jonespete45 1 Posted April 5, 2022 Posted April 5, 2022 Hi, I read in a couple of old threads that there was a problem with viewing extras if playback mode was set to addon mode instead of native/direct mode, which results in extras not being shown when you select 'extras' in the Kodi context menu. Where do I find the setting to change playback to native/addon mode? Is this setting in Kodi settings or in the configuration settings in the Emby for Kodi addon? Thanks
phunzie 42 Posted April 5, 2022 Posted April 5, 2022 (edited) do a Database Reset and you will get the option to choose Add-on or Native/Direct mode...to do the reset, go to the Add-on settings Edited April 5, 2022 by phunzie
jonespete45 1 Posted April 5, 2022 Author Posted April 5, 2022 (edited) 55 minutes ago, phunzie said: do a Database Reset and you will get the option to choose Add-on or Native/Direct mode...to do the reset, go to the Add-on settings Thanks. Does the local database reset take a long time to run? Edited April 5, 2022 by jonespete45 Typo
phunzie 42 Posted April 5, 2022 Posted April 5, 2022 i guess it would depend on how much media you have...for me it takes less than a minute
quickmic 1709 Posted April 6, 2022 Posted April 6, 2022 (edited) There is no need for the extras plugin and native mode. You can access extras via next-gen plugin in addon mode via context menu. Edited April 6, 2022 by quickmic
jonespete45 1 Posted April 6, 2022 Author Posted April 6, 2022 15 minutes ago, quickmic said: There is no need for the extras plugin and native mode. You can access extras via next-gen plugin in addon mode via context menu. Ah, OK, but how? I can see the 'extras' option in my context menu, but when I select it, I get a blank folder. Although there are extras, it doesn't see them. That is why I asked the question about native mode.
quickmic 1709 Posted April 6, 2022 Posted April 6, 2022 (edited) 6 minutes ago, jonespete45 said: Ah, OK, but how? I can see the 'extras' option in my context menu, but when I select it, I get a blank folder. Although there are extras, it doesn't see them. That is why I asked the question about native mode. ok, sounds like a bug. Is it movie content with extras? Kodi supports extras (special episodes) for TVShows out of the box. Edited April 6, 2022 by quickmic
Solution quickmic 1709 Posted April 6, 2022 Solution Posted April 6, 2022 I just performed a test: context menu -> emby options -> special features. Works fine, however there is a (minor) bug on movies without special features. I you use the "back" function in such a case, next-gen opens an empty list. This should be the case and I'll fix it. However, it's an inconvenience but actually not a "content bug".
jonespete45 1 Posted April 6, 2022 Author Posted April 6, 2022 5 minutes ago, quickmic said: I just performed a test: context menu -> emby options -> special features. Works fine, however there is a (minor) bug on movies without special features. I you use the "back" function in such a case, next-gen opens an empty list. This should be the case and I'll fix it. However, it's an inconvenience but actually not a "content bug". Thank you. Yes I was referring to movies. I've tried what you said and it works fine. I didn't realise it was under Emby Options, I was just pressing 'Extras' in the context menu. Thank you for your help. Much appreciated! 1
quickmic 1709 Posted April 6, 2022 Posted April 6, 2022 3 minutes ago, jonespete45 said: Thank you. Yes I was referring to movies. I've tried what you said and it works fine. I didn't realise it was under Emby Options, I was just pressing 'Extras' in the context menu. Thank you for your help. Much appreciated! I also try to move the emby specials directly in context menu and not in the emby options sub menu. It's a bit misleading.
jonespete45 1 Posted April 6, 2022 Author Posted April 6, 2022 17 minutes ago, quickmic said: I also try to move the emby specials directly in context menu and not in the emby options sub menu. It's a bit misleading. Thank you!
