AndyXH 77 Posted May 23, 2022 Author Posted May 23, 2022 Currently as a work around. To do this, you need to install the Diagnostics plugin, reboot, then go to Diagnostic Options and scroll down a bit to see the two text fields. Find: -segment_format mpegts Replace: -segment_format mpegts -segment_format_options mpegts_flags=+system_b It appears to be that the TV doesn't support ATSC-style E-AC3 descriptors in MPEGTS (when the HLS protocol is being used), but it supports the DVB-Standard EAC3 descriptors. The latter are actually also a bit more common. This seems to be more related on the Samsung TVs. Emby is currently working on a solutions. For now if anyone is having a simulator issues please try above commands. 2 1
AndyXH 77 Posted June 2, 2022 Author Posted June 2, 2022 Hey @softworkz hope everything is going well. Just wanted to see if there's any progress on this ?
softworkz 5133 Posted June 2, 2022 Posted June 2, 2022 @SamES said he can adjust the request to the server to indicate whether the server should switch to DVB style descriptors. I can make the server switch to use DVB-style for transcoding when the client requests it. But @Luke will have to coordinate the way how the client should request this from the server.
AndyXH 77 Posted June 2, 2022 Author Posted June 2, 2022 2 hours ago, softworkz said: @SamES said he can adjust the request to the server to indicate whether the server should switch to DVB style descriptors. I can make the server switch to use DVB-style for transcoding when the client requests it. But @Luke will have to coordinate the way how the client should request this from the server. Thank you so much for the update!! Let me know when you guys are ready to test
