Episode TV Retention Management (Auto Delete)
AgileHumor
I was wondering if some shows could get a retention for TV series.
My use case is using WMC to record shows and then DVRMSToolbox to rename Protected/Cablecard content or strip commercials for ClearQAM.  However, once I copy out of the WMC recorded TV folder (which is fine since I use MBC interface), I can't use WMC built in Recorded TV retention policies.
Was wondering if certain series can get episode management.  The WMC options are:
  1. Under Keep, select one of the following options:
    • Until space needed: Automatically deletes recordings to make space for new ones.
    • For 1 week: Automatically deletes a recording one week after it was recorded.
    • Until I watch: Automatically deletes a recording after you finish watching it.
    • Until I delete: Won't automatically delete any recordings.
When you schedule a recording for a TV series, Media Center automatically records episodes based on the options that you set here.
  1. Under Keep up to, choose how many recordings from this series to keep before older episodes are automatically deleted.
Just an idea...
Edited by AgileHumor
  • Like 1
