Joechung 5 Posted April 7, 2022 Posted April 7, 2022 HI everyone, about the media database, move the movie from folder A to folder B. There will be redundant movie posters and movie information files left in folder A. May I ask how to operate in this case, so that EMBY will not leave redundant files in folder A? The folder A is shown in the following figure.
Luke 42239 Posted April 7, 2022 Posted April 7, 2022 Hi, emby doesn't have a function to move files. How did you move them?
Joechung 5 Posted April 7, 2022 Author Posted April 7, 2022 I had to manually move the correct movie into the correct category file because of the wrong category.
Happy2Play 9811 Posted April 7, 2022 Posted April 7, 2022 (edited) This does not make any since, if you are moving the media then everything should be move and has nothng to do with Emby. But I guess maybe if Emby is importing the item when you move the media this could happen. But from the image provided is media and not folder being moved by you? Edited April 7, 2022 by Happy2Play
Joechung 5 Posted April 10, 2022 Author Posted April 10, 2022 Hello, happy, I moved A whole folder instead of A single media file, as shown in the figure above is the folder automatically generated by EMBY after I pulled it from folder A to folder B, which contains posters and movie information. So, what bothers me now is why does EMBY automatically generate a folder when I move the folder? Is there any solution?
Luke 42239 Posted April 11, 2022 Posted April 11, 2022 14 hours ago, Joechung said: Hello, happy, I moved A whole folder instead of A single media file, as shown in the figure above is the folder automatically generated by EMBY after I pulled it from folder A to folder B, which contains posters and movie information. So, what bothers me now is why does EMBY automatically generate a folder when I move the folder? Is there any solution? Hi, exactly what do you think was automatically generated?
