jlj1950 7 Posted April 19, 2022 Posted April 19, 2022 (edited) Hello, I had posted concerning missing data and the program disacarding some changes, but that was probaly my error. Something odd did occur though, and I doubyt the event can be duplicated. I decided to do some edits from my other laptop. I have one laptop dedicated to a couple of tasks and the Media server is one. I usually edit from the server laptop or from the LG Emby app onscreen. After about ten minutes, the other laptop locked up. I went back to the server laptop. I closed the webpage and the tray app. I happened to look at the Task Manager, and found there were two Emby servers in use. I tried to "End task" on both without success. The response was "Task could not be completed." "Access denied" As of this writing, I'm going to just power the server laptop down. Thought I'd mention this, though. Note: I reopened the browser, typed this post and closed the browser. At that time, the two instances of Emby Server closed. Edited April 19, 2022 by jlj1950 modification for content
Luke 42186 Posted April 19, 2022 Posted April 19, 2022 Hi there, please attach the emby server log from when this happened: Thanks.
jlj1950 7 Posted April 20, 2022 Author Posted April 20, 2022 The hardware detection file is the only file with that date. I'm including the server files from the day before and the day after. hardware_detection-63785913852.txt embyserver-63785835127.txt embyserver-63785923200.txt
Luke 42186 Posted April 20, 2022 Posted April 20, 2022 1 hour ago, jlj1950 said: The hardware detection file is the only file with that date. I'm including the server files from the day before and the day after. hardware_detection-63785913852.txt 127.1 kB · 0 downloads embyserver-63785835127.txt 36.93 MB · 0 downloads embyserver-63785923200.txt 11.75 MB · 0 downloads What time did the problem occur?
jlj1950 7 Posted April 20, 2022 Author Posted April 20, 2022 8 minutes ago, Luke said: What time did the problem occur? Just before bedtime, about 11PM.
Luke 42186 Posted April 21, 2022 Posted April 21, 2022 I don't see anything obvious here. Does this happen consistently? If only one server is running does it happen to that one?
jlj1950 7 Posted April 21, 2022 Author Posted April 21, 2022 2 hours ago, Luke said: I don't see anything obvious here. Does this happen consistently? If only one server is running does it happen to that one? Hi, "Does this happen consistently? If only one server is running does it happen to that one?" This happened once and is the only time I've used the non-server laptop to edit in Emby. Both locked up. I had to reboot the server laptop to clear the system and restart Emby.
Luke 42186 Posted April 22, 2022 Posted April 22, 2022 Ok please let us know if it happens again. Thanks.
