PeterWug 0 Posted April 24, 2022 Posted April 24, 2022 (edited) Hi community! I have several movies with multiple audio tracks (mostly MKV). Example: Movie1.mkv with audio spanish & english Movie2.mkv with audio french & english a.s.o. In the settings I can enable the folowwing for my collection: - Title - Year - Community Ranking - Critics Ranking - Age But NO LANGUAGE? How to enable (or hack or custom script) it? My family needs to know the avaible audio tracks / languages by browsing the libraries... At the moment they have to CLICK on every single movie to see the available audio tracks. Work around: I manualy edit every title to "Name of Movie (ES/EN)" or "Name of Movie (FR/EN)" or "Name of Move (EN)" or "Name of Movie (RUS/EN/ES) a.s.o. Edited April 24, 2022 by PeterWug
roaku 842 Posted April 24, 2022 Posted April 24, 2022 (edited) I wrote the Iconic plugin to solve similar problems to yours by adding icons to the item images based on the item's properties. I think the MediaStream rule might help your specific case. Edited April 24, 2022 by roaku
PeterWug 0 Posted April 24, 2022 Author Posted April 24, 2022 > For example, if you wanted to see a Commentary Icon for you movies with commentary tracks and you have your audio tracks titled like below, you can make a MediaStream rule with two properties like so: Type: 'Audio' Title: 'commentary' > I can't find "AUDIO" as property key
roaku 842 Posted April 24, 2022 Posted April 24, 2022 10 minutes ago, PeterWug said: > For example, if you wanted to see a Commentary Icon for you movies with commentary tracks and you have your audio tracks titled like below, you can make a MediaStream rule with two properties like so: Type: 'Audio' Title: 'commentary' > I can't find "AUDIO" as property key The property key is 'Type'. You give it the value 'Audio'.
PeterWug 0 Posted April 24, 2022 Author Posted April 24, 2022 Did it, but then there is no input field to enter "English" or any language (or "commentary) source: Quote: ---- For MediaStream rules, they're based on information you can see at the bottom of the web app for an individual movie item. For example, if you wanted to see a Commentary Icon for you movies with commentary tracks and you have your audio tracks titled like below, you can make a MediaStream rule with two properties like so: Type: 'Audio' Title: 'commentary' When Iconic checks this rule, it will look at each MediaStream below to see that the Type property *contains* 'audio' and that the Title property *contains* 'commentary'. The check is case insensitive and will match things like 'commentary', 'Commentary 1', 'This is a commentary'. You can do the same thing with Video MediaStreams.- ------
PeterWug 0 Posted April 24, 2022 Author Posted April 24, 2022 ...and what to select then as Property Key? (I can't select TYPE again, neither there is "AUDIO" (thank you very much by the way!!!)
roaku 842 Posted April 24, 2022 Posted April 24, 2022 2 minutes ago, PeterWug said: ...and what to select then as Property Key? (I can't select TYPE again, neither there is "AUDIO" (thank you very much by the way!!!) Well, it depends on what you're trying to accomplish. If you want to test against the Language field of your item's Audio tracks, select 'Language' or 'DisplayLanguage' as the key for your new property and give it a value of 'deutsch' or whatever makes sense. If you want to test against the Title field of your item's Audio tracks, select 'Title' as the key for your new property and give it a value of 'deutsch' or whatever makes sense. And this is how the rule tests for a match: 33 minutes ago When Iconic checks this rule, it will look at each MediaStream below to see that the Type property *contains* 'audio' and that the Title property *contains* 'commentary'. The check is case insensitive and will match things like 'commentary', 'Commentary 1', 'This is a commentary'.
PeterWug 0 Posted April 25, 2022 Author Posted April 25, 2022 Thanks a lot for your help, but at the very end this is not what I would expect. Too hacky, and not really visually working if 3 or more languages (multi language movies)... The Information is already there, in the INFO or NFO or METADATA of the movie: <audio> <codec>DTS</codec> <language>eng</language> <channels>6</channels> </audio> How to display it like this?
Happy2Play 9811 Posted April 25, 2022 Posted April 25, 2022 (edited) Currently there is no way to do this as there would need to be code changes in every client and server. But since you are talking about the web client you would have to find the script and possibly html to add. Edited April 25, 2022 by Happy2Play
roaku 842 Posted April 25, 2022 Posted April 25, 2022 8 hours ago, PeterWug said: Thanks a lot for your help, but at the very end this is not what I would expect. Too hacky, and not really visually working if 3 or more languages (multi language movies)... The Information is already there, in the INFO or NFO or METADATA of the movie: <audio> <codec>DTS</codec> <language>eng</language> <channels>6</channels> </audio> How to display it like this? Well, that's too bad. For everyone else, Iconic comes with a lot of badge customization options to get just the look you want, and registered versions support multiple tag rules.
