Live TV...need desperate help
Hello.  When I first installed the emby server and subsequently the app on two apple tvs, it worked flawlessly.  Yesterday, after switching routers, from tp-link omada to google nest wifi router, the live tv stopped working on both apple tv's where the apps are installed.  It plays back all the shows the I recorded and movies that I saved but not the live tv.
The server is on and functioning.  Live TV plays great on the pc where the server is installed so I know it's not the tv tuner.  I've attached the log and a file called ffmpeg.
Help?
ffmpeg-transcode-4ecdfa81-0827-4444-ab77-7ffd050ec527_1.txt.crdownload embyserver.txt
Nvm. It was the mcafee firewall that all of a sudden decided to block the port.
Hi, thanks for following up.
