VirulentPip 93 Posted April 14, 2022 Author Posted April 14, 2022 Interesting, seems odd as the Firestick app is newer, shouldn't it also have this stuff? Any idea how long that would be? Kinda annoying to have to walk someone through how to sideload an app if they're more of a "Plug and Play" person.
Luke 42245 Posted April 14, 2022 Posted April 14, 2022 3 hours ago, VirulentPip said: Interesting, seems odd as the Firestick app is newer, shouldn't it also have this stuff? Any idea how long that would be? Kinda annoying to have to walk someone through how to sideload an app if they're more of a "Plug and Play" person. HI, it will ultimately get the same updates. The standard app has just gotten them first. Thanks.
VirulentPip 93 Posted April 14, 2022 Author Posted April 14, 2022 2 hours ago, Luke said: HI, it will ultimately get the same updates. The standard app has just gotten them first. Thanks. Thanks, just seems a bit baffling as the FireStick app was only released on the 5th and the Android around 22nd March (If I'm correct?) But good to know it will end up working okay, hopefully not long. Really liking Emby other than this inconvenience 1
VirulentPip 93 Posted June 29, 2022 Author Posted June 29, 2022 (edited) Appears this is still an issue with 2.0.77a Would have hoped by now it would be solved. Refresh - Got to have transcoding forced off otherwise it unnecessarily transcodes 10 Bit HEVC (video profile not supported) - Plays fine when forced off or via sideloaded Android app as before. Edited June 29, 2022 by VirulentPip
Luke 42245 Posted June 30, 2022 Posted June 30, 2022 Quote Plays fine when forced off or via sideloaded Android app as before. That's good news because ultimately the TV app will get the same updates. Thanks.
VirulentPip 93 Posted June 30, 2022 Author Posted June 30, 2022 Well that was the case back in April lol. Would have thought the fix would come with the 2.0.77a update to FireStick
Luke 42245 Posted July 3, 2022 Posted July 3, 2022 On 6/30/2022 at 6:51 PM, VirulentPip said: Well that was the case back in April lol. Would have thought the fix would come with the 2.0.77a update to FireStick Is that the version number you have now?
VirulentPip 93 Posted July 5, 2022 Author Posted July 5, 2022 Yes, every 10bit HEVC file will unnecessarily transcode (video profile not supported) if set up in user to be able to transcode, when transcoding is not allowed it plays back fine. This is across multiple firesticks too.
ebr 16337 Posted July 5, 2022 Posted July 5, 2022 Hi. But it works fine with the standard Android app, correct?
VirulentPip 93 Posted July 5, 2022 Author Posted July 5, 2022 Yes since first used in April standard Android app sideloaded works. @ebr
