Thomas5020 3 Posted April 6, 2022 Posted April 6, 2022 At a loss with this one. Got some DVD rips here of Peter Kay comedy shows, I'd like them on my server. So I've gone to add them, and by default it does nothing. I've tried to identify "Live At The Top of the Tower" and it's setting the name as "Out of Control" made by Nickelodeon. (TVDB 62925 IMDB tt0285893 TheMovieDB 36044). When I'm searching the results are just showing up blank, even though everything is clearly available from TVDB and TheMovieDB. Tried refreshing metadata, rescanning library files, deleting and readding it, restarting the server, all yields the same result. Any ideas?
Abobader 3485 Posted April 6, 2022 Posted April 6, 2022 Hello Thomas5020, ** This is an auto reply ** Please wait for someone from staff support or our members to reply to you. It's recommended to provide more info, as it explain in this thread: Thank you. Emby Team
Happy2Play 9801 Posted April 6, 2022 Posted April 6, 2022 Please post a server log. What library content type library do you have this in? What metadata downloader do you have enabled and in what order on the library?
Thomas5020 3 Posted April 6, 2022 Author Posted April 6, 2022 @Happy2Play Hi, log attached. I've put it in with TV shows, seemed most fitting. Using the defaults for metadata downloading embyserver.txt
Solution Happy2Play 9801 Posted April 6, 2022 Solution Posted April 6, 2022 1 minute ago, Thomas5020 said: Hi, log attached. I've put it in with TV shows, seemed most fitting It cannot be identified as TV as both providers list it as a Movie. As TV Emby will not query the /movie side as it is restricted to /series /tv (depending on provider). Also note provider ids can be the same on both sides giving different results in some cases. Peter Kay: Live at the Top of the Tower (2000) — The Movie Database (TMDB) (themoviedb.org) Peter Kay - Live at the Top of the Tower - TheTVDB.com As a Documentary on IMDB, but note IMDB is never used, the id is used via Emby providers. Peter Kay: Live at the Top of the Tower (Video 2000) - IMDb So this loop between providers ends up with a bad match. 2022-04-06 00:12:13.221 Info App: MovieDbProvider: Finding id for item: Peter Kay Live at the Top of the Tower 2022-04-06 00:12:13.223 Info HttpClient: GET https://api.themoviedb.org/3/search/tv?api_key=f6bd687ffa63cd282b6ff2c6877f2669&query=Peter+Kay+Live+at+the+Top+of+the+Tower&language=en 2022-04-06 00:22:05.170 Info App: Setting provider id's to item 13111-Peter Kay Live at the Top of the Tower: {"Tvdb":"0"} 2022-04-06 00:22:05.172 Info HttpClient: GET https://api.themoviedb.org/3/find/0?api_key=f6bd687ffa63cd282b6ff2c6877f2669&external_source=tvdb_id Resulting in TV "Out of Control" being the best match to Emby.
Thomas5020 3 Posted April 6, 2022 Author Posted April 6, 2022 @Happy2Play Yep I've moved it and it's worked, legend. Now I know what to do with the rest of them, cheers.
