Albertax 14 Posted April 1, 2022 Posted April 1, 2022 Hi @Luke. I have been having issues where if i pause or exit an audiobook (similar fashion to how i would do the same for a TV show) that Emby does not keep it in the Continue Listening. Do you have any plans in upcoming releases to refine audiobooks?
Happy2Play 9811 Posted April 1, 2022 Posted April 1, 2022 15 minutes ago, Albertax said: Do you have any plans in upcoming releases to refine audiobooks? Yes, it is already in 4.7. Support Audio Book resume
Solution Albertax 14 Posted April 1, 2022 Author Solution Posted April 1, 2022 Hi @Happy2PlayI am on 4.7.0.32 beta 1 hour ago, Happy2Play said: Yes, it is already in 4.7. Support Audio Book resume
Happy2Play 9811 Posted April 1, 2022 Posted April 1, 2022 (edited) 8 minutes ago, Albertax said: Hi @Happy2PlayI am on 4.7.0.32 beta May need to go over a specific example, as I have Continue Listening. Edited April 1, 2022 by Happy2Play
Albertax 14 Posted April 2, 2022 Author Posted April 2, 2022 Hi Team, I figured it out. It seems to be under the libary settings & the min resume and max resume percentage settings. For instance, if i started an audiobook and then stopped it, it wouldn't recognise it. Adjusted to these and now its showing every time 18 hours ago, Happy2Play said: Another going from Chapter 1 to Chapter 2. 1
