SamES 1084 Posted May 19, 2022 Posted May 19, 2022 21 hours ago, andreaxheli said: Portable-Server-ffmpeg-transcode.txt 51.57 kB · 0 downloads Installed-Server-ffmpeg-transcode.txt 45.58 kB · 0 downloads Also i did notice on the Installed server is doing direct play on the audio while transcoding the video and on the portable its transcoding the audio while transcoding the video. Strange. I hope I don't have to reinstall and start from scratch. @Luke, in the two attached logs, why would the portable version and the installed version (both 4.7.0.60) be requesting different audio bitrates for transcoding? Portable : VideoBitrate=5616001&AudioBitrate=384000 Installed : VideoBitrate=5360001&AudioBitrate=640000
softworkz 5133 Posted May 19, 2022 Posted May 19, 2022 It's due to different information about the audio stream: It requires a metadata refresh to update the data. (please do on both versions) 1
AndyXH 77 Posted May 19, 2022 Author Posted May 19, 2022 Should I run a metadata refresh on that file on both versions and then okay the video on both version again?
softworkz 5133 Posted May 19, 2022 Posted May 19, 2022 1 minute ago, andreaxheli said: Should I run a metadata refresh on that file on both versions Yes please. And if "okay" means "play" then yes as well
AndyXH 77 Posted May 19, 2022 Author Posted May 19, 2022 Hahahaha ops spell check. thank you. Keep you all posted. 1
AndyXH 77 Posted May 19, 2022 Author Posted May 19, 2022 After a metadata refresh the audio stopped working on the portable version also Insatlled Server ffmpeg-transcode_1.txt Portable_ffmpeg-transcode_1.txt 1
SamES 1084 Posted May 19, 2022 Posted May 19, 2022 OK, but that's good. I expected that to be the case. @softworkz do you have any thoughts as to why the file in these logs will DirectPlay without problem, but when streamed (with the eac3 audio track being copied) audio no longer plays? This problem apparently happens on all files with eac3 for this user. My immediate thought is that the TV player doesn't support eac3 via hls (or at least not at that bitrate). That would be somewhat surprising (and disappointing) if that is the case. The same file plays fine on my older model Samsung TV.
softworkz 5133 Posted May 19, 2022 Posted May 19, 2022 20 minutes ago, andreaxheli said: After a metadata refresh the audio stopped working on the portable version also No, that's good, because all the wrong media data I've seen from the portable version is now correct (I've been afraid it might be the other way round, that's why I had ask to refresh on both installations). Please hold on, will round-up on this issue in a moment.. 3
softworkz 5133 Posted May 19, 2022 Posted May 19, 2022 (edited) What's happening here is this: 4.6 did not detect the audio bitrate when probing => E-AC3 with empty bitrate in Emby library db 4.7 detects it correctly as E-AC3 with 640 kbps After receiving the media info, the client makes its request: 4.6 without bitrate (and maybe channel layout), the client requests a generic audio bitrate of 384 kbps => the server doesn't know the E-AC3 stream bitrate => the server decides to transcode audio to AC3 4.7 the client sees the 640 kbps bitrate with E-AC3, thinks it can handle that and requests 640 for the audio bitrate => the server knows the actual bitrate, it matches the client request, the client has indicated to support E-AC3 => the server decides to copy the audio stream and muxes it with the video 35 minutes ago, SamES said: do you have any thoughts as to why the file in these logs will DirectPlay without problem, but when streamed (with the eac3 audio track being copied) audio no longer plays? This problem apparently happens on all files with eac3 for this user Unfortunately, there can be many reasons why it doesn't work: The HLS implementation can't handle it The player doesn't support E-AC3 in an mpegts container (unlikely - it's a TV and E-AC3 in mpegts is part of the standard) ffmpeg doesn't emit the mpeg E-AC3 descriptors (or not in a way that) the tv expects the tv doesn't like the delay between video and audio the generated time stamps the PCR PID selection something in the E-AC3 bitstream which is not part of (or not conforming to) the TV broadcast spec of maybe ffmpeg generates the ATSC-spec E-AC3 descriptors while the TV expects the DVB-spec variant (or vice versa) We'll need to look at the player to find out.. Edited May 19, 2022 by softworkz
AndyXH 77 Posted May 19, 2022 Author Posted May 19, 2022 Thank you for the explanation @softworkz Is there anything you need at the moment from me ?
softworkz 5133 Posted May 19, 2022 Posted May 19, 2022 Not at the moment but probably shortly. Please give us a moment.. Thanks
SamES 1084 Posted May 20, 2022 Posted May 20, 2022 @andreaxheli, I think previously you also tested with this file that you gave me to test (The.100.S01E03.Earth.Kills.1080p.BluRay). Can you please try it again and upload a log, then softworks can compare if there are any differences between our two systems
SamES 1084 Posted May 20, 2022 Posted May 20, 2022 Can you please also test playing this file with directplay (playback quality set to auto). It is only very short, but please tell me if you get any audio 65E631_5.ts
AndyXH 77 Posted May 20, 2022 Author Posted May 20, 2022 @SamES test on both systems? Installed and portable ?
AndyXH 77 Posted May 20, 2022 Author Posted May 20, 2022 (edited) @SamES No Audio on the test file that you gave me ffmpeg-transcode-a4a22eb6-eb3b-4926-9a2f-a5675b0f7264_1.txt Its set to Auto but since im remote right now its not doing a direct play its transcoding but if i set the quility to 25 mbps it dose direct and audio is there Working on the other files now (The.100.S01E03.Earth.Kills.1080p.BluRay) Edited May 20, 2022 by andreaxheli
AndyXH 77 Posted May 20, 2022 Author Posted May 20, 2022 The file (The.100.S01E03.Earth.Kills.1080p.BluRay) audio is working it direct play and transcode ffmpeg-transcode-e3102867-1d24-4e67-8da6-290b91776ecf_1.txt
softworkz 5133 Posted May 20, 2022 Posted May 20, 2022 Sorry for the confusion. We need to test two things: FIRST I need segment0.ts (when transcoding) from both of you to so I can compare them SECOND We need to test your file (remuxed to MPEGTS) amd then played via DirectPlay
softworkz 5133 Posted May 20, 2022 Posted May 20, 2022 2 minutes ago, andreaxheli said: The file (The.100.S01E03.Earth.Kills.1080p.BluRay) audio is working it direct play and transcode ffmpeg-transcode-e3102867-1d24-4e67-8da6-290b91776ecf_1.txt That file is not EAC-3, it just AC-3
AndyXH 77 Posted May 20, 2022 Author Posted May 20, 2022 Andreas segment0.ts ffmpeg-transcode.txt Working on the other file.
softworkz 5133 Posted May 20, 2022 Posted May 20, 2022 8 minutes ago, andreaxheli said: Andreas segment0.ts ffmpeg-transcode.txt 13.36 kB · 0 downloads Working on the other file. What I mean is the first segment which gets created in C:\EmbyTemp\transcoding-temp\XXXXX
AndyXH 77 Posted May 20, 2022 Author Posted May 20, 2022 (edited) Do you want file files from C:\EmbyTemp\transcoding-temp\XXXXX of the segment0.ts Sorry little confused. Edited May 20, 2022 by andreaxheli
softworkz 5133 Posted May 20, 2022 Posted May 20, 2022 Delete everything in C:\EmbyTemp\transcoding-temp When you start playback, a folder will be created Navigate to that folder and copy xxxx0.ts (and maybe 1 and 2). Please send me those ts files (+ ffmpeg log) Thanks
AndyXH 77 Posted May 20, 2022 Author Posted May 20, 2022 The.100.S01E03.Earth.Kills.1080p.BluRay EC7EB9.zip
