MADVirus 1 Posted April 22, 2022 Posted April 22, 2022 (edited) Hi, When i try to cast something to my TV , i get the image and description of the show/movie. But i can’t play it, and if i mash the play button it says "no compatible flux ....". And, of course, i did reboot the server and chromecast. If someone can help me, thank. hardware_detection-63786218748.txt embyserver.txt Edited April 22, 2022 by MADVirus Add info
Luke 42246 Posted April 22, 2022 Posted April 22, 2022 HI there, what exactly are you trying to play?
MADVirus 1 Posted April 22, 2022 Author Posted April 22, 2022 a movie, "the fantastic beast" encode with h264. But it's the same with all the other media.
MADVirus 1 Posted April 25, 2022 Author Posted April 25, 2022 Yes, I'm still getting the summary on the chromecast and the media is not playing. And if I repeatedly click play, there is the same message that appears over the summary (Aucun flux compatible n'est actuellement disponible. Veuillez ressayer plus tard ou contactez votre administrateur système pour plus de détails.)
Luke 42246 Posted April 30, 2022 Posted April 30, 2022 Can you provide a different log example as I don't see anything obvious here. Thanks.
MADVirus 1 Posted May 1, 2022 Author Posted May 1, 2022 Now it work. I thought, Emby settings where fine because, all work well on PC, Tablet, Phone even remotely every thing work well. But in fact for the chromecast to work you have to complete the network setting in Emby and specify Emby local and remote address. i hope it was only that, i'll will continue my testing to be sure.
Thuzad 50 Posted May 1, 2022 Posted May 1, 2022 If @MADVirus launch the media via the iOS app, I think is the same problem of this topic:
MADVirus 1 Posted May 2, 2022 Author Posted May 2, 2022 thx @Thuzad, i dont think this issue applis to me, because i was unable to cast from any device or client. And to answer your question i test the Android client app, i dont have Apple device. 1
Luke 42246 Posted May 10, 2022 Posted May 10, 2022 @MADVirus can you try this again? Are you still running into this?
MADVirus 1 Posted May 10, 2022 Author Posted May 10, 2022 I'm still getting the same issue. Can you tell me if I'm doing something wrong, I did attach my system config? By the way I forgot to say that Emby runs in a container. system.xml
Luke 42246 Posted May 20, 2022 Posted May 20, 2022 HI, are you still running into this? Have you updated to the new Emby Server 4.7 release?
