreams":[{"Codec":"mpeg2video","ColorTransfer":"bt470bg","ColorPrimaries":"bt470bg","ColorSpace":"bt470bg","TimeBase":"1/90000","CodecTimeBase":"1/25","VideoRange":"SDR","DisplayTitle":"576i MPEG2VIDEO","IsInterlaced":true,"BitRate":3091879,"BitDepth":8,"RefFrames":1,"IsDefault":false,"IsForced":false,"Height":576,"Width":720,"AverageFrameRate":25,"RealFrameRate":25,"Profile":"Main","Type":"Video","AspectRatio":"4:3","Index":0,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Protocol":"File","PixelFormat":"yuv420p","Level":8,"IsAnamorphic":true},{"Codec":"mp2","Language":"deu","TimeBase":"1/90000","CodecTimeBase":"1/48000","DisplayTitle":"German MP2 stereo","DisplayLanguage":"German","IsInterlaced":false,"ChannelLayout":"stereo","BitRate":192000,"Channels":2,"SampleRate":48000,"IsDefault":false,"IsForced":false,"Type":"Audio","Index":1,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Protocol":"File"},{"Codec":"dvb_teletext","Language":"deu","TimeBase":"1/90000","CodecTimeBase":"0/1","Extradata":"00000000: 0900","DisplayTitle":"German (DVB_TELETEXT)","DisplayLanguage":"German","IsInterlaced":false,"IsDefault":false,"IsForced":false,"Height":250,"Width":492,"Type":"Subtitle","Index":2,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Protocol":"File"}],"Formats":[],"Bitrate":3091879,"RequiredHttpHeaders":{},"ReadAtNativeFramerate":false} >>>>>> Affected codecs Encoder QuickSync Intel(R) UHD Graphics 630 - D3D11 - H.265 (HEVC) Adapter #0: 'Intel(R) UHD Graphics 630 - D3D11' Id:16024 (Driver: , Vendor: 32902, SDK Version: 1.35) Frame Sizes: 32x32...4096x2176 - Width Alignment: 16 - Height Alignment: 16 Color Formats: NV12, P010, QSV Profiles: Main Profile (Level 5.1), Main Still Picture (Level 5.1) Decoder DX11VA Intel(R) UHD Graphics 630 - MPEG-2 Adapter #0: 'Intel(R) UHD Graphics 630' Id:16024 (Driver: , Vendor: 32902) Frame Sizes: max 2048x1080 Color Formats: NV12, YUV420P Profiles: Simple Profile (High Level), Main Profile (High Level) >>>>>> FindVideoEncoder - Media: hevc, UseHardwareCodecs: True, Mode: Automatic Info Checking: 'QuickSync Intel(R) UHD Graphics 630 - D3D11 - H.265 (HEVC)' Info Check successful - selecting 'QuickSync Intel(R) UHD Graphics 630 - D3D11 - H.265 (HEVC)' >>>>>> FindVideoDecoder - MediaType: mpeg2video, Mode: Automatic Info Checking: 'DX11VA Intel(R) UHD Graphics 630 - MPEG-2' Info Check successful - selecting 'DX11VA Intel(R) UHD Graphics 630 - MPEG-2' >>>>>> Processing Plan Info Name CanDoInHardware WillDoInHardware Reason Info DX11VA Intel(R) UHD Graphics 630 - MP... >> True True Hardware Codec Info VideoInput >> True True Same adapter Id (0), same hardware co... Info Deinterlace >> True True Info VideoOutput >> True True Hardware encoder Info QuickSync Intel(R) UHD Graphics 630 -... >> True True Hardware Codec >>>>>> Projected Processing Formats Info Previous HW-Context Format SW-Format Size Next Info mpeg2video >> D3D11VA d3d11 nv12 720x576 >> hwmap Info hwmap >> QSV qsv nv12 720x576 >> vpp_qsv Info vpp_qsv >> QSV qsv nv12 720x576 >> C:\Users\xyz\AppData\Roaming\Emby-Server\system\ffmpeg.exe -loglevel +timing -y -print_graphs_file "C:\Users\xyz\AppData\Roaming\Emby-Server\programdata\logs\ffmpeg-transcode-3dddbcc1-f730-48b9-9ee5-96dcd14b82e4_1graph.txt" -copyts -start_at_zero -f mpegts -re -c:v:0 mpeg2video -hwaccel:v:0 d3d11va -hwaccel_device:v:0 0 -hwaccel_output_format:v:0 d3d11 -i "\\DEVICE\Path\tv-recording.ts" -filter_complex "[0:0]hwmap@f1=mode=+read:derive_device=qsv,vpp_qsv@f2=deinterlace=advanced[f2_out0]" -map [f2_out0] -map 0:1 -sn -c:v:0 hevc_qsv -g:v:0 150 -maxrate:v:0 1545940 -bufsize:v:0 3091880 -sc_threshold:v:0 0 -keyint_min:v:0 150 -r:v:0 25 -c:a:0 aac -ab:a:0 192000 -ac:a:0 2 -metadata:s:a:0 language=ger -disposition:a:0 default -avoid_negative_ts disabled -map_metadata -1 -map_chapters -1 "C:\Users\XYZ\AppData\Roaming\Emby-Server\programdata\sync\28\630\3dddbcc1-f730-48b9-9ee5-96dcd14b82e4.mkv" 10:05:55.383 ffmpeg version 4.3.0-emby_2021_02_27-g8f222573e9+634 Copyright (c) 2000-2021 the FFmpeg developers and softworkz for Emby LLC 10:05:55.384 built with gcc 9.2.0 (Rev2, Built by MSYS2 project) 10:05:55.384 Execution Date: 2022-04-22 10:05:55 10:05:55.484 [mpeg2video @ 000001f9ac130cc0] Invalid frame dimensions 0x0. Last message repeated 14 times 10:05:55.551 [mpegts @ 000001f9ac110e40] Could not find codec parameters for stream 3 (Unknown: none ([5][0][0][0] / 0x0005)): unknown codec Consider increasing the value for the 'analyzeduration' and 'probesize' options 10:05:55.552 Input #0, mpegts, from '\\DEVICE\Path\tv-recording.ts': 10:05:55.552 Duration: 00:23:04.06, start: 69008.024033, bitrate: 3091 kb/s 10:05:55.552 Program 66 10:05:55.552 Stream #0:0[0x250]: Video: mpeg2video (Main) ([2][0][0][0] / 0x0002), yuv420p(tv, bt470bg, top first), 720x576 [SAR 16:15 DAR 4:3], Level 8, 25 fps, 25 tbr, 90k tbn, 50 tbc, Start-Time 69008.641s 10:05:55.552 Stream #0:1[0x251](deu): Audio: mp2 ([3][0][0][0] / 0x0003), 48000 Hz, stereo, fltp, 192 kb/s, Start-Time 69008.068s 10:05:55.552 Stream #0:2[0x26e](deu): Subtitle: dvb_teletext ([6][0][0][0] / 0x0006), 492x250, Start-Time 69008.024s 10:05:55.552 Stream #0:3[0x270]: Unknown: none ([5][0][0][0] / 0x0005), Start-Time 69008.024s 10:05:55.560 [AVHWDeviceContext @ 000001f9ac150780] Using D3D11 device 8086:3e98 (Intel(R) UHD Graphics 630). 10:05:55.592 Stream mapping: 10:05:55.592 Stream #0:0 (mpeg2video) -> hwmap (graph 0) 10:05:55.592 vpp_qsv (graph 0) -> Stream #0:0 (hevc_qsv) 10:05:55.592 Stream #0:1 -> #0:1 (mp2 (native) -> aac (native)) 10:05:55.592 Press [q] to stop, [?] for help 10:05:56.093 frame= 0 fps=0.0 q=0.0 size= 0kB time=-577014:32:22.77 bitrate=N/A throttle=off speed= 0x 10:05:56.593 frame= 0 fps=0.0 q=0.0 size= 0kB time=-577014:32:22.77 bitrate=N/A throttle=off speed= 0x 10:05:57.009 Output #0, matroska, to 'C:\Users\XYZ\AppData\Roaming\Emby-Server\programdata\sync\28\630\3dddbcc1-f730-48b9-9ee5-96dcd14b82e4.mkv': 10:05:57.009 Metadata: 10:05:57.009 encoder : Lavf58.35.100 10:05:57.009 Stream #0:0: Video: hevc (hevc_qsv), qsv, 720x576 [SAR 16:15 DAR 4:3], q=2-31, 1000 kb/s, 25 fps, 1k tbn, 25 tbc 10:05:57.009 Metadata: 10:05:57.009 encoder : Lavc58.62.100 hevc_qsv 10:05:57.009 Side data: 10:05:57.009 cpb: bitrate max/min/avg: 1545940/0/1000000 buffer size: 3091880 vbv_delay: N/A 10:05:57.009 Stream #0:1(ger): Audio: aac (LC) ([255][0][0][0] / 0x00FF), 48000 Hz, stereo, fltp, 192 kb/s (default) 10:05:57.009 Metadata: 10:05:57.009 encoder : Lavc58.62.100 aac 10:05:57.113 frame= 6 fps=4.0 q=0.0 size= 1kB time=00:00:00.79 bitrate= 0.0kbits/s throttle=off speed=6.08e+12x 10:05:57.622 frame= 19 fps=9.4 q=-0.0 size= 28kB time=00:00:01.45 bitrate= 0.0kbits/s throttle=off speed=4.55e+12x 10:05:58.126 frame= 31 fps= 12 q=-0.0 size= 28kB time=00:00:01.96 bitrate= 0.0kbits/s throttle=off speed=3.64e+12x 10:05:58.636 frame= 44 fps= 14 q=-0.0 size= 28kB time=00:00:02.47 bitrate= 0.0kbits/s throttle=off speed=3.03e+12x 10:05:59.139 frame= 56 fps= 16 q=-0.0 size= 28kB time=00:00:02.88 bitrate= 0.0kbits/s throttle=off speed=2.6e+12x 10:05:59.659 frame= 70 fps= 17 q=-0.0 size= 28kB time=00:00:03.44 bitrate= 0.0kbits/s throttle=off speed=2.27e+12x 10:06:00.173 frame= 83 fps= 18 q=-0.0 size= 28kB time=00:00:03.96 bitrate= 0.0kbits/s throttle=off speed=2.02e+12x 10:06:00.671 frame= 95 fps= 19 q=-0.0 size= 28kB time=00:00:04.48 bitrate= 0.0kbits/s throttle=off speed=1.82e+12x 10:06:01.172 frame= 107 fps= 19 q=-0.0 size= 28kB time=00:00:04.92 bitrate= 0.0kbits/s throttle=off speed=1.65e+12x 10:06:01.679 frame= 120 fps= 20 q=-0.0 size= 28kB time=00:00:05.44 bitrate= 0.0kbits/s throttle=off speed=1.52e+12x 10:06:02.186 frame= 132 fps= 20 q=-0.0 size= 28kB time=00:00:05.92 bitrate= 0.0kbits/s throttle=off speed=1.4e+12x 10:06:02.688 frame= 145 fps= 20 q=-0.0 size= 580kB time=00:00:06.50 bitrate= 0.0kbits/s throttle=off speed=1.3e+12x 10:06:03.197 frame= 158 fps= 21 q=-0.0 size= 580kB time=00:00:06.96 bitrate= 0.0kbits/s throttle=off speed=1.21e+12x 10:06:03.706 frame= 171 fps= 21 q=-0.0 size= 744kB time=00:00:07.48 bitrate= 0.0kbits/s throttle=off speed=1.14e+12x 10:06:04.216 frame= 184 fps= 21 q=-0.0 size= 744kB time=00:00:08.00 bitrate= 0.0kbits/s throttle=off speed=1.07e+12x 10:06:04.738 frame= 197 fps= 22 q=-0.0 size= 744kB time=00:00:08.52 bitrate= 0.0kbits/s throttle=off speed=1.01e+12x 10:06:05.249 frame= 209 fps= 22 q=-0.0 size= 744kB time=00:00:09.00 bitrate= 0.0kbits/s throttle=off speed=9.55e+11x 10:06:05.759 frame= 222 fps= 22 q=-0.0 size= 744kB time=00:00:09.52 bitrate= 0.0kbits/s throttle=off speed=9.07e+11x 10:06:06.266 frame= 235 fps= 22 q=-0.0 size= 744kB time=00:00:10.04 bitrate= 0.0kbits/s throttle=off speed=8.64e+11x 10:06:06.778 frame= 248 fps= 22 q=-0.0 size= 744kB time=00:00:10.56 bitrate= 0.0kbits/s throttle=off speed=8.25e+11x 10:06:07.277 frame= 260 fps= 22 q=-0.0 size= 744kB time=00:00:11.04 bitrate= 0.0kbits/s throttle=off speed=7.89e+11x 10:06:07.782 frame= 273 fps= 22 q=-0.0 size= 744kB time=00:00:11.56 bitrate= 0.0kbits/s throttle=off speed=7.57e+11x 10:06:08.299 frame= 286 fps= 23 q=-0.0 size= 1306kB time=00:00:12.20 bitrate= 0.0kbits/s throttle=off speed=7.26e+11x 10:06:08.796 frame= 298 fps= 23 q=-0.0 size= 1306kB time=00:00:12.56 bitrate= 0.0kbits/s throttle=off speed=6.99e+11x 10:06:09.299 frame= 311 fps= 23 q=-0.0 size= 1306kB time=00:00:13.08 bitrate= 0.0kbits/s throttle=off speed=6.73e+11x 10:06:09.807 frame= 323 fps= 23 q=-0.0 size= 1464kB time=00:00:13.56 bitrate= 0.0kbits/s throttle=off speed=6.49e+11x 10:06:10.308 frame= 336 fps= 23 q=-0.0 size= 1464kB time=00:00:14.08 bitrate= 0.0kbits/s throttle=off speed=6.27e+11x 10:06:10.828 frame= 348 fps= 23 q=-0.0 size= 1464kB time=00:00:14.59 bitrate= 0.0kbits/s throttle=off speed=6.05e+11x 10:06:11.347 frame= 362 fps= 23 q=-0.0 size= 1464kB time=00:00:15.12 bitrate= 0.0kbits/s throttle=off speed=5.86e+11x 10:06:11.855 frame= 375 fps= 23 q=-0.0 size= 1464kB time=00:00:15.64 bitrate= 0.0kbits/s throttle=off speed=5.67e+11x 10:06:12.375 frame= 388 fps= 23 q=-0.0 size= 1464kB time=00:00:16.16 bitrate= 0.0kbits/s throttle=off speed=5.5e+11x 10:06:12.883 frame= 400 fps= 23 q=-0.0 size= 1464kB time=00:00:16.64 bitrate= 0.0kbits/s throttle=off speed=5.33e+11x 10:06:13.390 frame= 413 fps= 23 q=-0.0 size= 1464kB time=00:00:17.16 bitrate= 0.0kbits/s throttle=off speed=5.18e+11x 10:06:13.891 frame= 425 fps= 23 q=-0.0 size= 1464kB time=00:00:17.64 bitrate= 0.0kbits/s throttle=off speed=5.04e+11x 10:06:14.400 frame= 438 fps= 23 q=-0.0 size= 2025kB time=00:00:18.16 bitrate= 0.0kbits/s throttle=off speed=4.9e+11x 10:06:14.907 frame= 451 fps= 23 q=-0.0 size= 2025kB time=00:00:18.68 bitrate= 0.0kbits/s throttle=off speed=4.78e+11x 10:06:15.408 frame= 463 fps= 23 q=-0.0 size= 2170kB time=00:00:19.26 bitrate= 0.0kbits/s throttle=off speed=4.65e+11x 10:06:15.916 frame= 476 fps= 23 q=-0.0 size= 2170kB time=00:00:19.77 bitrate= 0.0kbits/s throttle=off speed=4.54e+11x 10:06:16.425 frame= 489 fps= 23 q=-0.0 size= 2170kB time=00:00:20.26 bitrate= 0.0kbits/s throttle=off speed=4.43e+11x 10:06:16.939 frame= 502 fps= 24 q=-0.0 size= 2170kB time=00:00:20.72 bitrate= 0.0kbits/s throttle=off speed=4.32e+11x 10:06:17.445 frame= 514 fps= 24 q=-0.0 size= 2170kB time=00:00:21.20 bitrate= 0.0kbits/s throttle=off speed=4.22e+11x 10:06:17.950 frame= 527 fps= 24 q=-0.0 size= 2170kB time=00:00:21.95 bitrate= 0.0kbits/s throttle=off speed=4.13e+11x 10:06:18.471 frame= 540 fps= 24 q=-0.0 size= 2170kB time=00:00:22.46 bitrate= 0.0kbits/s throttle=off speed=4.03e+11x 10:06:18.987 frame= 553 fps= 24 q=-0.0 size= 2170kB time=00:00:22.80 bitrate= 0.0kbits/s throttle=off speed=3.94e+11x 10:06:19.497 frame= 566 fps= 24 q=-0.0 size= 2170kB time=00:00:23.29 bitrate= 0.0kbits/s throttle=off speed=3.86e+11x 10:06:20.002 frame= 578 fps= 24 q=-0.0 size= 2170kB time=00:00:23.80 bitrate= 0.0kbits/s throttle=off speed=3.78e+11x 10:06:20.502 frame= 591 fps= 24 q=-0.0 size= 2767kB time=00:00:24.29 bitrate= 0.0kbits/s throttle=off speed=3.7e+11x 10:06:21.016 frame= 603 fps= 24 q=-0.0 size= 2767kB time=00:00:24.76 bitrate= 0.0kbits/s throttle=off speed=3.63e+11x 10:06:21.524 frame= 616 fps= 24 q=-0.0 size= 2767kB time=00:00:25.28 bitrate= 0.0kbits/s throttle=off speed=3.56e+11x 10:06:22.031 frame= 629 fps= 24 q=-0.0 size= 2936kB time=00:00:25.80 bitrate= 0.0kbits/s throttle=off speed=3.49e+11x 10:06:22.550 frame= 642 fps= 24 q=-0.0 size= 2936kB time=00:00:26.32 bitrate= 0.0kbits/s throttle=off speed=3.42e+11x 10:06:23.057 frame= 655 fps= 24 q=-0.0 size= 2936kB time=00:00:26.84 bitrate= 0.0kbits/s throttle=off speed=3.36e+11x 10:06:23.556 frame= 667 fps= 24 q=-0.0 size= 2936kB time=00:00:27.49 bitrate= 0.0kbits/s throttle=off speed=3.3e+11x 10:06:24.066 frame= 680 fps= 24 q=-0.0 size= 2936kB time=00:00:28.01 bitrate= 0.0kbits/s throttle=off speed=3.24e+11x 10:06:24.564 frame= 692 fps= 24 q=-0.0 size= 2936kB time=00:00:28.67 bitrate= 0.0kbits/s throttle=off speed=3.18e+11x 10:06:25.079 frame= 705 fps= 24 q=-0.0 size= 2936kB time=00:00:29.18 bitrate= 0.0kbits/s throttle=off speed=3.13e+11x 10:06:25.579 frame= 717 fps= 24 q=-0.0 size= 2936kB time=00:00:29.63 bitrate= 0.0kbits/s throttle=off speed=3.08e+11x 10:06:26.088 frame= 730 fps= 24 q=-0.0 size= 2936kB time=00:00:30.01 bitrate= 0.0kbits/s throttle=off speed=3.02e+11x 10:06:26.593 frame= 743 fps= 24 q=-0.0 size= 3634kB time=00:00:30.36 bitrate= 0.0kbits/s throttle=off speed=2.98e+11x 10:06:27.114 frame= 756 fps= 24 q=-0.0 size= 3634kB time=00:00:30.88 bitrate= 0.0kbits/s throttle=off speed=2.93e+11x 10:06:27.623 frame= 769 fps= 24 q=-0.0 size= 3778kB time=00:00:31.53 bitrate= 0.0kbits/s throttle=off speed=2.88e+11x 10:06:28.121 frame= 781 fps= 24 q=-0.0 size= 3778kB time=00:00:31.88 bitrate= 0.0kbits/s throttle=off speed=2.84e+11x 10:06:28.622 frame= 793 fps= 24 q=-0.0 size= 3778kB time=00:00:32.42 bitrate= 0.0kbits/s throttle=off speed=2.79e+11x 10:06:29.142 frame= 806 fps= 24 q=-0.0 size= 3778kB time=00:00:32.89 bitrate= 0.0kbits/s throttle=off speed=2.75e+11x 10:06:29.657 frame= 820 fps= 24 q=-0.0 size= 3778kB time=00:00:33.55 bitrate= 0.0kbits/s throttle=off speed=2.71e+11x 10:06:30.172 frame= 833 fps= 24 q=-0.0 size= 3778kB time=00:00:33.96 bitrate= 0.0kbits/s throttle=off speed=2.67e+11x 10:06:30.686 frame= 845 fps= 24 q=-0.0 size= 3778kB time=00:00:34.44 bitrate= 0.0kbits/s throttle=off speed=2.63e+11x 10:06:31.186 frame= 858 fps= 24 q=-0.0 size= 3778kB time=00:00:34.96 bitrate= 0.0kbits/s throttle=off speed=2.59e+11x 10:06:31.705 frame= 871 fps= 24 q=-0.0 size= 3778kB time=00:00:35.48 bitrate= 0.0kbits/s throttle=off speed=2.55e+11x 10:06:32.215 frame= 884 fps= 24 q=-0.0 size= 4430kB time=00:00:36.00 bitrate= 0.0kbits/s throttle=off speed=2.52e+11x 10:06:32.733 frame= 896 fps= 24 q=-0.0 size= 4430kB time=00:00:36.48 bitrate= 0.0kbits/s throttle=off speed=2.48e+11x 10:06:33.243 frame= 909 fps= 24 q=-0.0 size= 4430kB time=00:00:37.07 bitrate= 0.0kbits/s throttle=off speed=2.45e+11x 10:06:33.752 frame= 922 fps= 24 q=-0.0 size= 4594kB time=00:00:37.59 bitrate= 0.0kbits/s throttle=off speed=2.42e+11x 10:06:34.268 frame= 935 fps= 24 q=-0.0 size= 4594kB time=00:00:38.04 bitrate= 0.0kbits/s throttle=off speed=2.38e+11x 10:06:34.767 frame= 947 fps= 24 q=-0.0 size= 4594kB time=00:00:38.52 bitrate= 0.0kbits/s throttle=off speed=2.35e+11x 10:06:35.273 frame= 960 fps= 24 q=-0.0 size= 4594kB time=00:00:39.04 bitrate= 0.0kbits/s throttle=off speed=2.32e+11x 10:06:35.778 frame= 972 fps= 24 q=-0.0 size= 4594kB time=00:00:39.52 bitrate= 0.0kbits/s throttle=off speed=2.3e+11x 10:06:36.300 frame= 986 fps= 24 q=-0.0 size= 4594kB time=00:00:40.08 bitrate= 0.0kbits/s throttle=off speed=2.27e+11x 10:06:36.807 frame= 998 fps= 24 q=-0.0 size= 4594kB time=00:00:40.59 bitrate= 0.0kbits/s throttle=off speed=2.24e+11x 10:06:37.314 frame= 1011 fps= 24 q=-0.0 size= 4594kB time=00:00:41.08 bitrate= 0.0kbits/s throttle=off speed=2.21e+11x 10:06:37.830 frame= 1023 fps= 24 q=-0.0 size= 4594kB time=00:00:41.56 bitrate= 0.0kbits/s throttle=off speed=2.18e+11x 10:06:38.343 frame= 1037 fps= 24 q=-0.0 size= 5243kB time=00:00:42.12 bitrate= 0.0kbits/s throttle=off speed=2.16e+11x 10:06:38.841 frame= 1049 fps= 24 q=-0.0 size= 5243kB time=00:00:42.62 bitrate= 0.0kbits/s throttle=off speed=2.13e+11x 10:06:39.345 frame= 1062 fps= 24 q=-0.0 size= 5243kB time=00:00:43.12 bitrate= 0.0kbits/s throttle=off speed=2.11e+11x 10:06:39.430 Impossible to convert between the formats supported by the filter 'scaler_out_0_0' and the filter 'auto_scaler_0' 10:06:39.430 Error reinitializing filters! 10:06:39.430 Failed to inject frame into filter network: Function not implemented 10:06:39.430 Error while processing the decoded data for stream #0:0 10:06:39.437 [aac @ 000001f9ac722c40] Qavg: 186.726 10:06:39.438 [aac @ 000001f9ac722c40] 2 frames left in the queue on closing 10:06:39.439 Conversion failed! 10:06:39.439 ======= ExtraData 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 Thank you very much for your help! Edited April 22, 2022 by NicoLaz
Luke 42186 Posted April 28, 2022 Posted April 28, 2022 @NicoLaz please attach the complete emby server and ffmpeg log files from an example. Thanks !
