No images showing with web client
Hey,
I'm using the instructions from here:http://mediabrowser.tv/community/index.php?/topic/3634-linux-setup/page-41&do=findComment&comment=132620 to install media browser on ubuntu 14.04. No images are showing. If I view the source of an image, I see this exception (sorry, quite large): any ideas?
Response Status Error Code TypeInitializationException Message An exception was thrown by the type initializer for System.Drawing.GDIPlus Stack Trace [GetItemImage: 09/24/2014 21:36:27]: [REQUEST: {Id:7b99ffcabeb4765557a1fbb4f7dcd049,MaxHeight:560,Quality:90,Tag:142d9d5fd5cd5d10d7e31f2643c3e9c7,EnableImageEnhancers:True,Format:Webp,AddPlayedIndicator:False,Type:Primary}] System.TypeInitializationException: An exception was thrown by the type initializer for System.Drawing.GDIPlus ---> System.DllNotFoundException: /usr/local/lib/libgdiplus.so at (wrapper managed-to-native) System.Drawing.GDIPlus:GdiplusStartup (ulong&,System.Drawing.GdiplusStartupInput&,System.Drawing.GdiplusStartupOutput&) at System.Drawing.GDIPlus..cctor () [0x00000] in <filename unknown>:0 --- End of inner exception stack trace --- at System.Drawing.Image.InitFromStream (System.IO.Stream stream) [0x00000] in <filename unknown>:0 at System.Drawing.Image.LoadFromStream (System.IO.Stream stream, Boolean keepAlive) [0x00000] in <filename unknown>:0 at System.Drawing.Image.FromStream (System.IO.Stream stream, Boolean useEmbeddedColorManagement, Boolean validateImageData) [0x00000] in <filename unknown>:0 at MediaBrowser.Server.Implementations.Drawing.ImageProcessor+<ProcessImage>c__async1.MoveNext () [0x00000] in <filename unknown>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x00000] in <filename unknown>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable`1+ConfiguredTaskAwaiter[TResult].GetResult () [0x00000] in <filename unknown>:0 at MediaBrowser.Api.Images.ImageService+<GetImageResult>c__async0.MoveNext () [0x00000] in <filename unknown>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x00000] in <filename unknown>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable`1+ConfiguredTaskAwaiter[TResult].GetResult () [0x00000] in <filename unknown>:0 at MediaBrowser.Api.Images.ImageService+<GetImageResult>c__async0.MoveNext () [0x00000] in <filename unknown>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x00000] in <filename unknown>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable`1+ConfiguredTaskAwaiter[TResult].GetResult () [0x00000] in <filename unknown>:0 at MediaBrowser.Api.Images.ImageService+<GetImageResult>c__async0.MoveNext () [0x00000] in <filename unknown>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x00000] in <filename unknown>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable`1+ConfiguredTaskAwaiter[TResult].GetResult () [0x00000] in <filename unknown>:0 at MediaBrowser.Api.Images.ImageService+<GetImageResult>c__async0.MoveNext () [0x00000] in <filename unknown>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x00000] in <filename unknown>:0 at
Edited by marchaos
thefirstofthe300
Should be a simple
sudo apt-get install libgdiplus
I thought as much but:
marchaos@CUBE:~/.mediabrowser$ sudo apt-get install libgdiplus
Reading package lists... Done
Building dependency tree
Reading state information... Done
libgdiplus is already the newest version.
The following packages were automatically installed and are no longer required:
I noticed something else in the logs:
 InnerException: System.DllNotFoundException
adding  /usr/local/lib/ to /etc/ld.so.conf might have helped, but still no images.
Exception is now:
2014-09-24 23:34:04.5285 Error - HttpAsyncTaskHandler: Error occured while Processing Request: Object reference not set to an instance of an object
        System.NullReferenceException
          at System.Exception.AddFrames (System.Text.StringBuilder sb, System.String newline, System.String unknown, System.Diagnostics.StackTrace st) [0x00000] in <filename unknown>:0
          at System.Exception.get_StackTrace () [0x00000] in <filename unknown>:0
          at System.Exception.ToString () [0x00000] in <filename unknown>:0
          at System.String.Concat (System.Object arg0, System.Object arg1, System.Object arg2) [0x00000] in <filename unknown>:0
          at ServiceStack.DtoUtils.CreateErrorResponse (System.Object request, System.Exception ex) [0x00000] in <filename unknown>:0
          at ServiceStack.Host.ServiceRunner`1[MediaBrowser.Api.Images.GetItemImage].HandleException (IRequest request, MediaBrowser.Api.Images.GetItemImage requestDto, System.Exception ex) [0x00000] in <filename unknown>:0
          at ServiceStack.Host.ServiceRunner`1[MediaBrowser.Api.Images.GetItemImage].Execute (IRequest request, System.Object instance, MediaBrowser.Api.Images.GetItemImage requestDto) [0x00000] in <filename unknown>:0
          at ServiceStack.Host.ServiceRunner`1[MediaBrowser.Api.Images.GetItemImage].Process (IRequest requestContext, System.Object instance, System.Object request) [0x00000] in <filename unknown>:0
          at ServiceStack.Host.ServiceExec`1[MediaBrowser.Api.Images.ImageService].Execute (IRequest request, System.Object instance, System.Object requestDto, System.String requestName) [0x00000] in <filename unknown>:0
          at ServiceStack.Host.ServiceRequestExec`2[MediaBrowser.Api.Images.ImageService,MediaBrowser.Api.Images.GetItemImage].Execute (IRequest requestContext, System.Object instance, System.Object request) [0x00000] in <filename unknown>:0
          at ServiceStack.Host.ServiceController+<>c__DisplayClass11+<>c__DisplayClass13.<RegisterServiceExecutor>b__10 (IRequest reqCtx, System.Object req) [0x00000] in <filename unknown>:0
          at ServiceStack.Host.ServiceController.ManagedServiceExec (ServiceStack.Host.ServiceExecFn serviceExec, IService service, IRequest request, System.Object requestDto) [0x00000] in <filename unknown>:0
          at ServiceStack.Host.ServiceController+<>c__DisplayClass11.<RegisterServiceExecutor>b__f (IRequest requestContext, System.Object dto) [0x00000] in <filename unknown>:0
          at ServiceStack.Host.ServiceController.Execute (System.Object requestDto, IRequest request) [0x00000] in <filename unknown>:0
          at ServiceStack.HostContext.ExecuteService (System.Object request, IRequest httpReq) [0x00000] in <filename unknown>:0
          at ServiceStack.Host.Handlers.ServiceStackHandlerBase.ExecuteService (System.Object request, IRequest httpReq) [0x00000] in <filename unknown>:0
          at ServiceStack.Host.RestHandler.GetResponse (IRequest request, System.Object requestDto) [0x00000] in <filename unknown>:0
          at ServiceStack.Host.RestHandler.ProcessRequestAsync (IRequest httpReq, IResponse httpRes, System.String operationName) [0x00000] in <filename unknown>:0
Ok figured it out. It was complaining as it was in /usr/lib not /usr/local/lib.
Cheers for your help.
