mrpurr 0 Posted April 18, 2022 Posted April 18, 2022 i installed ver 4.6.7.0 yesterday and a lot of my files are not working but some are. still images show as the unreadable and the video errores at the "No compatible streams are currently available" error .everything worked fin before the update. the log gives this error over and over the server.txt is over 4 millions lines long. 2022-04-18 06:26:50.220 Error BaseItem: Error refreshing owned items for smb://tower/stuff/pics/MashaM01_008.jpg *** Error Report *** Version: 4.6.7.0 Command line: /usr/lib/emby-server/EmbyServer.dll -programdata /config -ffdetect -ffmpeg /usr/bin/ffmpeg -ffprobe /usr/bin/ffprobe -restartexitcode 3 Operating system: Linux version 5.10.28-Unraid (root@Develop) (gcc (GCC) 9.3.0, GNU ld version 2.33.1-slack15) #1 SMP Wed Apr 7 08:23:18 PDT 2021 Framework: .NET Core 3.1.20 OS/Process: x64/x64 Runtime: usr/share/dotnet/shared/Microsoft.NETCore.App/3.1.20/System.Private.CoreLib.dll Processor count: 16 Data path: /config Application path: /usr/lib/emby-server SharpCifs.Smb.SmbException: SharpCifs.Smb.SmbException: Failed to connect to server at SharpCifs.Smb.SmbFile.Connect0() at SharpCifs.Smb.SmbFile.QueryPath(String path, Int32 infoLevel) at SharpCifs.Smb.SmbFile.Exists() at Emby.Server.Implementations.IO.SharpCifsFileSystem.AssertDirectoryExists(SmbFile file, String path) at Emby.Server.Implementations.IO.SharpCifsFileSystem.GetFileSystemEntries(String path, Boolean recursive) at MediaBrowser.Controller.Providers.DirectoryService.GetFileSystemEntries(String path) at MediaBrowser.Controller.Entities.BaseItem.RefreshMetadata(MetadataRefreshOptions options, LibraryOptions libraryOptions, CancellationToken cancellationToken) SharpCifs.Util.Sharpen.UnknownHostException: TOWER<20> at SharpCifs.Netbios.NbtAddress.DoNameQuery(Name name, IPAddress svr) at SharpCifs.UniAddress.GetAllByName(String hostname, Boolean possibleNtDomainOrWorkgroup) at SharpCifs.Smb.SmbFile.GetFirstAddress() at SharpCifs.Smb.SmbFile.Connect() at SharpCifs.Smb.SmbFile.Connect0() Source: Emby.Server.Implementations TargetSite: Void Connect0()
Luke 42246 Posted April 18, 2022 Posted April 18, 2022 Hi, are some of your libraries on a windows share? Is your windows share down?
mrpurr 0 Posted April 18, 2022 Author Posted April 18, 2022 yes they are on a windows share and it is working. I can access libraries from another directory on same server
Luke 42246 Posted April 18, 2022 Posted April 18, 2022 OK, what you can do that will definitely work is mount the share to a local path in unraid/docker, and then then add that local path into Emby Server instead of the windows share path.
mrpurr 0 Posted April 18, 2022 Author Posted April 18, 2022 I re-added the lib I will let you know in a few days over 140,000 in there to rescan
mrpurr 0 Posted April 20, 2022 Author Posted April 20, 2022 Well it took over 24 hr but the new lib works fine and so does the old one too thanks for your help
