Cxodael 0 Posted April 21, 2022 Posted April 21, 2022 (edited) Hi, I'm using Emby on a Fire Stick 4k (last generation) plugged into an OLED TV powered by WebOS (LG), the C9 and everytime I launch a movie, 4K or not, HDR or not, with a ratio not equal to the one of the TV, there are grey bars showing on the sides of the content. It's as if Emby is filling up the empty space with grey bars instead of black ones. It's really annoying and distracting as I'm losing completely the point of having an OLED TV. The issue does not come up on the official Emby app on WebOS so everytime I face this issue, I must go back to using the WebOS app which has other issues too (PGSUB subtitles not displaying) so this is not an ideal solution. Thank you in advance. Edited April 21, 2022 by Cxodael
ebr 16337 Posted April 21, 2022 Posted April 21, 2022 Hi. What version of the Fire app do you have installed? We solved this issue years ago... Is it possible the TV has a setting that would be doing this?
rbjtech 5344 Posted April 21, 2022 Posted April 21, 2022 (edited) 1 hour ago, ebr said: Hi. What version of the Fire app do you have installed? We solved this issue years ago... Is it possible the TV has a setting that would be doing this? From memory Eric this was on Sony TV's ? @Cxodael - worth checking the 'Playback' settings in the Emby FireTV App (Match Video Resolution and maybe Enable Refresh Rate Switching) but also ensure your TV Aspect ratio is set to Auto ? Edited April 21, 2022 by rbjtech
Cxodael 0 Posted April 22, 2022 Author Posted April 22, 2022 (edited) Sorry I couldn't answer and still haven't got the chance to try these things out. Apparently there could be an issue with the Fire Stick brightness, requiring the LG OLED TV brightness to be decreased (and indeed, I already figured out months ago that my movies didn't look quite the same on WebOS and on the Fire Stick so it could be just that). This is something talked on reddit. I'm gonna try all this this evening and will sure post a feedback afterwards. Thanks! Edited April 22, 2022 by Cxodael
Luke 42245 Posted April 22, 2022 Posted April 22, 2022 58 minutes ago, Cxodael said: Sorry I couldn't answer and still haven't got the chance to try these things out. Apparently there could be an issue with the Fire Stick brightness, requiring the LG OLED TV brightness to be decreased (and indeed, I already figured out months ago that my movies didn't look quite the same on WebOS and on the Fire Stick so it could be just that). This is something talked on reddit. I'm gonna try all this this evening and will sure post a feedback afterwards. Thanks! Let us know how you get on. Thanks.
Solution Cxodael 0 Posted April 22, 2022 Author Solution Posted April 22, 2022 All settings on the Fire Stick and the app were fine. It was indeed an issue with the TV brightness which is kind of weird but the picture looks now cleaner and the issue is solved. For those experiencing this issue, if you're on Cinema Home mode, decrease WebOS brightness to 49.
ebr 16337 Posted April 23, 2022 Posted April 23, 2022 Excellent. Thanks for reporting back. A little known fact is that "brightness" on a display is actually an adjustment of black level.
ebr 16337 Posted April 23, 2022 Posted April 23, 2022 Just to complete the thought - the control labeled "contrast" is actually an adjustment of white level.
Cxodael 0 Posted April 23, 2022 Author Posted April 23, 2022 Oh interesting. Pretty confusing but I get it. Thank you
