softworkz 5133 Posted August 14, 2022 Posted August 14, 2022 (edited) 12 hours ago, horstepipe said: But just avoiding DV content in general honestly doesn't feel right lol. If watching videos with wrong tint feels "more right" to you, then feel free to continue collecting those videos... 12 hours ago, horstepipe said: I'm wondering whether that issue only occurs on TVs which do not support DV, or does this happen also on TVs which support DV? You'll need to try on a case-by-case basis. Case-by-case means testing each video on each TV with DV support. When a TV advertises "support" for DV, that doesn't mean that it will support each DV profile in each video container and with each codec variant. It's not much of Emby's business anymore as even when that works, it would rule out all Emby functionality (re-scaling, re-encoding, segmenting for HLS delivery, subtitle burn-in, etc.), which means that as soon as any of these would be used, you will get wrong tinted video, no matter what your TV's capabilities are. There's no solution in sight, hence my advice. Edited August 15, 2022 by softworkz 1
Guest Posted August 21, 2022 Posted August 21, 2022 Listen to Softworkz. Dolby is once again screwing everyone. They shout very loudly (just like Apple) that what they have produced is SO MUCH better than its predecessors, that they have convinced the masses (so they can make more money). Is Dolby Vision better that HDR10+, or even HDR10? Eh! Maybe... If you have perfect visual acuity, expensive displays which are correctly calibrated, you have the correct media, that media was perfectly graded by the colorist and you watch it in an environment that is tailored to the display calibration. Don't make yourself crazy, thinking that what you're seeing is the best possible version. It most probably isn't.
Lee 212 Posted September 4, 2022 Posted September 4, 2022 can you encode dolby vision out with ffmpeg?
softworkz 5133 Posted September 4, 2022 Posted September 4, 2022 7 minutes ago, Lee said: can you encode dolby vision out with ffmpeg? No. 1
horstepipe 423 Posted March 22, 2023 Posted March 22, 2023 (edited) I need to come back to this topic once more. Since our discussion here I blacklisted release groups which produce releases with the green/purple problem. This works quite good. Looks like some release groups handle it right, some not. Could anybody explain how the first group achieves that, I guess they do some postprocessing of the video like adding some kind of fallback? Unfortunately I'm having a bunch of old files which are renamed by filebot - so I don't know the groups of these files anymore. Is there any script (optimal case for linux) to check these files for wrong colors by reading out the dv profile or whatever is needed for a suspected case of the green/purple issue? Best regards Edited March 22, 2023 by horstepipe
KMBanana 116 Posted March 22, 2023 Posted March 22, 2023 DV Profile 5 has no HDR10/SDR fallback available. It's what is used in basically all web content with DV like Disney+ or Netflix or whatever. This works fine for them because if your setup doesn't support Dolby Vision they send you an entirely different file with either HDR or SDR instead. But if you have a local file with DV profile 5 and you try to play it on a setup that doesn't fully support DV, you get the green/purple mess. Profile 7 is what is used for UHDs and offers fallback, as does profile 8. Most playback clients that advertise DV support only support profile 5.
horstepipe 423 Posted March 22, 2023 Posted March 22, 2023 (edited) thanks. So videos coming from streaming service and DO NOT have the purple/green problem on a NOT dv compatible device have to be manually added that fallback by the release group? Is there something in mediainfo (or any other tool, preferably with cli support) where I can see whether the video has added that fallback although it is dv profile 5? Edited March 22, 2023 by horstepipe
KMBanana 116 Posted March 22, 2023 Posted March 22, 2023 DV is confusing with lots of options, and definitely don't treat this as fully accurate or me as an expert. I really only am somewhat familiar with remuxing a UHD disk, which uses profile 7 already and therefore already supports fallback. It isn't as simple as just adding fallback, if it's DV Profile 5 it cannot support fallback. Someone would need to extract the DV information from a DV file, then apply it to an HDR/SDR version while converting it to DV Profile 7/8. In general I would assume anything labeled DV without explicitly also being labeled as HDR10 is profile 5 and therefore has no fallback. This isn't a perfect solution, I believe files with DV and HDR10+ would only list as supporting DV despite HDR10+ having HDR10 fallback inherently. It's a mess, it'll probably get better over time. 1
Guest Posted March 23, 2023 Posted March 23, 2023 mpv does not pass the metadata like it does with HDR10. It will tone map (and potentially output to HDR10), and output to SDR. As for the profiles, it should be able to play all of them.
Guest Posted March 23, 2023 Posted March 23, 2023 13 hours ago, horstepipe said: Could anybody explain how the first group achieves that, I guess they do some postprocessing of the video like adding some kind of fallback It isn't fallback, unless the HDR10 stream is already present, then the player just chooses to play that. For DV exclusive streams, since Dolby made it proprietary, reverse engineering has been performed to identify the metadata in DV and map it so it can be read. Geniuses like Softworkz and his brethren at ffmpeg found a way to read the DV metadata, but I believe not all profiles. This is where other like minded geniuses come in. Haasn is one of the mpv developers. He's pretty much the only maintainer for the video decoding they have , now. He developed libplacebo. This is what gpu-next uses in mpv. Haasn was able to find a way to read and decode DV in libplacebo. There is an extreme amount of data and information in regards to this. I won't pretend to understand it all. These guys are on a level all their own. I have read some of the code that Haasn wrote. Not only do I not understand the language, but the mathematical equations to calculate and be written to adhere to the multitude of tonal curves, which he also rewrote, is simply mind-blowing. The overly simplified answer is, DV is converted to a more useable format.
rbjtech 5341 Posted March 23, 2023 Posted March 23, 2023 So a couple of options to identify the DV profile in emby. #1 - The MediaInfo plugin (and a lot more beside DV) #2 - The new beta Release (any day/hour now ..) will support DV as well - I believe it will mark as DV+HDR10 if it's DV7 or 8 and just say DV if it's DV5 - but to be confirmed. 1
horstepipe 423 Posted March 23, 2023 Posted March 23, 2023 thank you guys! Unfortunately the core of my questions hasn't really been answered Let's say I'm having 1000 episodes with dv, some of them have the purple/green problem. Is there any way to identify these without playing all of them back? Best regards
rbjtech 5341 Posted March 23, 2023 Posted March 23, 2023 (edited) 48 minutes ago, horstepipe said: thank you guys! Unfortunately the core of my questions hasn't really been answered Let's say I'm having 1000 episodes with dv, some of them have the purple/green problem. Is there any way to identify these without playing all of them back? Best regards Yes, filter by Tag=DV5 if using the Plugin. I hope (presume) the core DV implementation will also allow you to filter by HDR Type - in this instance you would search by DV Only. Example of the Tag Filters below from the Plugin - it does all the HDR layers and all the Audio layers too - so you can get a very specific filter if you wish. ie show me all DV5 items with DTS:X audio, for example. Edited March 23, 2023 by rbjtech 1
horstepipe 423 Posted March 23, 2023 Posted March 23, 2023 thanks, but as I said I am quite sure that I have lots of dv profile 5 videos where the colors are correct. But let me verify that and show you the mediainfo for that files.
horstepipe 423 Posted March 23, 2023 Posted March 23, 2023 so here is a mediainfo of a file which plays fine on Windows (non dv compatible hardware): Spoiler General Unique ID : 32937506982904509874711295211077567124 (0x18C78879302894340165365DEA3F0294) Complete name : D:\path\Servant.S04E10.GERMAN.DL.DV.2160P.WEB.H265-RiLE\servant.s04e10.german.dl.dv.2160p.web.h265-rile.mkv Format : Matroska Format version : Version 4 File size : 5.36 GiB Duration : 29 min 14 s Overall bit rate : 26.3 Mb/s Encoded date : UTC 2023-03-17 01:52:04 Writing application : mkvmerge v68.0.0 ('The Curtain') 64-bit Writing library : libebml v1.4.2 + libmatroska v1.6.4 / Lavf58.35.100 Video ID : 1 Format : HEVC Format/Info : High Efficiency Video Coding Format profile : Main 10@L5@High HDR format : Dolby Vision, Version 1.0, dvhe.05.06, BL+RPU Codec ID : V_MPEGH/ISO/HEVC Duration : 29 min 14 s Bit rate : 24.7 Mb/s Width : 3 840 pixels Height : 1 920 pixels Display aspect ratio : 2.000 Frame rate mode : Constant Frame rate : 23.976 (24000/1001) FPS Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 10 bits Bits/(Pixel*Frame) : 0.140 Stream size : 5.05 GiB (94%) Default : Yes Forced : No Audio #1 ID : 2 Format : E-AC-3 JOC Format/Info : Enhanced AC-3 with Joint Object Coding Commercial name : Dolby Digital Plus with Dolby Atmos Codec ID : A_EAC3 Duration : 29 min 14 s Bit rate mode : Constant Bit rate : 768 kb/s Channel(s) : 6 channels Channel layout : L R C LFE Ls Rs Sampling rate : 48.0 kHz Frame rate : 31.250 FPS (1536 SPF) Bit depth : 32 bits Compression mode : Lossy Stream size : 161 MiB (3%) Language : German Service kind : Complete Main Default : Yes Forced : No Complexity index : 16 Number of dynamic objects : 15 Bed channel count : 1 channel Bed channel configuration : LFE Audio #2 ID : 3 Format : E-AC-3 JOC Format/Info : Enhanced AC-3 with Joint Object Coding Commercial name : Dolby Digital Plus with Dolby Atmos Codec ID : A_EAC3 Duration : 29 min 14 s Bit rate mode : Constant Bit rate : 768 kb/s Channel(s) : 6 channels Channel layout : L R C LFE Ls Rs Sampling rate : 48.0 kHz Frame rate : 31.250 FPS (1536 SPF) Bit depth : 32 bits Compression mode : Lossy Stream size : 161 MiB (3%) Language : English Service kind : Complete Main Default : No Forced : No Complexity index : 16 Number of dynamic objects : 15 Bed channel count : 1 channel Bed channel configuration : LFE Text #1 ID : 4 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Duration : 4 s 170 ms Bit rate : 55 b/s Count of elements : 1 Stream size : 29.0 Bytes (0%) Title : Deutsch (forced) Language : German Default : Yes Forced : Yes Text #2 ID : 5 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Duration : 28 min 9 s Bit rate : 46 b/s Count of elements : 275 Stream size : 9.56 KiB (0%) Title : Deutsch Language : German Default : No Forced : No Text #3 ID : 6 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Duration : 28 min 7 s Bit rate : 60 b/s Count of elements : 282 Stream size : 12.6 KiB (0%) Title : العربية Language : Arabic Default : No Forced : No Text #4 ID : 7 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Duration : 28 min 7 s Bit rate : 62 b/s Count of elements : 267 Stream size : 13.0 KiB (0%) Title : български Language : Bulgarian Default : No Forced : No Text #5 ID : 8 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Duration : 28 min 7 s Bit rate : 38 b/s Count of elements : 282 Stream size : 7.84 KiB (0%) Title : 中文(简体) Language : Chinese Default : No Forced : No Text #6 ID : 9 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Duration : 28 min 19 s Bit rate : 38 b/s Count of elements : 283 Stream size : 7.99 KiB (0%) Title : 中文(繁體) Language : Chinese Default : No Forced : No Text #7 ID : 10 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Duration : 28 min 7 s Bit rate : 38 b/s Count of elements : 270 Stream size : 7.94 KiB (0%) Title : Čeština Language : Czech Default : No Forced : No Text #8 ID : 11 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Duration : 28 min 7 s Bit rate : 37 b/s Count of elements : 224 Stream size : 7.81 KiB (0%) Title : dansk Language : Danish Default : No Forced : No Text #9 ID : 12 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Duration : 28 min 7 s Bit rate : 75 b/s Count of elements : 270 Stream size : 15.6 KiB (0%) Title : Ελληνικά Language : Greek Default : No Forced : No Text #10 ID : 13 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Duration : 27 min 33 s Bit rate : 44 b/s Count of elements : 278 Stream size : 8.99 KiB (0%) Title : English Language : English Default : No Forced : No Text #11 ID : 14 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Duration : 28 min 6 s Bit rate : 43 b/s Count of elements : 281 Stream size : 8.88 KiB (0%) Title : Español (Latinoamérica) Language : Spanish Default : No Forced : No Text #12 ID : 15 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Duration : 28 min 7 s Bit rate : 45 b/s Count of elements : 279 Stream size : 9.28 KiB (0%) Title : Español (España) Language : Spanish Default : No Forced : No Text #13 ID : 16 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Duration : 28 min 7 s Bit rate : 40 b/s Count of elements : 264 Stream size : 8.35 KiB (0%) Title : eesti Language : Estonian Default : No Forced : No Text #14 ID : 17 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Duration : 28 min 7 s Bit rate : 40 b/s Count of elements : 264 Stream size : 8.43 KiB (0%) Title : Suomi Language : Finnish Default : No Forced : No Text #15 ID : 18 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Duration : 28 min 6 s Bit rate : 41 b/s Count of elements : 284 Stream size : 8.54 KiB (0%) Title : Français (Canada) Language : French Default : No Forced : No Text #16 ID : 19 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Duration : 27 min 54 s Bit rate : 41 b/s Count of elements : 283 Stream size : 8.52 KiB (0%) Title : Français (France) Language : French Default : No Forced : No Text #17 ID : 20 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Duration : 28 min 7 s Bit rate : 60 b/s Count of elements : 282 Stream size : 12.4 KiB (0%) Title : עברית Language : Hebrew Default : No Forced : No Text #18 ID : 21 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Duration : 28 min 19 s Bit rate : 117 b/s Count of elements : 283 Stream size : 24.5 KiB (0%) Title : हिन्दी Language : Hindi Default : No Forced : No Text #19 ID : 22 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Duration : 28 min 7 s Bit rate : 45 b/s Count of elements : 281 Stream size : 9.39 KiB (0%) Title : magyar Language : Hungarian Default : No Forced : No Text #20 ID : 23 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Duration : 28 min 6 s Bit rate : 44 b/s Count of elements : 281 Stream size : 9.06 KiB (0%) Title : Bahasa Indonesia Language : Indonesian Default : No Forced : No Text #21 ID : 24 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Duration : 28 min 7 s Bit rate : 46 b/s Count of elements : 266 Stream size : 9.50 KiB (0%) Title : Italiano Language : Italian Default : No Forced : No Text #22 ID : 25 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Duration : 28 min 24 s Bit rate : 37 b/s Count of elements : 282 Stream size : 7.71 KiB (0%) Title : 日本語 Language : Japanese Default : No Forced : No Text #23 ID : 26 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Duration : 28 min 19 s Bit rate : 48 b/s Count of elements : 283 Stream size : 9.98 KiB (0%) Title : 한국어 Language : Korean Default : No Forced : No Text #24 ID : 27 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Duration : 28 min 7 s Bit rate : 43 b/s Count of elements : 282 Stream size : 8.93 KiB (0%) Title : lietuvių Language : Lithuanian Default : No Forced : No Text #25 ID : 28 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Duration : 28 min 7 s Bit rate : 45 b/s Count of elements : 281 Stream size : 9.37 KiB (0%) Title : latviešu Language : Latvian Default : No Forced : No Text #26 ID : 29 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Duration : 28 min 7 s Bit rate : 42 b/s Count of elements : 280 Stream size : 8.66 KiB (0%) Title : Bahasa Melayu Language : Malayalam Default : No Forced : No Text #27 ID : 30 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Duration : 28 min 7 s Bit rate : 39 b/s Count of elements : 236 Stream size : 8.20 KiB (0%) Title : Nederlands Language : Dutch Default : No Forced : No Text #28 ID : 31 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Duration : 28 min 7 s Bit rate : 42 b/s Count of elements : 226 Stream size : 8.75 KiB (0%) Title : norsk Language : Norwegian Default : No Forced : No Text #29 ID : 32 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Duration : 28 min 7 s Bit rate : 40 b/s Count of elements : 266 Stream size : 8.39 KiB (0%) Title : polski Language : Polish Default : No Forced : No Text #30 ID : 33 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Duration : 28 min 7 s Bit rate : 38 b/s Count of elements : 280 Stream size : 8.03 KiB (0%) Title : Português (Brasil) Language : Portuguese Default : No Forced : No Text #31 ID : 34 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Duration : 28 min 7 s Bit rate : 42 b/s Count of elements : 279 Stream size : 8.69 KiB (0%) Title : Português Language : Portuguese Default : No Forced : No Text #32 ID : 35 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Duration : 28 min 18 s Bit rate : 65 b/s Count of elements : 284 Stream size : 13.6 KiB (0%) Title : Русский Language : Russian Default : No Forced : No Text #33 ID : 36 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Duration : 28 min 7 s Bit rate : 39 b/s Count of elements : 276 Stream size : 8.05 KiB (0%) Title : Slovenčina Language : Slovak Default : No Forced : No Text #34 ID : 37 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Duration : 28 min 7 s Bit rate : 35 b/s Count of elements : 234 Stream size : 7.25 KiB (0%) Title : slovenščina Language : Slovenian Default : No Forced : No Text #35 ID : 38 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Duration : 28 min 7 s Bit rate : 43 b/s Count of elements : 281 Stream size : 8.90 KiB (0%) Title : Svenska Language : Swedish Default : No Forced : No Text #36 ID : 39 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Duration : 28 min 7 s Bit rate : 142 b/s Count of elements : 282 Stream size : 29.3 KiB (0%) Title : தமிழ் Language : Tamil Default : No Forced : No Text #37 ID : 40 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Duration : 28 min 7 s Bit rate : 128 b/s Count of elements : 282 Stream size : 26.4 KiB (0%) Title : తెలుగు Language : Telugu Default : No Forced : No Text #38 ID : 41 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Duration : 28 min 7 s Bit rate : 107 b/s Count of elements : 282 Stream size : 22.0 KiB (0%) Title : ไทย Language : Thai Default : No Forced : No Text #39 ID : 42 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Duration : 28 min 6 s Bit rate : 42 b/s Count of elements : 280 Stream size : 8.71 KiB (0%) Title : Türkçe Language : Turkish Default : No Forced : No Text #40 ID : 43 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Duration : 28 min 19 s Bit rate : 62 b/s Count of elements : 283 Stream size : 13.0 KiB (0%) Title : українська Language : Ukrainian Default : No Forced : No Text #41 ID : 44 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Duration : 28 min 19 s Bit rate : 54 b/s Count of elements : 281 Stream size : 11.4 KiB (0%) Title : Tiếng Việt Language : Vietnamese Default : No Forced : No Text #42 ID : 45 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Duration : 28 min 18 s Bit rate : 38 b/s Count of elements : 283 Stream size : 7.95 KiB (0%) Title : 廣東話 Language : Chinese Default : No Forced : No and here is the mediainfo for a file where the green/purple issue is there: Spoiler General Unique ID : 51048575102075203930320266811290247191 (0x26679912A4EDCDF085539A9DCD756017) Complete name : D:\path\Star.Wars.The.Bad.Batch.S02E08.GERMAN.DL.DV.2160P.WEB.H265-RiLE\star.wars.the.bad.batch.s02e08.german.dl.dv.2160p.web.h265-rile.mkv Format : Matroska Format version : Version 4 File size : 3.31 GiB Duration : 28 min 18 s Overall bit rate : 16.7 Mb/s Encoded date : UTC 2023-02-08 08:54:27 Writing application : mkvmerge v68.0.0 ('The Curtain') 64-bit Writing library : libebml v1.4.2 + libmatroska v1.6.4 Video ID : 1 Format : HEVC Format/Info : High Efficiency Video Coding Format profile : Main 10@L5@High HDR format : Dolby Vision, Version 1.0, dvhe.05.06, BL+RPU Codec ID : V_MPEGH/ISO/HEVC Duration : 28 min 18 s Bit rate : 16.2 Mb/s Width : 3 840 pixels Height : 2 160 pixels Display aspect ratio : 16:9 Frame rate mode : Constant Frame rate : 24.000 FPS Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 10 bits Bits/(Pixel*Frame) : 0.082 Stream size : 3.21 GiB (97%) Default : Yes Forced : No Color range : Full Audio #1 ID : 2 Format : E-AC-3 Format/Info : Enhanced AC-3 Commercial name : Dolby Digital Plus Codec ID : A_EAC3 Duration : 28 min 18 s Bit rate mode : Constant Bit rate : 256 kb/s Channel(s) : 6 channels Channel layout : L R C LFE Ls Rs Sampling rate : 48.0 kHz Frame rate : 31.250 FPS (1536 SPF) Compression mode : Lossy Stream size : 51.8 MiB (2%) Language : German Service kind : Complete Main Default : Yes Forced : No Audio #2 ID : 3 Format : E-AC-3 Format/Info : Enhanced AC-3 Commercial name : Dolby Digital Plus Codec ID : A_EAC3 Duration : 28 min 18 s Bit rate mode : Constant Bit rate : 256 kb/s Channel(s) : 6 channels Channel layout : L R C LFE Ls Rs Sampling rate : 48.0 kHz Frame rate : 31.250 FPS (1536 SPF) Compression mode : Lossy Stream size : 51.8 MiB (2%) Language : English Service kind : Complete Main Default : No Forced : No Text #1 ID : 4 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Duration : 27 min 41 s Bit rate : 0 b/s Count of elements : 3 Stream size : 85.0 Bytes (0%) Title : German Forced Language : German Default : Yes Forced : Yes Text #2 ID : 5 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Duration : 27 min 55 s Bit rate : 44 b/s Count of elements : 329 Stream size : 9.01 KiB (0%) Title : Chinese (Hong Kong) Language : Chinese Default : No Forced : No Text #3 ID : 6 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Duration : 27 min 55 s Bit rate : 44 b/s Count of elements : 329 Stream size : 9.08 KiB (0%) Title : Chinese (Simplified) Language : Chinese Default : No Forced : No Text #4 ID : 7 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Duration : 27 min 55 s Bit rate : 44 b/s Count of elements : 323 Stream size : 9.01 KiB (0%) Title : Chinese (Traditional) Language : Chinese Default : No Forced : No Text #5 ID : 8 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Duration : 27 min 44 s Bit rate : 56 b/s Count of elements : 328 Stream size : 11.4 KiB (0%) Title : Dansk Language : Danish Default : No Forced : No Text #6 ID : 9 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Duration : 27 min 41 s Bit rate : 55 b/s Count of elements : 295 Stream size : 11.2 KiB (0%) Title : Deutsch Language : German Default : No Forced : No Text #7 ID : 10 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Duration : 26 min 13 s Bit rate : 63 b/s Count of elements : 371 Stream size : 12.2 KiB (0%) Title : English [CC] Language : English Default : No Forced : No Text #8 ID : 11 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Duration : 27 min 44 s Bit rate : 56 b/s Count of elements : 310 Stream size : 11.6 KiB (0%) Title : Español Language : Spanish Default : No Forced : No Text #9 ID : 12 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Duration : 27 min 44 s Bit rate : 53 b/s Count of elements : 306 Stream size : 10.8 KiB (0%) Title : Español (Latinoamericano) Language : Spanish Default : No Forced : No Text #10 ID : 13 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Duration : 27 min 41 s Bit rate : 55 b/s Count of elements : 326 Stream size : 11.3 KiB (0%) Title : Français Language : French Default : No Forced : No Text #11 ID : 14 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Duration : 27 min 41 s Bit rate : 99 b/s Count of elements : 326 Stream size : 20.2 KiB (0%) Title : Greek Language : Greek Default : No Forced : No Text #12 ID : 15 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Duration : 27 min 41 s Bit rate : 56 b/s Count of elements : 311 Stream size : 11.5 KiB (0%) Title : Italiano Language : Italian Default : No Forced : No Text #13 ID : 16 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Duration : 27 min 55 s Bit rate : 47 b/s Count of elements : 310 Stream size : 9.78 KiB (0%) Title : Japanese Language : Japanese Default : No Forced : No Text #14 ID : 17 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Duration : 27 min 55 s Bit rate : 60 b/s Count of elements : 328 Stream size : 12.3 KiB (0%) Title : Korean Language : Korean Default : No Forced : No Text #15 ID : 18 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Duration : 27 min 44 s Bit rate : 54 b/s Count of elements : 326 Stream size : 11.1 KiB (0%) Title : Magyar Language : Hungarian Default : No Forced : No Text #16 ID : 19 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Duration : 27 min 41 s Bit rate : 51 b/s Count of elements : 276 Stream size : 10.5 KiB (0%) Title : Nederlands Language : Dutch Default : No Forced : No Text #17 ID : 20 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Duration : 27 min 44 s Bit rate : 53 b/s Count of elements : 322 Stream size : 10.9 KiB (0%) Title : Norsk Language : Norwegian Default : No Forced : No Text #18 ID : 21 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Duration : 27 min 55 s Bit rate : 51 b/s Count of elements : 324 Stream size : 10.4 KiB (0%) Title : Polski Language : Polish Default : No Forced : No Text #19 ID : 22 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Duration : 27 min 44 s Bit rate : 58 b/s Count of elements : 326 Stream size : 11.8 KiB (0%) Title : Português Language : Portuguese Default : No Forced : No Text #20 ID : 23 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Duration : 27 min 41 s Bit rate : 54 b/s Count of elements : 319 Stream size : 11.0 KiB (0%) Title : Português (Brasil) Language : Portuguese Default : No Forced : No Text #21 ID : 24 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Duration : 27 min 55 s Bit rate : 54 b/s Count of elements : 274 Stream size : 11.1 KiB (0%) Title : Română Language : Romanian Default : No Forced : No Text #22 ID : 25 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Duration : 27 min 44 s Bit rate : 54 b/s Count of elements : 325 Stream size : 11.0 KiB (0%) Title : Slovenčina Language : Slovak Default : No Forced : No Text #23 ID : 26 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Duration : 27 min 41 s Bit rate : 49 b/s Count of elements : 318 Stream size : 10.0 KiB (0%) Title : Suomi Language : Finnish Default : No Forced : No Text #24 ID : 27 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Duration : 27 min 44 s Bit rate : 55 b/s Count of elements : 328 Stream size : 11.3 KiB (0%) Title : Svenska Language : Swedish Default : No Forced : No Text #25 ID : 28 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Duration : 27 min 44 s Bit rate : 56 b/s Count of elements : 327 Stream size : 11.5 KiB (0%) Title : Türkçe Language : Turkish Default : No Forced : No Text #26 ID : 29 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Duration : 27 min 44 s Bit rate : 51 b/s Count of elements : 309 Stream size : 10.6 KiB (0%) Title : Čeština Language : Czech Default : No Forced : No I do not see any differences, do you?
horstepipe 423 Posted March 23, 2023 Posted March 23, 2023 sorry wait, seems like I mixed something up there.
horstepipe 423 Posted March 23, 2023 Posted March 23, 2023 (edited) okay sorry for confusion. So this is The Mandalorian Season 2. It is a Web download, from what I see there is no bluray/uhd bluray available for this. But Mediainfo shows: Quote HDR format : Dolby Vision, Version 1.0, dvhe.08.06, BL+RPU, HDR10 compatible This is profile 8, right? What does that exactly mean lol? Either there seems to be a way to transform dv profile 5 to profile 8 or some streaming services deliver profile 8 instead of profile 5? So as you suggested I need to take a look for profile 5, thanks! Edited March 23, 2023 by horstepipe
rbjtech 5341 Posted March 23, 2023 Posted March 23, 2023 (edited) Yes - the dvhe.xx part shows the profile dv 5 = Dolby Vision ONLY. Will produce funky colours on any equipment not capable of reading the colour space. Not backwards compatible with HDR10. dv 7 = Dolby Vision + HDR10. Will use DV if available, but will fallback to HDR10 if not. ripped from from UHD Disk media. dv 8 = Dolby Vision + HDR10. Will use DV if available, but will fallback to HDR10 if not. Created by combining a DV5 rip with an HDR10 rip. 57 minutes ago, horstepipe said: So there seems to be a way to transform dv profile 5 to profile 8? Not easily no - it can be done (which is what the scene are doing to create DV8's) but unless you have the HDR10 source - then no. Tonemapping for DV5 is also a possibility but I don't think Emby wanna go there as its reverse engineering DV. The best thing to do is simply avoid DV5 content - which is I guess where you are going with this .. Edited March 23, 2023 by rbjtech 1
Guest Posted March 25, 2023 Posted March 25, 2023 One very important thing to take into account, is that most TVs don't support Profile 7 and 8, only 5
horstepipe 423 Posted March 27, 2023 Posted March 27, 2023 (edited) It looks like it is quite hard to find out which profiles are supported by the hardware, mostly you just see "dolby vision supported". So what I know so far: Amazon devices only support profile 5 Nvidia Shield Pro 2019 supports profile 5/7/8 What about the Nvidia Shield Tube and the new Nokia Streaming Box 8010? What's the best approach finding out what profiles are supported without buying the box? Is this chip based? I guess it is a licensing thing so not chipbased? Is there any alternative to the shield supporting all profiles at all? Also I'm wondering. Infuse added dolby vision profile 8 support to its app on TVOS. So shouldn't Emby theoretically being able to do the same for Android/AndroidTV - independent of the hardware support? Best regards Edited March 27, 2023 by horstepipe
Guest Posted March 27, 2023 Posted March 27, 2023 The TV has to support them along with the playback device. If shield supports it but not the TV then you'll still have issues. Though in the case of shield it might tone map
horstepipe 423 Posted March 27, 2023 Posted March 27, 2023 (edited) 35 minutes ago, generiq said: The TV has to support them along with the playback device. If shield supports it but not the TV then you'll still have issues. Though in the case of shield it might tone map thanks for the input but that didn't answer any of my above questions I do not have a dv compatible tv and avr anyway - but I want to understand all of that a bit better. Often friends ask me what box to buy so this will be a purchase criterium sooner or later I guess. Edited March 27, 2023 by horstepipe
Guest Posted March 28, 2023 Posted March 28, 2023 So all you want is a better idea of what device to use to tone-map DV content? Other than obviously using Theater/mpv (which would be my first recommendation), probably Shield Pro, but I'm not sure if it has the capability of tone-mapping DV. I would think it can. If you want a device to tone-map in the interim with future plans to buy DV enabled equipment (TV etc), just get a shield pro.
