clarkss12 304 Posted April 1, 2022 Posted April 1, 2022 I am trying to set up my camera recordings again, but the thumb nails are missing. From what I remember, there were always thumb nails of the video clip of my camera recording. What setting am I missing?? thanks.
rbjtech 5335 Posted April 1, 2022 Posted April 1, 2022 Probably Library > Screen Grabber is not selected or the top of the list - as these won't have any Metadata ...
clarkss12 304 Posted April 1, 2022 Author Posted April 1, 2022 (edited) 27 minutes ago, rbjtech said: Probably Library > Screen Grabber is not selected or the top of the list - as these won't have any Metadata ... Thank you. I enabled the Screen Grabber just now, will see if that solves this issue.......... Edit: That solved this issue......... thanks again..... Edited April 1, 2022 by clarkss12 solved. 1
Luke 42186 Posted April 1, 2022 Posted April 1, 2022 It is enabled by default for new libraries, so I guess the question is what did you think you were disabling when you turned it off?
clarkss12 304 Posted April 1, 2022 Author Posted April 1, 2022 (edited) 1 hour ago, Luke said: It is enabled by default for new libraries, so I guess the question is what did you think you were disabling when you turned it off? I don't recall disabling it........... Perhaps I did, but don't recall doing it. I guess the fist part is self explanatory " Enable and rank your preferred image fetchers in order of priority." Edited April 1, 2022 by clarkss12
