CyberPoison 33 Posted April 24, 2022 Posted April 24, 2022 Hello guys i have some artifact and jumps on emby wille on VLC is everything OK anyone have any idea ? bot screen shots here. Emby: VLC (Same Channel) : On my tvheadend it is on pass, tried all diferent profiles but no luck with that, IPTV Server Info: HardWare: Moi Pro AMD OS: Ubuntu 20.04 Internet speed : Local network is 1Gb/s and internet is 20Mb/s Upload | 80Mb/s Download https://www.speedtest.net/result/13072168284 IPTV SF: TVHeadEnd Emby: Image: linuxserver/emby:amd64-version-4.6.4.0 On a K8S/RKE Stack OS: Ubuntu 19.04 Dedicated Hosting: 10Gb/s The ffmpeg and emby logs: ffmpeg-transcode-d290a4ce-a674-44a0-888b-5d65b0350604_1.txt embyserver.txt Any idea ?
Luke 42243 Posted April 24, 2022 Posted April 24, 2022 Hi there, are you able to update to emby server 4.6.7?
CyberPoison 33 Posted April 24, 2022 Author Posted April 24, 2022 (edited) Hi @Luke i have set the image to a fixed version because i have changed some things in the web UI, i will try to update to newer versions the next weekend. But just questioning can unstable internet upload cause this kind of image jumps and image artifacts? Since i use it to upload to my dedicated server and then receive from dedicated to my home? Edited April 24, 2022 by CyberPoison
Luke 42243 Posted April 24, 2022 Posted April 24, 2022 That could be a factor, yes. Lowering the in app quality setting can help mitigate that although I see you've already set it to around 1 mpbs.
