Emby HEVC Transcode Killer
fbpeffer
17 minutes ago, fbpeffer said:
Hey, just want to add that I'm running this on the latest beta and the nag works fine, but its allowing 4k video to transcode. Log attached here.
Adding on top of this that I’m getting the nag message for video even when it’s direct playing? Maybe I’ve got something set up wrong?
  • 2 weeks later...
bakes82
I updated the nag logic so it now checks if its transcoding before it just checked if the nag option was enabled, my bad.  It should be on github in a few min.
Also this doesnt kill 4k, it kills HEVC or x265, so if you have a 4k file and its in x264 it wont kill it.  The issue is usually around transcoding x265 content not the resolution.  This means it will also kill any x265 content if its 1080p and they want to take it down to 720p.
Awesome, thanks for all the work.
None of my 4k files should be 264 but I'll try again with the new version.
bakes82
Let me know.  I do try to log a good bit of info so you guys have an idea of whats going on ;)
So if there is a transcoded file you should see the log for Is Direct Audio <T/F>, Is Direct Video <T/F>, Video Codec <the codec of the file>
Then based on the logic IE kill audio = true and audio is direct = false, and codec = hevc kill stream.
  • 1 month later...
Hi Bakes,
Thanks you for this.  I'm just testing this out but I can't get any of the 4k streams to kill.  Tried it on Firestick and Chrome, attached log.
Any idea why it's not killing the stream?
embyserver (1).txt
  • 1 year later...
Stevepruebas
Hi @bakes82thank you very much for this plugin!
I use only the Nag and Video warning... it´s great!
I don´t use Audio transcode warning, some players (like chrome) can´t play EAC5.1, so user can't fix it.
Stevepruebas
Hi again, can't edit previous message...
It would be possible to send first nag at "x" time, and the every "y" time?
