jott0204 1 Posted April 19, 2022 Posted April 19, 2022 So this is a new issue for me. I tried checking the forum, but I did not see this one posted. (If it is, please direct me there and ignore this post) My TV shows have all completely disappeared. They are in the folders of my hard drives, but Emby no longer recognizes them. When I check the dashboard, it shows a Library Scan that seems to be stuck at 90.8% and never moves forward from that. I tried to disable a couple of the plugins that I have, and then restart the Emby Service, but I have the same results. This is running on a Windows 10 Pro PC. I do not believe that Windows has updated in the last couple hours. (this worked last night without any problems) Any help would be greatly appreciated with this. Thanks!
Abobader 3485 Posted April 19, 2022 Posted April 19, 2022 Hello jott0204, ** This is an auto reply ** Please wait for someone from staff support or our members to reply to you. It's recommended to provide more info, as it explain in this thread: Thank you. Emby Team
jott0204 1 Posted April 19, 2022 Author Posted April 19, 2022 Here is the latest log file. I will add additional logs as requested. Thanks embyserver.txt
Solution jott0204 1 Posted April 19, 2022 Author Solution Posted April 19, 2022 I think that I found the problem myself. The Port Mapper Plugin was throwing errors and once I uninstalled that, it is working fine now. Sorry for posting too soon.
Luke 42186 Posted April 19, 2022 Posted April 19, 2022 That's not going to be related. It's just a matter of waiting for it to finish.
Happy2Play 9801 Posted April 19, 2022 Posted April 19, 2022 Log shows issue with G:\TV Shows and importing items from E:\TV Shows. 2022-04-19 12:42:23.852 Info LibraryMonitor: Watching directory H:\Movies 2022-04-19 12:42:23.853 Info LibraryMonitor: Watching directory E:\TV Shows 2022-04-19 12:42:23.853 Info LibraryMonitor: Watching directory F:\Movies 2022-04-19 12:42:23.853 Info LibraryMonitor: Watching directory F:\TV Shows 2022-04-19 12:42:23.853 Info LibraryMonitor: Watching directory H:\TV Shows 2022-04-19 12:42:23.853 Info LibraryMonitor: Watching directory E:\Movies 2022-04-19 12:42:23.853 Info LibraryMonitor: Watching directory I:\Movies 2022-04-19 12:42:23.853 Info LibraryMonitor: Watching directory I:\Music 2022-04-19 12:42:23.853 Info LibraryMonitor: Watching directory I:\TV Shows 2022-04-19 12:42:23.853 Info LibraryMonitor: Watching directory G:\Movies 2022-04-19 12:42:23.853 Info LibraryMonitor: Watching directory J:\Movies 2022-04-19 12:42:23.853 Info LibraryMonitor: Watching directory J:\Private 2022-04-19 12:42:23.853 Info LibraryMonitor: Watching directory G:\Music 2022-04-19 12:42:23.853 Info LibraryMonitor: Watching directory J:\TV Shows Could not find a part of the path 'G:\TV Shows'. 2022-04-19 12:43:06.549 Info MediaProbeManager: ProcessRun 'ffprobe' Execute: C:\Users\James\AppData\Roaming\Emby-Server\system\ffprobe.exe -i file:"E:\TV Shows\American Crime Story\Season 3\American.Crime.Story.S03E01.1080p.HEVC.x265-MeGusta.mkv" -threads 0 -v info -print_format json -show_streams -show_chapters -show_format -show_data 2022-04-19 12:43:07.539 Info MediaProbeManager: ProcessRun 'ffprobe' Process exited with code 0
