ebr 16337 Posted April 6, 2022 Posted April 6, 2022 Okay, that is the standard Android app. It does not have this setting.
gene0915 42 Posted April 6, 2022 Author Posted April 6, 2022 8 minutes ago, ebr said: Okay, that is the standard Android app. It does not have this setting. Is that the new version that will be on the Play store soon and all TVs will migrate to?
sean89us 0 Posted May 3, 2022 Posted May 3, 2022 (edited) Would like to add that I am having similar issues with Emby for Android TV 2.0.70g on my Hisense U7G TV. When I try to open a video it just sits there, paused on whatever frame it started from. Downgrading to 2.0.48g has solved my issues and I am having no playback problems with it. Worth noting that I have no issues with 2.0.70g on my NVIDIA Shield pro, only the Hisense TV. Edited May 3, 2022 by sean89us
gene0915 42 Posted May 3, 2022 Author Posted May 3, 2022 12 hours ago, sean89us said: Would like to add that I am having similar issues with Emby for Android TV 2.0.70g on my Hisense U7G TV. When I try to open a video it just sits there, paused on whatever frame it started from. Downgrading to 2.0.48g has solved my issues and I am having no playback problems with it. Worth noting that I have no issues with 2.0.70g on my NVIDIA Shield pro, only the Hisense TV. Same video file that I was referencing? So far, this is the only video I've ran across with this problem. As of now, I still have no way of playing it in Emby.
Luke 42245 Posted May 3, 2022 Posted May 3, 2022 On 4/1/2022 at 11:47 AM, Luke said: Please try the version from our website: https://emby.media/emby-for-android.html Thanks. Can you try this again with the latest version? Thanks.
sean89us 0 Posted May 3, 2022 Posted May 3, 2022 54 minutes ago, gene0915 said: Same video file that I was referencing? So far, this is the only video I've ran across with this problem. As of now, I still have no way of playing it in Emby. No, literally any video files on my server have this behavior. 30 minutes ago, Luke said: Can you try this again with the latest version? Thanks. Hey Luke, thanks for the suggestion. I wasn’t exactly expecting the android version to work well on a TV, but it seems to work almost identical. Using Emby for Android 3.2.47 I don’t seem to be having any playback issues!
Luke 42245 Posted May 3, 2022 Posted May 3, 2022 3 hours ago, sean89us said: No, literally any video files on my server have this behavior. Hey Luke, thanks for the suggestion. I wasn’t exactly expecting the android version to work well on a TV, but it seems to work almost identical. Using Emby for Android 3.2.47 I don’t seem to be having any playback issues! Thanks for the feedback.
Toxicedge 0 Posted May 3, 2022 Posted May 3, 2022 22 hours ago, sean89us said: Would like to add that I am having similar issues with Emby for Android TV 2.0.70g on my Hisense U7G TV. When I try to open a video it just sits there, paused on whatever frame it started from. Downgrading to 2.0.48g has solved my issues and I am having no playback problems with it. Worth noting that I have no issues with 2.0.70g on my NVIDIA Shield pro, only the Hisense TV. I would like to confirm that I also have a Hisense U7G TV and had the same issue with 2.0.70g and once I downgraded to 2.0.48g the problem is now gone
Toxicedge 0 Posted May 3, 2022 Posted May 3, 2022 35 minutes ago, Toxicedge said: I would like to confirm that I also have a Hisense U7G TV and had the same issue with 2.0.70g and once I downgraded to 2.0.48g the problem is now gone Sorry spoke too soon still have the same issue unless i select downgrade to stereo audio
Luke 42245 Posted May 4, 2022 Posted May 4, 2022 @Toxicedge can you try sideloading our standard android app on the same device and let us know how that compares? https://emby.media/emby-for-android.html Thanks.
Toxicedge 0 Posted May 4, 2022 Posted May 4, 2022 56 minutes ago, Luke said: @Toxicedge can you try sideloading our standard android app on the same device and let us know how that compares? https://emby.media/emby-for-android.html Thanks. Tried that same result seems to be an issue with emby and the Hisense tv's decided to try Plex to see if it would do the same thing but it plays all files fine direct play. Seems to be mostly files that have aac audio
Luke 42245 Posted May 4, 2022 Posted May 4, 2022 3 minutes ago, Toxicedge said: Tried that same result seems to be an issue with emby and the Hisense tv's decided to try Plex to see if it would do the same thing but it plays all files fine direct play. Seems to be mostly files that have aac audio What version number did you try?
Toxicedge 0 Posted May 4, 2022 Posted May 4, 2022 7 minutes ago, Luke said: What version number did you try? Whatever the latest version is 3.2.47 I believe
jh30uk 5 Posted May 4, 2022 Posted May 4, 2022 (edited) I am having the same issue on my 2017 Shield since the update, and I found out the audio setting was not on Stereo and had changed itself and it is set to normally stereo as the TV I use is connected to stereo speakers (Pioneer plasma). It was not just a black screen the video does not progress (stays at 00:00:00) along the timeline but I can view the chapter thumbs. Seems fixed now for me after changing it back to stereo but this will affect others that do not want it set to stereo. Edited May 5, 2022 by jh30uk
ebr 16337 Posted May 5, 2022 Posted May 5, 2022 15 hours ago, jh30uk said: Seems fixed now for me after changing it back to stereo but this will affect others that do not want it set to stereo. Hi. I think the only time this is an issue is your specific situation - feeding bitstreamed audio to a stereo setup. The past releases automatically selected mix down to stereo in that case.
gene0915 42 Posted May 19, 2022 Author Posted May 19, 2022 On 5/17/2022 at 1:36 PM, Luke said: Have your questions been answered? Kind of. On my Hisense TV, setting the audio option to stereo did indeed fix it (using the old version of the Android app) but doing that on the Shield made no difference....playback of those episodes is still screwed up. But if that new version of the Android app comes to the Hisense, looks like that audio option is no longer available and I'll be back to square 1.
