NeverExists 21 Posted April 25, 2022 Posted April 25, 2022 Hey, I just added One Piece Season 16 to my library, and it put it first ahead of Specials and season 1..... So it goes Season 16, Specials, Season 1, Season 2 , Season 3 etc......
RanmaCanada 500 Posted April 25, 2022 Posted April 25, 2022 Anime is a problem as the naming scheme is kind of broken. They don't have seasons but western media needs there to be seasons. The best thing I can recommend is to ensure files are named either as per the tvdb, or you have the entire library set to absolute numbering. Anime has been an absolute crap shoot for years.
NeverExists 21 Posted April 25, 2022 Author Posted April 25, 2022 1 minute ago, RanmaCanada said: Anime is a problem as the naming scheme is kind of broken. They don't have seasons but western media needs there to be seasons. The best thing I can recommend is to ensure files are named either as per the tvdb, or you have the entire library set to absolute numbering. Anime has been an absolute crap shoot for years. I have everything already named properly. Cause I use TVDB and this is the first time I've ever had this issue. I have over 300 anime and this is the only one that does it so I don't think it has to do with that. I'm pretty sure it's a bug.
RanmaCanada 500 Posted April 25, 2022 Posted April 25, 2022 15 minutes ago, NeverExists said: I have everything already named properly. Cause I use TVDB and this is the first time I've ever had this issue. I have over 300 anime and this is the only one that does it so I don't think it has to do with that. I'm pretty sure it's a bug. I've got over 900, and this type of stuff happens regularly.
NeverExists 21 Posted April 25, 2022 Author Posted April 25, 2022 45 minutes ago, RanmaCanada said: I've got over 900, and this type of stuff happens regularly. You must be doing something wrong, cause I've never has any problems with anime TV Shows. 1
Solution NeverExists 21 Posted April 25, 2022 Author Solution Posted April 25, 2022 47 minutes ago, Happy2Play said: What metadata is shown for Season 16? Haha thanks that sorted it out. I had it spelled Seaason 16 lol there's a first time for everything. Thanks again for the help. 1
Happy2Play 9801 Posted April 25, 2022 Posted April 25, 2022 3 minutes ago, NeverExists said: Haha thanks that sorted it out. I had it spelled Seaason 16 lol there's a first time for everything. Thanks again for the help. And none of us looks closely enough at the image to notice exactly that.
Luke 42186 Posted April 26, 2022 Posted April 26, 2022 Hi there, how are your files named and organized? I've actually been working on improving both anime and general absolute ordering number parsing. Not all of these changes will make it into Emby Server 4.7 but hopefully soon after in a 4.7.x follow-up. Thanks.
NeverExists 21 Posted April 26, 2022 Author Posted April 26, 2022 33 minutes ago, Luke said: Hi there, how are your files named and organized? I've actually been working on improving both anime and general absolute ordering number parsing. Not all of these changes will make it into Emby Server 4.7 but hopefully soon after in a 4.7.x follow-up. Thanks. I follow the TVDB naming convention. They have alot of info in the file name including the name of the encoder which is important to keep track of the release you have. So when a better release comes out you cam see which release you have compared to the other one. Besides that, the most important thing for me us the specials integrated into the seasons and the function of ASS Subtitles. It would be nice for you guys to bring back the option to use a different Metadata provider for each show. Cause some shows are better to use TMDB and some with TVDB. You guys used to have that feature and it worked great. Unless you moved it, I don't see it anymore per show.
