thor2002ro 5 Posted March 26, 2022 Posted March 26, 2022 I got a Xiaomi mi pad 5 Seek bar is dark no matter the theme's i tried... Hdr video's are very dark the screen is almost dark... I used external prayer mpv that has video brightness that is different from device brightness and fixes the video issue so we need a similar feature in emby to fix the issue. Seen the issue on a samsung with amoled
Luke 42243 Posted March 26, 2022 Posted March 26, 2022 Hi there, can you please show a screenshot example? Thanks !
GrimReaper 4897 Posted March 27, 2022 Posted March 27, 2022 Seems like it's not an isolated issue: Question - HDR on Mi Pad 5 doesn't work as it should | XDA Forums (xda-developers.com)
thor2002ro 5 Posted March 27, 2022 Author Posted March 27, 2022 (edited) Its not just the pad5 there more tablets with the same issue seen some Samsung's with oled on xda... Edited March 27, 2022 by thor2002ro
Luke 42243 Posted March 27, 2022 Posted March 27, 2022 What version of the app do you have installed?
thor2002ro 5 Posted March 27, 2022 Author Posted March 27, 2022 Latest... I think since its not on Google play anymore...
Luke 42243 Posted March 27, 2022 Posted March 27, 2022 OK yes that is the latest. We'll look into this. Thanks.
a5ian300zx 7 Posted August 10, 2022 Posted August 10, 2022 I have the similar issue on my ssung tab s8 ultra where the picture is not as bright as it should be for a 400+nits tablet. In comparison my dell xps oled laptop with 400mits display blow the Samsung out the water despite having similar nit levels. I also tested a older gen (non mini led) ipad Pro 12.9 and 4k monitor which is 350nits and even that was better than the Samsung tablet when it came to hdr playback. I was using emby to playback media from my local network sources. I will try a beta version of emby.
Luke 42243 Posted August 11, 2022 Posted August 11, 2022 We'll take another look at it. Thanks for reporting.
