Tjonson23 0 Posted March 27, 2022 Posted March 27, 2022 I use srt files for a lot of my subtitles. Emby sees them as und/undefined. Would it be possible to add it as a language. So emby would be able to add them by them self. Thanks a lot for a great service and hard work. Thanks in advance. best regards Tjonson23
sydlexius 301 Posted March 27, 2022 Posted March 27, 2022 Typically if you include the 2 character country/language code in the srt filename (ex: subtitle.en.srt), it'll display correctly.
Solution Luke 42246 Posted March 27, 2022 Solution Posted March 27, 2022 4 minutes ago, sydlexius said: Typically if you include the 2 character country/language code in the srt filename (ex: subtitle.en.srt), it'll display correctly. Hi, yes more info on that here: https://support.emby.media/support/solutions/articles/44001159160-subtitles
Bottles51 75 Posted March 27, 2022 Posted March 27, 2022 If your subs are encoded in the movie use mkvtoolnix to edit.
Tjonson23 0 Posted March 28, 2022 Author Posted March 28, 2022 Tried it today. and it worked. Had to write the name of language ex: subtitle.english.srt. Emby was able to pick subs after that thanks for the help
Luke 42246 Posted March 28, 2022 Posted March 28, 2022 Just now, Tjonson23 said: Tried it today. and it worked. Had to write the name of language ex: subtitle.english.srt. Emby was able to pick subs after that thanks for the help Hi, you don't need to write out the full name. The two letter code is enough (and suggested): https://support.emby.media/support/solutions/articles/44001159160-subtitles
Luke 42246 Posted March 28, 2022 Posted March 28, 2022 13 minutes ago, kailealq23 said: how do i add a server Hi, please check out our Quick Start guide: https://support.emby.media/support/solutions/articles/44001159034-quick-start Thanks.
