poltuiu 0 Posted April 16, 2022 Posted April 16, 2022 Hello, I can't find the application in the store of the LG HU710PW . Is there an incompatibility? (thank you for the quality of your product) Regards pol
SamES 1084 Posted April 16, 2022 Posted April 16, 2022 @Luke this is an all in one laser projector with webOS 6 and App Store. It was only released this year. It’s possible that LG might pick this up in the next release, but I suspect it will need another device category selected when you submit the app to pick up this type of device.
poltuiu 0 Posted April 18, 2022 Author Posted April 18, 2022 Yes it is. It's like the LG HU70LS (with WebOS 4.5) or the LG HU810PW (under WebOS 5.0).
Luke 42234 Posted April 18, 2022 Posted April 18, 2022 Ok, once we get the current submission through we can look at what it will take to support projectors. Thanks.
poltuiu 0 Posted June 17, 2023 Author Posted June 17, 2023 Hello, the application is still not available. Is LG refusing to add it to the store?
Luke 42234 Posted June 19, 2023 Posted June 19, 2023 We need to submit for projectors . As soon as our next normal app update goes through we can look at that.
Mr_Muh 1 Posted December 23, 2023 Posted December 23, 2023 I have a LG HU70LS with WebOS 4.5. I cannot find the emby app in the store. @LukePlease add support for the projectors. 1
Luke 42234 Posted December 26, 2023 Posted December 26, 2023 On 12/23/2023 at 5:22 PM, Mr_Muh said: I have a LG HU70LS with WebOS 4.5. I cannot find the emby app in the store. @LukePlease add support for the projectors. HI, yes this is planned for future updates. Thanks.
Luke 42234 Posted February 14, 2024 Posted February 14, 2024 Hi, for those running a projector please try searching the LG store. According to LG we're in the store for projectors running WebOS 4+. Thanks.
