FrostByte 5454 Posted May 29, 2022 Posted May 29, 2022 12 minutes ago, daedalus said: i dont have a shield That was my fault. Sorry.
ebr 16337 Posted May 30, 2022 Posted May 30, 2022 17 hours ago, daedalus said: except you want the better native decoding / downmixing and not your implementation Except the decoding we're using is not "ours" and is pretty much industry standard. However, if the system reports it can only accept a 2-channel input the we should not be sending a multi-channel input to it. This is why it is distorted I would imagine.
daedalus 434 Posted May 30, 2022 Author Posted May 30, 2022 (edited) 1 hour ago, ebr said: Except the decoding we're using is not "ours" and is pretty much industry standard. However, if the system reports it can only accept a 2-channel input the we should not be sending a multi-channel input to it. This is why it is distorted I would imagine. unbelievable rude one can be, if that's your answer, you have not read a single line i wrote, nor have attempt to address the problem pretty sure what u do is not "standard" cause other apps behave differently its pure barshness Edited May 30, 2022 by daedalus
Luke 42245 Posted June 16, 2022 Posted June 16, 2022 Can you try our 3.2.50 standard app update? https://emby.media/emby-for-android.html Thanks.
daedalus 434 Posted June 21, 2022 Author Posted June 21, 2022 (edited) multiple inputs for navigation is fixed, everything else is still present i had some little hopes, but this took the same turnout to the doomed road to tragedy like emby theater Edited June 22, 2022 by daedalus
daedalus 434 Posted August 6, 2022 Author Posted August 6, 2022 ok, 6 weeks later, new version and no sign to adress this nor to get the option back to choose how the tv should handle it so there's nothing left than staying on the last working version, just like the last years on Emby Theater
Luke 42245 Posted August 25, 2022 Posted August 25, 2022 On 5/4/2022 at 5:16 AM, daedalus said: i tried VLC and MX Player, no stutters / distortions there, but also no DTS notification, so i assume decoding happens inside these apps So if we did the same thing, that would be acceptable, right?
daedalus 434 Posted August 25, 2022 Author Posted August 25, 2022 would be better to really fix it and pass all the supported audio to the tv and let handle it software decoding will only be an option if its on par with the inbuilt solution and/or we can select the formats it will be applied cause, as said six month ago, the "Mix down to stereo" function is inferior to the tv inbuilt one, it has very low sound for multichannel streams and i have the feeling it is a bit muffeled
Luke 42245 Posted August 25, 2022 Posted August 25, 2022 Quote would be better to really fix it and pass all the supported audio to the tv and let handle it Is there any software that does that?
daedalus 434 Posted August 25, 2022 Author Posted August 25, 2022 the internal player does how should i know about any software else? hope u are not asking me to test any player out there cause im not one of your paid employees
Luke 42245 Posted August 25, 2022 Posted August 25, 2022 10 minutes ago, daedalus said: the internal player does how should i know about any software else? hope u are not asking me to test any player out there cause im not one of your paid employees We don't have your exact TV model on hand for testing. Can you please at least do this. Please sideload this dropbox version of our standard app: https://www.dropbox.com/s/u1obwrckg4lkjc8/emby-android-google-armeabi-v7a-release.apk?dl=0 Then reproduce the problem, and then provide an android app log by following these instructions: We obviously need some special behavior here, but first we need to determine what the conditions are in which to apply them. Thanks.
daedalus 434 Posted August 25, 2022 Author Posted August 25, 2022 with that apk video plays for 3 seconds and then hangs up log attached f12aca7f-fcbe-477a-8734-fe5e4fec1f7d.log
Luke 42245 Posted August 25, 2022 Posted August 25, 2022 15 minutes ago, daedalus said: with that apk video plays for 3 seconds and then hangs up log attached f12aca7f-fcbe-477a-8734-fe5e4fec1f7d.log 25.07 kB · 0 downloads That might be a separate issue and dolby vision related. We can definitely look at that, but for the sake of testing the dts distortion, do you have any other files that exhibit this with either plain hevc or h264?
daedalus 434 Posted August 25, 2022 Author Posted August 25, 2022 happens on all dtshd streams, as stated in the opening post but heres a log 4fdf5551-802c-44fe-8312-f674c0d30701.log
Luke 42245 Posted August 26, 2022 Posted August 26, 2022 5 hours ago, daedalus said: happens on all dtshd streams, as stated in the opening post but heres a log 4fdf5551-802c-44fe-8312-f674c0d30701.log 31.11 kB · 2 downloads Is this an example where it did play but audio was distorted?
Luke 42245 Posted August 26, 2022 Posted August 26, 2022 Sorry to trouble you, but would you mind downloading and installing again one more time? Yesterday we made a fix for a different issue but it was related to DTS @ 48000hz. It's possible this will help with your issue. Thanks !
Luke 42245 Posted January 20, 2023 Posted January 20, 2023 Can you try updating to the latest version of the sideload build? https://emby.media/emby-for-android.html We've updated our embedded video player to the latest version. Let's see if it plays better with that. Thanks !
daedalus 434 Posted January 21, 2023 Author Posted January 21, 2023 (edited) works now (direct playback) in ATV (forced dts/hd paththrough checked) and sideload app (no settings available), but still no dts popup and only for streams up to 5.1 7.1 streams are still distorted Edited January 21, 2023 by daedalus 1
Luke 42245 Posted January 21, 2023 Posted January 21, 2023 9 hours ago, daedalus said: works now (direct playback) in ATV (forced dts/hd paththrough checked) and sideload app (no settings available), but still no dts popup and only for streams up to 5.1 7.1 streams are still distorted Thanks for the update.
daedalus 434 Posted January 26, 2023 Author Posted January 26, 2023 On 1/21/2023 at 7:54 PM, Luke said: Thanks for the update. i have to correct myself, just checked it to briefly, it does not depend on the channel count but the bitness 16bit files work 24 bit files are still distorted and have choppy playback channel count does not matter and its the same in sideload and ATV version 1
neik 874 Posted February 2, 2023 Posted February 2, 2023 On 1/27/2023 at 12:14 AM, daedalus said: i have to correct myself, just checked it to briefly, it does not depend on the channel count but the bitness 16bit files work 24 bit files are still distorted and have choppy playback channel count does not matter and its the same in sideload and ATV version You might have written it already but what device are you using? I just tried DTS-HD 7.1, 24bit on my Shield Pro and it works just fine using Emby for Android (sideloaded app).
daedalus 434 Posted February 3, 2023 Author Posted February 3, 2023 14 hours ago, neik said: You might have written it already but what device are you using? I just tried DTS-HD 7.1, 24bit on my Shield Pro and it works just fine using Emby for Android (sideloaded app). written in the opening post -> Device: TCL C725 Android 11
