Q-Droid 1011 Posted May 3, 2022 Posted May 3, 2022 On 5/1/2022 at 12:29 AM, vaise said: you can test it - just put http://your-tvh-ip:9981/playlist/channels.m3u in a browser, it should download, the channels.m3u file from your TVH - open that with vlc, or any other m3u capable player, then you can watch tv, change channels etc - its the same as emby does. Then for the whole hog - have a look at this site for the guide data info for your region - https://www.xmltv.net/. Happy to help if you go forward - us aussies have to stick together. 8 minutes ago, fallenwitch3r said: This isn't working here because after double click on the playlist opens a window for username and password input I believe @fallenwitch3r doesn't want to use noauth for TVH, which AFAIK is the only way the m3u link would work in Emby. 1
fallenwitch3r 45 Posted May 3, 2022 Author Posted May 3, 2022 10 minutes ago, Q-Droid said: I believe @fallenwitch3r doesn't want to use noauth for TVH, which AFAIK is the only way the m3u link would work in Emby. And the plugin is also using noauth
Q-Droid 1011 Posted May 3, 2022 Posted May 3, 2022 Even with noauth you can still restrict the TVH user access from a single IP or subnet. Though it depends on what your needs are and may not be restrictive enough.
fallenwitch3r 45 Posted May 3, 2022 Author Posted May 3, 2022 1 hour ago, Q-Droid said: Even with noauth you can still restrict the TVH user access from a single IP or subnet. Though it depends on what your needs are and may not be restrictive enough. Can you show an example how to set this up?
Q-Droid 1011 Posted May 3, 2022 Posted May 3, 2022 The noauth user in TVH is named "*" with no password. I think HTTP digest authentication has to be enabled. In the Users settings for "*" you can disable Web Interface and Admin access. Enable all Streaming options, Video recorder access can be allowed but not needed if you plan to use Emby for DVR. For most other settings the defaults should be enough. Enter a source IP, list of IPs or subnet in Allowed Networks. The default profile should be "pass" unless you have specific needs for other profiles. Now, the TVH docs state that the "*" user should be first in the list. But for some, and I don't know why, it wouldn't work unless the "*" user was last. You might have to try one or the other. VLC is the easiest way to test these settings and changes. If you get it working in VLC with noauth then it should work in Emby.
fallenwitch3r 45 Posted May 3, 2022 Author Posted May 3, 2022 I set all up but the plugin don't let me add channels without setting an password. What password should I use for the * user?
Q-Droid 1011 Posted May 3, 2022 Posted May 3, 2022 That was meant for m3u, not plug-in. It's been years since I've looked at the plug-in, which I think expected user/pass to function.
fallenwitch3r 45 Posted May 3, 2022 Author Posted May 3, 2022 The plugin won't work here, this is why I switched to the m3u playlist. This is working perfect with a persistent authentication. But why is there a plugin without any documentation how to use it or how to set tvheadend up to get this thing to work
Q-Droid 1011 Posted May 3, 2022 Posted May 3, 2022 I'm confused. You're already using m3u playlist but with credentials for TVH? The info I posted was to use m3u playlist with noauth. I only tried the plugin briefly like four years ago and quickly got rid of it. I don't have anything to offer and not sure if it's even maintained. Out of curiosity, how long do channel tuning and changing take for you now?
fallenwitch3r 45 Posted May 4, 2022 Author Posted May 4, 2022 It tooks around 10 seconds with my first setup but after I switched the streaming container from mkv to ts it's around 3-5 seconds. But it's way to slow. My IPTV device switches the same channels under one second.
Q-Droid 1011 Posted May 4, 2022 Posted May 4, 2022 Is this with pause/rewind/skip enabled during playback? If so then 3-5 is pretty good. For me direct play is in the 3-5 range and with DVR options it's 5-8 using OTA broadcast.
fallenwitch3r 45 Posted May 4, 2022 Author Posted May 4, 2022 its without pause/rewind/skip enabled. It tooks around 6-8 sec with these features enabled
Groentjuh 0 Posted May 10, 2022 Posted May 10, 2022 (edited) I recently also got issues with the TVHeadend plugin. It used to work fine, so I wonder if an update on Emby OR TVHeadend possibly broke something. Can someone give me some pointers what I should look into. I do not believe this is a authentication issue, because both sides seem to log correct authentication. The tuner will also start tuning to the correct channel, but will be cancelled soon after. Logs in the spoiler: Spoiler Embyserver logs: 2022-05-10 14:30:25.580 Info Main: Application path: /system/EmbyServer.dll 2022-05-10 14:30:25.777 Info Main: Emby Command line: /system/EmbyServer.dll -programdata /config -ffdetect /bin/ffdetect -ffmpeg /bin/ffmpeg -ffprobe /bin/ffprobe -restartexitcode 3 Operating system: Linux version 5.15.0-27-generic (buildd@ubuntu) (gcc (Ubuntu 11.2.0-19ubuntu1) 11.2.0, GNU ld (GNU Binutils for Ubuntu) 2.38) #28-Ubuntu SMP Thu Apr 1 Framework: .NET Core 3.1.21 OS/Process: x64/x64 Runtime: system/System.Private.CoreLib.dll Processor count: 3 Data path: /config Application path: /system 2022-05-10 14:30:25.777 Info Main: Logs path: /config/logs 2022-05-10 14:30:25.777 Info Main: Cache path: /config/cache 2022-05-10 14:30:25.777 Info Main: Internal metadata path: /config/metadata 2022-05-10 14:30:25.777 Info Main: Transcoding temporary files path: /config/transcoding-temp 2022-05-10 14:30:25.806 Info App: Application version: 4.6.7.0 2022-05-10 14:30:25.808 Info App: Loading assemblies 2022-05-10 14:30:25.839 Info App: File /config/plugins/NfoMetadata.dll has version 1.0.56.0 2022-05-10 14:30:25.839 Info App: File /system/plugins/NfoMetadata.dll has version 1.0.56.0 2022-05-10 14:30:25.839 Info App: File /config/plugins/StudioImages.dll has version 1.0.3.0 2022-05-10 14:30:25.840 Info App: File /system/plugins/StudioImages.dll has version 1.0.3.0 2022-05-10 14:30:25.840 Info App: File /config/plugins/Emby.Server.CinemaMode.dll has version 1.0.38.0 2022-05-10 14:30:25.840 Info App: File /system/plugins/Emby.Server.CinemaMode.dll has version 1.0.38.0 2022-05-10 14:30:25.840 Info App: File /config/plugins/Fanart.dll has version 1.0.13.0 2022-05-10 14:30:25.840 Info App: File /system/plugins/Fanart.dll has version 1.0.13.0 2022-05-10 14:30:25.840 Info App: File /config/plugins/OpenSubtitles.dll has version 1.0.28.0 2022-05-10 14:30:25.841 Info App: File /system/plugins/OpenSubtitles.dll has version 1.0.28.0 2022-05-10 14:30:25.841 Info App: File /config/plugins/Emby.Webhooks.dll has version 1.0.15.0 2022-05-10 14:30:25.841 Info App: File /system/plugins/Emby.Webhooks.dll has version 1.0.15.0 2022-05-10 14:30:25.841 Info App: File /config/plugins/Emby.PortMapper.dll has version 1.0.9.0 2022-05-10 14:30:25.841 Info App: File /system/plugins/Emby.PortMapper.dll has version 1.0.6.0 2022-05-10 14:30:25.841 Info App: File /config/plugins/OMDb.dll has version 1.0.14.0 2022-05-10 14:30:25.841 Info App: File /system/plugins/OMDb.dll has version 1.0.14.0 2022-05-10 14:30:25.842 Info App: File /config/plugins/Emby.Dlna.dll has version 1.0.69.0 2022-05-10 14:30:25.842 Info App: File /system/plugins/Emby.Dlna.dll has version 1.0.69.0 2022-05-10 14:30:25.842 Info App: File /config/plugins/AudioDb.dll has version 1.0.14.0 2022-05-10 14:30:25.842 Info App: File /system/plugins/AudioDb.dll has version 1.0.14.0 2022-05-10 14:30:25.843 Info App: File /config/plugins/DvdMounter.dll has version 1.0.0.0 2022-05-10 14:30:25.843 Info App: File /system/plugins/DvdMounter.dll has version 1.0.0.0 2022-05-10 14:30:25.843 Info App: File /config/plugins/Tvdb.dll has version 1.0.42.0 2022-05-10 14:30:25.843 Info App: File /system/plugins/Tvdb.dll has version 1.0.42.0 2022-05-10 14:30:25.843 Info App: File /config/plugins/MusicBrainz.dll has version 1.0.18.0 2022-05-10 14:30:25.843 Info App: File /system/plugins/MusicBrainz.dll has version 1.0.17.0 2022-05-10 14:30:25.844 Info App: File /config/plugins/BlurayMounter.dll has version 1.0.0.0 2022-05-10 14:30:25.844 Info App: File /system/plugins/BlurayMounter.dll has version 1.0.0.0 2022-05-10 14:30:25.844 Info App: File /config/plugins/MovieDb.dll has version 1.5.2.0 2022-05-10 14:30:25.844 Info App: File /system/plugins/MovieDb.dll has version 1.5.1.0 2022-05-10 14:30:25.852 Info App: Loading NfoMetadata, Version=1.0.56.0, Culture=neutral, PublicKeyToken=null from /config/plugins/NfoMetadata.dll 2022-05-10 14:30:25.852 Info App: Loading StudioImages, Version=1.0.3.0, Culture=neutral, PublicKeyToken=null from /config/plugins/StudioImages.dll 2022-05-10 14:30:25.853 Info App: Loading Emby.Server.CinemaMode, Version=1.0.38.0, Culture=neutral, PublicKeyToken=null from /config/plugins/Emby.Server.CinemaMode.dll 2022-05-10 14:30:25.853 Info App: Loading Fanart, Version=1.0.13.0, Culture=neutral, PublicKeyToken=null from /config/plugins/Fanart.dll 2022-05-10 14:30:25.853 Info App: Loading OpenSubtitles, Version=1.0.28.0, Culture=neutral, PublicKeyToken=null from /config/plugins/OpenSubtitles.dll 2022-05-10 14:30:25.853 Info App: Loading Emby.Webhooks, Version=1.0.15.0, Culture=neutral, PublicKeyToken=null from /config/plugins/Emby.Webhooks.dll 2022-05-10 14:30:25.853 Info App: Loading Emby.PortMapper, Version=1.0.9.0, Culture=neutral, PublicKeyToken=null from /config/plugins/Emby.PortMapper.dll 2022-05-10 14:30:25.853 Info App: Loading OMDb, Version=1.0.14.0, Culture=neutral, PublicKeyToken=null from /config/plugins/OMDb.dll 2022-05-10 14:30:25.853 Info App: Loading Emby.Kodi.SyncQueue, Version=2.2.0.0, Culture=neutral, PublicKeyToken=null from /config/plugins/Emby.Kodi.SyncQueue.dll 2022-05-10 14:30:25.853 Info App: Loading Emby.Dlna, Version=1.0.69.0, Culture=neutral, PublicKeyToken=null from /config/plugins/Emby.Dlna.dll 2022-05-10 14:30:25.853 Info App: Loading AudioDb, Version=1.0.14.0, Culture=neutral, PublicKeyToken=null from /config/plugins/AudioDb.dll 2022-05-10 14:30:25.853 Info App: Loading DvdMounter, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null from /config/plugins/DvdMounter.dll 2022-05-10 14:30:25.853 Info App: Loading Tvdb, Version=1.0.42.0, Culture=neutral, PublicKeyToken=null from /config/plugins/Tvdb.dll 2022-05-10 14:30:25.853 Info App: Loading MusicBrainz, Version=1.0.18.0, Culture=neutral, PublicKeyToken=null from /config/plugins/MusicBrainz.dll 2022-05-10 14:30:25.854 Info App: Loading TVHeadEnd, Version=1.4.6.0, Culture=neutral, PublicKeyToken=null from /config/plugins/TVHeadEnd.dll 2022-05-10 14:30:25.854 Info App: Loading BlurayMounter, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null from /config/plugins/BlurayMounter.dll 2022-05-10 14:30:25.854 Info App: Loading MovieDb, Version=1.5.2.0, Culture=neutral, PublicKeyToken=null from /config/plugins/MovieDb.dll 2022-05-10 14:30:25.854 Info App: Loading Emby.Api, Version=4.6.7.0, Culture=neutral, PublicKeyToken=null 2022-05-10 14:30:25.854 Info App: Loading Emby.Web, Version=4.6.7.0, Culture=neutral, PublicKeyToken=null 2022-05-10 14:30:25.854 Info App: Loading MediaBrowser.Model, Version=4.6.7.0, Culture=neutral, PublicKeyToken=null 2022-05-10 14:30:25.854 Info App: Loading MediaBrowser.Common, Version=4.6.7.0, Culture=neutral, PublicKeyToken=null 2022-05-10 14:30:25.854 Info App: Loading MediaBrowser.Controller, Version=4.6.7.0, Culture=neutral, PublicKeyToken=null 2022-05-10 14:30:25.854 Info App: Loading Emby.Providers, Version=4.6.7.0, Culture=neutral, PublicKeyToken=null 2022-05-10 14:30:25.854 Info App: Loading Emby.Photos, Version=4.6.7.0, Culture=neutral, PublicKeyToken=null 2022-05-10 14:30:25.854 Info App: Loading Emby.Server.Implementations, Version=4.6.7.0, Culture=neutral, PublicKeyToken=null 2022-05-10 14:30:25.855 Info App: Loading Emby.LiveTV, Version=4.6.7.0, Culture=neutral, PublicKeyToken=null 2022-05-10 14:30:25.855 Info App: Loading Emby.ActivityLog, Version=4.6.7.0, Culture=neutral, PublicKeyToken=null 2022-05-10 14:30:25.855 Info App: Loading Emby.Server.MediaEncoding, Version=4.6.7.0, Culture=neutral, PublicKeyToken=null 2022-05-10 14:30:25.855 Info App: Loading Emby.LocalMetadata, Version=4.6.7.0, Culture=neutral, PublicKeyToken=null 2022-05-10 14:30:25.855 Info App: Loading Emby.Notifications, Version=4.6.7.0, Culture=neutral, PublicKeyToken=null 2022-05-10 14:30:25.855 Info App: Loading Emby.Codecs.Dxva, Version=4.6.7.0, Culture=neutral, PublicKeyToken=null 2022-05-10 14:30:25.855 Info App: Loading Emby.Codecs, Version=4.6.7.0, Culture=neutral, PublicKeyToken=null 2022-05-10 14:30:25.855 Info App: Loading Emby.Server.Connect, Version=4.6.7.0, Culture=neutral, PublicKeyToken=null 2022-05-10 14:30:25.855 Info App: Loading Emby.Server.Sync, Version=4.6.7.0, Culture=neutral, PublicKeyToken=null 2022-05-10 14:30:25.855 Info App: Loading EmbyServer, Version=4.6.7.0, Culture=neutral, PublicKeyToken=null 2022-05-10 14:30:25.990 Info SqliteUserRepository: Sqlite version: 3.35.5 2022-05-10 14:30:25.991 Info SqliteUserRepository: Sqlite compiler options: COMPILER=gcc-8.3.0,ENABLE_COLUMN_METADATA,ENABLE_DBSTAT_VTAB,ENABLE_FTS3_PARENTHESIS,ENABLE_FTS3_TOKENIZER,ENABLE_FTS4,ENABLE_FTS5,ENABLE_GEOPOLY,ENABLE_JSON1,ENABLE_MATH_FUNCTIONS,ENABLE_PREUPDATE_HOOK,ENABLE_RTREE,ENABLE_SESSION,ENABLE_UNLOCK_NOTIFY,ENABLE_UPDATE_DELETE_LIMIT,LIKE_DOESNT_MATCH_BLOBS,MAX_SCHEMA_RETRY=25,MAX_VARIABLE_NUMBER=250000,OMIT_LOOKASIDE,SECURE_DELETE,THREADSAFE=1 2022-05-10 14:30:26.004 Info SqliteUserRepository: Default journal_mode for /config/data/users.db is wal 2022-05-10 14:30:26.034 Info AuthenticationRepository: Default journal_mode for /config/data/authentication.db is wal 2022-05-10 14:30:26.076 Info ActivityRepository: Default journal_mode for /config/data/activitylog.db is wal 2022-05-10 14:30:26.080 Info SqliteDisplayPreferencesRepository: Default journal_mode for /config/data/displaypreferences.db is wal 2022-05-10 14:30:26.089 Info App: Adding HttpListener prefix http://+:8096/ 2022-05-10 14:30:26.089 Info App: Adding HttpListener prefix https://+:8920/ 2022-05-10 14:30:26.255 Info SqliteItemRepository: Default journal_mode for /config/data/library.db is wal 2022-05-10 14:30:26.256 Info SqliteItemRepository: cache_size is -98304 2022-05-10 14:30:26.256 Info SqliteItemRepository: page_size is 4096 2022-05-10 14:30:26.588 Info Server: http/1.1 GET http://[redacted-hostname]/emby/system/info/public. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:99.0) Gecko/20100101 Firefox/99.0 2022-05-10 14:30:26.617 Info Server: http/1.1 Response 503 to 10.10.0.10. Time: 43ms. http://[redacted-hostname]/emby/system/info/public 2022-05-10 14:30:27.026 Info App: [TVHclient] LiveTvService() 2022-05-10 14:30:27.027 Info App: [TVHclient] HTSConnectionHandler() 2022-05-10 14:30:27.065 Info FfmpegManager: FFMpeg: /bin/ffmpeg 2022-05-10 14:30:27.065 Info FfmpegManager: FFProbe: /bin/ffprobe 2022-05-10 14:30:27.065 Info FfmpegManager: FFDetect: /bin/ffdetect 2022-05-10 14:30:27.069 Info Skia: SkiaSharp version: 2.80.0.0 2022-05-10 14:30:27.101 Info TaskManager: Daily trigger for Thumbnail image extraction set to fire at 05/11/2022 02:00:00, which is 689.54831948 minutes from now. 2022-05-10 14:30:27.104 Info TaskManager: Daily trigger for Rotate log file set to fire at 05/11/2022 00:00:00, which is 569.548255345 minutes from now. 2022-05-10 14:30:27.112 Info App: ServerId: f6c778afb46f4b90b6ca5dee04215f1a 2022-05-10 14:30:27.162 Info App: Starting entry point Emby.Dlna.Main.DlnaEntryPoint 2022-05-10 14:30:27.181 Info Dlna: Registering publisher for urn:schemas-upnp-org:device:MediaServer:1 2022-05-10 14:30:27.248 Info App: Entry point completed: Emby.Dlna.Main.DlnaEntryPoint. Duration: 0.0856596 seconds 2022-05-10 14:30:27.248 Info App: Starting entry point Emby.Server.Connect.ConnectEntryPoint 2022-05-10 14:30:27.249 Info App: Loading data from /config/data/connect.txt 2022-05-10 14:30:27.254 Info App: Loading data from /config/data/wan.dat 2022-05-10 14:30:27.255 Info App: Entry point completed: Emby.Server.Connect.ConnectEntryPoint. Duration: 0.0073337 seconds 2022-05-10 14:30:27.255 Info App: Core startup complete 2022-05-10 14:30:27.255 Info App: Post-init migrations complete 2022-05-10 14:30:27.255 Info App: Starting entry point NfoMetadata.EntryPoint 2022-05-10 14:30:27.256 Info App: Entry point completed: NfoMetadata.EntryPoint. Duration: 0.0005072 seconds 2022-05-10 14:30:27.256 Info App: Starting entry point Emby.Security.PluginSecurityManager 2022-05-10 14:30:27.256 Info App: Entry point completed: Emby.Security.PluginSecurityManager. Duration: 2.65E-05 seconds 2022-05-10 14:30:27.256 Info App: Starting entry point Emby.Server.CinemaMode.IntrosEntryPoint 2022-05-10 14:30:27.256 Info App: Entry point completed: Emby.Server.CinemaMode.IntrosEntryPoint. Duration: 0.0001775 seconds 2022-05-10 14:30:27.256 Info App: Starting entry point Emby.Webhooks.WebhooksEntryPoint 2022-05-10 14:30:27.258 Info App: Entry point completed: Emby.Webhooks.WebhooksEntryPoint. Duration: 0.0016715 seconds 2022-05-10 14:30:27.258 Info App: Starting entry point Emby.PortMapper.ExternalPortForwarding 2022-05-10 14:30:27.259 Info App: Entry point completed: Emby.PortMapper.ExternalPortForwarding. Duration: 0.0005775 seconds 2022-05-10 14:30:27.259 Info App: Starting entry point Emby.Kodi.SyncQueue.EntryPoints.LibrarySyncNotification 2022-05-10 14:30:27.259 Info App: Entry point completed: Emby.Kodi.SyncQueue.EntryPoints.LibrarySyncNotification. Duration: 0.0006733 seconds 2022-05-10 14:30:27.259 Info App: Starting entry point MediaBrowser.Api.ApiEntryPoint 2022-05-10 14:30:27.259 Info App: Entry point completed: MediaBrowser.Api.ApiEntryPoint. Duration: 2.65E-05 seconds 2022-05-10 14:30:27.260 Info App: Starting entry point Emby.Server.Implementations.Udp.UdpServerEntryPoint 2022-05-10 14:30:27.261 Info App: Entry point completed: Emby.Server.Implementations.Udp.UdpServerEntryPoint. Duration: 0.0010209 seconds 2022-05-10 14:30:27.261 Info App: Starting entry point Emby.Server.Implementations.News.NewsEntryPoint 2022-05-10 14:30:27.261 Info App: Entry point completed: Emby.Server.Implementations.News.NewsEntryPoint. Duration: 0.0002232 seconds 2022-05-10 14:30:27.261 Info App: Starting entry point Emby.Server.Implementations.Library.DeviceAccessEntryPoint 2022-05-10 14:30:27.261 Info App: Entry point completed: Emby.Server.Implementations.Library.DeviceAccessEntryPoint. Duration: 0.0005984 seconds 2022-05-10 14:30:27.261 Info App: Starting entry point Emby.Server.Implementations.IO.LibraryMonitorStartup 2022-05-10 14:30:27.294 Info App: Init BeginReceive on 0.0.0.0 2022-05-10 14:30:27.294 Info App: Init BeginReceive on 0.0.0.0 2022-05-10 14:30:27.294 Info App: Init BeginReceive on 192.168.178.20 2022-05-10 14:30:27.374 Info Server: http/1.1 GET http://[redacted-hostname]/emby/system/info/public. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:99.0) Gecko/20100101 Firefox/99.0 2022-05-10 14:30:27.410 Info Server: http/1.1 Response 200 to 10.10.0.10. Time: 36ms. http://[redacted-hostname]/emby/system/info/public 2022-05-10 14:30:27.434 Info App: Entry point completed: Emby.Server.Implementations.IO.LibraryMonitorStartup. Duration: 0.1724127 seconds 2022-05-10 14:30:27.434 Info App: Starting entry point Emby.Server.Implementations.EntryPoints.AutomaticRestartEntryPoint 2022-05-10 14:30:27.441 Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.AutomaticRestartEntryPoint. Duration: 0.0065884 seconds 2022-05-10 14:30:27.441 Info App: Starting entry point Emby.Server.Implementations.EntryPoints.KeepServerAwake 2022-05-10 14:30:27.441 Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.KeepServerAwake. Duration: 0.0001894 seconds 2022-05-10 14:30:27.441 Info App: Starting entry point Emby.Server.Implementations.EntryPoints.LibraryChangedNotifier 2022-05-10 14:30:27.442 Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.LibraryChangedNotifier. Duration: 0.0013914 seconds 2022-05-10 14:30:27.442 Info App: Starting entry point Emby.Server.Implementations.EntryPoints.ServerEventNotifier 2022-05-10 14:30:27.444 Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.ServerEventNotifier. Duration: 0.0018697 seconds 2022-05-10 14:30:27.444 Info App: Starting entry point Emby.Server.Implementations.EntryPoints.StartupWizard 2022-05-10 14:30:27.445 Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.StartupWizard. Duration: 0.0003171 seconds 2022-05-10 14:30:27.445 Info App: Starting entry point Emby.Server.Implementations.EntryPoints.SystemEvents 2022-05-10 14:30:27.445 Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.SystemEvents. Duration: 0.0004516 seconds 2022-05-10 14:30:27.445 Info App: Starting entry point Emby.Server.Implementations.EntryPoints.UserDataChangeNotifier 2022-05-10 14:30:27.445 Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.UserDataChangeNotifier. Duration: 0.0001993 seconds 2022-05-10 14:30:27.445 Info App: Starting entry point Emby.Server.Implementations.Channels.ChannelsEntryPoint 2022-05-10 14:30:27.449 Info App: Entry point completed: Emby.Server.Implementations.Channels.ChannelsEntryPoint. Duration: 0.0040473 seconds 2022-05-10 14:30:27.449 Info App: Starting entry point Emby.LiveTV.EntryPoint 2022-05-10 14:30:27.452 Info LiveTV: Loading live tv data from /config/data/livetv/timers [Redacted access exception] 2022-05-10 14:30:27.481 Info LibraryMonitor: Watching directory /data/Movies 2022-05-10 14:30:27.488 Info Server: http/1.1 GET http://[redacted-hostname]/emby/System/Info?X-Emby-Client=Emby Web&X-Emby-Device-Name=Firefox Windows&X-Emby-Device-Id=9b0014dc-06bf-4a0a-8fba-bac2d419bd46&X-Emby-Client-Version=4.7.0.10. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:99.0) Gecko/20100101 Firefox/99.0 2022-05-10 14:30:27.490 Info App: Entry point completed: Emby.LiveTV.EntryPoint. Duration: 0.040676 seconds 2022-05-10 14:30:27.490 Info App: Starting entry point Emby.LiveTV.UpgradeChannelOptionsEntryPoint 2022-05-10 14:30:27.493 Info App: Entry point completed: Emby.LiveTV.UpgradeChannelOptionsEntryPoint. Duration: 0.0026412 seconds 2022-05-10 14:30:27.493 Info App: Starting entry point Emby.LiveTV.RecordingNotifier 2022-05-10 14:30:27.496 Info App: Entry point completed: Emby.LiveTV.RecordingNotifier. Duration: 0.00317 seconds 2022-05-10 14:30:27.496 Info App: Starting entry point Emby.ActivityLog.ActivityLogEntryPoint 2022-05-10 14:30:27.502 Info App: Entry point completed: Emby.ActivityLog.ActivityLogEntryPoint. Duration: 0.0055583 seconds 2022-05-10 14:30:27.502 Info App: Starting entry point Emby.Server.MediaEncoding.Api.EncodingManagerEntryPoint 2022-05-10 14:30:27.509 Info App: Entry point completed: Emby.Server.MediaEncoding.Api.EncodingManagerEntryPoint. Duration: 0.0069264 seconds 2022-05-10 14:30:27.509 Info App: Starting entry point Emby.Notifications.Notifications 2022-05-10 14:30:27.509 Info App: Entry point completed: Emby.Notifications.Notifications. Duration: 0.0003147 seconds 2022-05-10 14:30:27.509 Info App: Starting entry point Emby.Server.Sync.SyncManagerEntryPoint 2022-05-10 14:30:27.513 Info App: SyncRepository Initialize taking write lock 2022-05-10 14:30:27.513 Info App: SyncRepository Initialize write lock taken 2022-05-10 14:30:27.514 Info App: Entry point completed: Emby.Server.Sync.SyncManagerEntryPoint. Duration: 0.0041147 seconds 2022-05-10 14:30:27.514 Info App: Starting entry point Emby.Server.Sync.SyncNotificationEntryPoint 2022-05-10 14:30:27.515 Info App: Entry point completed: Emby.Server.Sync.SyncNotificationEntryPoint. Duration: 0.0016565 seconds 2022-05-10 14:30:27.515 Info App: Starting entry point EmbyServer.Windows.LoopUtilEntryPoint 2022-05-10 14:30:27.515 Info App: Entry point completed: EmbyServer.Windows.LoopUtilEntryPoint. Duration: 6.29E-05 seconds 2022-05-10 14:30:27.515 Info App: All entry points have started 2022-05-10 14:30:27.598 Info Server: http/1.1 Response 200 to 10.10.0.10. Time: 116ms. http://[redacted-hostname]/emby/System/Info?X-Emby-Client=Emby Web&X-Emby-Device-Name=Firefox Windows&X-Emby-Device-Id=9b0014dc-06bf-4a0a-8fba-bac2d419bd46&X-Emby-Client-Version=4.7.0.10 2022-05-10 14:30:27.747 Info LibraryMonitor: Watching directory /data/Photos 2022-05-10 14:30:27.764 Info HttpClient: GET https://emby.media/community/index.php?/blog/rss/1-media-browser-developers-blog 2022-05-10 14:30:30.138 Info HttpClient: GET https://www.mb3admin.com/admin/service/EmbyPackages.json 2022-05-10 14:30:30.145 Info FfmpegManager: ProcessRun 'ffmpeg -hide_banner -version' Execute: /bin/ffmpeg -hide_banner -version 2022-05-10 14:30:30.165 Info FfmpegManager: ProcessRun 'ffmpeg -hide_banner -version' Process exited with code 0 2022-05-10 14:30:30.244 Info SoftwareCodecProvider: h264, libx264, libx264 Software Encoder, V-E-libx264 2022-05-10 14:30:30.244 Info SoftwareCodecProvider: hevc, libx265, libx265 Software Encoder, V-E-libx265 2022-05-10 14:30:30.244 Info SoftwareCodecProvider: mpeg4, mpeg4, MPEG-4 part 2 Software Encoder, V-E-mpeg4 2022-05-10 14:30:30.244 Info SoftwareCodecProvider: msmpeg4v3, msmpeg4, MPEG-4 part 2 (MS Variant 3) Software Encoder, V-E-msmpeg4 2022-05-10 14:30:30.244 Info SoftwareCodecProvider: vp8, libvpx, libvpx VP8, V-E-libvpx 2022-05-10 14:30:30.247 Info SoftwareCodecProvider: h264, libx264, libx264 Software Encoder, V-E-libx264 2022-05-10 14:30:30.247 Info SoftwareCodecProvider: hevc, libx265, libx265 Software Encoder, V-E-libx265 2022-05-10 14:30:30.247 Info SoftwareCodecProvider: mpeg4, mpeg4, MPEG-4 part 2 Software Encoder, V-E-mpeg4 2022-05-10 14:30:30.247 Info SoftwareCodecProvider: msmpeg4v3, msmpeg4, MPEG-4 part 2 (MS Variant 3) Software Encoder, V-E-msmpeg4 2022-05-10 14:30:30.247 Info SoftwareCodecProvider: vp8, libvpx, libvpx VP8, V-E-libvpx 2022-05-10 14:30:30.298 Info VaapiCodecProvider: ProcessRun 'ffdetect_vaencdec' Execute: /bin/ffdetect -hide_banner -show_program_version -loglevel 48 -show_error -show_log 40 vaencdec -print_format json 2022-05-10 14:30:30.309 Info VaapiCodecProvider: ProcessRun 'ffdetect_vaencdec' Process exited with code 0 2022-05-10 14:30:30.376 Info VaapiCodecProvider: Adapter #0: 'GD 5446' Id:184 (Driver: , Vendor: Cirrus Logic) 2022-05-10 14:30:30.379 Info QuickSyncCodecProvider: ProcessRun 'ffdetect_qsvencdec' Execute: /bin/ffdetect -hide_banner -show_program_version -loglevel 48 -show_error -show_log 40 qsvencdec -print_format json 2022-05-10 14:30:30.391 Info QuickSyncCodecProvider: ProcessRun 'ffdetect_qsvencdec' Process exited with code 0 2022-05-10 14:30:30.448 Info NvidiaCodecProvider: ProcessRun 'ffdetect_nvencdec' Execute: /bin/ffdetect -hide_banner -show_program_version -loglevel 48 -show_error -show_log 40 nvencdec -print_format json 2022-05-10 14:30:30.451 Info NvidiaCodecProvider: ProcessRun 'ffdetect_nvencdec' Process exited with code 1 2022-05-10 14:31:28.110 Info Server: http/1.1 GET http://[redacted-hostname]/emby/System/Logs/embyserver.txt?Sanitize=true. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:99.0) Gecko/20100101 Firefox/99.0 2022-05-10 14:31:28.150 Info Server: http/1.1 Response 200 to 10.10.0.10. Time: 40ms. http://[redacted-hostname]/emby/System/Logs/embyserver.txt?Sanitize=true 2022-05-10 14:31:39.613 Info Server: http/1.1 GET http://[redacted-hostname]/emby/Users/eaf86e9c1dc84101a85a3f1d4eaa9839?X-Emby-Client=Emby Web&X-Emby-Device-Name=Firefox Windows&X-Emby-Device-Id=9b0014dc-06bf-4a0a-8fba-bac2d419bd46&X-Emby-Client-Version=4.7.0.9. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:99.0) Gecko/20100101 Firefox/99.0 2022-05-10 14:31:39.615 Info Server: http/1.1 OPTIONS http://[redacted-hostname]/emby/Items/2561360/PlaybackInfo?UserId=eaf86e9c1dc84101a85a3f1d4eaa9839&StartTimeTicks=0&IsPlayback=true&AutoOpenLiveStream=true&MaxStreamingBitrate=140000000&X-Emby-Client=Emby Web&X-Emby-Device-Name=Firefox Windows&X-Emby-Device-Id=9b0014dc-06bf-4a0a-8fba-bac2d419bd46&X-Emby-Client-Version=4.7.0.9. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:99.0) Gecko/20100101 Firefox/99.0 2022-05-10 14:31:39.615 Info Server: http/1.1 Response 200 to 10.10.0.10. Time: 1ms. http://[redacted-hostname]/emby/Items/2561360/PlaybackInfo?UserId=eaf86e9c1dc84101a85a3f1d4eaa9839&StartTimeTicks=0&IsPlayback=true&AutoOpenLiveStream=true&MaxStreamingBitrate=140000000&X-Emby-Client=Emby Web&X-Emby-Device-Name=Firefox Windows&X-Emby-Device-Id=9b0014dc-06bf-4a0a-8fba-bac2d419bd46&X-Emby-Client-Version=4.7.0.9 2022-05-10 14:31:39.620 Info Server: http/1.1 POST http://[redacted-hostname]/emby/Items/2561360/PlaybackInfo?UserId=eaf86e9c1dc84101a85a3f1d4eaa9839&StartTimeTicks=0&IsPlayback=true&AutoOpenLiveStream=true&MaxStreamingBitrate=140000000&X-Emby-Client=Emby Web&X-Emby-Device-Name=Firefox Windows&X-Emby-Device-Id=9b0014dc-06bf-4a0a-8fba-bac2d419bd46&X-Emby-Client-Version=4.7.0.9. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:99.0) Gecko/20100101 Firefox/99.0 2022-05-10 14:31:39.686 Info NetworkManager: Detected local ip addresses: 10.10.1.20, 192.168.178.20, 127.0.0.1, fe80::f87c:a2ff:fe69:d333%2, 2001:1c00:1401:4c00:7cb7:d7ff:fed9:f61a, fe80::7cb7:d7ff:fed9:f61a%3, ::1 2022-05-10 14:31:39.709 Info Server: http/1.1 Response 200 to 10.10.0.10. Time: 96ms. http://[redacted-hostname]/emby/Users/eaf86e9c1dc84101a85a3f1d4eaa9839?X-Emby-Client=Emby Web&X-Emby-Device-Name=Firefox Windows&X-Emby-Device-Id=9b0014dc-06bf-4a0a-8fba-bac2d419bd46&X-Emby-Client-Version=4.7.0.9 2022-05-10 14:31:39.713 Info Server: http/1.1 GET http://[redacted-hostname]/emby/Users/eaf86e9c1dc84101a85a3f1d4eaa9839?X-Emby-Client=Emby Web&X-Emby-Device-Name=Firefox Windows&X-Emby-Device-Id=9b0014dc-06bf-4a0a-8fba-bac2d419bd46&X-Emby-Client-Version=4.7.0.9. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:99.0) Gecko/20100101 Firefox/99.0 2022-05-10 14:31:39.714 Info Server: http/1.1 Response 200 to 10.10.0.10. Time: 1ms. http://[redacted-hostname]/emby/Users/eaf86e9c1dc84101a85a3f1d4eaa9839?X-Emby-Client=Emby Web&X-Emby-Device-Name=Firefox Windows&X-Emby-Device-Id=9b0014dc-06bf-4a0a-8fba-bac2d419bd46&X-Emby-Client-Version=4.7.0.9 2022-05-10 14:31:39.759 Info App: User policy for Groentjuh. EnablePlaybackRemuxing: True EnableVideoPlaybackTranscoding: True EnableAudioPlaybackTranscoding: True 2022-05-10 14:31:39.811 Info App: RemoteClientBitrateLimit: 25000000, RemoteIp: 10.10.0.10, IsInLocalNetwork: True 2022-05-10 14:31:39.824 Info App: RemoteClientBitrateLimit: 25000000, RemoteIp: 10.10.0.10, IsInLocalNetwork: True 2022-05-10 14:31:39.826 Info App: RemoteClientBitrateLimit: 25000000, RemoteIp: 10.10.0.10, IsInLocalNetwork: True 2022-05-10 14:31:39.831 Info LiveTvManager: Opening channel stream from TVHclient LiveTvService, external channel Id: 1487494759 2022-05-10 14:31:39.837 Info App: [TVHclient] HTSConnectionHandler.ensureConnection() : create new HTS-Connection 2022-05-10 14:31:39.838 Info App: [TVHclient] HTSConnectionHandler.ensureConnection: Used connection parameters: TVH Server = '127.0.0.1'; HTTP Port = '9981'; HTSP Port = '9982'; Web-Root = ''; User = 'Emby'; Password set = 'True' 2022-05-10 14:31:39.839 Info App: [TVHclient] HTSConnectionAsync.open: IPEndPoint = '127.0.0.1:9982'; AddressFamily = 'InterNetwork' 2022-05-10 14:31:39.842 Info App: [TVHclient] HTSConnectionAsync.open: socket connected. 2022-05-10 14:31:39.847 Info App: [TVHclient] HTSConnectionAsync.authenticate: start 2022-05-10 14:31:39.855 Info App: [TVHclient] HTSConnectionAsync.authenticate: authenticated = True 2022-05-10 14:31:39.855 Info App: [TVHclient] HTSConnectionHandler.ensureConnection: connection established True 2022-05-10 14:31:39.916 Info App: [TVHclient] Support for live TV subtitles and multiple audio tracks is enabled. 2022-05-10 14:31:39.916 Info App: [TVHclient] Force video deinterlacing for all channels and recordings is enabled. 2022-05-10 14:31:39.927 Info SharedHttpPipelineSource: Opening SharedHttpPipelineSource Live stream from http://Emby:[redacted-tvheadend-password]@127.0.0.1:9981/stream/channelid/1487494759 2022-05-10 14:31:39.928 Info HttpClient: Found userInfo in url: Emby:[redacted-tvheadend-password] ... url: http://Emby:[redacted-tvheadend-password]@127.0.0.1:9981/stream/channelid/1487494759 2022-05-10 14:31:39.928 Info HttpClient: GET http://Emby:[redacted-tvheadend-password]@127.0.0.1:9981/stream/channelid/1487494759 2022-05-10 14:31:56.275 Info HttpClient: Http response 200 from http://Emby:[redacted-tvheadend-password]@127.0.0.1:9981/stream/channelid/1487494759 after 16346ms. HeadersServer=HTS/tvheadend, Cache-Control=no-cache, Connection=close 2022-05-10 14:31:56.295 Info SharedHttpPipelineSource: Beginning SharedHttpPipelineSource stream to /data/EmbyTranscoding/transcoding-temp/bf7880bbcb4e4ff4a58dcb70d5eed19e.ts 2022-05-10 14:31:56.337 Info LiveTvManager: Live stream opened after 16413.7454ms 2022-05-10 14:31:57.366 Error GraphRunner: GraphRunnerTimestampFixup *** Error Report *** Version: 4.6.7.0 Command line: /system/EmbyServer.dll -programdata /config -ffdetect /bin/ffdetect -ffmpeg /bin/ffmpeg -ffprobe /bin/ffprobe -restartexitcode 3 Operating system: Linux version 5.15.0-27-generic (buildd@ubuntu) (gcc (Ubuntu 11.2.0-19ubuntu1) 11.2.0, GNU ld (GNU Binutils for Ubuntu) 2.38) #28-Ubuntu SMP Thu Apr 1 Framework: .NET Core 3.1.21 OS/Process: x64/x64 Runtime: system/System.Private.CoreLib.dll Processor count: 3 Data path: /config Application path: /system System.AggregateException: System.AggregateException: One or more errors occurred. (Access to the path '/data/EmbyTranscoding/transcoding-temp/bf7880bbcb4e4ff4a58dcb70d5eed19e.ts' is denied.) ---> System.UnauthorizedAccessException: Access to the path '/data/EmbyTranscoding/transcoding-temp/bf7880bbcb4e4ff4a58dcb70d5eed19e.ts' is denied. ---> System.IO.IOException: Permission denied --- End of inner exception stack trace --- at System.IO.FileStream.WriteNative(ReadOnlySpan`1 source) at System.IO.FileStream.FlushWriteBuffer() at System.IO.FileStream.WriteSpan(ReadOnlySpan`1 source) at System.IO.FileStream.Write(Byte[] array, Int32 offset, Int32 count) at Emby.TV.TsProcessor.DataFlow.Output.FileStreamWriter.ProcessPackets(TsPacketGroup tsPackets) at Emby.TV.TsProcessor.Runners.GraphRunnerTimestampFixup.WriteOutput(TsPacketGroup e) at System.Threading.Tasks.Dataflow.ActionBlock`1.ProcessMessage(Action`1 action, KeyValuePair`2 messageWithId) at System.Threading.Tasks.Dataflow.ActionBlock`1.<>c__DisplayClass6_0.<.ctor>b__0(KeyValuePair`2 messageWithId) at System.Threading.Tasks.Dataflow.Internal.TargetCore`1.ProcessMessagesLoopCore() --- End of inner exception stack trace --- Source: TargetSite: No Stack Trace Available InnerException: System.UnauthorizedAccessException: Access to the path '/data/EmbyTranscoding/transcoding-temp/bf7880bbcb4e4ff4a58dcb70d5eed19e.ts' is denied. Source: System.Private.CoreLib TargetSite: Void WriteNative(System.ReadOnlySpan`1[System.Byte]) DataflowMessageValue: Emby.TV.TsProcessor.Model.Packets.TsPacketGroup at System.IO.FileStream.WriteNative(ReadOnlySpan`1 source) at System.IO.FileStream.FlushWriteBuffer() at System.IO.FileStream.WriteSpan(ReadOnlySpan`1 source) at System.IO.FileStream.Write(Byte[] array, Int32 offset, Int32 count) at Emby.TV.TsProcessor.DataFlow.Output.FileStreamWriter.ProcessPackets(TsPacketGroup tsPackets) at Emby.TV.TsProcessor.Runners.GraphRunnerTimestampFixup.WriteOutput(TsPacketGroup e) at System.Threading.Tasks.Dataflow.ActionBlock`1.ProcessMessage(Action`1 action, KeyValuePair`2 messageWithId) at System.Threading.Tasks.Dataflow.ActionBlock`1.<>c__DisplayClass6_0.<.ctor>b__0(KeyValuePair`2 messageWithId) at System.Threading.Tasks.Dataflow.Internal.TargetCore`1.ProcessMessagesLoopCore() InnerException: System.IO.IOException: Permission denied Source: TargetSite: 2022-05-10 14:31:57.367 Error GraphRunner: GraphRunnerTimestampFixup: CloseOutput *** Error Report *** Version: 4.6.7.0 Command line: /system/EmbyServer.dll -programdata /config -ffdetect /bin/ffdetect -ffmpeg /bin/ffmpeg -ffprobe /bin/ffprobe -restartexitcode 3 Operating system: Linux version 5.15.0-27-generic (buildd@ubuntu) (gcc (Ubuntu 11.2.0-19ubuntu1) 11.2.0, GNU ld (GNU Binutils for Ubuntu) 2.38) #28-Ubuntu SMP Thu Apr 1 Framework: .NET Core 3.1.21 OS/Process: x64/x64 Runtime: system/System.Private.CoreLib.dll Processor count: 3 Data path: /config Application path: /system System.UnauthorizedAccessException: System.UnauthorizedAccessException: Access to the path '/data/EmbyTranscoding/transcoding-temp/bf7880bbcb4e4ff4a58dcb70d5eed19e.ts' is denied. ---> System.IO.IOException: Permission denied --- End of inner exception stack trace --- at System.IO.FileStream.WriteNative(ReadOnlySpan`1 source) at System.IO.FileStream.FlushWriteBuffer() at System.IO.FileStream.Dispose(Boolean disposing) at System.IO.Stream.Close() at Emby.TV.TsProcessor.DataFlow.Output.FileStreamWriter.CloseOutput() at Emby.TV.TsProcessor.Runners.GraphRunnerTimestampFixup.RunAsyncFixTimings(CancellationToken cancellationToken1) Source: System.Private.CoreLib TargetSite: Void WriteNative(System.ReadOnlySpan`1[System.Byte]) InnerException: System.IO.IOException: Permission denied Source: TargetSite: 2022-05-10 14:31:57.410 Error SharedHttpPipelineSource: Give up retries copying live stream http://Emby:[redacted-tvheadend-password]@127.0.0.1:9981/stream/channelid/1487494759 *** Error Report *** Version: 4.6.7.0 Command line: /system/EmbyServer.dll -programdata /config -ffdetect /bin/ffdetect -ffmpeg /bin/ffmpeg -ffprobe /bin/ffprobe -restartexitcode 3 Operating system: Linux version 5.15.0-27-generic (buildd@ubuntu) (gcc (Ubuntu 11.2.0-19ubuntu1) 11.2.0, GNU ld (GNU Binutils for Ubuntu) 2.38) #28-Ubuntu SMP Thu Apr 1 Framework: .NET Core 3.1.21 OS/Process: x64/x64 Runtime: system/System.Private.CoreLib.dll Processor count: 3 Data path: /config Application path: /system System.NullReferenceException: System.NullReferenceException: Object reference not set to an instance of an object. at System.IO.Pipelines.Pipe.CommitUnsynchronized() at System.IO.Pipelines.Pipe.PrepareFlush(CompletionData& completionData, ValueTask`1& result, CancellationToken cancellationToken) at System.IO.Pipelines.Pipe.FlushAsync(CancellationToken cancellationToken) at System.IO.Pipelines.Pipe.DefaultPipeWriter.FlushAsync(CancellationToken cancellationToken) at System.IO.Pipelines.PipeWriter.CopyFromAsync(Stream source, CancellationToken cancellationToken) at Emby.LiveTV.TunerHosts.SharedHttpPipelineSource.<>c__DisplayClass8_0.<<StartStreaming>b__0>d.MoveNext() Source: System.IO.Pipelines TargetSite: Boolean CommitUnsynchronized() 2022-05-10 14:31:57.411 Error SharedHttpPipelineSource: Error copying live stream. *** Error Report *** Version: 4.6.7.0 Command line: /system/EmbyServer.dll -programdata /config -ffdetect /bin/ffdetect -ffmpeg /bin/ffmpeg -ffprobe /bin/ffprobe -restartexitcode 3 Operating system: Linux version 5.15.0-27-generic (buildd@ubuntu) (gcc (Ubuntu 11.2.0-19ubuntu1) 11.2.0, GNU ld (GNU Binutils for Ubuntu) 2.38) #28-Ubuntu SMP Thu Apr 1 Framework: .NET Core 3.1.21 OS/Process: x64/x64 Runtime: system/System.Private.CoreLib.dll Processor count: 3 Data path: /config Application path: /system System.NullReferenceException: System.NullReferenceException: Object reference not set to an instance of an object. at System.IO.Pipelines.Pipe.CommitUnsynchronized() at System.IO.Pipelines.Pipe.PrepareFlush(CompletionData& completionData, ValueTask`1& result, CancellationToken cancellationToken) at System.IO.Pipelines.Pipe.FlushAsync(CancellationToken cancellationToken) at System.IO.Pipelines.Pipe.DefaultPipeWriter.FlushAsync(CancellationToken cancellationToken) at System.IO.Pipelines.PipeWriter.CopyFromAsync(Stream source, CancellationToken cancellationToken) at Emby.LiveTV.TunerHosts.SharedHttpPipelineSource.<>c__DisplayClass8_0.<<StartStreaming>b__0>d.MoveNext() --- End of stack trace from previous location where exception was thrown --- at Emby.LiveTV.TunerHosts.SharedHttpPipelineSource.<>c__DisplayClass8_0.<<StartStreaming>b__0>d.MoveNext() Source: System.IO.Pipelines TargetSite: Boolean CommitUnsynchronized() 2022-05-10 14:31:57.411 Info SharedHttpPipelineSource: SharedHttpPipelineSource is done streaming. 2022-05-10 14:31:57.413 Info SharedHttpPipelineSource: Deleting temp files /data/EmbyTranscoding/transcoding-temp/bf7880bbcb4e4ff4a58dcb70d5eed19e.ts 2022-05-10 14:31:59.355 Info MediaProbeManager: ProcessRun 'ffprobe' Execute: /bin/ffprobe -analyzeduration 3000000 -i "http://127.0.0.1:8096/LiveTv/LiveStreamFiles/bf7880bbcb4e4ff4a58dcb70d5eed19e/stream.ts" -threads 0 -v info -print_format json -show_streams -show_format -show_data 2022-05-10 14:31:59.364 Info Server: http/1.1 GET http://127.0.0.1:8096/LiveTv/LiveStreamFiles/bf7880bbcb4e4ff4a58dcb70d5eed19e/stream.ts. UserAgent: Lavf/58.35.100 2022-05-10 14:31:59.375 Error Server: Error processing request *** Error Report *** Version: 4.6.7.0 Command line: /system/EmbyServer.dll -programdata /config -ffdetect /bin/ffdetect -ffmpeg /bin/ffmpeg -ffprobe /bin/ffprobe -restartexitcode 3 Operating system: Linux version 5.15.0-27-generic (buildd@ubuntu) (gcc (Ubuntu 11.2.0-19ubuntu1) 11.2.0, GNU ld (GNU Binutils for Ubuntu) 2.38) #28-Ubuntu SMP Thu Apr 1 Framework: .NET Core 3.1.21 OS/Process: x64/x64 Runtime: system/System.Private.CoreLib.dll Processor count: 3 Data path: /config Application path: /system System.IO.FileNotFoundException: System.IO.FileNotFoundException: Could not find file '/data/EmbyTranscoding/transcoding-temp/bf7880bbcb4e4ff4a58dcb70d5eed19e.ts'. File name: '/data/EmbyTranscoding/transcoding-temp/bf7880bbcb4e4ff4a58dcb70d5eed19e.ts' at Interop.ThrowExceptionForIoErrno(ErrorInfo errorInfo, String path, Boolean isDirectory, Func`2 errorRewriter) at Microsoft.Win32.SafeHandles.SafeFileHandle.Open(String path, OpenFlags flags, Int32 mode) at System.IO.FileStream.OpenHandle(FileMode mode, FileShare share, FileOptions options) at System.IO.FileStream..ctor(String path, FileMode mode, FileAccess access, FileShare share, Int32 bufferSize, FileOptions options) at Emby.Server.Implementations.IO.ManagedFileSystem.GetFileStream(String path, FileOpenMode mode, FileAccessMode access, FileShareMode share, Int32 bufferSize, FileOpenOptions fileOpenOptions) at Emby.LiveTV.TunerHosts.LiveStream.CopyFile(String path, Boolean seekFile, Int32 emptyReadLimit, PipeWriter writer, IFileSystem fileSystem, IStreamHelper streamHelper, CancellationToken cancellationToken) at Emby.LiveTV.TunerHosts.LiveStream.CopyToAsync(PipeWriter writer, CancellationToken cancellationToken) at Emby.Server.Implementations.Services.ServiceHandler.ProcessRequestAsync(HttpListenerHost appHost, IRequest httpReq, IResponse httpRes, RestPath restPath, String responseContentType, CancellationToken cancellationToken) at Emby.Server.Implementations.HttpServer.HttpListenerHost.RequestHandler(IRequest httpReq, ReadOnlyMemory`1 urlString, ReadOnlyMemory`1 localPath, CancellationToken cancellationToken) Source: System.Private.CoreLib TargetSite: Void ThrowExceptionForIoErrno(ErrorInfo, System.String, Boolean, System.Func`2[Interop+ErrorInfo,Interop+ErrorInfo]) 2022-05-10 14:31:59.375 Info Server: http/1.1 Response 404 to 127.0.0.1. Time: 11ms. http://127.0.0.1:8096/LiveTv/LiveStreamFiles/bf7880bbcb4e4ff4a58dcb70d5eed19e/stream.ts 2022-05-10 14:31:59.377 Info MediaProbeManager: ProcessRun 'ffprobe' Process exited with code 1 2022-05-10 14:31:59.387 Error MediaSourceManager: Error probing live tv stream *** Error Report *** Version: 4.6.7.0 Command line: /system/EmbyServer.dll -programdata /config -ffdetect /bin/ffdetect -ffmpeg /bin/ffmpeg -ffprobe /bin/ffprobe -restartexitcode 3 Operating system: Linux version 5.15.0-27-generic (buildd@ubuntu) (gcc (Ubuntu 11.2.0-19ubuntu1) 11.2.0, GNU ld (GNU Binutils for Ubuntu) 2.38) #28-Ubuntu SMP Thu Apr 1 Framework: .NET Core 3.1.21 OS/Process: x64/x64 Runtime: system/System.Private.CoreLib.dll Processor count: 3 Data path: /config Application path: /system System.Exception: System.Exception: ffprobe failed for "http://127.0.0.1:8096/LiveTv/LiveStreamFiles/bf7880bbcb4e4ff4a58dcb70d5eed19e/stream.ts" - streams and format are both null: { } ffprobe version 4.3.0-emby_2021_02_27 Copyright (c) 2007-2021 the FFmpeg developers and softworkz for Emby LLC built with gcc 8.3.0 (crosstool-NG 1.24.0) [http @ 0x1382180] HTTP error 404 Not Found http://127.0.0.1:8096/LiveTv/LiveStreamFiles/bf7880bbcb4e4ff4a58dcb70d5eed19e/stream.ts: Server returned 404 Not Found at Emby.Server.MediaEncoding.Probing.MediaProbeManager.GetMediaInfoInternal(String inputPath, String primaryPath, MediaProtocol protocol, String userAgent, Boolean extractChapters, String probeSizeArgument, Boolean isAudio, Boolean forceEnableLogging, CancellationToken cancellationToken) at Emby.Server.Implementations.Library.MediaSourceManager.AddMediaInfoWithProbe(MediaSourceInfo mediaSource, Boolean isAudio, ReadOnlyMemory`1 cacheKey, Boolean addProbeDelay, CancellationToken cancellationToken) at Emby.Server.Implementations.Library.MediaSourceManager.OpenLiveStreamInternal(LiveStreamRequest request, CancellationToken cancellationToken) Source: Emby.Server.MediaEncoding TargetSite: Void MoveNext() 2022-05-10 14:31:59.391 Info MediaSourceManager: Live stream opened: {"Protocol":"Http","Id":"0","Path":"http://127.0.0.1:8096/LiveTv/LiveStreamFiles/bf7880bbcb4e4ff4a58dcb70d5eed19e/stream.ts","Type":"Default","IsRemote":false,"SupportsTranscoding":true,"SupportsDirectStream":true,"SupportsDirectPlay":false,"IsInfiniteStream":true,"RequiresOpening":false,"RequiresClosing":true,"LiveStreamId":"06044cf0e6f93cdae5f285c9ecfaaeb4_41c95b6de5174f82acbc56fe82d0a2f8_0","RequiresLooping":false,"SupportsProbing":false,"MediaStreams":[{"VideoRange":"SDR","NalLengthSize":"0","IsInterlaced":true,"BitRate":10000000,"IsDefault":false,"IsForced":false,"Type":"Video","Index":-1,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Protocol":"File"},{"IsInterlaced":false,"IsDefault":false,"IsForced":false,"Type":"Audio","Index":-1,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Protocol":"File"}],"Formats":[],"Bitrate":10000000,"RequiredHttpHeaders":{"Authorization":"Basic RW1ieTo4WHI5V2ZwV3JQa0JBNWdEODJ0aDlSd3pwQVRWYzJIWUV1Rk53ekRUY3FzWTlKdzlmalZFalNjdGRFTUZQTXdOclJTbllZa1dKNVA5Q3JkNFREMkJjRktxWFd1M0NVeFh0QWtqdUhSUg=="},"ReadAtNativeFramerate":false} 2022-05-10 14:31:59.395 Info App: User policy for Groentjuh. EnablePlaybackRemuxing: True EnableVideoPlaybackTranscoding: True EnableAudioPlaybackTranscoding: True 2022-05-10 14:31:59.395 Info App: RemoteClientBitrateLimit: 25000000, RemoteIp: 10.10.0.10, IsInLocalNetwork: True 2022-05-10 14:31:59.397 Info App: RemoteClientBitrateLimit: 25000000, RemoteIp: 10.10.0.10, IsInLocalNetwork: True 2022-05-10 14:31:59.404 Info Server: http/1.1 Response 200 to 10.10.0.10. Time: 19783ms. http://[redacted-hostname]/emby/Items/2561360/PlaybackInfo?UserId=eaf86e9c1dc84101a85a3f1d4eaa9839&StartTimeTicks=0&IsPlayback=true&AutoOpenLiveStream=true&MaxStreamingBitrate=140000000&X-Emby-Client=Emby Web&X-Emby-Device-Name=Firefox Windows&X-Emby-Device-Id=9b0014dc-06bf-4a0a-8fba-bac2d419bd46&X-Emby-Client-Version=4.7.0.9 2022-05-10 14:31:59.436 Info Server: http/1.1 GET http://[redacted-hostname]/emby/videos/2561360/master.m3u8?DeviceId=9b0014dc-06bf-4a0a-8fba-bac2d419bd46&MediaSourceId=0&PlaySessionId=58bb6938f2b84364827e11f1ac7ae529&LiveStreamId=06044cf0e6f93cdae5f285c9ecfaaeb4_41c95b6de5174f82acbc56fe82d0a2f8_0&VideoCodec=h264&AudioCodec=aac&VideoBitrate=139808000&AudioBitrate=192000&TranscodingMaxAudioChannels=2&SegmentContainer=ts&MinSegments=1&BreakOnNonKeyFrames=True&ManifestSubtitles=vtt&h264-profile=high,main,baseline,constrainedbaseline&h264-level=52&TranscodeReasons=ContainerNotSupported. Accept=*/*, Accept-Encoding=gzip, deflate, br, Accept-Language=nl,en-US;q=0.7,en;q=0.3, Host=[redacted-hostname], Referer=https://app.emby.media/, User-Agent=Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:99.0) Gecko/20100101 Firefox/99.0, DNT=1, Origin=https://app.emby.media, X-Real-IP=10.10.0.10, X-Forwarded-For=10.10.0.10, sec-fetch-dest=empty, sec-fetch-mode=cors, sec-fetch-site=cross-site 2022-05-10 14:31:59.468 Info Server: http/1.1 Response 200 to 10.10.0.10. Time: 30ms. http://[redacted-hostname]/emby/videos/2561360/master.m3u8?DeviceId=9b0014dc-06bf-4a0a-8fba-bac2d419bd46&MediaSourceId=0&PlaySessionId=58bb6938f2b84364827e11f1ac7ae529&LiveStreamId=06044cf0e6f93cdae5f285c9ecfaaeb4_41c95b6de5174f82acbc56fe82d0a2f8_0&VideoCodec=h264&AudioCodec=aac&VideoBitrate=139808000&AudioBitrate=192000&TranscodingMaxAudioChannels=2&SegmentContainer=ts&MinSegments=1&BreakOnNonKeyFrames=True&ManifestSubtitles=vtt&h264-profile=high,main,baseline,constrainedbaseline&h264-level=52&TranscodeReasons=ContainerNotSupported 2022-05-10 14:31:59.484 Info Server: http/1.1 GET http://[redacted-hostname]/emby/videos/2561360/live.m3u8?DeviceId=9b0014dc-06bf-4a0a-8fba-bac2d419bd46&MediaSourceId=0&PlaySessionId=58bb6938f2b84364827e11f1ac7ae529&LiveStreamId=06044cf0e6f93cdae5f285c9ecfaaeb4_41c95b6de5174f82acbc56fe82d0a2f8_0&VideoCodec=h264&AudioCodec=aac&VideoBitrate=139808000&AudioBitrate=192000&TranscodingMaxAudioChannels=2&SegmentContainer=ts&MinSegments=1&BreakOnNonKeyFrames=True&ManifestSubtitles=vtt&h264-profile=high,main,baseline,constrainedbaseline&h264-level=52&TranscodeReasons=ContainerNotSupported. Accept=*/*, Accept-Encoding=gzip, deflate, br, Accept-Language=nl,en-US;q=0.7,en;q=0.3, Host=[redacted-hostname], Referer=https://app.emby.media/, User-Agent=Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:99.0) Gecko/20100101 Firefox/99.0, DNT=1, Origin=https://app.emby.media, X-Real-IP=10.10.0.10, X-Forwarded-For=10.10.0.10, sec-fetch-dest=empty, sec-fetch-mode=cors, sec-fetch-site=cross-site 2022-05-10 14:31:59.743 Info App: ProcessRun 'StreamTranscode 6a1965' Execute: /bin/ffmpeg -loglevel +timing -y -print_graphs_file "/config/logs/ffmpeg-transcode-6a196556-6999-4f04-8729-8112f9979394_1graph.txt" -copyts -start_at_zero -analyzeduration 3000000 -i "http://127.0.0.1:8096/LiveTv/LiveStreamFiles/bf7880bbcb4e4ff4a58dcb70d5eed19e/stream.ts" -filter_complex "[v:0]yadif@f1=mode=send_frame:parity=auto:deint=all,format@f2=pix_fmts=yuv420p[f2_out0]" -map [f2_out0] -map a:0 -sn -c:v:0 libx264 -maxrate:v:0 10000000 -bufsize:v:0 20000000 -pix_fmt:v:0 yuv420p -force_key_frames:v:0 "expr:if(isnan(prev_forced_t),eq(t,t),gte(t,prev_forced_t+3))" -preset:v:0 veryfast -profile:v:0 high -level:v:0 3.1 -x264opts:v:0 "subme=0:me_range=4:rc_lookahead=10:partitions=none" -crf:v:0 23 -c:a:0 aac -ab:a:0 192000 -ac:a:0 2 -disposition:a:0 default -max_delay 5000000 -avoid_negative_ts disabled -f segment -map_metadata -1 -map_chapters -1 -segment_format mpegts -segment_list "/data/EmbyTranscoding/transcoding-temp/1F5071.m3u8" -segment_list_type m3u8 -segment_time 3 -segment_list_entry_prefix hls/1F5071/ -segment_start_number 0 -individual_header_trailer 0 -write_header_trailer 0 -segment_write_temp 1 "/data/EmbyTranscoding/transcoding-temp/1F5071_%d.ts" 2022-05-10 14:31:59.757 Info Server: http/1.1 GET http://127.0.0.1:8096/LiveTv/LiveStreamFiles/bf7880bbcb4e4ff4a58dcb70d5eed19e/stream.ts. UserAgent: Lavf/58.35.100 2022-05-10 14:31:59.758 Error Server: Error processing request *** Error Report *** Version: 4.6.7.0 Command line: /system/EmbyServer.dll -programdata /config -ffdetect /bin/ffdetect -ffmpeg /bin/ffmpeg -ffprobe /bin/ffprobe -restartexitcode 3 Operating system: Linux version 5.15.0-27-generic (buildd@ubuntu) (gcc (Ubuntu 11.2.0-19ubuntu1) 11.2.0, GNU ld (GNU Binutils for Ubuntu) 2.38) #28-Ubuntu SMP Thu Apr 1 Framework: .NET Core 3.1.21 OS/Process: x64/x64 Runtime: system/System.Private.CoreLib.dll Processor count: 3 Data path: /config Application path: /system System.IO.FileNotFoundException: System.IO.FileNotFoundException: Could not find file '/data/EmbyTranscoding/transcoding-temp/bf7880bbcb4e4ff4a58dcb70d5eed19e.ts'. File name: '/data/EmbyTranscoding/transcoding-temp/bf7880bbcb4e4ff4a58dcb70d5eed19e.ts' at Interop.ThrowExceptionForIoErrno(ErrorInfo errorInfo, String path, Boolean isDirectory, Func`2 errorRewriter) at Microsoft.Win32.SafeHandles.SafeFileHandle.Open(String path, OpenFlags flags, Int32 mode) at System.IO.FileStream.OpenHandle(FileMode mode, FileShare share, FileOptions options) at System.IO.FileStream..ctor(String path, FileMode mode, FileAccess access, FileShare share, Int32 bufferSize, FileOptions options) at Emby.Server.Implementations.IO.ManagedFileSystem.GetFileStream(String path, FileOpenMode mode, FileAccessMode access, FileShareMode share, Int32 bufferSize, FileOpenOptions fileOpenOptions) at Emby.LiveTV.TunerHosts.LiveStream.CopyFile(String path, Boolean seekFile, Int32 emptyReadLimit, PipeWriter writer, IFileSystem fileSystem, IStreamHelper streamHelper, CancellationToken cancellationToken) at Emby.LiveTV.TunerHosts.LiveStream.CopyToAsync(PipeWriter writer, CancellationToken cancellationToken) at Emby.Server.Implementations.Services.ServiceHandler.ProcessRequestAsync(HttpListenerHost appHost, IRequest httpReq, IResponse httpRes, RestPath restPath, String responseContentType, CancellationToken cancellationToken) at Emby.Server.Implementations.HttpServer.HttpListenerHost.RequestHandler(IRequest httpReq, ReadOnlyMemory`1 urlString, ReadOnlyMemory`1 localPath, CancellationToken cancellationToken) Source: System.Private.CoreLib TargetSite: Void ThrowExceptionForIoErrno(ErrorInfo, System.String, Boolean, System.Func`2[Interop+ErrorInfo,Interop+ErrorInfo]) 2022-05-10 14:31:59.758 Info Server: http/1.1 Response 404 to 127.0.0.1. Time: 1ms. http://127.0.0.1:8096/LiveTv/LiveStreamFiles/bf7880bbcb4e4ff4a58dcb70d5eed19e/stream.ts 2022-05-10 14:31:59.776 Info App: AppendExtraLogData - Read graph file: /config/logs/ffmpeg-transcode-6a196556-6999-4f04-8729-8112f9979394_1graph.txt 2022-05-10 14:31:59.785 Info App: AppendExtraLogData - Deserialized GraphData fileStream: {0:n} bytes Graph Count: 1 2022-05-10 14:31:59.785 Info App: AppendExtraLogData - File Deleted 2022-05-10 14:31:59.800 Error Server: Error processing request *** Error Report *** Version: 4.6.7.0 Command line: /system/EmbyServer.dll -programdata /config -ffdetect /bin/ffdetect -ffmpeg /bin/ffmpeg -ffprobe /bin/ffprobe -restartexitcode 3 Operating system: Linux version 5.15.0-27-generic (buildd@ubuntu) (gcc (Ubuntu 11.2.0-19ubuntu1) 11.2.0, GNU ld (GNU Binutils for Ubuntu) 2.38) #28-Ubuntu SMP Thu Apr 1 Framework: .NET Core 3.1.21 OS/Process: x64/x64 Runtime: system/System.Private.CoreLib.dll Processor count: 3 Data path: /config Application path: /system System.Exception: System.Exception: Error starting ffmpeg at Emby.Server.MediaEncoding.Api.BaseStreamingService.StartFfMpeg(StreamState state, String outputPath, CancellationToken cancellationToken, Boolean acquireResources) at Emby.Server.MediaEncoding.Api.Hls.BaseHlsService.ProcessRequest(StreamRequest request) at Emby.Server.Implementations.Services.ServiceController.GetTaskResult(Task task) at Emby.Server.Implementations.Services.ServiceHandler.ProcessRequestAsync(HttpListenerHost appHost, IRequest httpReq, IResponse httpRes, RestPath restPath, String responseContentType, CancellationToken cancellationToken) at Emby.Server.Implementations.HttpServer.HttpListenerHost.RequestHandler(IRequest httpReq, ReadOnlyMemory`1 urlString, ReadOnlyMemory`1 localPath, CancellationToken cancellationToken) Source: Emby.Server.MediaEncoding TargetSite: Void MoveNext() 2022-05-10 14:31:59.800 Info Server: http/1.1 Response 500 to 10.10.0.10. Time: 316ms. http://[redacted-hostname]/emby/videos/2561360/live.m3u8?DeviceId=9b0014dc-06bf-4a0a-8fba-bac2d419bd46&MediaSourceId=0&PlaySessionId=58bb6938f2b84364827e11f1ac7ae529&LiveStreamId=06044cf0e6f93cdae5f285c9ecfaaeb4_41c95b6de5174f82acbc56fe82d0a2f8_0&VideoCodec=h264&AudioCodec=aac&VideoBitrate=139808000&AudioBitrate=192000&TranscodingMaxAudioChannels=2&SegmentContainer=ts&MinSegments=1&BreakOnNonKeyFrames=True&ManifestSubtitles=vtt&h264-profile=high,main,baseline,constrainedbaseline&h264-level=52&TranscodeReasons=ContainerNotSupported 2022-05-10 14:31:59.845 Info App: ProcessRun 'StreamTranscode 6a1965' Process exited with code 1 2022-05-10 14:31:59.889 Info Server: http/1.1 OPTIONS http://[redacted-hostname]/emby/Sessions/Playing?X-Emby-Client=Emby Web&X-Emby-Device-Name=Firefox Windows&X-Emby-Device-Id=9b0014dc-06bf-4a0a-8fba-bac2d419bd46&X-Emby-Client-Version=4.7.0.9. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:99.0) Gecko/20100101 Firefox/99.0 2022-05-10 14:31:59.889 Info Server: http/1.1 Response 200 to 10.10.0.10. Time: 0ms. http://[redacted-hostname]/emby/Sessions/Playing?X-Emby-Client=Emby Web&X-Emby-Device-Name=Firefox Windows&X-Emby-Device-Id=9b0014dc-06bf-4a0a-8fba-bac2d419bd46&X-Emby-Client-Version=4.7.0.9 2022-05-10 14:31:59.894 Info Server: http/1.1 POST http://[redacted-hostname]/emby/Sessions/Playing?X-Emby-Client=Emby Web&X-Emby-Device-Name=Firefox Windows&X-Emby-Device-Id=9b0014dc-06bf-4a0a-8fba-bac2d419bd46&X-Emby-Client-Version=4.7.0.9. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:99.0) Gecko/20100101 Firefox/99.0 2022-05-10 14:31:59.911 Info Server: http/1.1 OPTIONS http://[redacted-hostname]/emby/Items/2561360/PlaybackInfo?UserId=eaf86e9c1dc84101a85a3f1d4eaa9839&StartTimeTicks=0&IsPlayback=true&AutoOpenLiveStream=true&AudioStreamIndex=-1&SubtitleStreamIndex=-1&EnableDirectPlay=false&EnableDirectStream=false&AllowVideoStreamCopy=false&MediaSourceId=0&LiveStreamId=06044cf0e6f93cdae5f285c9ecfaaeb4_41c95b6de5174f82acbc56fe82d0a2f8_0&MaxStreamingBitrate=140000000&CurrentPlaySessionId=58bb6938f2b84364827e11f1ac7ae529&X-Emby-Client=Emby Web&X-Emby-Device-Name=Firefox Windows&X-Emby-Device-Id=9b0014dc-06bf-4a0a-8fba-bac2d419bd46&X-Emby-Client-Version=4.7.0.9. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:99.0) Gecko/20100101 Firefox/99.0 2022-05-10 14:31:59.912 Info Server: http/1.1 Response 200 to 10.10.0.10. Time: 0ms. http://[redacted-hostname]/emby/Items/2561360/PlaybackInfo?UserId=eaf86e9c1dc84101a85a3f1d4eaa9839&StartTimeTicks=0&IsPlayback=true&AutoOpenLiveStream=true&AudioStreamIndex=-1&SubtitleStreamIndex=-1&EnableDirectPlay=false&EnableDirectStream=false&AllowVideoStreamCopy=false&MediaSourceId=0&LiveStreamId=06044cf0e6f93cdae5f285c9ecfaaeb4_41c95b6de5174f82acbc56fe82d0a2f8_0&MaxStreamingBitrate=140000000&CurrentPlaySessionId=58bb6938f2b84364827e11f1ac7ae529&X-Emby-Client=Emby Web&X-Emby-Device-Name=Firefox Windows&X-Emby-Device-Id=9b0014dc-06bf-4a0a-8fba-bac2d419bd46&X-Emby-Client-Version=4.7.0.9 2022-05-10 14:31:59.917 Info Server: http/1.1 POST http://[redacted-hostname]/emby/Items/2561360/PlaybackInfo?UserId=eaf86e9c1dc84101a85a3f1d4eaa9839&StartTimeTicks=0&IsPlayback=true&AutoOpenLiveStream=true&AudioStreamIndex=-1&SubtitleStreamIndex=-1&EnableDirectPlay=false&EnableDirectStream=false&AllowVideoStreamCopy=false&MediaSourceId=0&LiveStreamId=06044cf0e6f93cdae5f285c9ecfaaeb4_41c95b6de5174f82acbc56fe82d0a2f8_0&MaxStreamingBitrate=140000000&CurrentPlaySessionId=58bb6938f2b84364827e11f1ac7ae529&X-Emby-Client=Emby Web&X-Emby-Device-Name=Firefox Windows&X-Emby-Device-Id=9b0014dc-06bf-4a0a-8fba-bac2d419bd46&X-Emby-Client-Version=4.7.0.9. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:99.0) Gecko/20100101 Firefox/99.0 2022-05-10 14:31:59.920 Info App: User policy for Groentjuh. EnablePlaybackRemuxing: True EnableVideoPlaybackTranscoding: True EnableAudioPlaybackTranscoding: True 2022-05-10 14:31:59.920 Info App: RemoteClientBitrateLimit: 25000000, RemoteIp: 10.10.0.10, IsInLocalNetwork: True 2022-05-10 14:31:59.922 Info App: RemoteClientBitrateLimit: 25000000, RemoteIp: 10.10.0.10, IsInLocalNetwork: True 2022-05-10 14:31:59.922 Info Server: http/1.1 Response 200 to 10.10.0.10. Time: 6ms. http://[redacted-hostname]/emby/Items/2561360/PlaybackInfo?UserId=eaf86e9c1dc84101a85a3f1d4eaa9839&StartTimeTicks=0&IsPlayback=true&AutoOpenLiveStream=true&AudioStreamIndex=-1&SubtitleStreamIndex=-1&EnableDirectPlay=false&EnableDirectStream=false&AllowVideoStreamCopy=false&MediaSourceId=0&LiveStreamId=06044cf0e6f93cdae5f285c9ecfaaeb4_41c95b6de5174f82acbc56fe82d0a2f8_0&MaxStreamingBitrate=140000000&CurrentPlaySessionId=58bb6938f2b84364827e11f1ac7ae529&X-Emby-Client=Emby Web&X-Emby-Device-Name=Firefox Windows&X-Emby-Device-Id=9b0014dc-06bf-4a0a-8fba-bac2d419bd46&X-Emby-Client-Version=4.7.0.9 2022-05-10 14:31:59.944 Info Server: http/1.1 OPTIONS http://[redacted-hostname]/emby/Videos/ActiveEncodings?deviceId=9b0014dc-06bf-4a0a-8fba-bac2d419bd46&PlaySessionId=58bb6938f2b84364827e11f1ac7ae529&X-Emby-Client=Emby Web&X-Emby-Device-Name=Firefox Windows&X-Emby-Device-Id=9b0014dc-06bf-4a0a-8fba-bac2d419bd46&X-Emby-Client-Version=4.7.0.9. Accept=*/*, Accept-Encoding=gzip, deflate, br, Accept-Language=nl,en-US;q=0.7,en;q=0.3, Host=[redacted-hostname], Referer=https://app.emby.media/, User-Agent=Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:99.0) Gecko/20100101 Firefox/99.0, DNT=1, Origin=https://app.emby.media, Access-Control-Request-Method=DELETE, X-Real-IP=10.10.0.10, X-Forwarded-For=10.10.0.10, sec-fetch-dest=empty, sec-fetch-mode=cors, sec-fetch-site=cross-site 2022-05-10 14:31:59.944 Info Server: http/1.1 Response 200 to 10.10.0.10. Time: 0ms. http://[redacted-hostname]/emby/Videos/ActiveEncodings?deviceId=9b0014dc-06bf-4a0a-8fba-bac2d419bd46&PlaySessionId=58bb6938f2b84364827e11f1ac7ae529&X-Emby-Client=Emby Web&X-Emby-Device-Name=Firefox Windows&X-Emby-Device-Id=9b0014dc-06bf-4a0a-8fba-bac2d419bd46&X-Emby-Client-Version=4.7.0.9 2022-05-10 14:31:59.963 Info Server: http/1.1 DELETE http://[redacted-hostname]/emby/Videos/ActiveEncodings?deviceId=9b0014dc-06bf-4a0a-8fba-bac2d419bd46&PlaySessionId=58bb6938f2b84364827e11f1ac7ae529&X-Emby-Client=Emby Web&X-Emby-Device-Name=Firefox Windows&X-Emby-Device-Id=9b0014dc-06bf-4a0a-8fba-bac2d419bd46&X-Emby-Client-Version=4.7.0.9. Accept=*/*, Accept-Encoding=gzip, deflate, br, Accept-Language=nl,en-US;q=0.7,en;q=0.3, Host=[redacted-hostname], Referer=https://app.emby.media/, User-Agent=Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:99.0) Gecko/20100101 Firefox/99.0, DNT=1, Origin=https://app.emby.media, X-Real-IP=10.10.0.10, X-Forwarded-For=10.10.0.10, sec-fetch-dest=empty, sec-fetch-mode=cors, sec-fetch-site=cross-site 2022-05-10 14:31:59.966 Info Server: http/1.1 Response 204 to 10.10.0.10. Time: 16ms. http://[redacted-hostname]/emby/Videos/ActiveEncodings?deviceId=9b0014dc-06bf-4a0a-8fba-bac2d419bd46&PlaySessionId=58bb6938f2b84364827e11f1ac7ae529&X-Emby-Client=Emby Web&X-Emby-Device-Name=Firefox Windows&X-Emby-Device-Id=9b0014dc-06bf-4a0a-8fba-bac2d419bd46&X-Emby-Client-Version=4.7.0.9 2022-05-10 14:31:59.992 Info Server: http/1.1 GET http://[redacted-hostname]/emby/videos/2561360/master.m3u8?DeviceId=9b0014dc-06bf-4a0a-8fba-bac2d419bd46&MediaSourceId=0&PlaySessionId=b40a2b0ed89b49b9a8c8f0dbffc12059&LiveStreamId=06044cf0e6f93cdae5f285c9ecfaaeb4_41c95b6de5174f82acbc56fe82d0a2f8_0&VideoCodec=h264&AudioCodec=aac&VideoBitrate=139808000&AudioBitrate=192000&TranscodingMaxAudioChannels=2&SegmentContainer=ts&MinSegments=1&BreakOnNonKeyFrames=True&ManifestSubtitles=vtt&h264-profile=high,main,baseline,constrainedbaseline&h264-level=52&TranscodeReasons=ContainerNotSupported,DirectPlayError&allowVideoStreamCopy=false. Accept=*/*, Accept-Encoding=gzip, deflate, br, Accept-Language=nl,en-US;q=0.7,en;q=0.3, Host=[redacted-hostname], Referer=https://app.emby.media/, User-Agent=Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:99.0) Gecko/20100101 Firefox/99.0, DNT=1, Origin=https://app.emby.media, X-Real-IP=10.10.0.10, X-Forwarded-For=10.10.0.10, sec-fetch-dest=empty, sec-fetch-mode=cors, sec-fetch-site=cross-site 2022-05-10 14:31:59.993 Info Server: http/1.1 Response 200 to 10.10.0.10. Time: 1ms. http://[redacted-hostname]/emby/videos/2561360/master.m3u8?DeviceId=9b0014dc-06bf-4a0a-8fba-bac2d419bd46&MediaSourceId=0&PlaySessionId=b40a2b0ed89b49b9a8c8f0dbffc12059&LiveStreamId=06044cf0e6f93cdae5f285c9ecfaaeb4_41c95b6de5174f82acbc56fe82d0a2f8_0&VideoCodec=h264&AudioCodec=aac&VideoBitrate=139808000&AudioBitrate=192000&TranscodingMaxAudioChannels=2&SegmentContainer=ts&MinSegments=1&BreakOnNonKeyFrames=True&ManifestSubtitles=vtt&h264-profile=high,main,baseline,constrainedbaseline&h264-level=52&TranscodeReasons=ContainerNotSupported,DirectPlayError&allowVideoStreamCopy=false 2022-05-10 14:32:00.000 Info SessionManager: Playback start reported by app Emby Web 4.7.0.9 playing NPO 1 HD. Started at 0 ms 2022-05-10 14:32:00.012 Info Server: http/1.1 Response 204 to 10.10.0.10. Time: 118ms. http://[redacted-hostname]/emby/Sessions/Playing?X-Emby-Client=Emby Web&X-Emby-Device-Name=Firefox Windows&X-Emby-Device-Id=9b0014dc-06bf-4a0a-8fba-bac2d419bd46&X-Emby-Client-Version=4.7.0.9 2022-05-10 14:32:00.015 Info Server: http/1.1 GET http://[redacted-hostname]/emby/videos/2561360/live.m3u8?DeviceId=9b0014dc-06bf-4a0a-8fba-bac2d419bd46&MediaSourceId=0&PlaySessionId=b40a2b0ed89b49b9a8c8f0dbffc12059&LiveStreamId=06044cf0e6f93cdae5f285c9ecfaaeb4_41c95b6de5174f82acbc56fe82d0a2f8_0&VideoCodec=h264&AudioCodec=aac&VideoBitrate=139808000&AudioBitrate=192000&TranscodingMaxAudioChannels=2&SegmentContainer=ts&MinSegments=1&BreakOnNonKeyFrames=True&ManifestSubtitles=vtt&h264-profile=high,main,baseline,constrainedbaseline&h264-level=52&TranscodeReasons=ContainerNotSupported,DirectPlayError&allowVideoStreamCopy=false. Accept=*/*, Accept-Encoding=gzip, deflate, br, Accept-Language=nl,en-US;q=0.7,en;q=0.3, Host=[redacted-hostname], Referer=https://app.emby.media/, User-Agent=Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:99.0) Gecko/20100101 Firefox/99.0, DNT=1, Origin=https://app.emby.media, X-Real-IP=10.10.0.10, X-Forwarded-For=10.10.0.10, sec-fetch-dest=empty, sec-fetch-mode=cors, sec-fetch-site=cross-site 2022-05-10 14:32:00.043 Info App: ProcessRun 'StreamTranscode 7a0332' Execute: /bin/ffmpeg -loglevel +timing -y -print_graphs_file "/config/logs/ffmpeg-transcode-7a033210-dcfe-44da-a6a1-6c9858124533_1graph.txt" -copyts -start_at_zero -analyzeduration 3000000 -i "http://127.0.0.1:8096/LiveTv/LiveStreamFiles/bf7880bbcb4e4ff4a58dcb70d5eed19e/stream.ts" -filter_complex "[v:0]yadif@f1=mode=send_frame:parity=auto:deint=all,format@f2=pix_fmts=yuv420p[f2_out0]" -map [f2_out0] -map a:0 -sn -c:v:0 libx264 -maxrate:v:0 10000000 -bufsize:v:0 20000000 -pix_fmt:v:0 yuv420p -force_key_frames:v:0 "expr:if(isnan(prev_forced_t),eq(t,t),gte(t,prev_forced_t+3))" -preset:v:0 veryfast -profile:v:0 high -level:v:0 3.1 -x264opts:v:0 "subme=0:me_range=4:rc_lookahead=10:partitions=none" -crf:v:0 23 -c:a:0 aac -ab:a:0 192000 -ac:a:0 2 -disposition:a:0 default -max_delay 5000000 -avoid_negative_ts disabled -f segment -map_metadata -1 -map_chapters -1 -segment_format mpegts -segment_list "/data/EmbyTranscoding/transcoding-temp/E7C48D.m3u8" -segment_list_type m3u8 -segment_time 3 -segment_list_entry_prefix hls/E7C48D/ -segment_start_number 0 -individual_header_trailer 0 -write_header_trailer 0 -segment_write_temp 1 "/data/EmbyTranscoding/transcoding-temp/E7C48D_%d.ts" 2022-05-10 14:32:00.057 Info Server: http/1.1 GET http://127.0.0.1:8096/LiveTv/LiveStreamFiles/bf7880bbcb4e4ff4a58dcb70d5eed19e/stream.ts. UserAgent: Lavf/58.35.100 2022-05-10 14:32:00.058 Error Server: Error processing request *** Error Report *** Version: 4.6.7.0 Command line: /system/EmbyServer.dll -programdata /config -ffdetect /bin/ffdetect -ffmpeg /bin/ffmpeg -ffprobe /bin/ffprobe -restartexitcode 3 Operating system: Linux version 5.15.0-27-generic (buildd@ubuntu) (gcc (Ubuntu 11.2.0-19ubuntu1) 11.2.0, GNU ld (GNU Binutils for Ubuntu) 2.38) #28-Ubuntu SMP Thu Apr 1 Framework: .NET Core 3.1.21 OS/Process: x64/x64 Runtime: system/System.Private.CoreLib.dll Processor count: 3 Data path: /config Application path: /system System.IO.FileNotFoundException: System.IO.FileNotFoundException: Could not find file '/data/EmbyTranscoding/transcoding-temp/bf7880bbcb4e4ff4a58dcb70d5eed19e.ts'. File name: '/data/EmbyTranscoding/transcoding-temp/bf7880bbcb4e4ff4a58dcb70d5eed19e.ts' at Interop.ThrowExceptionForIoErrno(ErrorInfo errorInfo, String path, Boolean isDirectory, Func`2 errorRewriter) at Microsoft.Win32.SafeHandles.SafeFileHandle.Open(String path, OpenFlags flags, Int32 mode) at System.IO.FileStream.OpenHandle(FileMode mode, FileShare share, FileOptions options) at System.IO.FileStream..ctor(String path, FileMode mode, FileAccess access, FileShare share, Int32 bufferSize, FileOptions options) at Emby.Server.Implementations.IO.ManagedFileSystem.GetFileStream(String path, FileOpenMode mode, FileAccessMode access, FileShareMode share, Int32 bufferSize, FileOpenOptions fileOpenOptions) at Emby.LiveTV.TunerHosts.LiveStream.CopyFile(String path, Boolean seekFile, Int32 emptyReadLimit, PipeWriter writer, IFileSystem fileSystem, IStreamHelper streamHelper, CancellationToken cancellationToken) at Emby.LiveTV.TunerHosts.LiveStream.CopyToAsync(PipeWriter writer, CancellationToken cancellationToken) at Emby.Server.Implementations.Services.ServiceHandler.ProcessRequestAsync(HttpListenerHost appHost, IRequest httpReq, IResponse httpRes, RestPath restPath, String responseContentType, CancellationToken cancellationToken) at Emby.Server.Implementations.HttpServer.HttpListenerHost.RequestHandler(IRequest httpReq, ReadOnlyMemory`1 urlString, ReadOnlyMemory`1 localPath, CancellationToken cancellationToken) Source: System.Private.CoreLib TargetSite: Void ThrowExceptionForIoErrno(ErrorInfo, System.String, Boolean, System.Func`2[Interop+ErrorInfo,Interop+ErrorInfo]) 2022-05-10 14:32:00.058 Info Server: http/1.1 Response 404 to 127.0.0.1. Time: 1ms. http://127.0.0.1:8096/LiveTv/LiveStreamFiles/bf7880bbcb4e4ff4a58dcb70d5eed19e/stream.ts 2022-05-10 14:32:00.062 Info App: AppendExtraLogData - Read graph file: /config/logs/ffmpeg-transcode-7a033210-dcfe-44da-a6a1-6c9858124533_1graph.txt 2022-05-10 14:32:00.062 Info App: AppendExtraLogData - Deserialized GraphData fileStream: {0:n} bytes Graph Count: 1 2022-05-10 14:32:00.062 Info App: AppendExtraLogData - File Deleted 2022-05-10 14:32:00.062 Info App: ProcessRun 'StreamTranscode 7a0332' Process exited with code 1 2022-05-10 14:32:00.087 Info Server: http/1.1 GET http://[redacted-hostname]/emby/Items/2561360/Images/Primary?maxWidth=12&blur=2&tag=0f57f1c0ec3b5097c0dfd034489e175b&quality=90. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:99.0) Gecko/20100101 Firefox/99.0 2022-05-10 14:32:00.101 Info Server: http/1.1 GET http://[redacted-hostname]/emby/Items/2561360/Images/Primary?maxHeight=78&maxWidth=78&tag=0f57f1c0ec3b5097c0dfd034489e175b&quality=90. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:99.0) Gecko/20100101 Firefox/99.0 2022-05-10 14:32:00.103 Error Server: Error processing request *** Error Report *** Version: 4.6.7.0 Command line: /system/EmbyServer.dll -programdata /config -ffdetect /bin/ffdetect -ffmpeg /bin/ffmpeg -ffprobe /bin/ffprobe -restartexitcode 3 Operating system: Linux version 5.15.0-27-generic (buildd@ubuntu) (gcc (Ubuntu 11.2.0-19ubuntu1) 11.2.0, GNU ld (GNU Binutils for Ubuntu) 2.38) #28-Ubuntu SMP Thu Apr 1 Framework: .NET Core 3.1.21 OS/Process: x64/x64 Runtime: system/System.Private.CoreLib.dll Processor count: 3 Data path: /config Application path: /system System.Exception: System.Exception: Error starting ffmpeg at Emby.Server.MediaEncoding.Api.BaseStreamingService.StartFfMpeg(StreamState state, String outputPath, CancellationToken cancellationToken, Boolean acquireResources) at Emby.Server.MediaEncoding.Api.Hls.BaseHlsService.ProcessRequest(StreamRequest request) at Emby.Server.Implementations.Services.ServiceController.GetTaskResult(Task task) at Emby.Server.Implementations.Services.ServiceHandler.ProcessRequestAsync(HttpListenerHost appHost, IRequest httpReq, IResponse httpRes, RestPath restPath, String responseContentType, CancellationToken cancellationToken) at Emby.Server.Implementations.HttpServer.HttpListenerHost.RequestHandler(IRequest httpReq, ReadOnlyMemory`1 urlString, ReadOnlyMemory`1 localPath, CancellationToken cancellationToken) Source: Emby.Server.MediaEncoding TargetSite: Void MoveNext() 2022-05-10 14:32:00.103 Info Server: http/1.1 Response 500 to 10.10.0.10. Time: 89ms. http://[redacted-hostname]/emby/videos/2561360/live.m3u8?DeviceId=9b0014dc-06bf-4a0a-8fba-bac2d419bd46&MediaSourceId=0&PlaySessionId=b40a2b0ed89b49b9a8c8f0dbffc12059&LiveStreamId=06044cf0e6f93cdae5f285c9ecfaaeb4_41c95b6de5174f82acbc56fe82d0a2f8_0&VideoCodec=h264&AudioCodec=aac&VideoBitrate=139808000&AudioBitrate=192000&TranscodingMaxAudioChannels=2&SegmentContainer=ts&MinSegments=1&BreakOnNonKeyFrames=True&ManifestSubtitles=vtt&h264-profile=high,main,baseline,constrainedbaseline&h264-level=52&TranscodeReasons=ContainerNotSupported,DirectPlayError&allowVideoStreamCopy=false 2022-05-10 14:32:00.138 Info Server: http/1.1 Response 200 to 10.10.0.10. Time: 37ms. http://[redacted-hostname]/emby/Items/2561360/Images/Primary?maxHeight=78&maxWidth=78&tag=0f57f1c0ec3b5097c0dfd034489e175b&quality=90 2022-05-10 14:32:00.139 Info Server: http/1.1 Response 200 to 10.10.0.10. Time: 52ms. http://[redacted-hostname]/emby/Items/2561360/Images/Primary?maxWidth=12&blur=2&tag=0f57f1c0ec3b5097c0dfd034489e175b&quality=90 2022-05-10 14:32:00.175 Info Server: http/1.1 OPTIONS http://[redacted-hostname]/emby/Videos/ActiveEncodings?deviceId=9b0014dc-06bf-4a0a-8fba-bac2d419bd46&PlaySessionId=58bb6938f2b84364827e11f1ac7ae529&X-Emby-Client=Emby Web&X-Emby-Device-Name=Firefox Windows&X-Emby-Device-Id=9b0014dc-06bf-4a0a-8fba-bac2d419bd46&X-Emby-Client-Version=4.7.0.9. Accept=*/*, Accept-Encoding=gzip, deflate, br, Accept-Language=nl,en-US;q=0.7,en;q=0.3, Host=[redacted-hostname], Referer=https://app.emby.media/, User-Agent=Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:99.0) Gecko/20100101 Firefox/99.0, DNT=1, Origin=https://app.emby.media, Access-Control-Request-Method=DELETE, X-Real-IP=10.10.0.10, X-Forwarded-For=10.10.0.10, sec-fetch-dest=empty, sec-fetch-mode=cors, sec-fetch-site=cross-site 2022-05-10 14:32:00.175 Info Server: http/1.1 Response 200 to 10.10.0.10. Time: 0ms. http://[redacted-hostname]/emby/Videos/ActiveEncodings?deviceId=9b0014dc-06bf-4a0a-8fba-bac2d419bd46&PlaySessionId=58bb6938f2b84364827e11f1ac7ae529&X-Emby-Client=Emby Web&X-Emby-Device-Name=Firefox Windows&X-Emby-Device-Id=9b0014dc-06bf-4a0a-8fba-bac2d419bd46&X-Emby-Client-Version=4.7.0.9 2022-05-10 14:32:00.192 Info Server: http/1.1 DELETE http://[redacted-hostname]/emby/Videos/ActiveEncodings?deviceId=9b0014dc-06bf-4a0a-8fba-bac2d419bd46&PlaySessionId=58bb6938f2b84364827e11f1ac7ae529&X-Emby-Client=Emby Web&X-Emby-Device-Name=Firefox Windows&X-Emby-Device-Id=9b0014dc-06bf-4a0a-8fba-bac2d419bd46&X-Emby-Client-Version=4.7.0.9. Accept=*/*, Accept-Encoding=gzip, deflate, br, Accept-Language=nl,en-US;q=0.7,en;q=0.3, Host=[redacted-hostname], Referer=https://app.emby.media/, User-Agent=Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:99.0) Gecko/20100101 Firefox/99.0, DNT=1, Origin=https://app.emby.media, X-Real-IP=10.10.0.10, X-Forwarded-For=10.10.0.10, sec-fetch-dest=empty, sec-fetch-mode=cors, sec-fetch-site=cross-site 2022-05-10 14:32:00.192 Info Server: http/1.1 Response 204 to 10.10.0.10. Time: 1ms. http://[redacted-hostname]/emby/Videos/ActiveEncodings?deviceId=9b0014dc-06bf-4a0a-8fba-bac2d419bd46&PlaySessionId=58bb6938f2b84364827e11f1ac7ae529&X-Emby-Client=Emby Web&X-Emby-Device-Name=Firefox Windows&X-Emby-Device-Id=9b0014dc-06bf-4a0a-8fba-bac2d419bd46&X-Emby-Client-Version=4.7.0.9 2022-05-10 14:32:00.242 Info Server: http/1.1 OPTIONS http://[redacted-hostname]/emby/Items/2561360/PlaybackInfo?UserId=eaf86e9c1dc84101a85a3f1d4eaa9839&StartTimeTicks=0&IsPlayback=true&AutoOpenLiveStream=true&AudioStreamIndex=-1&SubtitleStreamIndex=-1&EnableDirectPlay=false&EnableDirectStream=false&AllowVideoStreamCopy=false&AllowAudioStreamCopy=false&MediaSourceId=0&LiveStreamId=06044cf0e6f93cdae5f285c9ecfaaeb4_41c95b6de5174f82acbc56fe82d0a2f8_0&MaxStreamingBitrate=140000000&CurrentPlaySessionId=b40a2b0ed89b49b9a8c8f0dbffc12059&X-Emby-Client=Emby Web&X-Emby-Device-Name=Firefox Windows&X-Emby-Device-Id=9b0014dc-06bf-4a0a-8fba-bac2d419bd46&X-Emby-Client-Version=4.7.0.9. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:99.0) Gecko/20100101 Firefox/99.0 2022-05-10 14:32:00.242 Info Server: http/1.1 Response 200 to 10.10.0.10. Time: 0ms. http://[redacted-hostname]/emby/Items/2561360/PlaybackInfo?UserId=eaf86e9c1dc84101a85a3f1d4eaa9839&StartTimeTicks=0&IsPlayback=true&AutoOpenLiveStream=true&AudioStreamIndex=-1&SubtitleStreamIndex=-1&EnableDirectPlay=false&EnableDirectStream=false&AllowVideoStreamCopy=false&AllowAudioStreamCopy=false&MediaSourceId=0&LiveStreamId=06044cf0e6f93cdae5f285c9ecfaaeb4_41c95b6de5174f82acbc56fe82d0a2f8_0&MaxStreamingBitrate=140000000&CurrentPlaySessionId=b40a2b0ed89b49b9a8c8f0dbffc12059&X-Emby-Client=Emby Web&X-Emby-Device-Name=Firefox Windows&X-Emby-Device-Id=9b0014dc-06bf-4a0a-8fba-bac2d419bd46&X-Emby-Client-Version=4.7.0.9 2022-05-10 14:32:00.305 Info Server: http/1.1 POST http://[redacted-hostname]/emby/Items/2561360/PlaybackInfo?UserId=eaf86e9c1dc84101a85a3f1d4eaa9839&StartTimeTicks=0&IsPlayback=true&AutoOpenLiveStream=true&AudioStreamIndex=-1&SubtitleStreamIndex=-1&EnableDirectPlay=false&EnableDirectStream=false&AllowVideoStreamCopy=false&AllowAudioStreamCopy=false&MediaSourceId=0&LiveStreamId=06044cf0e6f93cdae5f285c9ecfaaeb4_41c95b6de5174f82acbc56fe82d0a2f8_0&MaxStreamingBitrate=140000000&CurrentPlaySessionId=b40a2b0ed89b49b9a8c8f0dbffc12059&X-Emby-Client=Emby Web&X-Emby-Device-Name=Firefox Windows&X-Emby-Device-Id=9b0014dc-06bf-4a0a-8fba-bac2d419bd46&X-Emby-Client-Version=4.7.0.9. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:99.0) Gecko/20100101 Firefox/99.0 2022-05-10 14:32:00.309 Info App: User policy for Groentjuh. EnablePlaybackRemuxing: True EnableVideoPlaybackTranscoding: True EnableAudioPlaybackTranscoding: True 2022-05-10 14:32:00.309 Info App: RemoteClientBitrateLimit: 25000000, RemoteIp: 10.10.0.10, IsInLocalNetwork: True 2022-05-10 14:32:00.310 Info App: RemoteClientBitrateLimit: 25000000, RemoteIp: 10.10.0.10, IsInLocalNetwork: True 2022-05-10 14:32:00.311 Info Server: http/1.1 Response 200 to 10.10.0.10. Time: 6ms. http://[redacted-hostname]/emby/Items/2561360/PlaybackInfo?UserId=eaf86e9c1dc84101a85a3f1d4eaa9839&StartTimeTicks=0&IsPlayback=true&AutoOpenLiveStream=true&AudioStreamIndex=-1&SubtitleStreamIndex=-1&EnableDirectPlay=false&EnableDirectStream=false&AllowVideoStreamCopy=false&AllowAudioStreamCopy=false&MediaSourceId=0&LiveStreamId=06044cf0e6f93cdae5f285c9ecfaaeb4_41c95b6de5174f82acbc56fe82d0a2f8_0&MaxStreamingBitrate=140000000&CurrentPlaySessionId=b40a2b0ed89b49b9a8c8f0dbffc12059&X-Emby-Client=Emby Web&X-Emby-Device-Name=Firefox Windows&X-Emby-Device-Id=9b0014dc-06bf-4a0a-8fba-bac2d419bd46&X-Emby-Client-Version=4.7.0.9 2022-05-10 14:32:00.345 Info Server: http/1.1 OPTIONS http://[redacted-hostname]/emby/Videos/ActiveEncodings?deviceId=9b0014dc-06bf-4a0a-8fba-bac2d419bd46&PlaySessionId=b40a2b0ed89b49b9a8c8f0dbffc12059&X-Emby-Client=Emby Web&X-Emby-Device-Name=Firefox Windows&X-Emby-Device-Id=9b0014dc-06bf-4a0a-8fba-bac2d419bd46&X-Emby-Client-Version=4.7.0.9. Accept=*/*, Accept-Encoding=gzip, deflate, br, Accept-Language=nl,en-US;q=0.7,en;q=0.3, Host=[redacted-hostname], Referer=https://app.emby.media/, User-Agent=Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:99.0) Gecko/20100101 Firefox/99.0, DNT=1, Origin=https://app.emby.media, Access-Control-Request-Method=DELETE, X-Real-IP=10.10.0.10, X-Forwarded-For=10.10.0.10, sec-fetch-dest=empty, sec-fetch-mode=cors, sec-fetch-site=cross-site 2022-05-10 14:32:00.345 Info Server: http/1.1 Response 200 to 10.10.0.10. Time: 0ms. http://[redacted-hostname]/emby/Videos/ActiveEncodings?deviceId=9b0014dc-06bf-4a0a-8fba-bac2d419bd46&PlaySessionId=b40a2b0ed89b49b9a8c8f0dbffc12059&X-Emby-Client=Emby Web&X-Emby-Device-Name=Firefox Windows&X-Emby-Device-Id=9b0014dc-06bf-4a0a-8fba-bac2d419bd46&X-Emby-Client-Version=4.7.0.9 2022-05-10 14:32:00.384 Info Server: http/1.1 DELETE http://[redacted-hostname]/emby/Videos/ActiveEncodings?deviceId=9b0014dc-06bf-4a0a-8fba-bac2d419bd46&PlaySessionId=b40a2b0ed89b49b9a8c8f0dbffc12059&X-Emby-Client=Emby Web&X-Emby-Device-Name=Firefox Windows&X-Emby-Device-Id=9b0014dc-06bf-4a0a-8fba-bac2d419bd46&X-Emby-Client-Version=4.7.0.9. Accept=*/*, Accept-Encoding=gzip, deflate, br, Accept-Language=nl,en-US;q=0.7,en;q=0.3, Host=[redacted-hostname], Referer=https://app.emby.media/, User-Agent=Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:99.0) Gecko/20100101 Firefox/99.0, DNT=1, Origin=https://app.emby.media, X-Real-IP=10.10.0.10, X-Forwarded-For=10.10.0.10, sec-fetch-dest=empty, sec-fetch-mode=cors, sec-fetch-site=cross-site 2022-05-10 14:32:00.386 Info Server: http/1.1 Response 204 to 10.10.0.10. Time: 2ms. http://[redacted-hostname]/emby/Videos/ActiveEncodings?deviceId=9b0014dc-06bf-4a0a-8fba-bac2d419bd46&PlaySessionId=b40a2b0ed89b49b9a8c8f0dbffc12059&X-Emby-Client=Emby Web&X-Emby-Device-Name=Firefox Windows&X-Emby-Device-Id=9b0014dc-06bf-4a0a-8fba-bac2d419bd46&X-Emby-Client-Version=4.7.0.9 2022-05-10 14:32:00.417 Info Server: http/1.1 GET http://[redacted-hostname]/emby/videos/2561360/master.m3u8?DeviceId=9b0014dc-06bf-4a0a-8fba-bac2d419bd46&MediaSourceId=0&PlaySessionId=5b68630ba74a477a84e27877bd21132a&LiveStreamId=06044cf0e6f93cdae5f285c9ecfaaeb4_41c95b6de5174f82acbc56fe82d0a2f8_0&VideoCodec=h264&AudioCodec=aac&VideoBitrate=139808000&AudioBitrate=192000&TranscodingMaxAudioChannels=2&SegmentContainer=ts&MinSegments=1&BreakOnNonKeyFrames=True&ManifestSubtitles=vtt&h264-profile=high,main,baseline,constrainedbaseline&h264-level=52&TranscodeReasons=ContainerNotSupported,DirectPlayError&allowVideoStreamCopy=false&allowAudioStreamCopy=false. Accept=*/*, Accept-Encoding=gzip, deflate, br, Accept-Language=nl,en-US;q=0.7,en;q=0.3, Host=[redacted-hostname], Referer=https://app.emby.media/, User-Agent=Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:99.0) Gecko/20100101 Firefox/99.0, DNT=1, Origin=https://app.emby.media, X-Real-IP=10.10.0.10, X-Forwarded-For=10.10.0.10, sec-fetch-dest=empty, sec-fetch-mode=cors, sec-fetch-site=cross-site 2022-05-10 14:32:00.420 Info Server: http/1.1 Response 200 to 10.10.0.10. Time: 3ms. http://[redacted-hostname]/emby/videos/2561360/master.m3u8?DeviceId=9b0014dc-06bf-4a0a-8fba-bac2d419bd46&MediaSourceId=0&PlaySessionId=5b68630ba74a477a84e27877bd21132a&LiveStreamId=06044cf0e6f93cdae5f285c9ecfaaeb4_41c95b6de5174f82acbc56fe82d0a2f8_0&VideoCodec=h264&AudioCodec=aac&VideoBitrate=139808000&AudioBitrate=192000&TranscodingMaxAudioChannels=2&SegmentContainer=ts&MinSegments=1&BreakOnNonKeyFrames=True&ManifestSubtitles=vtt&h264-profile=high,main,baseline,constrainedbaseline&h264-level=52&TranscodeReasons=ContainerNotSupported,DirectPlayError&allowVideoStreamCopy=false&allowAudioStreamCopy=false 2022-05-10 14:32:00.438 Info Server: http/1.1 GET http://[redacted-hostname]/emby/videos/2561360/live.m3u8?DeviceId=9b0014dc-06bf-4a0a-8fba-bac2d419bd46&MediaSourceId=0&PlaySessionId=5b68630ba74a477a84e27877bd21132a&LiveStreamId=06044cf0e6f93cdae5f285c9ecfaaeb4_41c95b6de5174f82acbc56fe82d0a2f8_0&VideoCodec=h264&AudioCodec=aac&VideoBitrate=139808000&AudioBitrate=192000&TranscodingMaxAudioChannels=2&SegmentContainer=ts&MinSegments=1&BreakOnNonKeyFrames=True&ManifestSubtitles=vtt&h264-profile=high,main,baseline,constrainedbaseline&h264-level=52&TranscodeReasons=ContainerNotSupported,DirectPlayError&allowVideoStreamCopy=false&allowAudioStreamCopy=false. Accept=*/*, Accept-Encoding=gzip, deflate, br, Accept-Language=nl,en-US;q=0.7,en;q=0.3, Host=[redacted-hostname], Referer=https://app.emby.media/, User-Agent=Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:99.0) Gecko/20100101 Firefox/99.0, DNT=1, Origin=https://app.emby.media, X-Real-IP=10.10.0.10, X-Forwarded-For=10.10.0.10, sec-fetch-dest=empty, sec-fetch-mode=cors, sec-fetch-site=cross-site 2022-05-10 14:32:00.458 Info App: ProcessRun 'StreamTranscode 109d00' Execute: /bin/ffmpeg -loglevel +timing -y -print_graphs_file "/config/logs/ffmpeg-transcode-109d0027-4d9c-43ac-8873-80b135c0b07f_1graph.txt" -copyts -start_at_zero -analyzeduration 3000000 -i "http://127.0.0.1:8096/LiveTv/LiveStreamFiles/bf7880bbcb4e4ff4a58dcb70d5eed19e/stream.ts" -filter_complex "[v:0]yadif@f1=mode=send_frame:parity=auto:deint=all,format@f2=pix_fmts=yuv420p[f2_out0]" -map [f2_out0] -map a:0 -sn -c:v:0 libx264 -maxrate:v:0 10000000 -bufsize:v:0 20000000 -pix_fmt:v:0 yuv420p -force_key_frames:v:0 "expr:if(isnan(prev_forced_t),eq(t,t),gte(t,prev_forced_t+3))" -preset:v:0 veryfast -profile:v:0 high -level:v:0 3.1 -x264opts:v:0 "subme=0:me_range=4:rc_lookahead=10:partitions=none" -crf:v:0 23 -c:a:0 aac -ab:a:0 192000 -ac:a:0 2 -disposition:a:0 default -max_delay 5000000 -avoid_negative_ts disabled -f segment -map_metadata -1 -map_chapters -1 -segment_format mpegts -segment_list "/data/EmbyTranscoding/transcoding-temp/97BAFD.m3u8" -segment_list_type m3u8 -segment_time 3 -segment_list_entry_prefix hls/97BAFD/ -segment_start_number 0 -individual_header_trailer 0 -write_header_trailer 0 -segment_write_temp 1 "/data/EmbyTranscoding/transcoding-temp/97BAFD_%d.ts" 2022-05-10 14:32:00.503 Info Server: http/1.1 GET http://127.0.0.1:8096/LiveTv/LiveStreamFiles/bf7880bbcb4e4ff4a58dcb70d5eed19e/stream.ts. UserAgent: Lavf/58.35.100 2022-05-10 14:32:00.508 Error Server: Error processing request *** Error Report *** Version: 4.6.7.0 Command line: /system/EmbyServer.dll -programdata /config -ffdetect /bin/ffdetect -ffmpeg /bin/ffmpeg -ffprobe /bin/ffprobe -restartexitcode 3 Operating system: Linux version 5.15.0-27-generic (buildd@ubuntu) (gcc (Ubuntu 11.2.0-19ubuntu1) 11.2.0, GNU ld (GNU Binutils for Ubuntu) 2.38) #28-Ubuntu SMP Thu Apr 1 Framework: .NET Core 3.1.21 OS/Process: x64/x64 Runtime: system/System.Private.CoreLib.dll Processor count: 3 Data path: /config Application path: /system System.IO.FileNotFoundException: System.IO.FileNotFoundException: Could not find file '/data/EmbyTranscoding/transcoding-temp/bf7880bbcb4e4ff4a58dcb70d5eed19e.ts'. File name: '/data/EmbyTranscoding/transcoding-temp/bf7880bbcb4e4ff4a58dcb70d5eed19e.ts' at Interop.ThrowExceptionForIoErrno(ErrorInfo errorInfo, String path, Boolean isDirectory, Func`2 errorRewriter) at Microsoft.Win32.SafeHandles.SafeFileHandle.Open(String path, OpenFlags flags, Int32 mode) at System.IO.FileStream.OpenHandle(FileMode mode, FileShare share, FileOptions options) at System.IO.FileStream..ctor(String path, FileMode mode, FileAccess access, FileShare share, Int32 bufferSize, FileOptions options) at Emby.Server.Implementations.IO.ManagedFileSystem.GetFileStream(String path, FileOpenMode mode, FileAccessMode access, FileShareMode share, Int32 bufferSize, FileOpenOptions fileOpenOptions) at Emby.LiveTV.TunerHosts.LiveStream.CopyFile(String path, Boolean seekFile, Int32 emptyReadLimit, PipeWriter writer, IFileSystem fileSystem, IStreamHelper streamHelper, CancellationToken cancellationToken) at Emby.LiveTV.TunerHosts.LiveStream.CopyToAsync(PipeWriter writer, CancellationToken cancellationToken) at Emby.Server.Implementations.Services.ServiceHandler.ProcessRequestAsync(HttpListenerHost appHost, IRequest httpReq, IResponse httpRes, RestPath restPath, String responseContentType, CancellationToken cancellationToken) at Emby.Server.Implementations.HttpServer.HttpListenerHost.RequestHandler(IRequest httpReq, ReadOnlyMemory`1 urlString, ReadOnlyMemory`1 localPath, CancellationToken cancellationToken) Source: System.Private.CoreLib TargetSite: Void ThrowExceptionForIoErrno(ErrorInfo, System.String, Boolean, System.Func`2[Interop+ErrorInfo,Interop+ErrorInfo]) 2022-05-10 14:32:00.510 Info Server: http/1.1 Response 404 to 127.0.0.1. Time: 7ms. http://127.0.0.1:8096/LiveTv/LiveStreamFiles/bf7880bbcb4e4ff4a58dcb70d5eed19e/stream.ts 2022-05-10 14:32:00.516 Info App: AppendExtraLogData - Read graph file: /config/logs/ffmpeg-transcode-109d0027-4d9c-43ac-8873-80b135c0b07f_1graph.txt 2022-05-10 14:32:00.520 Info App: AppendExtraLogData - Deserialized GraphData fileStream: {0:n} bytes Graph Count: 1 2022-05-10 14:32:00.520 Info App: AppendExtraLogData - File Deleted 2022-05-10 14:32:00.521 Info App: ProcessRun 'StreamTranscode 109d00' Process exited with code 1 2022-05-10 14:32:00.526 Error Server: Error processing request *** Error Report *** Version: 4.6.7.0 Command line: /system/EmbyServer.dll -programdata /config -ffdetect /bin/ffdetect -ffmpeg /bin/ffmpeg -ffprobe /bin/ffprobe -restartexitcode 3 Operating system: Linux version 5.15.0-27-generic (buildd@ubuntu) (gcc (Ubuntu 11.2.0-19ubuntu1) 11.2.0, GNU ld (GNU Binutils for Ubuntu) 2.38) #28-Ubuntu SMP Thu Apr 1 Framework: .NET Core 3.1.21 OS/Process: x64/x64 Runtime: system/System.Private.CoreLib.dll Processor count: 3 Data path: /config Application path: /system System.Exception: System.Exception: Error starting ffmpeg at Emby.Server.MediaEncoding.Api.BaseStreamingService.StartFfMpeg(StreamState state, String outputPath, CancellationToken cancellationToken, Boolean acquireResources) at Emby.Server.MediaEncoding.Api.Hls.BaseHlsService.ProcessRequest(StreamRequest request) at Emby.Server.Implementations.Services.ServiceController.GetTaskResult(Task task) at Emby.Server.Implementations.Services.ServiceHandler.ProcessRequestAsync(HttpListenerHost appHost, IRequest httpReq, IResponse httpRes, RestPath restPath, String responseContentType, CancellationToken cancellationToken) at Emby.Server.Implementations.HttpServer.HttpListenerHost.RequestHandler(IRequest httpReq, ReadOnlyMemory`1 urlString, ReadOnlyMemory`1 localPath, CancellationToken cancellationToken) Source: Emby.Server.MediaEncoding TargetSite: Void MoveNext() 2022-05-10 14:32:00.527 Info Server: http/1.1 Response 500 to 10.10.0.10. Time: 88ms. http://[redacted-hostname]/emby/videos/2561360/live.m3u8?DeviceId=9b0014dc-06bf-4a0a-8fba-bac2d419bd46&MediaSourceId=0&PlaySessionId=5b68630ba74a477a84e27877bd21132a&LiveStreamId=06044cf0e6f93cdae5f285c9ecfaaeb4_41c95b6de5174f82acbc56fe82d0a2f8_0&VideoCodec=h264&AudioCodec=aac&VideoBitrate=139808000&AudioBitrate=192000&TranscodingMaxAudioChannels=2&SegmentContainer=ts&MinSegments=1&BreakOnNonKeyFrames=True&ManifestSubtitles=vtt&h264-profile=high,main,baseline,constrainedbaseline&h264-level=52&TranscodeReasons=ContainerNotSupported,DirectPlayError&allowVideoStreamCopy=false&allowAudioStreamCopy=false 2022-05-10 14:32:00.592 Info Server: http/1.1 OPTIONS http://[redacted-hostname]/emby/Sessions/Playing/Stopped?X-Emby-Client=Emby Web&X-Emby-Device-Name=Firefox Windows&X-Emby-Device-Id=9b0014dc-06bf-4a0a-8fba-bac2d419bd46&X-Emby-Client-Version=4.7.0.9. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:99.0) Gecko/20100101 Firefox/99.0 2022-05-10 14:32:00.592 Info Server: http/1.1 Response 200 to 10.10.0.10. Time: 0ms. http://[redacted-hostname]/emby/Sessions/Playing/Stopped?X-Emby-Client=Emby Web&X-Emby-Device-Name=Firefox Windows&X-Emby-Device-Id=9b0014dc-06bf-4a0a-8fba-bac2d419bd46&X-Emby-Client-Version=4.7.0.9 2022-05-10 14:32:00.593 Info Server: http/1.1 OPTIONS http://[redacted-hostname]/emby/Videos/ActiveEncodings?deviceId=9b0014dc-06bf-4a0a-8fba-bac2d419bd46&PlaySessionId=b40a2b0ed89b49b9a8c8f0dbffc12059&X-Emby-Client=Emby Web&X-Emby-Device-Name=Firefox Windows&X-Emby-Device-Id=9b0014dc-06bf-4a0a-8fba-bac2d419bd46&X-Emby-Client-Version=4.7.0.9. Accept=*/*, Accept-Encoding=gzip, deflate, br, Accept-Language=nl,en-US;q=0.7,en;q=0.3, Host=[redacted-hostname], Referer=https://app.emby.media/, User-Agent=Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:99.0) Gecko/20100101 Firefox/99.0, DNT=1, Origin=https://app.emby.media, Access-Control-Request-Method=DELETE, X-Real-IP=10.10.0.10, X-Forwarded-For=10.10.0.10, sec-fetch-dest=empty, sec-fetch-mode=cors, sec-fetch-site=cross-site 2022-05-10 14:32:00.593 Info Server: http/1.1 Response 200 to 10.10.0.10. Time: 0ms. http://[redacted-hostname]/emby/Videos/ActiveEncodings?deviceId=9b0014dc-06bf-4a0a-8fba-bac2d419bd46&PlaySessionId=b40a2b0ed89b49b9a8c8f0dbffc12059&X-Emby-Client=Emby Web&X-Emby-Device-Name=Firefox Windows&X-Emby-Device-Id=9b0014dc-06bf-4a0a-8fba-bac2d419bd46&X-Emby-Client-Version=4.7.0.9 2022-05-10 14:32:00.636 Info Server: http/1.1 POST http://[redacted-hostname]/emby/Sessions/Playing/Stopped?X-Emby-Client=Emby Web&X-Emby-Device-Name=Firefox Windows&X-Emby-Device-Id=9b0014dc-06bf-4a0a-8fba-bac2d419bd46&X-Emby-Client-Version=4.7.0.9. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:99.0) Gecko/20100101 Firefox/99.0 2022-05-10 14:32:00.636 Info Server: http/1.1 DELETE http://[redacted-hostname]/emby/Videos/ActiveEncodings?deviceId=9b0014dc-06bf-4a0a-8fba-bac2d419bd46&PlaySessionId=b40a2b0ed89b49b9a8c8f0dbffc12059&X-Emby-Client=Emby Web&X-Emby-Device-Name=Firefox Windows&X-Emby-Device-Id=9b0014dc-06bf-4a0a-8fba-bac2d419bd46&X-Emby-Client-Version=4.7.0.9. Accept=*/*, Accept-Encoding=gzip, deflate, br, Accept-Language=nl,en-US;q=0.7,en;q=0.3, Host=[redacted-hostname], Referer=https://app.emby.media/, User-Agent=Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:99.0) Gecko/20100101 Firefox/99.0, DNT=1, Origin=https://app.emby.media, X-Real-IP=10.10.0.10, X-Forwarded-For=10.10.0.10, sec-fetch-dest=empty, sec-fetch-mode=cors, sec-fetch-site=cross-site 2022-05-10 14:32:00.637 Info Server: http/1.1 Response 204 to 10.10.0.10. Time: 1ms. http://[redacted-hostname]/emby/Videos/ActiveEncodings?deviceId=9b0014dc-06bf-4a0a-8fba-bac2d419bd46&PlaySessionId=b40a2b0ed89b49b9a8c8f0dbffc12059&X-Emby-Client=Emby Web&X-Emby-Device-Name=Firefox Windows&X-Emby-Device-Id=9b0014dc-06bf-4a0a-8fba-bac2d419bd46&X-Emby-Client-Version=4.7.0.9 2022-05-10 14:32:00.644 Info SessionManager: Playback stopped reported by app Emby Web 4.7.0.9 playing NPO 1 HD. Stopped at 0 ms 2022-05-10 14:32:00.647 Info MediaSourceManager: Live stream null consumer count is now 0 2022-05-10 14:32:00.647 Info MediaSourceManager: Closing live stream 06044cf0e6f93cdae5f285c9ecfaaeb4_41c95b6de5174f82acbc56fe82d0a2f8_0 2022-05-10 14:32:00.647 Info SharedHttpPipelineSource: Closing SharedHttpPipelineSource 2022-05-10 14:32:00.650 Info MediaSourceManager: Live stream 06044cf0e6f93cdae5f285c9ecfaaeb4_41c95b6de5174f82acbc56fe82d0a2f8_0 closed successfully 2022-05-10 14:32:00.651 Info Server: http/1.1 Response 204 to 10.10.0.10. Time: 15ms. http://[redacted-hostname]/emby/Sessions/Playing/Stopped?X-Emby-Client=Emby Web&X-Emby-Device-Name=Firefox Windows&X-Emby-Device-Id=9b0014dc-06bf-4a0a-8fba-bac2d419bd46&X-Emby-Client-Version=4.7.0.9 2022-05-10 14:32:04.348 Info Server: http/1.1 GET http://[redacted-hostname]/emby/System/ActivityLog/Entries?StartIndex=0&Limit=10&MinDate=2022-05-03T12:32:03.551Z&hasUserId=true&X-Emby-Client=Emby Web&X-Emby-Device-Name=Firefox Windows&X-Emby-Device-Id=9b0014dc-06bf-4a0a-8fba-bac2d419bd46&X-Emby-Client-Version=4.7.0.10. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:99.0) Gecko/20100101 Firefox/99.0 2022-05-10 14:32:04.354 Info Server: http/1.1 GET http://[redacted-hostname]/emby/System/ActivityLog/Entries?StartIndex=0&Limit=4&MinDate=2022-05-03T12:32:03.552Z&hasUserId=false&X-Emby-Client=Emby Web&X-Emby-Device-Name=Firefox Windows&X-Emby-Device-Id=9b0014dc-06bf-4a0a-8fba-bac2d419bd46&X-Emby-Client-Version=4.7.0.10. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:99.0) Gecko/20100101 Firefox/99.0 2022-05-10 14:32:04.354 Info Server: http/1.1 GET http://[redacted-hostname]/emby/System/ActivityLog/Entries?StartIndex=0&Limit=10&MinDate=2022-05-03T12:32:03.554Z&hasUserId=true&X-Emby-Client=Emby Web&X-Emby-Device-Name=Firefox Windows&X-Emby-Device-Id=9b0014dc-06bf-4a0a-8fba-bac2d419bd46&X-Emby-Client-Version=4.7.0.10. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:99.0) Gecko/20100101 Firefox/99.0 2022-05-10 14:32:04.363 Info Server: http/1.1 Response 200 to 10.10.0.10. Time: 15ms. http://[redacted-hostname]/emby/System/ActivityLog/Entries?StartIndex=0&Limit=10&MinDate=2022-05-03T12:32:03.551Z&hasUserId=true&X-Emby-Client=Emby Web&X-Emby-Device-Name=Firefox Windows&X-Emby-Device-Id=9b0014dc-06bf-4a0a-8fba-bac2d419bd46&X-Emby-Client-Version=4.7.0.10 2022-05-10 14:32:04.363 Info Server: http/1.1 Response 200 to 10.10.0.10. Time: 10ms. http://[redacted-hostname]/emby/System/ActivityLog/Entries?StartIndex=0&Limit=4&MinDate=2022-05-03T12:32:03.552Z&hasUserId=false&X-Emby-Client=Emby Web&X-Emby-Device-Name=Firefox Windows&X-Emby-Device-Id=9b0014dc-06bf-4a0a-8fba-bac2d419bd46&X-Emby-Client-Version=4.7.0.10 2022-05-10 14:32:04.364 Info Server: http/1.1 Response 200 to 10.10.0.10. Time: 10ms. http://[redacted-hostname]/emby/System/ActivityLog/Entries?StartIndex=0&Limit=10&MinDate=2022-05-03T12:32:03.554Z&hasUserId=true&X-Emby-Client=Emby Web&X-Emby-Device-Name=Firefox Windows&X-Emby-Device-Id=9b0014dc-06bf-4a0a-8fba-bac2d419bd46&X-Emby-Client-Version=4.7.0.10 2022-05-10 14:32:04.588 Info Server: http/1.1 GET http://[redacted-hostname]/emby/System/ActivityLog/Entries?StartIndex=0&Limit=10&MinDate=2022-05-03T12:32:03.798Z&hasUserId=true&X-Emby-Client=Emby Web&X-Emby-Device-Name=Firefox Windows&X-Emby-Device-Id=9b0014dc-06bf-4a0a-8fba-bac2d419bd46&X-Emby-Client-Version=4.7.0.9. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:99.0) Gecko/20100101 Firefox/99.0 2022-05-10 14:32:04.592 Info Server: http/1.1 Response 200 to 10.10.0.10. Time: 3ms. http://[redacted-hostname]/emby/System/ActivityLog/Entries?StartIndex=0&Limit=10&MinDate=2022-05-03T12:32:03.798Z&hasUserId=true&X-Emby-Client=Emby Web&X-Emby-Device-Name=Firefox Windows&X-Emby-Device-Id=9b0014dc-06bf-4a0a-8fba-bac2d419bd46&X-Emby-Client-Version=4.7.0.9 2022-05-10 14:32:04.596 Info Server: http/1.1 GET http://[redacted-hostname]/emby/System/ActivityLog/Entries?StartIndex=0&Limit=4&MinDate=2022-05-03T12:32:03.798Z&hasUserId=false&X-Emby-Client=Emby Web&X-Emby-Device-Name=Firefox Windows&X-Emby-Device-Id=9b0014dc-06bf-4a0a-8fba-bac2d419bd46&X-Emby-Client-Version=4.7.0.9. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:99.0) Gecko/20100101 Firefox/99.0 2022-05-10 14:32:04.598 Info Server: http/1.1 Response 200 to 10.10.0.10. Time: 2ms. http://[redacted-hostname]/emby/System/ActivityLog/Entries?StartIndex=0&Limit=4&MinDate=2022-05-03T12:32:03.798Z&hasUserId=false&X-Emby-Client=Emby Web&X-Emby-Device-Name=Firefox Windows&X-Emby-Device-Id=9b0014dc-06bf-4a0a-8fba-bac2d419bd46&X-Emby-Client-Version=4.7.0.9 2022-05-10 14:32:05.362 Info Server: http/1.1 GET http://[redacted-hostname]/emby/System/ActivityLog/Entries?StartIndex=0&Limit=4&MinDate=2022-05-03T12:32:04.561Z&hasUserId=false&X-Emby-Client=Emby Web&X-Emby-Device-Name=Firefox Windows&X-Emby-Device-Id=9b0014dc-06bf-4a0a-8fba-bac2d419bd46&X-Emby-Client-Version=4.7.0.10. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:99.0) Gecko/20100101 Firefox/99.0 2022-05-10 14:32:05.364 Info Server: http/1.1 Response 200 to 10.10.0.10. Time: 2ms. http://[redacted-hostname]/emby/System/ActivityLog/Entries?StartIndex=0&Limit=4&MinDate=2022-05-03T12:32:04.561Z&hasUserId=false&X-Emby-Client=Emby Web&X-Emby-Device-Name=Firefox Windows&X-Emby-Device-Id=9b0014dc-06bf-4a0a-8fba-bac2d419bd46&X-Emby-Client-Version=4.7.0.10 2022-05-10 14:32:08.157 Info Server: http/1.1 GET http://[redacted-hostname]/emby/System/Logs/embyserver.txt?Sanitize=true. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:99.0) Gecko/20100101 Firefox/99.0 TvHeadend: 2022-05-10 14:29:34.421 htsp: Got connection from 127.0.0.1 2022-05-10 14:29:34.430 htsp: 127.0.0.1: Identified as user 'Emby' (unverified) 2022-05-10 14:29:34.430 htsp: 127.0.0.1 [ Emby ]: Welcomed client software: TVHclient4Emby-4.6.7.0 (HTSPv20) 2022-05-10 14:29:34.434 htsp: 127.0.0.1 [ Emby | TVHclient4Emby-4.6.7.0 ]: Identified as user 'Emby' 2022-05-10 14:29:34.434 htsp: 127.0.0.1 [ Emby | TVHclient4Emby-4.6.7.0 ]: Privileges updated 2022-05-10 14:30:25.470 htsp: 127.0.0.1 [ Emby | TVHclient4Emby-4.6.7.0 ]: Disconnected 2022-05-10 14:31:39.841 htsp: Got connection from 127.0.0.1 2022-05-10 14:31:39.851 htsp: 127.0.0.1: Identified as user 'Emby' (unverified) 2022-05-10 14:31:39.851 htsp: 127.0.0.1 [ Emby ]: Welcomed client software: TVHclient4Emby-4.6.7.0 (HTSPv20) 2022-05-10 14:31:39.855 htsp: 127.0.0.1 [ Emby | TVHclient4Emby-4.6.7.0 ]: Identified as user 'Emby' 2022-05-10 14:31:39.855 htsp: 127.0.0.1 [ Emby | TVHclient4Emby-4.6.7.0 ]: Privileges updated 2022-05-10 14:31:39.931 mpegts: 386MHz in Ziggo - tuning on Minisatip DVB-C Tuner #1 (10.10.0.86@TCP) 2022-05-10 14:31:39.932 subscription: 01A4: "HTTP" subscribing on channel "NPO 1 HD", weight: 100, adapter: "Minisatip DVB-C Tuner #1 (10.10.0.86@TCP)", network: "Ziggo", mux: "386MHz", provider: "Ziggo", service: "NPO 1 HD", profile="pass", hostname="127.0.0.1", username="Emby" 2022-05-10 14:31:56.273 TS: Ziggo/386MHz/NPO 1 HD: H264 @ #2001 Continuity counter error (total 1) 2022-05-10 14:31:56.273 TS: Ziggo/386MHz/NPO 1 HD: MPEG2AUDIO @ #2013 Continuity counter error (total 1) 2022-05-10 14:31:56.273 TS: Ziggo/386MHz/NPO 1 HD: MPEG2AUDIO @ #2011 Continuity counter error (total 1) 2022-05-10 14:31:56.273 TS: Ziggo/386MHz/NPO 1 HD: TELETEXT @ #2101 Continuity counter error (total 1) 2022-05-10 14:31:56.273 TS: Ziggo/386MHz/NPO 1 HD: AC3 @ #2012 Continuity counter error (total 1) 2022-05-10 14:31:57.420 subscription: 01A4: "HTTP" unsubscribing from "NPO 1 HD", hostname="127.0.0.1", username="Emby" What did i verify: TvHeadend works and http://Emby:[redacted-tvheadend-password]@127.0.0.1:9981/stream/channelid/1487494759 returns infinite amounts of data. Channels, Icons and Guide all are being loaded successfully. /data/EmbyTranscoding/transcoding-temp/ is writeable. So... What else should I check? Edited May 10, 2022 by Groentjuh
Luke 42241 Posted May 10, 2022 Posted May 10, 2022 2 hours ago, Groentjuh said: I recently also got issues with the TVHeadend plugin. It used to work fine, so I wonder if an update on Emby OR TVHeadend possibly broke something. Can someone give me some pointers what I should look into. I do not believe this is a authentication issue, because both sides seem to log correct authentication. The tuner will also start tuning to the correct channel, but will be cancelled soon after. Logs in the spoiler: Reveal hidden contents Embyserver logs: 2022-05-10 14:30:25.580 Info Main: Application path: /system/EmbyServer.dll 2022-05-10 14:30:25.777 Info Main: Emby Command line: /system/EmbyServer.dll -programdata /config -ffdetect /bin/ffdetect -ffmpeg /bin/ffmpeg -ffprobe /bin/ffprobe -restartexitcode 3 Operating system: Linux version 5.15.0-27-generic (buildd@ubuntu) (gcc (Ubuntu 11.2.0-19ubuntu1) 11.2.0, GNU ld (GNU Binutils for Ubuntu) 2.38) #28-Ubuntu SMP Thu Apr 1 Framework: .NET Core 3.1.21 OS/Process: x64/x64 Runtime: system/System.Private.CoreLib.dll Processor count: 3 Data path: /config Application path: /system 2022-05-10 14:30:25.777 Info Main: Logs path: /config/logs 2022-05-10 14:30:25.777 Info Main: Cache path: /config/cache 2022-05-10 14:30:25.777 Info Main: Internal metadata path: /config/metadata 2022-05-10 14:30:25.777 Info Main: Transcoding temporary files path: /config/transcoding-temp 2022-05-10 14:30:25.806 Info App: Application version: 4.6.7.0 2022-05-10 14:30:25.808 Info App: Loading assemblies 2022-05-10 14:30:25.839 Info App: File /config/plugins/NfoMetadata.dll has version 1.0.56.0 2022-05-10 14:30:25.839 Info App: File /system/plugins/NfoMetadata.dll has version 1.0.56.0 2022-05-10 14:30:25.839 Info App: File /config/plugins/StudioImages.dll has version 1.0.3.0 2022-05-10 14:30:25.840 Info App: File /system/plugins/StudioImages.dll has version 1.0.3.0 2022-05-10 14:30:25.840 Info App: File /config/plugins/Emby.Server.CinemaMode.dll has version 1.0.38.0 2022-05-10 14:30:25.840 Info App: File /system/plugins/Emby.Server.CinemaMode.dll has version 1.0.38.0 2022-05-10 14:30:25.840 Info App: File /config/plugins/Fanart.dll has version 1.0.13.0 2022-05-10 14:30:25.840 Info App: File /system/plugins/Fanart.dll has version 1.0.13.0 2022-05-10 14:30:25.840 Info App: File /config/plugins/OpenSubtitles.dll has version 1.0.28.0 2022-05-10 14:30:25.841 Info App: File /system/plugins/OpenSubtitles.dll has version 1.0.28.0 2022-05-10 14:30:25.841 Info App: File /config/plugins/Emby.Webhooks.dll has version 1.0.15.0 2022-05-10 14:30:25.841 Info App: File /system/plugins/Emby.Webhooks.dll has version 1.0.15.0 2022-05-10 14:30:25.841 Info App: File /config/plugins/Emby.PortMapper.dll has version 1.0.9.0 2022-05-10 14:30:25.841 Info App: File /system/plugins/Emby.PortMapper.dll has version 1.0.6.0 2022-05-10 14:30:25.841 Info App: File /config/plugins/OMDb.dll has version 1.0.14.0 2022-05-10 14:30:25.841 Info App: File /system/plugins/OMDb.dll has version 1.0.14.0 2022-05-10 14:30:25.842 Info App: File /config/plugins/Emby.Dlna.dll has version 1.0.69.0 2022-05-10 14:30:25.842 Info App: File /system/plugins/Emby.Dlna.dll has version 1.0.69.0 2022-05-10 14:30:25.842 Info App: File /config/plugins/AudioDb.dll has version 1.0.14.0 2022-05-10 14:30:25.842 Info App: File /system/plugins/AudioDb.dll has version 1.0.14.0 2022-05-10 14:30:25.843 Info App: File /config/plugins/DvdMounter.dll has version 1.0.0.0 2022-05-10 14:30:25.843 Info App: File /system/plugins/DvdMounter.dll has version 1.0.0.0 2022-05-10 14:30:25.843 Info App: File /config/plugins/Tvdb.dll has version 1.0.42.0 2022-05-10 14:30:25.843 Info App: File /system/plugins/Tvdb.dll has version 1.0.42.0 2022-05-10 14:30:25.843 Info App: File /config/plugins/MusicBrainz.dll has version 1.0.18.0 2022-05-10 14:30:25.843 Info App: File /system/plugins/MusicBrainz.dll has version 1.0.17.0 2022-05-10 14:30:25.844 Info App: File /config/plugins/BlurayMounter.dll has version 1.0.0.0 2022-05-10 14:30:25.844 Info App: File /system/plugins/BlurayMounter.dll has version 1.0.0.0 2022-05-10 14:30:25.844 Info App: File /config/plugins/MovieDb.dll has version 1.5.2.0 2022-05-10 14:30:25.844 Info App: File /system/plugins/MovieDb.dll has version 1.5.1.0 2022-05-10 14:30:25.852 Info App: Loading NfoMetadata, Version=1.0.56.0, Culture=neutral, PublicKeyToken=null from /config/plugins/NfoMetadata.dll 2022-05-10 14:30:25.852 Info App: Loading StudioImages, Version=1.0.3.0, Culture=neutral, PublicKeyToken=null from /config/plugins/StudioImages.dll 2022-05-10 14:30:25.853 Info App: Loading Emby.Server.CinemaMode, Version=1.0.38.0, Culture=neutral, PublicKeyToken=null from /config/plugins/Emby.Server.CinemaMode.dll 2022-05-10 14:30:25.853 Info App: Loading Fanart, Version=1.0.13.0, Culture=neutral, PublicKeyToken=null from /config/plugins/Fanart.dll 2022-05-10 14:30:25.853 Info App: Loading OpenSubtitles, Version=1.0.28.0, Culture=neutral, PublicKeyToken=null from /config/plugins/OpenSubtitles.dll 2022-05-10 14:30:25.853 Info App: Loading Emby.Webhooks, Version=1.0.15.0, Culture=neutral, PublicKeyToken=null from /config/plugins/Emby.Webhooks.dll 2022-05-10 14:30:25.853 Info App: Loading Emby.PortMapper, Version=1.0.9.0, Culture=neutral, PublicKeyToken=null from /config/plugins/Emby.PortMapper.dll 2022-05-10 14:30:25.853 Info App: Loading OMDb, Version=1.0.14.0, Culture=neutral, PublicKeyToken=null from /config/plugins/OMDb.dll 2022-05-10 14:30:25.853 Info App: Loading Emby.Kodi.SyncQueue, Version=2.2.0.0, Culture=neutral, PublicKeyToken=null from /config/plugins/Emby.Kodi.SyncQueue.dll 2022-05-10 14:30:25.853 Info App: Loading Emby.Dlna, Version=1.0.69.0, Culture=neutral, PublicKeyToken=null from /config/plugins/Emby.Dlna.dll 2022-05-10 14:30:25.853 Info App: Loading AudioDb, Version=1.0.14.0, Culture=neutral, PublicKeyToken=null from /config/plugins/AudioDb.dll 2022-05-10 14:30:25.853 Info App: Loading DvdMounter, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null from /config/plugins/DvdMounter.dll 2022-05-10 14:30:25.853 Info App: Loading Tvdb, Version=1.0.42.0, Culture=neutral, PublicKeyToken=null from /config/plugins/Tvdb.dll 2022-05-10 14:30:25.853 Info App: Loading MusicBrainz, Version=1.0.18.0, Culture=neutral, PublicKeyToken=null from /config/plugins/MusicBrainz.dll 2022-05-10 14:30:25.854 Info App: Loading TVHeadEnd, Version=1.4.6.0, Culture=neutral, PublicKeyToken=null from /config/plugins/TVHeadEnd.dll 2022-05-10 14:30:25.854 Info App: Loading BlurayMounter, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null from /config/plugins/BlurayMounter.dll 2022-05-10 14:30:25.854 Info App: Loading MovieDb, Version=1.5.2.0, Culture=neutral, PublicKeyToken=null from /config/plugins/MovieDb.dll 2022-05-10 14:30:25.854 Info App: Loading Emby.Api, Version=4.6.7.0, Culture=neutral, PublicKeyToken=null 2022-05-10 14:30:25.854 Info App: Loading Emby.Web, Version=4.6.7.0, Culture=neutral, PublicKeyToken=null 2022-05-10 14:30:25.854 Info App: Loading MediaBrowser.Model, Version=4.6.7.0, Culture=neutral, PublicKeyToken=null 2022-05-10 14:30:25.854 Info App: Loading MediaBrowser.Common, Version=4.6.7.0, Culture=neutral, PublicKeyToken=null 2022-05-10 14:30:25.854 Info App: Loading MediaBrowser.Controller, Version=4.6.7.0, Culture=neutral, PublicKeyToken=null 2022-05-10 14:30:25.854 Info App: Loading Emby.Providers, Version=4.6.7.0, Culture=neutral, PublicKeyToken=null 2022-05-10 14:30:25.854 Info App: Loading Emby.Photos, Version=4.6.7.0, Culture=neutral, PublicKeyToken=null 2022-05-10 14:30:25.854 Info App: Loading Emby.Server.Implementations, Version=4.6.7.0, Culture=neutral, PublicKeyToken=null 2022-05-10 14:30:25.855 Info App: Loading Emby.LiveTV, Version=4.6.7.0, Culture=neutral, PublicKeyToken=null 2022-05-10 14:30:25.855 Info App: Loading Emby.ActivityLog, Version=4.6.7.0, Culture=neutral, PublicKeyToken=null 2022-05-10 14:30:25.855 Info App: Loading Emby.Server.MediaEncoding, Version=4.6.7.0, Culture=neutral, PublicKeyToken=null 2022-05-10 14:30:25.855 Info App: Loading Emby.LocalMetadata, Version=4.6.7.0, Culture=neutral, PublicKeyToken=null 2022-05-10 14:30:25.855 Info App: Loading Emby.Notifications, Version=4.6.7.0, Culture=neutral, PublicKeyToken=null 2022-05-10 14:30:25.855 Info App: Loading Emby.Codecs.Dxva, Version=4.6.7.0, Culture=neutral, PublicKeyToken=null 2022-05-10 14:30:25.855 Info App: Loading Emby.Codecs, Version=4.6.7.0, Culture=neutral, PublicKeyToken=null 2022-05-10 14:30:25.855 Info App: Loading Emby.Server.Connect, Version=4.6.7.0, Culture=neutral, PublicKeyToken=null 2022-05-10 14:30:25.855 Info App: Loading Emby.Server.Sync, Version=4.6.7.0, Culture=neutral, PublicKeyToken=null 2022-05-10 14:30:25.855 Info App: Loading EmbyServer, Version=4.6.7.0, Culture=neutral, PublicKeyToken=null 2022-05-10 14:30:25.990 Info SqliteUserRepository: Sqlite version: 3.35.5 2022-05-10 14:30:25.991 Info SqliteUserRepository: Sqlite compiler options: COMPILER=gcc-8.3.0,ENABLE_COLUMN_METADATA,ENABLE_DBSTAT_VTAB,ENABLE_FTS3_PARENTHESIS,ENABLE_FTS3_TOKENIZER,ENABLE_FTS4,ENABLE_FTS5,ENABLE_GEOPOLY,ENABLE_JSON1,ENABLE_MATH_FUNCTIONS,ENABLE_PREUPDATE_HOOK,ENABLE_RTREE,ENABLE_SESSION,ENABLE_UNLOCK_NOTIFY,ENABLE_UPDATE_DELETE_LIMIT,LIKE_DOESNT_MATCH_BLOBS,MAX_SCHEMA_RETRY=25,MAX_VARIABLE_NUMBER=250000,OMIT_LOOKASIDE,SECURE_DELETE,THREADSAFE=1 2022-05-10 14:30:26.004 Info SqliteUserRepository: Default journal_mode for /config/data/users.db is wal 2022-05-10 14:30:26.034 Info AuthenticationRepository: Default journal_mode for /config/data/authentication.db is wal 2022-05-10 14:30:26.076 Info ActivityRepository: Default journal_mode for /config/data/activitylog.db is wal 2022-05-10 14:30:26.080 Info SqliteDisplayPreferencesRepository: Default journal_mode for /config/data/displaypreferences.db is wal 2022-05-10 14:30:26.089 Info App: Adding HttpListener prefix http://+:8096/ 2022-05-10 14:30:26.089 Info App: Adding HttpListener prefix https://+:8920/ 2022-05-10 14:30:26.255 Info SqliteItemRepository: Default journal_mode for /config/data/library.db is wal 2022-05-10 14:30:26.256 Info SqliteItemRepository: cache_size is -98304 2022-05-10 14:30:26.256 Info SqliteItemRepository: page_size is 4096 2022-05-10 14:30:26.588 Info Server: http/1.1 GET http://[redacted-hostname]/emby/system/info/public. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:99.0) Gecko/20100101 Firefox/99.0 2022-05-10 14:30:26.617 Info Server: http/1.1 Response 503 to 10.10.0.10. Time: 43ms. http://[redacted-hostname]/emby/system/info/public 2022-05-10 14:30:27.026 Info App: [TVHclient] LiveTvService() 2022-05-10 14:30:27.027 Info App: [TVHclient] HTSConnectionHandler() 2022-05-10 14:30:27.065 Info FfmpegManager: FFMpeg: /bin/ffmpeg 2022-05-10 14:30:27.065 Info FfmpegManager: FFProbe: /bin/ffprobe 2022-05-10 14:30:27.065 Info FfmpegManager: FFDetect: /bin/ffdetect 2022-05-10 14:30:27.069 Info Skia: SkiaSharp version: 2.80.0.0 2022-05-10 14:30:27.101 Info TaskManager: Daily trigger for Thumbnail image extraction set to fire at 05/11/2022 02:00:00, which is 689.54831948 minutes from now. 2022-05-10 14:30:27.104 Info TaskManager: Daily trigger for Rotate log file set to fire at 05/11/2022 00:00:00, which is 569.548255345 minutes from now. 2022-05-10 14:30:27.112 Info App: ServerId: f6c778afb46f4b90b6ca5dee04215f1a 2022-05-10 14:30:27.162 Info App: Starting entry point Emby.Dlna.Main.DlnaEntryPoint 2022-05-10 14:30:27.181 Info Dlna: Registering publisher for urn:schemas-upnp-org:device:MediaServer:1 2022-05-10 14:30:27.248 Info App: Entry point completed: Emby.Dlna.Main.DlnaEntryPoint. Duration: 0.0856596 seconds 2022-05-10 14:30:27.248 Info App: Starting entry point Emby.Server.Connect.ConnectEntryPoint 2022-05-10 14:30:27.249 Info App: Loading data from /config/data/connect.txt 2022-05-10 14:30:27.254 Info App: Loading data from /config/data/wan.dat 2022-05-10 14:30:27.255 Info App: Entry point completed: Emby.Server.Connect.ConnectEntryPoint. Duration: 0.0073337 seconds 2022-05-10 14:30:27.255 Info App: Core startup complete 2022-05-10 14:30:27.255 Info App: Post-init migrations complete 2022-05-10 14:30:27.255 Info App: Starting entry point NfoMetadata.EntryPoint 2022-05-10 14:30:27.256 Info App: Entry point completed: NfoMetadata.EntryPoint. Duration: 0.0005072 seconds 2022-05-10 14:30:27.256 Info App: Starting entry point Emby.Security.PluginSecurityManager 2022-05-10 14:30:27.256 Info App: Entry point completed: Emby.Security.PluginSecurityManager. Duration: 2.65E-05 seconds 2022-05-10 14:30:27.256 Info App: Starting entry point Emby.Server.CinemaMode.IntrosEntryPoint 2022-05-10 14:30:27.256 Info App: Entry point completed: Emby.Server.CinemaMode.IntrosEntryPoint. Duration: 0.0001775 seconds 2022-05-10 14:30:27.256 Info App: Starting entry point Emby.Webhooks.WebhooksEntryPoint 2022-05-10 14:30:27.258 Info App: Entry point completed: Emby.Webhooks.WebhooksEntryPoint. Duration: 0.0016715 seconds 2022-05-10 14:30:27.258 Info App: Starting entry point Emby.PortMapper.ExternalPortForwarding 2022-05-10 14:30:27.259 Info App: Entry point completed: Emby.PortMapper.ExternalPortForwarding. Duration: 0.0005775 seconds 2022-05-10 14:30:27.259 Info App: Starting entry point Emby.Kodi.SyncQueue.EntryPoints.LibrarySyncNotification 2022-05-10 14:30:27.259 Info App: Entry point completed: Emby.Kodi.SyncQueue.EntryPoints.LibrarySyncNotification. Duration: 0.0006733 seconds 2022-05-10 14:30:27.259 Info App: Starting entry point MediaBrowser.Api.ApiEntryPoint 2022-05-10 14:30:27.259 Info App: Entry point completed: MediaBrowser.Api.ApiEntryPoint. Duration: 2.65E-05 seconds 2022-05-10 14:30:27.260 Info App: Starting entry point Emby.Server.Implementations.Udp.UdpServerEntryPoint 2022-05-10 14:30:27.261 Info App: Entry point completed: Emby.Server.Implementations.Udp.UdpServerEntryPoint. Duration: 0.0010209 seconds 2022-05-10 14:30:27.261 Info App: Starting entry point Emby.Server.Implementations.News.NewsEntryPoint 2022-05-10 14:30:27.261 Info App: Entry point completed: Emby.Server.Implementations.News.NewsEntryPoint. Duration: 0.0002232 seconds 2022-05-10 14:30:27.261 Info App: Starting entry point Emby.Server.Implementations.Library.DeviceAccessEntryPoint 2022-05-10 14:30:27.261 Info App: Entry point completed: Emby.Server.Implementations.Library.DeviceAccessEntryPoint. Duration: 0.0005984 seconds 2022-05-10 14:30:27.261 Info App: Starting entry point Emby.Server.Implementations.IO.LibraryMonitorStartup 2022-05-10 14:30:27.294 Info App: Init BeginReceive on 0.0.0.0 2022-05-10 14:30:27.294 Info App: Init BeginReceive on 0.0.0.0 2022-05-10 14:30:27.294 Info App: Init BeginReceive on 192.168.178.20 2022-05-10 14:30:27.374 Info Server: http/1.1 GET http://[redacted-hostname]/emby/system/info/public. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:99.0) Gecko/20100101 Firefox/99.0 2022-05-10 14:30:27.410 Info Server: http/1.1 Response 200 to 10.10.0.10. Time: 36ms. http://[redacted-hostname]/emby/system/info/public 2022-05-10 14:30:27.434 Info App: Entry point completed: Emby.Server.Implementations.IO.LibraryMonitorStartup. Duration: 0.1724127 seconds 2022-05-10 14:30:27.434 Info App: Starting entry point Emby.Server.Implementations.EntryPoints.AutomaticRestartEntryPoint 2022-05-10 14:30:27.441 Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.AutomaticRestartEntryPoint. Duration: 0.0065884 seconds 2022-05-10 14:30:27.441 Info App: Starting entry point Emby.Server.Implementations.EntryPoints.KeepServerAwake 2022-05-10 14:30:27.441 Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.KeepServerAwake. Duration: 0.0001894 seconds 2022-05-10 14:30:27.441 Info App: Starting entry point Emby.Server.Implementations.EntryPoints.LibraryChangedNotifier 2022-05-10 14:30:27.442 Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.LibraryChangedNotifier. Duration: 0.0013914 seconds 2022-05-10 14:30:27.442 Info App: Starting entry point Emby.Server.Implementations.EntryPoints.ServerEventNotifier 2022-05-10 14:30:27.444 Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.ServerEventNotifier. Duration: 0.0018697 seconds 2022-05-10 14:30:27.444 Info App: Starting entry point Emby.Server.Implementations.EntryPoints.StartupWizard 2022-05-10 14:30:27.445 Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.StartupWizard. Duration: 0.0003171 seconds 2022-05-10 14:30:27.445 Info App: Starting entry point Emby.Server.Implementations.EntryPoints.SystemEvents 2022-05-10 14:30:27.445 Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.SystemEvents. Duration: 0.0004516 seconds 2022-05-10 14:30:27.445 Info App: Starting entry point Emby.Server.Implementations.EntryPoints.UserDataChangeNotifier 2022-05-10 14:30:27.445 Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.UserDataChangeNotifier. Duration: 0.0001993 seconds 2022-05-10 14:30:27.445 Info App: Starting entry point Emby.Server.Implementations.Channels.ChannelsEntryPoint 2022-05-10 14:30:27.449 Info App: Entry point completed: Emby.Server.Implementations.Channels.ChannelsEntryPoint. Duration: 0.0040473 seconds 2022-05-10 14:30:27.449 Info App: Starting entry point Emby.LiveTV.EntryPoint 2022-05-10 14:30:27.452 Info LiveTV: Loading live tv data from /config/data/livetv/timers [Redacted access exception] 2022-05-10 14:30:27.481 Info LibraryMonitor: Watching directory /data/Movies 2022-05-10 14:30:27.488 Info Server: http/1.1 GET http://[redacted-hostname]/emby/System/Info?X-Emby-Client=Emby Web&X-Emby-Device-Name=Firefox Windows&X-Emby-Device-Id=9b0014dc-06bf-4a0a-8fba-bac2d419bd46&X-Emby-Client-Version=4.7.0.10. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:99.0) Gecko/20100101 Firefox/99.0 2022-05-10 14:30:27.490 Info App: Entry point completed: Emby.LiveTV.EntryPoint. Duration: 0.040676 seconds 2022-05-10 14:30:27.490 Info App: Starting entry point Emby.LiveTV.UpgradeChannelOptionsEntryPoint 2022-05-10 14:30:27.493 Info App: Entry point completed: Emby.LiveTV.UpgradeChannelOptionsEntryPoint. Duration: 0.0026412 seconds 2022-05-10 14:30:27.493 Info App: Starting entry point Emby.LiveTV.RecordingNotifier 2022-05-10 14:30:27.496 Info App: Entry point completed: Emby.LiveTV.RecordingNotifier. Duration: 0.00317 seconds 2022-05-10 14:30:27.496 Info App: Starting entry point Emby.ActivityLog.ActivityLogEntryPoint 2022-05-10 14:30:27.502 Info App: Entry point completed: Emby.ActivityLog.ActivityLogEntryPoint. Duration: 0.0055583 seconds 2022-05-10 14:30:27.502 Info App: Starting entry point Emby.Server.MediaEncoding.Api.EncodingManagerEntryPoint 2022-05-10 14:30:27.509 Info App: Entry point completed: Emby.Server.MediaEncoding.Api.EncodingManagerEntryPoint. Duration: 0.0069264 seconds 2022-05-10 14:30:27.509 Info App: Starting entry point Emby.Notifications.Notifications 2022-05-10 14:30:27.509 Info App: Entry point completed: Emby.Notifications.Notifications. Duration: 0.0003147 seconds 2022-05-10 14:30:27.509 Info App: Starting entry point Emby.Server.Sync.SyncManagerEntryPoint 2022-05-10 14:30:27.513 Info App: SyncRepository Initialize taking write lock 2022-05-10 14:30:27.513 Info App: SyncRepository Initialize write lock taken 2022-05-10 14:30:27.514 Info App: Entry point completed: Emby.Server.Sync.SyncManagerEntryPoint. Duration: 0.0041147 seconds 2022-05-10 14:30:27.514 Info App: Starting entry point Emby.Server.Sync.SyncNotificationEntryPoint 2022-05-10 14:30:27.515 Info App: Entry point completed: Emby.Server.Sync.SyncNotificationEntryPoint. Duration: 0.0016565 seconds 2022-05-10 14:30:27.515 Info App: Starting entry point EmbyServer.Windows.LoopUtilEntryPoint 2022-05-10 14:30:27.515 Info App: Entry point completed: EmbyServer.Windows.LoopUtilEntryPoint. Duration: 6.29E-05 seconds 2022-05-10 14:30:27.515 Info App: All entry points have started 2022-05-10 14:30:27.598 Info Server: http/1.1 Response 200 to 10.10.0.10. Time: 116ms. http://[redacted-hostname]/emby/System/Info?X-Emby-Client=Emby Web&X-Emby-Device-Name=Firefox Windows&X-Emby-Device-Id=9b0014dc-06bf-4a0a-8fba-bac2d419bd46&X-Emby-Client-Version=4.7.0.10 2022-05-10 14:30:27.747 Info LibraryMonitor: Watching directory /data/Photos 2022-05-10 14:30:27.764 Info HttpClient: GET https://emby.media/community/index.php?/blog/rss/1-media-browser-developers-blog 2022-05-10 14:30:30.138 Info HttpClient: GET https://www.mb3admin.com/admin/service/EmbyPackages.json 2022-05-10 14:30:30.145 Info FfmpegManager: ProcessRun 'ffmpeg -hide_banner -version' Execute: /bin/ffmpeg -hide_banner -version 2022-05-10 14:30:30.165 Info FfmpegManager: ProcessRun 'ffmpeg -hide_banner -version' Process exited with code 0 2022-05-10 14:30:30.244 Info SoftwareCodecProvider: h264, libx264, libx264 Software Encoder, V-E-libx264 2022-05-10 14:30:30.244 Info SoftwareCodecProvider: hevc, libx265, libx265 Software Encoder, V-E-libx265 2022-05-10 14:30:30.244 Info SoftwareCodecProvider: mpeg4, mpeg4, MPEG-4 part 2 Software Encoder, V-E-mpeg4 2022-05-10 14:30:30.244 Info SoftwareCodecProvider: msmpeg4v3, msmpeg4, MPEG-4 part 2 (MS Variant 3) Software Encoder, V-E-msmpeg4 2022-05-10 14:30:30.244 Info SoftwareCodecProvider: vp8, libvpx, libvpx VP8, V-E-libvpx 2022-05-10 14:30:30.247 Info SoftwareCodecProvider: h264, libx264, libx264 Software Encoder, V-E-libx264 2022-05-10 14:30:30.247 Info SoftwareCodecProvider: hevc, libx265, libx265 Software Encoder, V-E-libx265 2022-05-10 14:30:30.247 Info SoftwareCodecProvider: mpeg4, mpeg4, MPEG-4 part 2 Software Encoder, V-E-mpeg4 2022-05-10 14:30:30.247 Info SoftwareCodecProvider: msmpeg4v3, msmpeg4, MPEG-4 part 2 (MS Variant 3) Software Encoder, V-E-msmpeg4 2022-05-10 14:30:30.247 Info SoftwareCodecProvider: vp8, libvpx, libvpx VP8, V-E-libvpx 2022-05-10 14:30:30.298 Info VaapiCodecProvider: ProcessRun 'ffdetect_vaencdec' Execute: /bin/ffdetect -hide_banner -show_program_version -loglevel 48 -show_error -show_log 40 vaencdec -print_format json 2022-05-10 14:30:30.309 Info VaapiCodecProvider: ProcessRun 'ffdetect_vaencdec' Process exited with code 0 2022-05-10 14:30:30.376 Info VaapiCodecProvider: Adapter #0: 'GD 5446' Id:184 (Driver: , Vendor: Cirrus Logic) 2022-05-10 14:30:30.379 Info QuickSyncCodecProvider: ProcessRun 'ffdetect_qsvencdec' Execute: /bin/ffdetect -hide_banner -show_program_version -loglevel 48 -show_error -show_log 40 qsvencdec -print_format json 2022-05-10 14:30:30.391 Info QuickSyncCodecProvider: ProcessRun 'ffdetect_qsvencdec' Process exited with code 0 2022-05-10 14:30:30.448 Info NvidiaCodecProvider: ProcessRun 'ffdetect_nvencdec' Execute: /bin/ffdetect -hide_banner -show_program_version -loglevel 48 -show_error -show_log 40 nvencdec -print_format json 2022-05-10 14:30:30.451 Info NvidiaCodecProvider: ProcessRun 'ffdetect_nvencdec' Process exited with code 1 2022-05-10 14:31:28.110 Info Server: http/1.1 GET http://[redacted-hostname]/emby/System/Logs/embyserver.txt?Sanitize=true. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:99.0) Gecko/20100101 Firefox/99.0 2022-05-10 14:31:28.150 Info Server: http/1.1 Response 200 to 10.10.0.10. Time: 40ms. http://[redacted-hostname]/emby/System/Logs/embyserver.txt?Sanitize=true 2022-05-10 14:31:39.613 Info Server: http/1.1 GET http://[redacted-hostname]/emby/Users/eaf86e9c1dc84101a85a3f1d4eaa9839?X-Emby-Client=Emby Web&X-Emby-Device-Name=Firefox Windows&X-Emby-Device-Id=9b0014dc-06bf-4a0a-8fba-bac2d419bd46&X-Emby-Client-Version=4.7.0.9. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:99.0) Gecko/20100101 Firefox/99.0 2022-05-10 14:31:39.615 Info Server: http/1.1 OPTIONS http://[redacted-hostname]/emby/Items/2561360/PlaybackInfo?UserId=eaf86e9c1dc84101a85a3f1d4eaa9839&StartTimeTicks=0&IsPlayback=true&AutoOpenLiveStream=true&MaxStreamingBitrate=140000000&X-Emby-Client=Emby Web&X-Emby-Device-Name=Firefox Windows&X-Emby-Device-Id=9b0014dc-06bf-4a0a-8fba-bac2d419bd46&X-Emby-Client-Version=4.7.0.9. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:99.0) Gecko/20100101 Firefox/99.0 2022-05-10 14:31:39.615 Info Server: http/1.1 Response 200 to 10.10.0.10. Time: 1ms. http://[redacted-hostname]/emby/Items/2561360/PlaybackInfo?UserId=eaf86e9c1dc84101a85a3f1d4eaa9839&StartTimeTicks=0&IsPlayback=true&AutoOpenLiveStream=true&MaxStreamingBitrate=140000000&X-Emby-Client=Emby Web&X-Emby-Device-Name=Firefox Windows&X-Emby-Device-Id=9b0014dc-06bf-4a0a-8fba-bac2d419bd46&X-Emby-Client-Version=4.7.0.9 2022-05-10 14:31:39.620 Info Server: http/1.1 POST http://[redacted-hostname]/emby/Items/2561360/PlaybackInfo?UserId=eaf86e9c1dc84101a85a3f1d4eaa9839&StartTimeTicks=0&IsPlayback=true&AutoOpenLiveStream=true&MaxStreamingBitrate=140000000&X-Emby-Client=Emby Web&X-Emby-Device-Name=Firefox Windows&X-Emby-Device-Id=9b0014dc-06bf-4a0a-8fba-bac2d419bd46&X-Emby-Client-Version=4.7.0.9. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:99.0) Gecko/20100101 Firefox/99.0 2022-05-10 14:31:39.686 Info NetworkManager: Detected local ip addresses: 10.10.1.20, 192.168.178.20, 127.0.0.1, fe80::f87c:a2ff:fe69:d333%2, 2001:1c00:1401:4c00:7cb7:d7ff:fed9:f61a, fe80::7cb7:d7ff:fed9:f61a%3, ::1 2022-05-10 14:31:39.709 Info Server: http/1.1 Response 200 to 10.10.0.10. Time: 96ms. http://[redacted-hostname]/emby/Users/eaf86e9c1dc84101a85a3f1d4eaa9839?X-Emby-Client=Emby Web&X-Emby-Device-Name=Firefox Windows&X-Emby-Device-Id=9b0014dc-06bf-4a0a-8fba-bac2d419bd46&X-Emby-Client-Version=4.7.0.9 2022-05-10 14:31:39.713 Info Server: http/1.1 GET http://[redacted-hostname]/emby/Users/eaf86e9c1dc84101a85a3f1d4eaa9839?X-Emby-Client=Emby Web&X-Emby-Device-Name=Firefox Windows&X-Emby-Device-Id=9b0014dc-06bf-4a0a-8fba-bac2d419bd46&X-Emby-Client-Version=4.7.0.9. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:99.0) Gecko/20100101 Firefox/99.0 2022-05-10 14:31:39.714 Info Server: http/1.1 Response 200 to 10.10.0.10. Time: 1ms. http://[redacted-hostname]/emby/Users/eaf86e9c1dc84101a85a3f1d4eaa9839?X-Emby-Client=Emby Web&X-Emby-Device-Name=Firefox Windows&X-Emby-Device-Id=9b0014dc-06bf-4a0a-8fba-bac2d419bd46&X-Emby-Client-Version=4.7.0.9 2022-05-10 14:31:39.759 Info App: User policy for Groentjuh. EnablePlaybackRemuxing: True EnableVideoPlaybackTranscoding: True EnableAudioPlaybackTranscoding: True 2022-05-10 14:31:39.811 Info App: RemoteClientBitrateLimit: 25000000, RemoteIp: 10.10.0.10, IsInLocalNetwork: True 2022-05-10 14:31:39.824 Info App: RemoteClientBitrateLimit: 25000000, RemoteIp: 10.10.0.10, IsInLocalNetwork: True 2022-05-10 14:31:39.826 Info App: RemoteClientBitrateLimit: 25000000, RemoteIp: 10.10.0.10, IsInLocalNetwork: True 2022-05-10 14:31:39.831 Info LiveTvManager: Opening channel stream from TVHclient LiveTvService, external channel Id: 1487494759 2022-05-10 14:31:39.837 Info App: [TVHclient] HTSConnectionHandler.ensureConnection() : create new HTS-Connection 2022-05-10 14:31:39.838 Info App: [TVHclient] HTSConnectionHandler.ensureConnection: Used connection parameters: TVH Server = '127.0.0.1'; HTTP Port = '9981'; HTSP Port = '9982'; Web-Root = ''; User = 'Emby'; Password set = 'True' 2022-05-10 14:31:39.839 Info App: [TVHclient] HTSConnectionAsync.open: IPEndPoint = '127.0.0.1:9982'; AddressFamily = 'InterNetwork' 2022-05-10 14:31:39.842 Info App: [TVHclient] HTSConnectionAsync.open: socket connected. 2022-05-10 14:31:39.847 Info App: [TVHclient] HTSConnectionAsync.authenticate: start 2022-05-10 14:31:39.855 Info App: [TVHclient] HTSConnectionAsync.authenticate: authenticated = True 2022-05-10 14:31:39.855 Info App: [TVHclient] HTSConnectionHandler.ensureConnection: connection established True 2022-05-10 14:31:39.916 Info App: [TVHclient] Support for live TV subtitles and multiple audio tracks is enabled. 2022-05-10 14:31:39.916 Info App: [TVHclient] Force video deinterlacing for all channels and recordings is enabled. 2022-05-10 14:31:39.927 Info SharedHttpPipelineSource: Opening SharedHttpPipelineSource Live stream from http://Emby:[redacted-tvheadend-password]@127.0.0.1:9981/stream/channelid/1487494759 2022-05-10 14:31:39.928 Info HttpClient: Found userInfo in url: Emby:[redacted-tvheadend-password] ... url: http://Emby:[redacted-tvheadend-password]@127.0.0.1:9981/stream/channelid/1487494759 2022-05-10 14:31:39.928 Info HttpClient: GET http://Emby:[redacted-tvheadend-password]@127.0.0.1:9981/stream/channelid/1487494759 2022-05-10 14:31:56.275 Info HttpClient: Http response 200 from http://Emby:[redacted-tvheadend-password]@127.0.0.1:9981/stream/channelid/1487494759 after 16346ms. HeadersServer=HTS/tvheadend, Cache-Control=no-cache, Connection=close 2022-05-10 14:31:56.295 Info SharedHttpPipelineSource: Beginning SharedHttpPipelineSource stream to /data/EmbyTranscoding/transcoding-temp/bf7880bbcb4e4ff4a58dcb70d5eed19e.ts 2022-05-10 14:31:56.337 Info LiveTvManager: Live stream opened after 16413.7454ms 2022-05-10 14:31:57.366 Error GraphRunner: GraphRunnerTimestampFixup *** Error Report *** Version: 4.6.7.0 Command line: /system/EmbyServer.dll -programdata /config -ffdetect /bin/ffdetect -ffmpeg /bin/ffmpeg -ffprobe /bin/ffprobe -restartexitcode 3 Operating system: Linux version 5.15.0-27-generic (buildd@ubuntu) (gcc (Ubuntu 11.2.0-19ubuntu1) 11.2.0, GNU ld (GNU Binutils for Ubuntu) 2.38) #28-Ubuntu SMP Thu Apr 1 Framework: .NET Core 3.1.21 OS/Process: x64/x64 Runtime: system/System.Private.CoreLib.dll Processor count: 3 Data path: /config Application path: /system System.AggregateException: System.AggregateException: One or more errors occurred. (Access to the path '/data/EmbyTranscoding/transcoding-temp/bf7880bbcb4e4ff4a58dcb70d5eed19e.ts' is denied.) ---> System.UnauthorizedAccessException: Access to the path '/data/EmbyTranscoding/transcoding-temp/bf7880bbcb4e4ff4a58dcb70d5eed19e.ts' is denied. ---> System.IO.IOException: Permission denied --- End of inner exception stack trace --- at System.IO.FileStream.WriteNative(ReadOnlySpan`1 source) at System.IO.FileStream.FlushWriteBuffer() at System.IO.FileStream.WriteSpan(ReadOnlySpan`1 source) at System.IO.FileStream.Write(Byte[] array, Int32 offset, Int32 count) at Emby.TV.TsProcessor.DataFlow.Output.FileStreamWriter.ProcessPackets(TsPacketGroup tsPackets) at Emby.TV.TsProcessor.Runners.GraphRunnerTimestampFixup.WriteOutput(TsPacketGroup e) at System.Threading.Tasks.Dataflow.ActionBlock`1.ProcessMessage(Action`1 action, KeyValuePair`2 messageWithId) at System.Threading.Tasks.Dataflow.ActionBlock`1.<>c__DisplayClass6_0.<.ctor>b__0(KeyValuePair`2 messageWithId) at System.Threading.Tasks.Dataflow.Internal.TargetCore`1.ProcessMessagesLoopCore() --- End of inner exception stack trace --- Source: TargetSite: No Stack Trace Available InnerException: System.UnauthorizedAccessException: Access to the path '/data/EmbyTranscoding/transcoding-temp/bf7880bbcb4e4ff4a58dcb70d5eed19e.ts' is denied. Source: System.Private.CoreLib TargetSite: Void WriteNative(System.ReadOnlySpan`1[System.Byte]) DataflowMessageValue: Emby.TV.TsProcessor.Model.Packets.TsPacketGroup at System.IO.FileStream.WriteNative(ReadOnlySpan`1 source) at System.IO.FileStream.FlushWriteBuffer() at System.IO.FileStream.WriteSpan(ReadOnlySpan`1 source) at System.IO.FileStream.Write(Byte[] array, Int32 offset, Int32 count) at Emby.TV.TsProcessor.DataFlow.Output.FileStreamWriter.ProcessPackets(TsPacketGroup tsPackets) at Emby.TV.TsProcessor.Runners.GraphRunnerTimestampFixup.WriteOutput(TsPacketGroup e) at System.Threading.Tasks.Dataflow.ActionBlock`1.ProcessMessage(Action`1 action, KeyValuePair`2 messageWithId) at System.Threading.Tasks.Dataflow.ActionBlock`1.<>c__DisplayClass6_0.<.ctor>b__0(KeyValuePair`2 messageWithId) at System.Threading.Tasks.Dataflow.Internal.TargetCore`1.ProcessMessagesLoopCore() InnerException: System.IO.IOException: Permission denied Source: TargetSite: 2022-05-10 14:31:57.367 Error GraphRunner: GraphRunnerTimestampFixup: CloseOutput *** Error Report *** Version: 4.6.7.0 Command line: /system/EmbyServer.dll -programdata /config -ffdetect /bin/ffdetect -ffmpeg /bin/ffmpeg -ffprobe /bin/ffprobe -restartexitcode 3 Operating system: Linux version 5.15.0-27-generic (buildd@ubuntu) (gcc (Ubuntu 11.2.0-19ubuntu1) 11.2.0, GNU ld (GNU Binutils for Ubuntu) 2.38) #28-Ubuntu SMP Thu Apr 1 Framework: .NET Core 3.1.21 OS/Process: x64/x64 Runtime: system/System.Private.CoreLib.dll Processor count: 3 Data path: /config Application path: /system System.UnauthorizedAccessException: System.UnauthorizedAccessException: Access to the path '/data/EmbyTranscoding/transcoding-temp/bf7880bbcb4e4ff4a58dcb70d5eed19e.ts' is denied. ---> System.IO.IOException: Permission denied --- End of inner exception stack trace --- at System.IO.FileStream.WriteNative(ReadOnlySpan`1 source) at System.IO.FileStream.FlushWriteBuffer() at System.IO.FileStream.Dispose(Boolean disposing) at System.IO.Stream.Close() at Emby.TV.TsProcessor.DataFlow.Output.FileStreamWriter.CloseOutput() at Emby.TV.TsProcessor.Runners.GraphRunnerTimestampFixup.RunAsyncFixTimings(CancellationToken cancellationToken1) Source: System.Private.CoreLib TargetSite: Void WriteNative(System.ReadOnlySpan`1[System.Byte]) InnerException: System.IO.IOException: Permission denied Source: TargetSite: 2022-05-10 14:31:57.410 Error SharedHttpPipelineSource: Give up retries copying live stream http://Emby:[redacted-tvheadend-password]@127.0.0.1:9981/stream/channelid/1487494759 *** Error Report *** Version: 4.6.7.0 Command line: /system/EmbyServer.dll -programdata /config -ffdetect /bin/ffdetect -ffmpeg /bin/ffmpeg -ffprobe /bin/ffprobe -restartexitcode 3 Operating system: Linux version 5.15.0-27-generic (buildd@ubuntu) (gcc (Ubuntu 11.2.0-19ubuntu1) 11.2.0, GNU ld (GNU Binutils for Ubuntu) 2.38) #28-Ubuntu SMP Thu Apr 1 Framework: .NET Core 3.1.21 OS/Process: x64/x64 Runtime: system/System.Private.CoreLib.dll Processor count: 3 Data path: /config Application path: /system System.NullReferenceException: System.NullReferenceException: Object reference not set to an instance of an object. at System.IO.Pipelines.Pipe.CommitUnsynchronized() at System.IO.Pipelines.Pipe.PrepareFlush(CompletionData& completionData, ValueTask`1& result, CancellationToken cancellationToken) at System.IO.Pipelines.Pipe.FlushAsync(CancellationToken cancellationToken) at System.IO.Pipelines.Pipe.DefaultPipeWriter.FlushAsync(CancellationToken cancellationToken) at System.IO.Pipelines.PipeWriter.CopyFromAsync(Stream source, CancellationToken cancellationToken) at Emby.LiveTV.TunerHosts.SharedHttpPipelineSource.<>c__DisplayClass8_0.<<StartStreaming>b__0>d.MoveNext() Source: System.IO.Pipelines TargetSite: Boolean CommitUnsynchronized() 2022-05-10 14:31:57.411 Error SharedHttpPipelineSource: Error copying live stream. *** Error Report *** Version: 4.6.7.0 Command line: /system/EmbyServer.dll -programdata /config -ffdetect /bin/ffdetect -ffmpeg /bin/ffmpeg -ffprobe /bin/ffprobe -restartexitcode 3 Operating system: Linux version 5.15.0-27-generic (buildd@ubuntu) (gcc (Ubuntu 11.2.0-19ubuntu1) 11.2.0, GNU ld (GNU Binutils for Ubuntu) 2.38) #28-Ubuntu SMP Thu Apr 1 Framework: .NET Core 3.1.21 OS/Process: x64/x64 Runtime: system/System.Private.CoreLib.dll Processor count: 3 Data path: /config Application path: /system System.NullReferenceException: System.NullReferenceException: Object reference not set to an instance of an object. at System.IO.Pipelines.Pipe.CommitUnsynchronized() at System.IO.Pipelines.Pipe.PrepareFlush(CompletionData& completionData, ValueTask`1& result, CancellationToken cancellationToken) at System.IO.Pipelines.Pipe.FlushAsync(CancellationToken cancellationToken) at System.IO.Pipelines.Pipe.DefaultPipeWriter.FlushAsync(CancellationToken cancellationToken) at System.IO.Pipelines.PipeWriter.CopyFromAsync(Stream source, CancellationToken cancellationToken) at Emby.LiveTV.TunerHosts.SharedHttpPipelineSource.<>c__DisplayClass8_0.<<StartStreaming>b__0>d.MoveNext() --- End of stack trace from previous location where exception was thrown --- at Emby.LiveTV.TunerHosts.SharedHttpPipelineSource.<>c__DisplayClass8_0.<<StartStreaming>b__0>d.MoveNext() Source: System.IO.Pipelines TargetSite: Boolean CommitUnsynchronized() 2022-05-10 14:31:57.411 Info SharedHttpPipelineSource: SharedHttpPipelineSource is done streaming. 2022-05-10 14:31:57.413 Info SharedHttpPipelineSource: Deleting temp files /data/EmbyTranscoding/transcoding-temp/bf7880bbcb4e4ff4a58dcb70d5eed19e.ts 2022-05-10 14:31:59.355 Info MediaProbeManager: ProcessRun 'ffprobe' Execute: /bin/ffprobe -analyzeduration 3000000 -i "http://127.0.0.1:8096/LiveTv/LiveStreamFiles/bf7880bbcb4e4ff4a58dcb70d5eed19e/stream.ts" -threads 0 -v info -print_format json -show_streams -show_format -show_data 2022-05-10 14:31:59.364 Info Server: http/1.1 GET http://127.0.0.1:8096/LiveTv/LiveStreamFiles/bf7880bbcb4e4ff4a58dcb70d5eed19e/stream.ts. UserAgent: Lavf/58.35.100 2022-05-10 14:31:59.375 Error Server: Error processing request *** Error Report *** Version: 4.6.7.0 Command line: /system/EmbyServer.dll -programdata /config -ffdetect /bin/ffdetect -ffmpeg /bin/ffmpeg -ffprobe /bin/ffprobe -restartexitcode 3 Operating system: Linux version 5.15.0-27-generic (buildd@ubuntu) (gcc (Ubuntu 11.2.0-19ubuntu1) 11.2.0, GNU ld (GNU Binutils for Ubuntu) 2.38) #28-Ubuntu SMP Thu Apr 1 Framework: .NET Core 3.1.21 OS/Process: x64/x64 Runtime: system/System.Private.CoreLib.dll Processor count: 3 Data path: /config Application path: /system System.IO.FileNotFoundException: System.IO.FileNotFoundException: Could not find file '/data/EmbyTranscoding/transcoding-temp/bf7880bbcb4e4ff4a58dcb70d5eed19e.ts'. File name: '/data/EmbyTranscoding/transcoding-temp/bf7880bbcb4e4ff4a58dcb70d5eed19e.ts' at Interop.ThrowExceptionForIoErrno(ErrorInfo errorInfo, String path, Boolean isDirectory, Func`2 errorRewriter) at Microsoft.Win32.SafeHandles.SafeFileHandle.Open(String path, OpenFlags flags, Int32 mode) at System.IO.FileStream.OpenHandle(FileMode mode, FileShare share, FileOptions options) at System.IO.FileStream..ctor(String path, FileMode mode, FileAccess access, FileShare share, Int32 bufferSize, FileOptions options) at Emby.Server.Implementations.IO.ManagedFileSystem.GetFileStream(String path, FileOpenMode mode, FileAccessMode access, FileShareMode share, Int32 bufferSize, FileOpenOptions fileOpenOptions) at Emby.LiveTV.TunerHosts.LiveStream.CopyFile(String path, Boolean seekFile, Int32 emptyReadLimit, PipeWriter writer, IFileSystem fileSystem, IStreamHelper streamHelper, CancellationToken cancellationToken) at Emby.LiveTV.TunerHosts.LiveStream.CopyToAsync(PipeWriter writer, CancellationToken cancellationToken) at Emby.Server.Implementations.Services.ServiceHandler.ProcessRequestAsync(HttpListenerHost appHost, IRequest httpReq, IResponse httpRes, RestPath restPath, String responseContentType, CancellationToken cancellationToken) at Emby.Server.Implementations.HttpServer.HttpListenerHost.RequestHandler(IRequest httpReq, ReadOnlyMemory`1 urlString, ReadOnlyMemory`1 localPath, CancellationToken cancellationToken) Source: System.Private.CoreLib TargetSite: Void ThrowExceptionForIoErrno(ErrorInfo, System.String, Boolean, System.Func`2[Interop+ErrorInfo,Interop+ErrorInfo]) 2022-05-10 14:31:59.375 Info Server: http/1.1 Response 404 to 127.0.0.1. Time: 11ms. http://127.0.0.1:8096/LiveTv/LiveStreamFiles/bf7880bbcb4e4ff4a58dcb70d5eed19e/stream.ts 2022-05-10 14:31:59.377 Info MediaProbeManager: ProcessRun 'ffprobe' Process exited with code 1 2022-05-10 14:31:59.387 Error MediaSourceManager: Error probing live tv stream *** Error Report *** Version: 4.6.7.0 Command line: /system/EmbyServer.dll -programdata /config -ffdetect /bin/ffdetect -ffmpeg /bin/ffmpeg -ffprobe /bin/ffprobe -restartexitcode 3 Operating system: Linux version 5.15.0-27-generic (buildd@ubuntu) (gcc (Ubuntu 11.2.0-19ubuntu1) 11.2.0, GNU ld (GNU Binutils for Ubuntu) 2.38) #28-Ubuntu SMP Thu Apr 1 Framework: .NET Core 3.1.21 OS/Process: x64/x64 Runtime: system/System.Private.CoreLib.dll Processor count: 3 Data path: /config Application path: /system System.Exception: System.Exception: ffprobe failed for "http://127.0.0.1:8096/LiveTv/LiveStreamFiles/bf7880bbcb4e4ff4a58dcb70d5eed19e/stream.ts" - streams and format are both null: { } ffprobe version 4.3.0-emby_2021_02_27 Copyright (c) 2007-2021 the FFmpeg developers and softworkz for Emby LLC built with gcc 8.3.0 (crosstool-NG 1.24.0) [http @ 0x1382180] HTTP error 404 Not Found http://127.0.0.1:8096/LiveTv/LiveStreamFiles/bf7880bbcb4e4ff4a58dcb70d5eed19e/stream.ts: Server returned 404 Not Found at Emby.Server.MediaEncoding.Probing.MediaProbeManager.GetMediaInfoInternal(String inputPath, String primaryPath, MediaProtocol protocol, String userAgent, Boolean extractChapters, String probeSizeArgument, Boolean isAudio, Boolean forceEnableLogging, CancellationToken cancellationToken) at Emby.Server.Implementations.Library.MediaSourceManager.AddMediaInfoWithProbe(MediaSourceInfo mediaSource, Boolean isAudio, ReadOnlyMemory`1 cacheKey, Boolean addProbeDelay, CancellationToken cancellationToken) at Emby.Server.Implementations.Library.MediaSourceManager.OpenLiveStreamInternal(LiveStreamRequest request, CancellationToken cancellationToken) Source: Emby.Server.MediaEncoding TargetSite: Void MoveNext() 2022-05-10 14:31:59.391 Info MediaSourceManager: Live stream opened: {"Protocol":"Http","Id":"0","Path":"http://127.0.0.1:8096/LiveTv/LiveStreamFiles/bf7880bbcb4e4ff4a58dcb70d5eed19e/stream.ts","Type":"Default","IsRemote":false,"SupportsTranscoding":true,"SupportsDirectStream":true,"SupportsDirectPlay":false,"IsInfiniteStream":true,"RequiresOpening":false,"RequiresClosing":true,"LiveStreamId":"06044cf0e6f93cdae5f285c9ecfaaeb4_41c95b6de5174f82acbc56fe82d0a2f8_0","RequiresLooping":false,"SupportsProbing":false,"MediaStreams":[{"VideoRange":"SDR","NalLengthSize":"0","IsInterlaced":true,"BitRate":10000000,"IsDefault":false,"IsForced":false,"Type":"Video","Index":-1,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Protocol":"File"},{"IsInterlaced":false,"IsDefault":false,"IsForced":false,"Type":"Audio","Index":-1,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Protocol":"File"}],"Formats":[],"Bitrate":10000000,"RequiredHttpHeaders":{"Authorization":"Basic RW1ieTo4WHI5V2ZwV3JQa0JBNWdEODJ0aDlSd3pwQVRWYzJIWUV1Rk53ekRUY3FzWTlKdzlmalZFalNjdGRFTUZQTXdOclJTbllZa1dKNVA5Q3JkNFREMkJjRktxWFd1M0NVeFh0QWtqdUhSUg=="},"ReadAtNativeFramerate":false} 2022-05-10 14:31:59.395 Info App: User policy for Groentjuh. EnablePlaybackRemuxing: True EnableVideoPlaybackTranscoding: True EnableAudioPlaybackTranscoding: True 2022-05-10 14:31:59.395 Info App: RemoteClientBitrateLimit: 25000000, RemoteIp: 10.10.0.10, IsInLocalNetwork: True 2022-05-10 14:31:59.397 Info App: RemoteClientBitrateLimit: 25000000, RemoteIp: 10.10.0.10, IsInLocalNetwork: True 2022-05-10 14:31:59.404 Info Server: http/1.1 Response 200 to 10.10.0.10. Time: 19783ms. http://[redacted-hostname]/emby/Items/2561360/PlaybackInfo?UserId=eaf86e9c1dc84101a85a3f1d4eaa9839&StartTimeTicks=0&IsPlayback=true&AutoOpenLiveStream=true&MaxStreamingBitrate=140000000&X-Emby-Client=Emby Web&X-Emby-Device-Name=Firefox Windows&X-Emby-Device-Id=9b0014dc-06bf-4a0a-8fba-bac2d419bd46&X-Emby-Client-Version=4.7.0.9 2022-05-10 14:31:59.436 Info Server: http/1.1 GET http://[redacted-hostname]/emby/videos/2561360/master.m3u8?DeviceId=9b0014dc-06bf-4a0a-8fba-bac2d419bd46&MediaSourceId=0&PlaySessionId=58bb6938f2b84364827e11f1ac7ae529&LiveStreamId=06044cf0e6f93cdae5f285c9ecfaaeb4_41c95b6de5174f82acbc56fe82d0a2f8_0&VideoCodec=h264&AudioCodec=aac&VideoBitrate=139808000&AudioBitrate=192000&TranscodingMaxAudioChannels=2&SegmentContainer=ts&MinSegments=1&BreakOnNonKeyFrames=True&ManifestSubtitles=vtt&h264-profile=high,main,baseline,constrainedbaseline&h264-level=52&TranscodeReasons=ContainerNotSupported. Accept=*/*, Accept-Encoding=gzip, deflate, br, Accept-Language=nl,en-US;q=0.7,en;q=0.3, Host=[redacted-hostname], Referer=https://app.emby.media/, User-Agent=Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:99.0) Gecko/20100101 Firefox/99.0, DNT=1, Origin=https://app.emby.media, X-Real-IP=10.10.0.10, X-Forwarded-For=10.10.0.10, sec-fetch-dest=empty, sec-fetch-mode=cors, sec-fetch-site=cross-site 2022-05-10 14:31:59.468 Info Server: http/1.1 Response 200 to 10.10.0.10. Time: 30ms. http://[redacted-hostname]/emby/videos/2561360/master.m3u8?DeviceId=9b0014dc-06bf-4a0a-8fba-bac2d419bd46&MediaSourceId=0&PlaySessionId=58bb6938f2b84364827e11f1ac7ae529&LiveStreamId=06044cf0e6f93cdae5f285c9ecfaaeb4_41c95b6de5174f82acbc56fe82d0a2f8_0&VideoCodec=h264&AudioCodec=aac&VideoBitrate=139808000&AudioBitrate=192000&TranscodingMaxAudioChannels=2&SegmentContainer=ts&MinSegments=1&BreakOnNonKeyFrames=True&ManifestSubtitles=vtt&h264-profile=high,main,baseline,constrainedbaseline&h264-level=52&TranscodeReasons=ContainerNotSupported 2022-05-10 14:31:59.484 Info Server: http/1.1 GET http://[redacted-hostname]/emby/videos/2561360/live.m3u8?DeviceId=9b0014dc-06bf-4a0a-8fba-bac2d419bd46&MediaSourceId=0&PlaySessionId=58bb6938f2b84364827e11f1ac7ae529&LiveStreamId=06044cf0e6f93cdae5f285c9ecfaaeb4_41c95b6de5174f82acbc56fe82d0a2f8_0&VideoCodec=h264&AudioCodec=aac&VideoBitrate=139808000&AudioBitrate=192000&TranscodingMaxAudioChannels=2&SegmentContainer=ts&MinSegments=1&BreakOnNonKeyFrames=True&ManifestSubtitles=vtt&h264-profile=high,main,baseline,constrainedbaseline&h264-level=52&TranscodeReasons=ContainerNotSupported. Accept=*/*, Accept-Encoding=gzip, deflate, br, Accept-Language=nl,en-US;q=0.7,en;q=0.3, Host=[redacted-hostname], Referer=https://app.emby.media/, User-Agent=Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:99.0) Gecko/20100101 Firefox/99.0, DNT=1, Origin=https://app.emby.media, X-Real-IP=10.10.0.10, X-Forwarded-For=10.10.0.10, sec-fetch-dest=empty, sec-fetch-mode=cors, sec-fetch-site=cross-site 2022-05-10 14:31:59.743 Info App: ProcessRun 'StreamTranscode 6a1965' Execute: /bin/ffmpeg -loglevel +timing -y -print_graphs_file "/config/logs/ffmpeg-transcode-6a196556-6999-4f04-8729-8112f9979394_1graph.txt" -copyts -start_at_zero -analyzeduration 3000000 -i "http://127.0.0.1:8096/LiveTv/LiveStreamFiles/bf7880bbcb4e4ff4a58dcb70d5eed19e/stream.ts" -filter_complex "[v:0]yadif@f1=mode=send_frame:parity=auto:deint=all,format@f2=pix_fmts=yuv420p[f2_out0]" -map [f2_out0] -map a:0 -sn -c:v:0 libx264 -maxrate:v:0 10000000 -bufsize:v:0 20000000 -pix_fmt:v:0 yuv420p -force_key_frames:v:0 "expr:if(isnan(prev_forced_t),eq(t,t),gte(t,prev_forced_t+3))" -preset:v:0 veryfast -profile:v:0 high -level:v:0 3.1 -x264opts:v:0 "subme=0:me_range=4:rc_lookahead=10:partitions=none" -crf:v:0 23 -c:a:0 aac -ab:a:0 192000 -ac:a:0 2 -disposition:a:0 default -max_delay 5000000 -avoid_negative_ts disabled -f segment -map_metadata -1 -map_chapters -1 -segment_format mpegts -segment_list "/data/EmbyTranscoding/transcoding-temp/1F5071.m3u8" -segment_list_type m3u8 -segment_time 3 -segment_list_entry_prefix hls/1F5071/ -segment_start_number 0 -individual_header_trailer 0 -write_header_trailer 0 -segment_write_temp 1 "/data/EmbyTranscoding/transcoding-temp/1F5071_%d.ts" 2022-05-10 14:31:59.757 Info Server: http/1.1 GET http://127.0.0.1:8096/LiveTv/LiveStreamFiles/bf7880bbcb4e4ff4a58dcb70d5eed19e/stream.ts. UserAgent: Lavf/58.35.100 2022-05-10 14:31:59.758 Error Server: Error processing request *** Error Report *** Version: 4.6.7.0 Command line: /system/EmbyServer.dll -programdata /config -ffdetect /bin/ffdetect -ffmpeg /bin/ffmpeg -ffprobe /bin/ffprobe -restartexitcode 3 Operating system: Linux version 5.15.0-27-generic (buildd@ubuntu) (gcc (Ubuntu 11.2.0-19ubuntu1) 11.2.0, GNU ld (GNU Binutils for Ubuntu) 2.38) #28-Ubuntu SMP Thu Apr 1 Framework: .NET Core 3.1.21 OS/Process: x64/x64 Runtime: system/System.Private.CoreLib.dll Processor count: 3 Data path: /config Application path: /system System.IO.FileNotFoundException: System.IO.FileNotFoundException: Could not find file '/data/EmbyTranscoding/transcoding-temp/bf7880bbcb4e4ff4a58dcb70d5eed19e.ts'. File name: '/data/EmbyTranscoding/transcoding-temp/bf7880bbcb4e4ff4a58dcb70d5eed19e.ts' at Interop.ThrowExceptionForIoErrno(ErrorInfo errorInfo, String path, Boolean isDirectory, Func`2 errorRewriter) at Microsoft.Win32.SafeHandles.SafeFileHandle.Open(String path, OpenFlags flags, Int32 mode) at System.IO.FileStream.OpenHandle(FileMode mode, FileShare share, FileOptions options) at System.IO.FileStream..ctor(String path, FileMode mode, FileAccess access, FileShare share, Int32 bufferSize, FileOptions options) at Emby.Server.Implementations.IO.ManagedFileSystem.GetFileStream(String path, FileOpenMode mode, FileAccessMode access, FileShareMode share, Int32 bufferSize, FileOpenOptions fileOpenOptions) at Emby.LiveTV.TunerHosts.LiveStream.CopyFile(String path, Boolean seekFile, Int32 emptyReadLimit, PipeWriter writer, IFileSystem fileSystem, IStreamHelper streamHelper, CancellationToken cancellationToken) at Emby.LiveTV.TunerHosts.LiveStream.CopyToAsync(PipeWriter writer, CancellationToken cancellationToken) at Emby.Server.Implementations.Services.ServiceHandler.ProcessRequestAsync(HttpListenerHost appHost, IRequest httpReq, IResponse httpRes, RestPath restPath, String responseContentType, CancellationToken cancellationToken) at Emby.Server.Implementations.HttpServer.HttpListenerHost.RequestHandler(IRequest httpReq, ReadOnlyMemory`1 urlString, ReadOnlyMemory`1 localPath, CancellationToken cancellationToken) Source: System.Private.CoreLib TargetSite: Void ThrowExceptionForIoErrno(ErrorInfo, System.String, Boolean, System.Func`2[Interop+ErrorInfo,Interop+ErrorInfo]) 2022-05-10 14:31:59.758 Info Server: http/1.1 Response 404 to 127.0.0.1. Time: 1ms. http://127.0.0.1:8096/LiveTv/LiveStreamFiles/bf7880bbcb4e4ff4a58dcb70d5eed19e/stream.ts 2022-05-10 14:31:59.776 Info App: AppendExtraLogData - Read graph file: /config/logs/ffmpeg-transcode-6a196556-6999-4f04-8729-8112f9979394_1graph.txt 2022-05-10 14:31:59.785 Info App: AppendExtraLogData - Deserialized GraphData fileStream: {0:n} bytes Graph Count: 1 2022-05-10 14:31:59.785 Info App: AppendExtraLogData - File Deleted 2022-05-10 14:31:59.800 Error Server: Error processing request *** Error Report *** Version: 4.6.7.0 Command line: /system/EmbyServer.dll -programdata /config -ffdetect /bin/ffdetect -ffmpeg /bin/ffmpeg -ffprobe /bin/ffprobe -restartexitcode 3 Operating system: Linux version 5.15.0-27-generic (buildd@ubuntu) (gcc (Ubuntu 11.2.0-19ubuntu1) 11.2.0, GNU ld (GNU Binutils for Ubuntu) 2.38) #28-Ubuntu SMP Thu Apr 1 Framework: .NET Core 3.1.21 OS/Process: x64/x64 Runtime: system/System.Private.CoreLib.dll Processor count: 3 Data path: /config Application path: /system System.Exception: System.Exception: Error starting ffmpeg at Emby.Server.MediaEncoding.Api.BaseStreamingService.StartFfMpeg(StreamState state, String outputPath, CancellationToken cancellationToken, Boolean acquireResources) at Emby.Server.MediaEncoding.Api.Hls.BaseHlsService.ProcessRequest(StreamRequest request) at Emby.Server.Implementations.Services.ServiceController.GetTaskResult(Task task) at Emby.Server.Implementations.Services.ServiceHandler.ProcessRequestAsync(HttpListenerHost appHost, IRequest httpReq, IResponse httpRes, RestPath restPath, String responseContentType, CancellationToken cancellationToken) at Emby.Server.Implementations.HttpServer.HttpListenerHost.RequestHandler(IRequest httpReq, ReadOnlyMemory`1 urlString, ReadOnlyMemory`1 localPath, CancellationToken cancellationToken) Source: Emby.Server.MediaEncoding TargetSite: Void MoveNext() 2022-05-10 14:31:59.800 Info Server: http/1.1 Response 500 to 10.10.0.10. Time: 316ms. http://[redacted-hostname]/emby/videos/2561360/live.m3u8?DeviceId=9b0014dc-06bf-4a0a-8fba-bac2d419bd46&MediaSourceId=0&PlaySessionId=58bb6938f2b84364827e11f1ac7ae529&LiveStreamId=06044cf0e6f93cdae5f285c9ecfaaeb4_41c95b6de5174f82acbc56fe82d0a2f8_0&VideoCodec=h264&AudioCodec=aac&VideoBitrate=139808000&AudioBitrate=192000&TranscodingMaxAudioChannels=2&SegmentContainer=ts&MinSegments=1&BreakOnNonKeyFrames=True&ManifestSubtitles=vtt&h264-profile=high,main,baseline,constrainedbaseline&h264-level=52&TranscodeReasons=ContainerNotSupported 2022-05-10 14:31:59.845 Info App: ProcessRun 'StreamTranscode 6a1965' Process exited with code 1 2022-05-10 14:31:59.889 Info Server: http/1.1 OPTIONS http://[redacted-hostname]/emby/Sessions/Playing?X-Emby-Client=Emby Web&X-Emby-Device-Name=Firefox Windows&X-Emby-Device-Id=9b0014dc-06bf-4a0a-8fba-bac2d419bd46&X-Emby-Client-Version=4.7.0.9. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:99.0) Gecko/20100101 Firefox/99.0 2022-05-10 14:31:59.889 Info Server: http/1.1 Response 200 to 10.10.0.10. Time: 0ms. http://[redacted-hostname]/emby/Sessions/Playing?X-Emby-Client=Emby Web&X-Emby-Device-Name=Firefox Windows&X-Emby-Device-Id=9b0014dc-06bf-4a0a-8fba-bac2d419bd46&X-Emby-Client-Version=4.7.0.9 2022-05-10 14:31:59.894 Info Server: http/1.1 POST http://[redacted-hostname]/emby/Sessions/Playing?X-Emby-Client=Emby Web&X-Emby-Device-Name=Firefox Windows&X-Emby-Device-Id=9b0014dc-06bf-4a0a-8fba-bac2d419bd46&X-Emby-Client-Version=4.7.0.9. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:99.0) Gecko/20100101 Firefox/99.0 2022-05-10 14:31:59.911 Info Server: http/1.1 OPTIONS http://[redacted-hostname]/emby/Items/2561360/PlaybackInfo?UserId=eaf86e9c1dc84101a85a3f1d4eaa9839&StartTimeTicks=0&IsPlayback=true&AutoOpenLiveStream=true&AudioStreamIndex=-1&SubtitleStreamIndex=-1&EnableDirectPlay=false&EnableDirectStream=false&AllowVideoStreamCopy=false&MediaSourceId=0&LiveStreamId=06044cf0e6f93cdae5f285c9ecfaaeb4_41c95b6de5174f82acbc56fe82d0a2f8_0&MaxStreamingBitrate=140000000&CurrentPlaySessionId=58bb6938f2b84364827e11f1ac7ae529&X-Emby-Client=Emby Web&X-Emby-Device-Name=Firefox Windows&X-Emby-Device-Id=9b0014dc-06bf-4a0a-8fba-bac2d419bd46&X-Emby-Client-Version=4.7.0.9. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:99.0) Gecko/20100101 Firefox/99.0 2022-05-10 14:31:59.912 Info Server: http/1.1 Response 200 to 10.10.0.10. Time: 0ms. http://[redacted-hostname]/emby/Items/2561360/PlaybackInfo?UserId=eaf86e9c1dc84101a85a3f1d4eaa9839&StartTimeTicks=0&IsPlayback=true&AutoOpenLiveStream=true&AudioStreamIndex=-1&SubtitleStreamIndex=-1&EnableDirectPlay=false&EnableDirectStream=false&AllowVideoStreamCopy=false&MediaSourceId=0&LiveStreamId=06044cf0e6f93cdae5f285c9ecfaaeb4_41c95b6de5174f82acbc56fe82d0a2f8_0&MaxStreamingBitrate=140000000&CurrentPlaySessionId=58bb6938f2b84364827e11f1ac7ae529&X-Emby-Client=Emby Web&X-Emby-Device-Name=Firefox Windows&X-Emby-Device-Id=9b0014dc-06bf-4a0a-8fba-bac2d419bd46&X-Emby-Client-Version=4.7.0.9 2022-05-10 14:31:59.917 Info Server: http/1.1 POST http://[redacted-hostname]/emby/Items/2561360/PlaybackInfo?UserId=eaf86e9c1dc84101a85a3f1d4eaa9839&StartTimeTicks=0&IsPlayback=true&AutoOpenLiveStream=true&AudioStreamIndex=-1&SubtitleStreamIndex=-1&EnableDirectPlay=false&EnableDirectStream=false&AllowVideoStreamCopy=false&MediaSourceId=0&LiveStreamId=06044cf0e6f93cdae5f285c9ecfaaeb4_41c95b6de5174f82acbc56fe82d0a2f8_0&MaxStreamingBitrate=140000000&CurrentPlaySessionId=58bb6938f2b84364827e11f1ac7ae529&X-Emby-Client=Emby Web&X-Emby-Device-Name=Firefox Windows&X-Emby-Device-Id=9b0014dc-06bf-4a0a-8fba-bac2d419bd46&X-Emby-Client-Version=4.7.0.9. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:99.0) Gecko/20100101 Firefox/99.0 2022-05-10 14:31:59.920 Info App: User policy for Groentjuh. EnablePlaybackRemuxing: True EnableVideoPlaybackTranscoding: True EnableAudioPlaybackTranscoding: True 2022-05-10 14:31:59.920 Info App: RemoteClientBitrateLimit: 25000000, RemoteIp: 10.10.0.10, IsInLocalNetwork: True 2022-05-10 14:31:59.922 Info App: RemoteClientBitrateLimit: 25000000, RemoteIp: 10.10.0.10, IsInLocalNetwork: True 2022-05-10 14:31:59.922 Info Server: http/1.1 Response 200 to 10.10.0.10. Time: 6ms. http://[redacted-hostname]/emby/Items/2561360/PlaybackInfo?UserId=eaf86e9c1dc84101a85a3f1d4eaa9839&StartTimeTicks=0&IsPlayback=true&AutoOpenLiveStream=true&AudioStreamIndex=-1&SubtitleStreamIndex=-1&EnableDirectPlay=false&EnableDirectStream=false&AllowVideoStreamCopy=false&MediaSourceId=0&LiveStreamId=06044cf0e6f93cdae5f285c9ecfaaeb4_41c95b6de5174f82acbc56fe82d0a2f8_0&MaxStreamingBitrate=140000000&CurrentPlaySessionId=58bb6938f2b84364827e11f1ac7ae529&X-Emby-Client=Emby Web&X-Emby-Device-Name=Firefox Windows&X-Emby-Device-Id=9b0014dc-06bf-4a0a-8fba-bac2d419bd46&X-Emby-Client-Version=4.7.0.9 2022-05-10 14:31:59.944 Info Server: http/1.1 OPTIONS http://[redacted-hostname]/emby/Videos/ActiveEncodings?deviceId=9b0014dc-06bf-4a0a-8fba-bac2d419bd46&PlaySessionId=58bb6938f2b84364827e11f1ac7ae529&X-Emby-Client=Emby Web&X-Emby-Device-Name=Firefox Windows&X-Emby-Device-Id=9b0014dc-06bf-4a0a-8fba-bac2d419bd46&X-Emby-Client-Version=4.7.0.9. Accept=*/*, Accept-Encoding=gzip, deflate, br, Accept-Language=nl,en-US;q=0.7,en;q=0.3, Host=[redacted-hostname], Referer=https://app.emby.media/, User-Agent=Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:99.0) Gecko/20100101 Firefox/99.0, DNT=1, Origin=https://app.emby.media, Access-Control-Request-Method=DELETE, X-Real-IP=10.10.0.10, X-Forwarded-For=10.10.0.10, sec-fetch-dest=empty, sec-fetch-mode=cors, sec-fetch-site=cross-site 2022-05-10 14:31:59.944 Info Server: http/1.1 Response 200 to 10.10.0.10. Time: 0ms. http://[redacted-hostname]/emby/Videos/ActiveEncodings?deviceId=9b0014dc-06bf-4a0a-8fba-bac2d419bd46&PlaySessionId=58bb6938f2b84364827e11f1ac7ae529&X-Emby-Client=Emby Web&X-Emby-Device-Name=Firefox Windows&X-Emby-Device-Id=9b0014dc-06bf-4a0a-8fba-bac2d419bd46&X-Emby-Client-Version=4.7.0.9 2022-05-10 14:31:59.963 Info Server: http/1.1 DELETE http://[redacted-hostname]/emby/Videos/ActiveEncodings?deviceId=9b0014dc-06bf-4a0a-8fba-bac2d419bd46&PlaySessionId=58bb6938f2b84364827e11f1ac7ae529&X-Emby-Client=Emby Web&X-Emby-Device-Name=Firefox Windows&X-Emby-Device-Id=9b0014dc-06bf-4a0a-8fba-bac2d419bd46&X-Emby-Client-Version=4.7.0.9. Accept=*/*, Accept-Encoding=gzip, deflate, br, Accept-Language=nl,en-US;q=0.7,en;q=0.3, Host=[redacted-hostname], Referer=https://app.emby.media/, User-Agent=Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:99.0) Gecko/20100101 Firefox/99.0, DNT=1, Origin=https://app.emby.media, X-Real-IP=10.10.0.10, X-Forwarded-For=10.10.0.10, sec-fetch-dest=empty, sec-fetch-mode=cors, sec-fetch-site=cross-site 2022-05-10 14:31:59.966 Info Server: http/1.1 Response 204 to 10.10.0.10. Time: 16ms. http://[redacted-hostname]/emby/Videos/ActiveEncodings?deviceId=9b0014dc-06bf-4a0a-8fba-bac2d419bd46&PlaySessionId=58bb6938f2b84364827e11f1ac7ae529&X-Emby-Client=Emby Web&X-Emby-Device-Name=Firefox Windows&X-Emby-Device-Id=9b0014dc-06bf-4a0a-8fba-bac2d419bd46&X-Emby-Client-Version=4.7.0.9 2022-05-10 14:31:59.992 Info Server: http/1.1 GET http://[redacted-hostname]/emby/videos/2561360/master.m3u8?DeviceId=9b0014dc-06bf-4a0a-8fba-bac2d419bd46&MediaSourceId=0&PlaySessionId=b40a2b0ed89b49b9a8c8f0dbffc12059&LiveStreamId=06044cf0e6f93cdae5f285c9ecfaaeb4_41c95b6de5174f82acbc56fe82d0a2f8_0&VideoCodec=h264&AudioCodec=aac&VideoBitrate=139808000&AudioBitrate=192000&TranscodingMaxAudioChannels=2&SegmentContainer=ts&MinSegments=1&BreakOnNonKeyFrames=True&ManifestSubtitles=vtt&h264-profile=high,main,baseline,constrainedbaseline&h264-level=52&TranscodeReasons=ContainerNotSupported,DirectPlayError&allowVideoStreamCopy=false. Accept=*/*, Accept-Encoding=gzip, deflate, br, Accept-Language=nl,en-US;q=0.7,en;q=0.3, Host=[redacted-hostname], Referer=https://app.emby.media/, User-Agent=Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:99.0) Gecko/20100101 Firefox/99.0, DNT=1, Origin=https://app.emby.media, X-Real-IP=10.10.0.10, X-Forwarded-For=10.10.0.10, sec-fetch-dest=empty, sec-fetch-mode=cors, sec-fetch-site=cross-site 2022-05-10 14:31:59.993 Info Server: http/1.1 Response 200 to 10.10.0.10. Time: 1ms. http://[redacted-hostname]/emby/videos/2561360/master.m3u8?DeviceId=9b0014dc-06bf-4a0a-8fba-bac2d419bd46&MediaSourceId=0&PlaySessionId=b40a2b0ed89b49b9a8c8f0dbffc12059&LiveStreamId=06044cf0e6f93cdae5f285c9ecfaaeb4_41c95b6de5174f82acbc56fe82d0a2f8_0&VideoCodec=h264&AudioCodec=aac&VideoBitrate=139808000&AudioBitrate=192000&TranscodingMaxAudioChannels=2&SegmentContainer=ts&MinSegments=1&BreakOnNonKeyFrames=True&ManifestSubtitles=vtt&h264-profile=high,main,baseline,constrainedbaseline&h264-level=52&TranscodeReasons=ContainerNotSupported,DirectPlayError&allowVideoStreamCopy=false 2022-05-10 14:32:00.000 Info SessionManager: Playback start reported by app Emby Web 4.7.0.9 playing NPO 1 HD. Started at 0 ms 2022-05-10 14:32:00.012 Info Server: http/1.1 Response 204 to 10.10.0.10. Time: 118ms. http://[redacted-hostname]/emby/Sessions/Playing?X-Emby-Client=Emby Web&X-Emby-Device-Name=Firefox Windows&X-Emby-Device-Id=9b0014dc-06bf-4a0a-8fba-bac2d419bd46&X-Emby-Client-Version=4.7.0.9 2022-05-10 14:32:00.015 Info Server: http/1.1 GET http://[redacted-hostname]/emby/videos/2561360/live.m3u8?DeviceId=9b0014dc-06bf-4a0a-8fba-bac2d419bd46&MediaSourceId=0&PlaySessionId=b40a2b0ed89b49b9a8c8f0dbffc12059&LiveStreamId=06044cf0e6f93cdae5f285c9ecfaaeb4_41c95b6de5174f82acbc56fe82d0a2f8_0&VideoCodec=h264&AudioCodec=aac&VideoBitrate=139808000&AudioBitrate=192000&TranscodingMaxAudioChannels=2&SegmentContainer=ts&MinSegments=1&BreakOnNonKeyFrames=True&ManifestSubtitles=vtt&h264-profile=high,main,baseline,constrainedbaseline&h264-level=52&TranscodeReasons=ContainerNotSupported,DirectPlayError&allowVideoStreamCopy=false. Accept=*/*, Accept-Encoding=gzip, deflate, br, Accept-Language=nl,en-US;q=0.7,en;q=0.3, Host=[redacted-hostname], Referer=https://app.emby.media/, User-Agent=Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:99.0) Gecko/20100101 Firefox/99.0, DNT=1, Origin=https://app.emby.media, X-Real-IP=10.10.0.10, X-Forwarded-For=10.10.0.10, sec-fetch-dest=empty, sec-fetch-mode=cors, sec-fetch-site=cross-site 2022-05-10 14:32:00.043 Info App: ProcessRun 'StreamTranscode 7a0332' Execute: /bin/ffmpeg -loglevel +timing -y -print_graphs_file "/config/logs/ffmpeg-transcode-7a033210-dcfe-44da-a6a1-6c9858124533_1graph.txt" -copyts -start_at_zero -analyzeduration 3000000 -i "http://127.0.0.1:8096/LiveTv/LiveStreamFiles/bf7880bbcb4e4ff4a58dcb70d5eed19e/stream.ts" -filter_complex "[v:0]yadif@f1=mode=send_frame:parity=auto:deint=all,format@f2=pix_fmts=yuv420p[f2_out0]" -map [f2_out0] -map a:0 -sn -c:v:0 libx264 -maxrate:v:0 10000000 -bufsize:v:0 20000000 -pix_fmt:v:0 yuv420p -force_key_frames:v:0 "expr:if(isnan(prev_forced_t),eq(t,t),gte(t,prev_forced_t+3))" -preset:v:0 veryfast -profile:v:0 high -level:v:0 3.1 -x264opts:v:0 "subme=0:me_range=4:rc_lookahead=10:partitions=none" -crf:v:0 23 -c:a:0 aac -ab:a:0 192000 -ac:a:0 2 -disposition:a:0 default -max_delay 5000000 -avoid_negative_ts disabled -f segment -map_metadata -1 -map_chapters -1 -segment_format mpegts -segment_list "/data/EmbyTranscoding/transcoding-temp/E7C48D.m3u8" -segment_list_type m3u8 -segment_time 3 -segment_list_entry_prefix hls/E7C48D/ -segment_start_number 0 -individual_header_trailer 0 -write_header_trailer 0 -segment_write_temp 1 "/data/EmbyTranscoding/transcoding-temp/E7C48D_%d.ts" 2022-05-10 14:32:00.057 Info Server: http/1.1 GET http://127.0.0.1:8096/LiveTv/LiveStreamFiles/bf7880bbcb4e4ff4a58dcb70d5eed19e/stream.ts. UserAgent: Lavf/58.35.100 2022-05-10 14:32:00.058 Error Server: Error processing request *** Error Report *** Version: 4.6.7.0 Command line: /system/EmbyServer.dll -programdata /config -ffdetect /bin/ffdetect -ffmpeg /bin/ffmpeg -ffprobe /bin/ffprobe -restartexitcode 3 Operating system: Linux version 5.15.0-27-generic (buildd@ubuntu) (gcc (Ubuntu 11.2.0-19ubuntu1) 11.2.0, GNU ld (GNU Binutils for Ubuntu) 2.38) #28-Ubuntu SMP Thu Apr 1 Framework: .NET Core 3.1.21 OS/Process: x64/x64 Runtime: system/System.Private.CoreLib.dll Processor count: 3 Data path: /config Application path: /system System.IO.FileNotFoundException: System.IO.FileNotFoundException: Could not find file '/data/EmbyTranscoding/transcoding-temp/bf7880bbcb4e4ff4a58dcb70d5eed19e.ts'. File name: '/data/EmbyTranscoding/transcoding-temp/bf7880bbcb4e4ff4a58dcb70d5eed19e.ts' at Interop.ThrowExceptionForIoErrno(ErrorInfo errorInfo, String path, Boolean isDirectory, Func`2 errorRewriter) at Microsoft.Win32.SafeHandles.SafeFileHandle.Open(String path, OpenFlags flags, Int32 mode) at System.IO.FileStream.OpenHandle(FileMode mode, FileShare share, FileOptions options) at System.IO.FileStream..ctor(String path, FileMode mode, FileAccess access, FileShare share, Int32 bufferSize, FileOptions options) at Emby.Server.Implementations.IO.ManagedFileSystem.GetFileStream(String path, FileOpenMode mode, FileAccessMode access, FileShareMode share, Int32 bufferSize, FileOpenOptions fileOpenOptions) at Emby.LiveTV.TunerHosts.LiveStream.CopyFile(String path, Boolean seekFile, Int32 emptyReadLimit, PipeWriter writer, IFileSystem fileSystem, IStreamHelper streamHelper, CancellationToken cancellationToken) at Emby.LiveTV.TunerHosts.LiveStream.CopyToAsync(PipeWriter writer, CancellationToken cancellationToken) at Emby.Server.Implementations.Services.ServiceHandler.ProcessRequestAsync(HttpListenerHost appHost, IRequest httpReq, IResponse httpRes, RestPath restPath, String responseContentType, CancellationToken cancellationToken) at Emby.Server.Implementations.HttpServer.HttpListenerHost.RequestHandler(IRequest httpReq, ReadOnlyMemory`1 urlString, ReadOnlyMemory`1 localPath, CancellationToken cancellationToken) Source: System.Private.CoreLib TargetSite: Void ThrowExceptionForIoErrno(ErrorInfo, System.String, Boolean, System.Func`2[Interop+ErrorInfo,Interop+ErrorInfo]) 2022-05-10 14:32:00.058 Info Server: http/1.1 Response 404 to 127.0.0.1. Time: 1ms. http://127.0.0.1:8096/LiveTv/LiveStreamFiles/bf7880bbcb4e4ff4a58dcb70d5eed19e/stream.ts 2022-05-10 14:32:00.062 Info App: AppendExtraLogData - Read graph file: /config/logs/ffmpeg-transcode-7a033210-dcfe-44da-a6a1-6c9858124533_1graph.txt 2022-05-10 14:32:00.062 Info App: AppendExtraLogData - Deserialized GraphData fileStream: {0:n} bytes Graph Count: 1 2022-05-10 14:32:00.062 Info App: AppendExtraLogData - File Deleted 2022-05-10 14:32:00.062 Info App: ProcessRun 'StreamTranscode 7a0332' Process exited with code 1 2022-05-10 14:32:00.087 Info Server: http/1.1 GET http://[redacted-hostname]/emby/Items/2561360/Images/Primary?maxWidth=12&blur=2&tag=0f57f1c0ec3b5097c0dfd034489e175b&quality=90. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:99.0) Gecko/20100101 Firefox/99.0 2022-05-10 14:32:00.101 Info Server: http/1.1 GET http://[redacted-hostname]/emby/Items/2561360/Images/Primary?maxHeight=78&maxWidth=78&tag=0f57f1c0ec3b5097c0dfd034489e175b&quality=90. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:99.0) Gecko/20100101 Firefox/99.0 2022-05-10 14:32:00.103 Error Server: Error processing request *** Error Report *** Version: 4.6.7.0 Command line: /system/EmbyServer.dll -programdata /config -ffdetect /bin/ffdetect -ffmpeg /bin/ffmpeg -ffprobe /bin/ffprobe -restartexitcode 3 Operating system: Linux version 5.15.0-27-generic (buildd@ubuntu) (gcc (Ubuntu 11.2.0-19ubuntu1) 11.2.0, GNU ld (GNU Binutils for Ubuntu) 2.38) #28-Ubuntu SMP Thu Apr 1 Framework: .NET Core 3.1.21 OS/Process: x64/x64 Runtime: system/System.Private.CoreLib.dll Processor count: 3 Data path: /config Application path: /system System.Exception: System.Exception: Error starting ffmpeg at Emby.Server.MediaEncoding.Api.BaseStreamingService.StartFfMpeg(StreamState state, String outputPath, CancellationToken cancellationToken, Boolean acquireResources) at Emby.Server.MediaEncoding.Api.Hls.BaseHlsService.ProcessRequest(StreamRequest request) at Emby.Server.Implementations.Services.ServiceController.GetTaskResult(Task task) at Emby.Server.Implementations.Services.ServiceHandler.ProcessRequestAsync(HttpListenerHost appHost, IRequest httpReq, IResponse httpRes, RestPath restPath, String responseContentType, CancellationToken cancellationToken) at Emby.Server.Implementations.HttpServer.HttpListenerHost.RequestHandler(IRequest httpReq, ReadOnlyMemory`1 urlString, ReadOnlyMemory`1 localPath, CancellationToken cancellationToken) Source: Emby.Server.MediaEncoding TargetSite: Void MoveNext() 2022-05-10 14:32:00.103 Info Server: http/1.1 Response 500 to 10.10.0.10. Time: 89ms. http://[redacted-hostname]/emby/videos/2561360/live.m3u8?DeviceId=9b0014dc-06bf-4a0a-8fba-bac2d419bd46&MediaSourceId=0&PlaySessionId=b40a2b0ed89b49b9a8c8f0dbffc12059&LiveStreamId=06044cf0e6f93cdae5f285c9ecfaaeb4_41c95b6de5174f82acbc56fe82d0a2f8_0&VideoCodec=h264&AudioCodec=aac&VideoBitrate=139808000&AudioBitrate=192000&TranscodingMaxAudioChannels=2&SegmentContainer=ts&MinSegments=1&BreakOnNonKeyFrames=True&ManifestSubtitles=vtt&h264-profile=high,main,baseline,constrainedbaseline&h264-level=52&TranscodeReasons=ContainerNotSupported,DirectPlayError&allowVideoStreamCopy=false 2022-05-10 14:32:00.138 Info Server: http/1.1 Response 200 to 10.10.0.10. Time: 37ms. http://[redacted-hostname]/emby/Items/2561360/Images/Primary?maxHeight=78&maxWidth=78&tag=0f57f1c0ec3b5097c0dfd034489e175b&quality=90 2022-05-10 14:32:00.139 Info Server: http/1.1 Response 200 to 10.10.0.10. Time: 52ms. http://[redacted-hostname]/emby/Items/2561360/Images/Primary?maxWidth=12&blur=2&tag=0f57f1c0ec3b5097c0dfd034489e175b&quality=90 2022-05-10 14:32:00.175 Info Server: http/1.1 OPTIONS http://[redacted-hostname]/emby/Videos/ActiveEncodings?deviceId=9b0014dc-06bf-4a0a-8fba-bac2d419bd46&PlaySessionId=58bb6938f2b84364827e11f1ac7ae529&X-Emby-Client=Emby Web&X-Emby-Device-Name=Firefox Windows&X-Emby-Device-Id=9b0014dc-06bf-4a0a-8fba-bac2d419bd46&X-Emby-Client-Version=4.7.0.9. Accept=*/*, Accept-Encoding=gzip, deflate, br, Accept-Language=nl,en-US;q=0.7,en;q=0.3, Host=[redacted-hostname], Referer=https://app.emby.media/, User-Agent=Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:99.0) Gecko/20100101 Firefox/99.0, DNT=1, Origin=https://app.emby.media, Access-Control-Request-Method=DELETE, X-Real-IP=10.10.0.10, X-Forwarded-For=10.10.0.10, sec-fetch-dest=empty, sec-fetch-mode=cors, sec-fetch-site=cross-site 2022-05-10 14:32:00.175 Info Server: http/1.1 Response 200 to 10.10.0.10. Time: 0ms. http://[redacted-hostname]/emby/Videos/ActiveEncodings?deviceId=9b0014dc-06bf-4a0a-8fba-bac2d419bd46&PlaySessionId=58bb6938f2b84364827e11f1ac7ae529&X-Emby-Client=Emby Web&X-Emby-Device-Name=Firefox Windows&X-Emby-Device-Id=9b0014dc-06bf-4a0a-8fba-bac2d419bd46&X-Emby-Client-Version=4.7.0.9 2022-05-10 14:32:00.192 Info Server: http/1.1 DELETE http://[redacted-hostname]/emby/Videos/ActiveEncodings?deviceId=9b0014dc-06bf-4a0a-8fba-bac2d419bd46&PlaySessionId=58bb6938f2b84364827e11f1ac7ae529&X-Emby-Client=Emby Web&X-Emby-Device-Name=Firefox Windows&X-Emby-Device-Id=9b0014dc-06bf-4a0a-8fba-bac2d419bd46&X-Emby-Client-Version=4.7.0.9. Accept=*/*, Accept-Encoding=gzip, deflate, br, Accept-Language=nl,en-US;q=0.7,en;q=0.3, Host=[redacted-hostname], Referer=https://app.emby.media/, User-Agent=Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:99.0) Gecko/20100101 Firefox/99.0, DNT=1, Origin=https://app.emby.media, X-Real-IP=10.10.0.10, X-Forwarded-For=10.10.0.10, sec-fetch-dest=empty, sec-fetch-mode=cors, sec-fetch-site=cross-site 2022-05-10 14:32:00.192 Info Server: http/1.1 Response 204 to 10.10.0.10. Time: 1ms. http://[redacted-hostname]/emby/Videos/ActiveEncodings?deviceId=9b0014dc-06bf-4a0a-8fba-bac2d419bd46&PlaySessionId=58bb6938f2b84364827e11f1ac7ae529&X-Emby-Client=Emby Web&X-Emby-Device-Name=Firefox Windows&X-Emby-Device-Id=9b0014dc-06bf-4a0a-8fba-bac2d419bd46&X-Emby-Client-Version=4.7.0.9 2022-05-10 14:32:00.242 Info Server: http/1.1 OPTIONS http://[redacted-hostname]/emby/Items/2561360/PlaybackInfo?UserId=eaf86e9c1dc84101a85a3f1d4eaa9839&StartTimeTicks=0&IsPlayback=true&AutoOpenLiveStream=true&AudioStreamIndex=-1&SubtitleStreamIndex=-1&EnableDirectPlay=false&EnableDirectStream=false&AllowVideoStreamCopy=false&AllowAudioStreamCopy=false&MediaSourceId=0&LiveStreamId=06044cf0e6f93cdae5f285c9ecfaaeb4_41c95b6de5174f82acbc56fe82d0a2f8_0&MaxStreamingBitrate=140000000&CurrentPlaySessionId=b40a2b0ed89b49b9a8c8f0dbffc12059&X-Emby-Client=Emby Web&X-Emby-Device-Name=Firefox Windows&X-Emby-Device-Id=9b0014dc-06bf-4a0a-8fba-bac2d419bd46&X-Emby-Client-Version=4.7.0.9. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:99.0) Gecko/20100101 Firefox/99.0 2022-05-10 14:32:00.242 Info Server: http/1.1 Response 200 to 10.10.0.10. Time: 0ms. http://[redacted-hostname]/emby/Items/2561360/PlaybackInfo?UserId=eaf86e9c1dc84101a85a3f1d4eaa9839&StartTimeTicks=0&IsPlayback=true&AutoOpenLiveStream=true&AudioStreamIndex=-1&SubtitleStreamIndex=-1&EnableDirectPlay=false&EnableDirectStream=false&AllowVideoStreamCopy=false&AllowAudioStreamCopy=false&MediaSourceId=0&LiveStreamId=06044cf0e6f93cdae5f285c9ecfaaeb4_41c95b6de5174f82acbc56fe82d0a2f8_0&MaxStreamingBitrate=140000000&CurrentPlaySessionId=b40a2b0ed89b49b9a8c8f0dbffc12059&X-Emby-Client=Emby Web&X-Emby-Device-Name=Firefox Windows&X-Emby-Device-Id=9b0014dc-06bf-4a0a-8fba-bac2d419bd46&X-Emby-Client-Version=4.7.0.9 2022-05-10 14:32:00.305 Info Server: http/1.1 POST http://[redacted-hostname]/emby/Items/2561360/PlaybackInfo?UserId=eaf86e9c1dc84101a85a3f1d4eaa9839&StartTimeTicks=0&IsPlayback=true&AutoOpenLiveStream=true&AudioStreamIndex=-1&SubtitleStreamIndex=-1&EnableDirectPlay=false&EnableDirectStream=false&AllowVideoStreamCopy=false&AllowAudioStreamCopy=false&MediaSourceId=0&LiveStreamId=06044cf0e6f93cdae5f285c9ecfaaeb4_41c95b6de5174f82acbc56fe82d0a2f8_0&MaxStreamingBitrate=140000000&CurrentPlaySessionId=b40a2b0ed89b49b9a8c8f0dbffc12059&X-Emby-Client=Emby Web&X-Emby-Device-Name=Firefox Windows&X-Emby-Device-Id=9b0014dc-06bf-4a0a-8fba-bac2d419bd46&X-Emby-Client-Version=4.7.0.9. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:99.0) Gecko/20100101 Firefox/99.0 2022-05-10 14:32:00.309 Info App: User policy for Groentjuh. EnablePlaybackRemuxing: True EnableVideoPlaybackTranscoding: True EnableAudioPlaybackTranscoding: True 2022-05-10 14:32:00.309 Info App: RemoteClientBitrateLimit: 25000000, RemoteIp: 10.10.0.10, IsInLocalNetwork: True 2022-05-10 14:32:00.310 Info App: RemoteClientBitrateLimit: 25000000, RemoteIp: 10.10.0.10, IsInLocalNetwork: True 2022-05-10 14:32:00.311 Info Server: http/1.1 Response 200 to 10.10.0.10. Time: 6ms. http://[redacted-hostname]/emby/Items/2561360/PlaybackInfo?UserId=eaf86e9c1dc84101a85a3f1d4eaa9839&StartTimeTicks=0&IsPlayback=true&AutoOpenLiveStream=true&AudioStreamIndex=-1&SubtitleStreamIndex=-1&EnableDirectPlay=false&EnableDirectStream=false&AllowVideoStreamCopy=false&AllowAudioStreamCopy=false&MediaSourceId=0&LiveStreamId=06044cf0e6f93cdae5f285c9ecfaaeb4_41c95b6de5174f82acbc56fe82d0a2f8_0&MaxStreamingBitrate=140000000&CurrentPlaySessionId=b40a2b0ed89b49b9a8c8f0dbffc12059&X-Emby-Client=Emby Web&X-Emby-Device-Name=Firefox Windows&X-Emby-Device-Id=9b0014dc-06bf-4a0a-8fba-bac2d419bd46&X-Emby-Client-Version=4.7.0.9 2022-05-10 14:32:00.345 Info Server: http/1.1 OPTIONS http://[redacted-hostname]/emby/Videos/ActiveEncodings?deviceId=9b0014dc-06bf-4a0a-8fba-bac2d419bd46&PlaySessionId=b40a2b0ed89b49b9a8c8f0dbffc12059&X-Emby-Client=Emby Web&X-Emby-Device-Name=Firefox Windows&X-Emby-Device-Id=9b0014dc-06bf-4a0a-8fba-bac2d419bd46&X-Emby-Client-Version=4.7.0.9. Accept=*/*, Accept-Encoding=gzip, deflate, br, Accept-Language=nl,en-US;q=0.7,en;q=0.3, Host=[redacted-hostname], Referer=https://app.emby.media/, User-Agent=Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:99.0) Gecko/20100101 Firefox/99.0, DNT=1, Origin=https://app.emby.media, Access-Control-Request-Method=DELETE, X-Real-IP=10.10.0.10, X-Forwarded-For=10.10.0.10, sec-fetch-dest=empty, sec-fetch-mode=cors, sec-fetch-site=cross-site 2022-05-10 14:32:00.345 Info Server: http/1.1 Response 200 to 10.10.0.10. Time: 0ms. http://[redacted-hostname]/emby/Videos/ActiveEncodings?deviceId=9b0014dc-06bf-4a0a-8fba-bac2d419bd46&PlaySessionId=b40a2b0ed89b49b9a8c8f0dbffc12059&X-Emby-Client=Emby Web&X-Emby-Device-Name=Firefox Windows&X-Emby-Device-Id=9b0014dc-06bf-4a0a-8fba-bac2d419bd46&X-Emby-Client-Version=4.7.0.9 2022-05-10 14:32:00.384 Info Server: http/1.1 DELETE http://[redacted-hostname]/emby/Videos/ActiveEncodings?deviceId=9b0014dc-06bf-4a0a-8fba-bac2d419bd46&PlaySessionId=b40a2b0ed89b49b9a8c8f0dbffc12059&X-Emby-Client=Emby Web&X-Emby-Device-Name=Firefox Windows&X-Emby-Device-Id=9b0014dc-06bf-4a0a-8fba-bac2d419bd46&X-Emby-Client-Version=4.7.0.9. Accept=*/*, Accept-Encoding=gzip, deflate, br, Accept-Language=nl,en-US;q=0.7,en;q=0.3, Host=[redacted-hostname], Referer=https://app.emby.media/, User-Agent=Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:99.0) Gecko/20100101 Firefox/99.0, DNT=1, Origin=https://app.emby.media, X-Real-IP=10.10.0.10, X-Forwarded-For=10.10.0.10, sec-fetch-dest=empty, sec-fetch-mode=cors, sec-fetch-site=cross-site 2022-05-10 14:32:00.386 Info Server: http/1.1 Response 204 to 10.10.0.10. Time: 2ms. http://[redacted-hostname]/emby/Videos/ActiveEncodings?deviceId=9b0014dc-06bf-4a0a-8fba-bac2d419bd46&PlaySessionId=b40a2b0ed89b49b9a8c8f0dbffc12059&X-Emby-Client=Emby Web&X-Emby-Device-Name=Firefox Windows&X-Emby-Device-Id=9b0014dc-06bf-4a0a-8fba-bac2d419bd46&X-Emby-Client-Version=4.7.0.9 2022-05-10 14:32:00.417 Info Server: http/1.1 GET http://[redacted-hostname]/emby/videos/2561360/master.m3u8?DeviceId=9b0014dc-06bf-4a0a-8fba-bac2d419bd46&MediaSourceId=0&PlaySessionId=5b68630ba74a477a84e27877bd21132a&LiveStreamId=06044cf0e6f93cdae5f285c9ecfaaeb4_41c95b6de5174f82acbc56fe82d0a2f8_0&VideoCodec=h264&AudioCodec=aac&VideoBitrate=139808000&AudioBitrate=192000&TranscodingMaxAudioChannels=2&SegmentContainer=ts&MinSegments=1&BreakOnNonKeyFrames=True&ManifestSubtitles=vtt&h264-profile=high,main,baseline,constrainedbaseline&h264-level=52&TranscodeReasons=ContainerNotSupported,DirectPlayError&allowVideoStreamCopy=false&allowAudioStreamCopy=false. Accept=*/*, Accept-Encoding=gzip, deflate, br, Accept-Language=nl,en-US;q=0.7,en;q=0.3, Host=[redacted-hostname], Referer=https://app.emby.media/, User-Agent=Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:99.0) Gecko/20100101 Firefox/99.0, DNT=1, Origin=https://app.emby.media, X-Real-IP=10.10.0.10, X-Forwarded-For=10.10.0.10, sec-fetch-dest=empty, sec-fetch-mode=cors, sec-fetch-site=cross-site 2022-05-10 14:32:00.420 Info Server: http/1.1 Response 200 to 10.10.0.10. Time: 3ms. http://[redacted-hostname]/emby/videos/2561360/master.m3u8?DeviceId=9b0014dc-06bf-4a0a-8fba-bac2d419bd46&MediaSourceId=0&PlaySessionId=5b68630ba74a477a84e27877bd21132a&LiveStreamId=06044cf0e6f93cdae5f285c9ecfaaeb4_41c95b6de5174f82acbc56fe82d0a2f8_0&VideoCodec=h264&AudioCodec=aac&VideoBitrate=139808000&AudioBitrate=192000&TranscodingMaxAudioChannels=2&SegmentContainer=ts&MinSegments=1&BreakOnNonKeyFrames=True&ManifestSubtitles=vtt&h264-profile=high,main,baseline,constrainedbaseline&h264-level=52&TranscodeReasons=ContainerNotSupported,DirectPlayError&allowVideoStreamCopy=false&allowAudioStreamCopy=false 2022-05-10 14:32:00.438 Info Server: http/1.1 GET http://[redacted-hostname]/emby/videos/2561360/live.m3u8?DeviceId=9b0014dc-06bf-4a0a-8fba-bac2d419bd46&MediaSourceId=0&PlaySessionId=5b68630ba74a477a84e27877bd21132a&LiveStreamId=06044cf0e6f93cdae5f285c9ecfaaeb4_41c95b6de5174f82acbc56fe82d0a2f8_0&VideoCodec=h264&AudioCodec=aac&VideoBitrate=139808000&AudioBitrate=192000&TranscodingMaxAudioChannels=2&SegmentContainer=ts&MinSegments=1&BreakOnNonKeyFrames=True&ManifestSubtitles=vtt&h264-profile=high,main,baseline,constrainedbaseline&h264-level=52&TranscodeReasons=ContainerNotSupported,DirectPlayError&allowVideoStreamCopy=false&allowAudioStreamCopy=false. Accept=*/*, Accept-Encoding=gzip, deflate, br, Accept-Language=nl,en-US;q=0.7,en;q=0.3, Host=[redacted-hostname], Referer=https://app.emby.media/, User-Agent=Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:99.0) Gecko/20100101 Firefox/99.0, DNT=1, Origin=https://app.emby.media, X-Real-IP=10.10.0.10, X-Forwarded-For=10.10.0.10, sec-fetch-dest=empty, sec-fetch-mode=cors, sec-fetch-site=cross-site 2022-05-10 14:32:00.458 Info App: ProcessRun 'StreamTranscode 109d00' Execute: /bin/ffmpeg -loglevel +timing -y -print_graphs_file "/config/logs/ffmpeg-transcode-109d0027-4d9c-43ac-8873-80b135c0b07f_1graph.txt" -copyts -start_at_zero -analyzeduration 3000000 -i "http://127.0.0.1:8096/LiveTv/LiveStreamFiles/bf7880bbcb4e4ff4a58dcb70d5eed19e/stream.ts" -filter_complex "[v:0]yadif@f1=mode=send_frame:parity=auto:deint=all,format@f2=pix_fmts=yuv420p[f2_out0]" -map [f2_out0] -map a:0 -sn -c:v:0 libx264 -maxrate:v:0 10000000 -bufsize:v:0 20000000 -pix_fmt:v:0 yuv420p -force_key_frames:v:0 "expr:if(isnan(prev_forced_t),eq(t,t),gte(t,prev_forced_t+3))" -preset:v:0 veryfast -profile:v:0 high -level:v:0 3.1 -x264opts:v:0 "subme=0:me_range=4:rc_lookahead=10:partitions=none" -crf:v:0 23 -c:a:0 aac -ab:a:0 192000 -ac:a:0 2 -disposition:a:0 default -max_delay 5000000 -avoid_negative_ts disabled -f segment -map_metadata -1 -map_chapters -1 -segment_format mpegts -segment_list "/data/EmbyTranscoding/transcoding-temp/97BAFD.m3u8" -segment_list_type m3u8 -segment_time 3 -segment_list_entry_prefix hls/97BAFD/ -segment_start_number 0 -individual_header_trailer 0 -write_header_trailer 0 -segment_write_temp 1 "/data/EmbyTranscoding/transcoding-temp/97BAFD_%d.ts" 2022-05-10 14:32:00.503 Info Server: http/1.1 GET http://127.0.0.1:8096/LiveTv/LiveStreamFiles/bf7880bbcb4e4ff4a58dcb70d5eed19e/stream.ts. UserAgent: Lavf/58.35.100 2022-05-10 14:32:00.508 Error Server: Error processing request *** Error Report *** Version: 4.6.7.0 Command line: /system/EmbyServer.dll -programdata /config -ffdetect /bin/ffdetect -ffmpeg /bin/ffmpeg -ffprobe /bin/ffprobe -restartexitcode 3 Operating system: Linux version 5.15.0-27-generic (buildd@ubuntu) (gcc (Ubuntu 11.2.0-19ubuntu1) 11.2.0, GNU ld (GNU Binutils for Ubuntu) 2.38) #28-Ubuntu SMP Thu Apr 1 Framework: .NET Core 3.1.21 OS/Process: x64/x64 Runtime: system/System.Private.CoreLib.dll Processor count: 3 Data path: /config Application path: /system System.IO.FileNotFoundException: System.IO.FileNotFoundException: Could not find file '/data/EmbyTranscoding/transcoding-temp/bf7880bbcb4e4ff4a58dcb70d5eed19e.ts'. File name: '/data/EmbyTranscoding/transcoding-temp/bf7880bbcb4e4ff4a58dcb70d5eed19e.ts' at Interop.ThrowExceptionForIoErrno(ErrorInfo errorInfo, String path, Boolean isDirectory, Func`2 errorRewriter) at Microsoft.Win32.SafeHandles.SafeFileHandle.Open(String path, OpenFlags flags, Int32 mode) at System.IO.FileStream.OpenHandle(FileMode mode, FileShare share, FileOptions options) at System.IO.FileStream..ctor(String path, FileMode mode, FileAccess access, FileShare share, Int32 bufferSize, FileOptions options) at Emby.Server.Implementations.IO.ManagedFileSystem.GetFileStream(String path, FileOpenMode mode, FileAccessMode access, FileShareMode share, Int32 bufferSize, FileOpenOptions fileOpenOptions) at Emby.LiveTV.TunerHosts.LiveStream.CopyFile(String path, Boolean seekFile, Int32 emptyReadLimit, PipeWriter writer, IFileSystem fileSystem, IStreamHelper streamHelper, CancellationToken cancellationToken) at Emby.LiveTV.TunerHosts.LiveStream.CopyToAsync(PipeWriter writer, CancellationToken cancellationToken) at Emby.Server.Implementations.Services.ServiceHandler.ProcessRequestAsync(HttpListenerHost appHost, IRequest httpReq, IResponse httpRes, RestPath restPath, String responseContentType, CancellationToken cancellationToken) at Emby.Server.Implementations.HttpServer.HttpListenerHost.RequestHandler(IRequest httpReq, ReadOnlyMemory`1 urlString, ReadOnlyMemory`1 localPath, CancellationToken cancellationToken) Source: System.Private.CoreLib TargetSite: Void ThrowExceptionForIoErrno(ErrorInfo, System.String, Boolean, System.Func`2[Interop+ErrorInfo,Interop+ErrorInfo]) 2022-05-10 14:32:00.510 Info Server: http/1.1 Response 404 to 127.0.0.1. Time: 7ms. http://127.0.0.1:8096/LiveTv/LiveStreamFiles/bf7880bbcb4e4ff4a58dcb70d5eed19e/stream.ts 2022-05-10 14:32:00.516 Info App: AppendExtraLogData - Read graph file: /config/logs/ffmpeg-transcode-109d0027-4d9c-43ac-8873-80b135c0b07f_1graph.txt 2022-05-10 14:32:00.520 Info App: AppendExtraLogData - Deserialized GraphData fileStream: {0:n} bytes Graph Count: 1 2022-05-10 14:32:00.520 Info App: AppendExtraLogData - File Deleted 2022-05-10 14:32:00.521 Info App: ProcessRun 'StreamTranscode 109d00' Process exited with code 1 2022-05-10 14:32:00.526 Error Server: Error processing request *** Error Report *** Version: 4.6.7.0 Command line: /system/EmbyServer.dll -programdata /config -ffdetect /bin/ffdetect -ffmpeg /bin/ffmpeg -ffprobe /bin/ffprobe -restartexitcode 3 Operating system: Linux version 5.15.0-27-generic (buildd@ubuntu) (gcc (Ubuntu 11.2.0-19ubuntu1) 11.2.0, GNU ld (GNU Binutils for Ubuntu) 2.38) #28-Ubuntu SMP Thu Apr 1 Framework: .NET Core 3.1.21 OS/Process: x64/x64 Runtime: system/System.Private.CoreLib.dll Processor count: 3 Data path: /config Application path: /system System.Exception: System.Exception: Error starting ffmpeg at Emby.Server.MediaEncoding.Api.BaseStreamingService.StartFfMpeg(StreamState state, String outputPath, CancellationToken cancellationToken, Boolean acquireResources) at Emby.Server.MediaEncoding.Api.Hls.BaseHlsService.ProcessRequest(StreamRequest request) at Emby.Server.Implementations.Services.ServiceController.GetTaskResult(Task task) at Emby.Server.Implementations.Services.ServiceHandler.ProcessRequestAsync(HttpListenerHost appHost, IRequest httpReq, IResponse httpRes, RestPath restPath, String responseContentType, CancellationToken cancellationToken) at Emby.Server.Implementations.HttpServer.HttpListenerHost.RequestHandler(IRequest httpReq, ReadOnlyMemory`1 urlString, ReadOnlyMemory`1 localPath, CancellationToken cancellationToken) Source: Emby.Server.MediaEncoding TargetSite: Void MoveNext() 2022-05-10 14:32:00.527 Info Server: http/1.1 Response 500 to 10.10.0.10. Time: 88ms. http://[redacted-hostname]/emby/videos/2561360/live.m3u8?DeviceId=9b0014dc-06bf-4a0a-8fba-bac2d419bd46&MediaSourceId=0&PlaySessionId=5b68630ba74a477a84e27877bd21132a&LiveStreamId=06044cf0e6f93cdae5f285c9ecfaaeb4_41c95b6de5174f82acbc56fe82d0a2f8_0&VideoCodec=h264&AudioCodec=aac&VideoBitrate=139808000&AudioBitrate=192000&TranscodingMaxAudioChannels=2&SegmentContainer=ts&MinSegments=1&BreakOnNonKeyFrames=True&ManifestSubtitles=vtt&h264-profile=high,main,baseline,constrainedbaseline&h264-level=52&TranscodeReasons=ContainerNotSupported,DirectPlayError&allowVideoStreamCopy=false&allowAudioStreamCopy=false 2022-05-10 14:32:00.592 Info Server: http/1.1 OPTIONS http://[redacted-hostname]/emby/Sessions/Playing/Stopped?X-Emby-Client=Emby Web&X-Emby-Device-Name=Firefox Windows&X-Emby-Device-Id=9b0014dc-06bf-4a0a-8fba-bac2d419bd46&X-Emby-Client-Version=4.7.0.9. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:99.0) Gecko/20100101 Firefox/99.0 2022-05-10 14:32:00.592 Info Server: http/1.1 Response 200 to 10.10.0.10. Time: 0ms. http://[redacted-hostname]/emby/Sessions/Playing/Stopped?X-Emby-Client=Emby Web&X-Emby-Device-Name=Firefox Windows&X-Emby-Device-Id=9b0014dc-06bf-4a0a-8fba-bac2d419bd46&X-Emby-Client-Version=4.7.0.9 2022-05-10 14:32:00.593 Info Server: http/1.1 OPTIONS http://[redacted-hostname]/emby/Videos/ActiveEncodings?deviceId=9b0014dc-06bf-4a0a-8fba-bac2d419bd46&PlaySessionId=b40a2b0ed89b49b9a8c8f0dbffc12059&X-Emby-Client=Emby Web&X-Emby-Device-Name=Firefox Windows&X-Emby-Device-Id=9b0014dc-06bf-4a0a-8fba-bac2d419bd46&X-Emby-Client-Version=4.7.0.9. Accept=*/*, Accept-Encoding=gzip, deflate, br, Accept-Language=nl,en-US;q=0.7,en;q=0.3, Host=[redacted-hostname], Referer=https://app.emby.media/, User-Agent=Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:99.0) Gecko/20100101 Firefox/99.0, DNT=1, Origin=https://app.emby.media, Access-Control-Request-Method=DELETE, X-Real-IP=10.10.0.10, X-Forwarded-For=10.10.0.10, sec-fetch-dest=empty, sec-fetch-mode=cors, sec-fetch-site=cross-site 2022-05-10 14:32:00.593 Info Server: http/1.1 Response 200 to 10.10.0.10. Time: 0ms. http://[redacted-hostname]/emby/Videos/ActiveEncodings?deviceId=9b0014dc-06bf-4a0a-8fba-bac2d419bd46&PlaySessionId=b40a2b0ed89b49b9a8c8f0dbffc12059&X-Emby-Client=Emby Web&X-Emby-Device-Name=Firefox Windows&X-Emby-Device-Id=9b0014dc-06bf-4a0a-8fba-bac2d419bd46&X-Emby-Client-Version=4.7.0.9 2022-05-10 14:32:00.636 Info Server: http/1.1 POST http://[redacted-hostname]/emby/Sessions/Playing/Stopped?X-Emby-Client=Emby Web&X-Emby-Device-Name=Firefox Windows&X-Emby-Device-Id=9b0014dc-06bf-4a0a-8fba-bac2d419bd46&X-Emby-Client-Version=4.7.0.9. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:99.0) Gecko/20100101 Firefox/99.0 2022-05-10 14:32:00.636 Info Server: http/1.1 DELETE http://[redacted-hostname]/emby/Videos/ActiveEncodings?deviceId=9b0014dc-06bf-4a0a-8fba-bac2d419bd46&PlaySessionId=b40a2b0ed89b49b9a8c8f0dbffc12059&X-Emby-Client=Emby Web&X-Emby-Device-Name=Firefox Windows&X-Emby-Device-Id=9b0014dc-06bf-4a0a-8fba-bac2d419bd46&X-Emby-Client-Version=4.7.0.9. Accept=*/*, Accept-Encoding=gzip, deflate, br, Accept-Language=nl,en-US;q=0.7,en;q=0.3, Host=[redacted-hostname], Referer=https://app.emby.media/, User-Agent=Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:99.0) Gecko/20100101 Firefox/99.0, DNT=1, Origin=https://app.emby.media, X-Real-IP=10.10.0.10, X-Forwarded-For=10.10.0.10, sec-fetch-dest=empty, sec-fetch-mode=cors, sec-fetch-site=cross-site 2022-05-10 14:32:00.637 Info Server: http/1.1 Response 204 to 10.10.0.10. Time: 1ms. http://[redacted-hostname]/emby/Videos/ActiveEncodings?deviceId=9b0014dc-06bf-4a0a-8fba-bac2d419bd46&PlaySessionId=b40a2b0ed89b49b9a8c8f0dbffc12059&X-Emby-Client=Emby Web&X-Emby-Device-Name=Firefox Windows&X-Emby-Device-Id=9b0014dc-06bf-4a0a-8fba-bac2d419bd46&X-Emby-Client-Version=4.7.0.9 2022-05-10 14:32:00.644 Info SessionManager: Playback stopped reported by app Emby Web 4.7.0.9 playing NPO 1 HD. Stopped at 0 ms 2022-05-10 14:32:00.647 Info MediaSourceManager: Live stream null consumer count is now 0 2022-05-10 14:32:00.647 Info MediaSourceManager: Closing live stream 06044cf0e6f93cdae5f285c9ecfaaeb4_41c95b6de5174f82acbc56fe82d0a2f8_0 2022-05-10 14:32:00.647 Info SharedHttpPipelineSource: Closing SharedHttpPipelineSource 2022-05-10 14:32:00.650 Info MediaSourceManager: Live stream 06044cf0e6f93cdae5f285c9ecfaaeb4_41c95b6de5174f82acbc56fe82d0a2f8_0 closed successfully 2022-05-10 14:32:00.651 Info Server: http/1.1 Response 204 to 10.10.0.10. Time: 15ms. http://[redacted-hostname]/emby/Sessions/Playing/Stopped?X-Emby-Client=Emby Web&X-Emby-Device-Name=Firefox Windows&X-Emby-Device-Id=9b0014dc-06bf-4a0a-8fba-bac2d419bd46&X-Emby-Client-Version=4.7.0.9 2022-05-10 14:32:04.348 Info Server: http/1.1 GET http://[redacted-hostname]/emby/System/ActivityLog/Entries?StartIndex=0&Limit=10&MinDate=2022-05-03T12:32:03.551Z&hasUserId=true&X-Emby-Client=Emby Web&X-Emby-Device-Name=Firefox Windows&X-Emby-Device-Id=9b0014dc-06bf-4a0a-8fba-bac2d419bd46&X-Emby-Client-Version=4.7.0.10. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:99.0) Gecko/20100101 Firefox/99.0 2022-05-10 14:32:04.354 Info Server: http/1.1 GET http://[redacted-hostname]/emby/System/ActivityLog/Entries?StartIndex=0&Limit=4&MinDate=2022-05-03T12:32:03.552Z&hasUserId=false&X-Emby-Client=Emby Web&X-Emby-Device-Name=Firefox Windows&X-Emby-Device-Id=9b0014dc-06bf-4a0a-8fba-bac2d419bd46&X-Emby-Client-Version=4.7.0.10. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:99.0) Gecko/20100101 Firefox/99.0 2022-05-10 14:32:04.354 Info Server: http/1.1 GET http://[redacted-hostname]/emby/System/ActivityLog/Entries?StartIndex=0&Limit=10&MinDate=2022-05-03T12:32:03.554Z&hasUserId=true&X-Emby-Client=Emby Web&X-Emby-Device-Name=Firefox Windows&X-Emby-Device-Id=9b0014dc-06bf-4a0a-8fba-bac2d419bd46&X-Emby-Client-Version=4.7.0.10. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:99.0) Gecko/20100101 Firefox/99.0 2022-05-10 14:32:04.363 Info Server: http/1.1 Response 200 to 10.10.0.10. Time: 15ms. http://[redacted-hostname]/emby/System/ActivityLog/Entries?StartIndex=0&Limit=10&MinDate=2022-05-03T12:32:03.551Z&hasUserId=true&X-Emby-Client=Emby Web&X-Emby-Device-Name=Firefox Windows&X-Emby-Device-Id=9b0014dc-06bf-4a0a-8fba-bac2d419bd46&X-Emby-Client-Version=4.7.0.10 2022-05-10 14:32:04.363 Info Server: http/1.1 Response 200 to 10.10.0.10. Time: 10ms. http://[redacted-hostname]/emby/System/ActivityLog/Entries?StartIndex=0&Limit=4&MinDate=2022-05-03T12:32:03.552Z&hasUserId=false&X-Emby-Client=Emby Web&X-Emby-Device-Name=Firefox Windows&X-Emby-Device-Id=9b0014dc-06bf-4a0a-8fba-bac2d419bd46&X-Emby-Client-Version=4.7.0.10 2022-05-10 14:32:04.364 Info Server: http/1.1 Response 200 to 10.10.0.10. Time: 10ms. http://[redacted-hostname]/emby/System/ActivityLog/Entries?StartIndex=0&Limit=10&MinDate=2022-05-03T12:32:03.554Z&hasUserId=true&X-Emby-Client=Emby Web&X-Emby-Device-Name=Firefox Windows&X-Emby-Device-Id=9b0014dc-06bf-4a0a-8fba-bac2d419bd46&X-Emby-Client-Version=4.7.0.10 2022-05-10 14:32:04.588 Info Server: http/1.1 GET http://[redacted-hostname]/emby/System/ActivityLog/Entries?StartIndex=0&Limit=10&MinDate=2022-05-03T12:32:03.798Z&hasUserId=true&X-Emby-Client=Emby Web&X-Emby-Device-Name=Firefox Windows&X-Emby-Device-Id=9b0014dc-06bf-4a0a-8fba-bac2d419bd46&X-Emby-Client-Version=4.7.0.9. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:99.0) Gecko/20100101 Firefox/99.0 2022-05-10 14:32:04.592 Info Server: http/1.1 Response 200 to 10.10.0.10. Time: 3ms. http://[redacted-hostname]/emby/System/ActivityLog/Entries?StartIndex=0&Limit=10&MinDate=2022-05-03T12:32:03.798Z&hasUserId=true&X-Emby-Client=Emby Web&X-Emby-Device-Name=Firefox Windows&X-Emby-Device-Id=9b0014dc-06bf-4a0a-8fba-bac2d419bd46&X-Emby-Client-Version=4.7.0.9 2022-05-10 14:32:04.596 Info Server: http/1.1 GET http://[redacted-hostname]/emby/System/ActivityLog/Entries?StartIndex=0&Limit=4&MinDate=2022-05-03T12:32:03.798Z&hasUserId=false&X-Emby-Client=Emby Web&X-Emby-Device-Name=Firefox Windows&X-Emby-Device-Id=9b0014dc-06bf-4a0a-8fba-bac2d419bd46&X-Emby-Client-Version=4.7.0.9. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:99.0) Gecko/20100101 Firefox/99.0 2022-05-10 14:32:04.598 Info Server: http/1.1 Response 200 to 10.10.0.10. Time: 2ms. http://[redacted-hostname]/emby/System/ActivityLog/Entries?StartIndex=0&Limit=4&MinDate=2022-05-03T12:32:03.798Z&hasUserId=false&X-Emby-Client=Emby Web&X-Emby-Device-Name=Firefox Windows&X-Emby-Device-Id=9b0014dc-06bf-4a0a-8fba-bac2d419bd46&X-Emby-Client-Version=4.7.0.9 2022-05-10 14:32:05.362 Info Server: http/1.1 GET http://[redacted-hostname]/emby/System/ActivityLog/Entries?StartIndex=0&Limit=4&MinDate=2022-05-03T12:32:04.561Z&hasUserId=false&X-Emby-Client=Emby Web&X-Emby-Device-Name=Firefox Windows&X-Emby-Device-Id=9b0014dc-06bf-4a0a-8fba-bac2d419bd46&X-Emby-Client-Version=4.7.0.10. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:99.0) Gecko/20100101 Firefox/99.0 2022-05-10 14:32:05.364 Info Server: http/1.1 Response 200 to 10.10.0.10. Time: 2ms. http://[redacted-hostname]/emby/System/ActivityLog/Entries?StartIndex=0&Limit=4&MinDate=2022-05-03T12:32:04.561Z&hasUserId=false&X-Emby-Client=Emby Web&X-Emby-Device-Name=Firefox Windows&X-Emby-Device-Id=9b0014dc-06bf-4a0a-8fba-bac2d419bd46&X-Emby-Client-Version=4.7.0.10 2022-05-10 14:32:08.157 Info Server: http/1.1 GET http://[redacted-hostname]/emby/System/Logs/embyserver.txt?Sanitize=true. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:99.0) Gecko/20100101 Firefox/99.0 TvHeadend: 2022-05-10 14:29:34.421 htsp: Got connection from 127.0.0.1 2022-05-10 14:29:34.430 htsp: 127.0.0.1: Identified as user 'Emby' (unverified) 2022-05-10 14:29:34.430 htsp: 127.0.0.1 [ Emby ]: Welcomed client software: TVHclient4Emby-4.6.7.0 (HTSPv20) 2022-05-10 14:29:34.434 htsp: 127.0.0.1 [ Emby | TVHclient4Emby-4.6.7.0 ]: Identified as user 'Emby' 2022-05-10 14:29:34.434 htsp: 127.0.0.1 [ Emby | TVHclient4Emby-4.6.7.0 ]: Privileges updated 2022-05-10 14:30:25.470 htsp: 127.0.0.1 [ Emby | TVHclient4Emby-4.6.7.0 ]: Disconnected 2022-05-10 14:31:39.841 htsp: Got connection from 127.0.0.1 2022-05-10 14:31:39.851 htsp: 127.0.0.1: Identified as user 'Emby' (unverified) 2022-05-10 14:31:39.851 htsp: 127.0.0.1 [ Emby ]: Welcomed client software: TVHclient4Emby-4.6.7.0 (HTSPv20) 2022-05-10 14:31:39.855 htsp: 127.0.0.1 [ Emby | TVHclient4Emby-4.6.7.0 ]: Identified as user 'Emby' 2022-05-10 14:31:39.855 htsp: 127.0.0.1 [ Emby | TVHclient4Emby-4.6.7.0 ]: Privileges updated 2022-05-10 14:31:39.931 mpegts: 386MHz in Ziggo - tuning on Minisatip DVB-C Tuner #1 (10.10.0.86@TCP) 2022-05-10 14:31:39.932 subscription: 01A4: "HTTP" subscribing on channel "NPO 1 HD", weight: 100, adapter: "Minisatip DVB-C Tuner #1 (10.10.0.86@TCP)", network: "Ziggo", mux: "386MHz", provider: "Ziggo", service: "NPO 1 HD", profile="pass", hostname="127.0.0.1", username="Emby" 2022-05-10 14:31:56.273 TS: Ziggo/386MHz/NPO 1 HD: H264 @ #2001 Continuity counter error (total 1) 2022-05-10 14:31:56.273 TS: Ziggo/386MHz/NPO 1 HD: MPEG2AUDIO @ #2013 Continuity counter error (total 1) 2022-05-10 14:31:56.273 TS: Ziggo/386MHz/NPO 1 HD: MPEG2AUDIO @ #2011 Continuity counter error (total 1) 2022-05-10 14:31:56.273 TS: Ziggo/386MHz/NPO 1 HD: TELETEXT @ #2101 Continuity counter error (total 1) 2022-05-10 14:31:56.273 TS: Ziggo/386MHz/NPO 1 HD: AC3 @ #2012 Continuity counter error (total 1) 2022-05-10 14:31:57.420 subscription: 01A4: "HTTP" unsubscribing from "NPO 1 HD", hostname="127.0.0.1", username="Emby" What did i verify: TvHeadend works and http://Emby:[redacted-tvheadend-password]@127.0.0.1:9981/stream/channelid/1487494759 returns infinite amounts of data. Channels, Icons and Guide all are being loaded successfully. /data/EmbyTranscoding/transcoding-temp/ is writeable. So... What else should I check? looks like you may have customized your server transcoding temp folder to a location that the server doesn't have write access to. Try setting that back to default.
Groentjuh 0 Posted May 10, 2022 Posted May 10, 2022 (edited) 8 hours ago, Luke said: looks like you may have customized your server transcoding temp folder to a location that the server doesn't have write access to. Try setting that back to default. That seems to be the issue. I do not really know how I will fix it, but it does give me some direction. What is happening here: I use a NAS for big file storage. Long TV sessions will become pretty big, so I mount a "transcoding temp folder" to a cif mounted folder on the nas. That folder gets passed to the docker container. It seems updates (somewhere; could even be Ubuntu in this case) have broken something there. What I noticed is that Emby can make the transcoding-temp directory if missing, so it seem writeable...!? It seems to also create and remove a ".ts"-file. Edit: Remounting using NFS also does not work. Edited May 11, 2022 by Groentjuh
Luke 42241 Posted May 11, 2022 Posted May 11, 2022 You can't just revert it back to default, even for testing purposes?
Groentjuh 0 Posted May 11, 2022 Posted May 11, 2022 (edited) 4 hours ago, Luke said: You can't just revert it back to default, even for testing purposes? If i do not make it a share from the nas, it works. But that limits my playback time, so is not the wanted situation. Edit: Got it fixed! Needed to add "cache=none" to the mount options. Guessing it is some race condition happening here... Edited May 11, 2022 by Groentjuh
mrtj18 4 Posted August 12, 2024 Posted August 12, 2024 I just would like to add, I was receiving the "mediabroswer" error as well , using the tvheadend plug-in. What fixed the error for me, was I had to use persistent authentication for my username I use with Emby and tvheadend. And after I rebooted tvheadend the plug-in began to work 1
